make -p # GNU Make 3.81 # Copyright (C) 2006 Free Software Foundation, Inc. # This is free software; see the source for copying conditions. # There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A # PARTICULAR PURPOSE. # This program built for i386-pc-mingw32 Das System kann den angegebenen Pfad nicht finden. Das System kann den angegebenen Pfad nicht finden. ECHO ist ausgeschaltet (OFF). -------- begin -------- avr-gcc (AVR_Toolchain_3.0_149) 4.4.3 Copyright (C) 2010 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. ECHO ist ausgeschaltet (OFF). Compiling C: main.c avr-gcc -c -mmcu=atmega644 -I. -gdwarf-2 -DF_CPU=20000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=/main.lst -std=gnu99 -ffunction-sections -fdata-sections -Wundef -MMD -MP -MF .dep/main.o.d main.c -o /main.o main.c: In function 'main': main.c:78: warning: passing argument 2 of 'read_string_flash' discards qualifiers from pointer target type include/project_func.h:101: note: expected 'char *' but argument is of type 'volatile char *' main.c:175: warning: passing argument 1 of 'execute' discards qualifiers from pointer target type include/comando_routines.h:26: note: expected 'u8 *' but argument is of type 'volatile char *' main.c:180: warning: passing argument 2 of 'read_string_flash' discards qualifiers from pointer target type include/project_func.h:101: note: expected 'char *' but argument is of type 'volatile char *' main.c:183: warning: passing argument 2 of 'read_string_flash' discards qualifiers from pointer target type include/project_func.h:101: note: expected 'char *' but argument is of type 'volatile char *' main.c:186: warning: passing argument 2 of 'read_string_flash' discards qualifiers from pointer target type include/project_func.h:101: note: expected 'char *' but argument is of type 'volatile char *' main.c:189: warning: passing argument 2 of 'read_string_flash' discards qualifiers from pointer target type include/project_func.h:101: note: expected 'char *' but argument is of type 'volatile char *' main.c:201: warning: passing argument 2 of 'read_string_flash' discards qualifiers from pointer target type include/project_func.h:101: note: expected 'char *' but argument is of type 'volatile char *' main.c: At top level: main.c:295: fatal error: opening dependency file .dep/main.o.d: No such file or directory compilation terminated. make: *** [/main.o] Fehler 1 # +Make½-Datenbank; erstellt am: Wed Feb 09 13:16:49 2011 # Variablen # Makefile (from `makefile', line 206) ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100 # automatisch $@ %.sym: %.elf # Auszuf³hrende Kommandos (aus +makefile½, Zeile 520): @echo @echo $(MSG_SYMBOL_TABLE) $@ $(NM) -n $< > $@ %.a: /main.o /lcd_routines.o /soft_spi.o /project_func.o /comando_routines.o /comando_func.o # Auszuf³hrende Kommandos (aus +makefile½, Zeile 530): @echo @echo $(MSG_CREATING_LIBRARY) $@ $(AR) $@ $(OBJ) %.elf: /main.o /lcd_routines.o /soft_spi.o /project_func.o /comando_routines.o /comando_func.o # Auszuf³hrende Kommandos (aus +makefile½, Zeile 539): @echo @echo $(MSG_LINKING) $@ $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS) /%.o: %.c # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ /%.o: %.cpp # Auszuf³hrende Kommandos (aus +makefile½, Zeile 553): @echo @echo $(MSG_COMPILING_CPP) $< $(CC) -c $(ALL_CPPFLAGS) $< -o $@ %.s: %.c # Auszuf³hrende Kommandos (aus +makefile½, Zeile 560): $(CC) -S $(ALL_CFLAGS) $< -o $@ %.s: %.cpp # Auszuf³hrende Kommandos (aus +makefile½, Zeile 565): $(CC) -S $(ALL_CPPFLAGS) $< -o $@ /%.o: %.S # Auszuf³hrende Kommandos (aus +makefile½, Zeile 570): @echo @echo $(MSG_ASSEMBLING) $< $(CC) -c $(ALL_ASFLAGS) $< -o $@ %.i: %.c # Auszuf³hrende Kommandos (aus +makefile½, Zeile 577): $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@ %.out: %.a: %.ln: %.o: %: %.o # Auszuf³hrende Kommandos (eingebaut): $(LINK.o) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.c: %: %.c # Auszuf³hrende Kommandos (eingebaut): $(LINK.c) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.ln: %.c # Auszuf³hrende Kommandos (eingebaut): $(LINT.c) -C$* $< %.o: %.c # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.c) $(OUTPUT_OPTION) $< %.cc: %: %.cc # Auszuf³hrende Kommandos (eingebaut): $(LINK.cc) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.o: %.cc # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.cc) $(OUTPUT_OPTION) $< %.cpp: %: %.cpp # Auszuf³hrende Kommandos (eingebaut): $(LINK.cpp) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.o: %.cpp # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.cpp) $(OUTPUT_OPTION) $< %.p: %: %.p # Auszuf³hrende Kommandos (eingebaut): $(LINK.p) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.o: %.p # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.p) $(OUTPUT_OPTION) $< %.f: %: %.f # Auszuf³hrende Kommandos (eingebaut): $(LINK.f) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.o: %.f # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.f) $(OUTPUT_OPTION) $< %.r: %: %.r # Auszuf³hrende Kommandos (eingebaut): $(LINK.r) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.o: %.r # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.r) $(OUTPUT_OPTION) $< %.f: %.r # Auszuf³hrende Kommandos (eingebaut): $(PREPROCESS.r) $(OUTPUT_OPTION) $< %.y: %.ln: %.y # Auszuf³hrende Kommandos (eingebaut): $(YACC.y) $< $(LINT.c) -C$* y.tab.c $(RM) y.tab.c %.c: %.y # Auszuf³hrende Kommandos (eingebaut): $(YACC.y) $< mv -f y.tab.c $@ %.l: %.ln: %.l # Auszuf³hrende Kommandos (eingebaut): @$(RM) $*.c $(LEX.l) $< > $*.c $(LINT.c) -i $*.c -o $@ $(RM) $*.c %.c: %.l # Auszuf³hrende Kommandos (eingebaut): @$(RM) $@ $(LEX.l) $< > $@ %.r: %.l # Auszuf³hrende Kommandos (eingebaut): $(LEX.l) $< > $@ mv -f lex.yy.r $@ %.s: %: %.s # Auszuf³hrende Kommandos (eingebaut): $(LINK.s) $^ $(LOADLIBES) $(LDLIBS) -o $@ %.o: %.s # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.s) -o $@ $< %.mod: %: %.mod # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.mod) -o $@ -e $@ $^ %.o: %.mod # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.mod) -o $@ $< %.sym: %.def: %.sym: %.def # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.def) -o $@ $< %.h: %.info: %.dvi: %.tex: %.dvi: %.tex # Auszuf³hrende Kommandos (eingebaut): $(TEX) $< %.texinfo: %.info: %.texinfo # Auszuf³hrende Kommandos (eingebaut): $(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@ %.dvi: %.texinfo # Auszuf³hrende Kommandos (eingebaut): $(TEXI2DVI) $(TEXI2DVI_FLAGS) $< %.texi: %.info: %.texi # Auszuf³hrende Kommandos (eingebaut): $(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@ %.dvi: %.texi # Auszuf³hrende Kommandos (eingebaut): $(TEXI2DVI) $(TEXI2DVI_FLAGS) $< %.txinfo: %.info: %.txinfo # Auszuf³hrende Kommandos (eingebaut): $(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@ %.dvi: %.txinfo # Auszuf³hrende Kommandos (eingebaut): $(TEXI2DVI) $(TEXI2DVI_FLAGS) $< %.w: %.c: %.w # Auszuf³hrende Kommandos (eingebaut): $(CTANGLE) $< - $@ %.tex: %.w # Auszuf³hrende Kommandos (eingebaut): $(CWEAVE) $< - $@ %.ch: %.web: %.p: %.web # Auszuf³hrende Kommandos (eingebaut): $(TANGLE) $< %.tex: %.web # Auszuf³hrende Kommandos (eingebaut): $(WEAVE) $< %.sh: %: %.sh # Auszuf³hrende Kommandos (eingebaut): cat $< >$@ chmod a+x $@ %.elc: %.el: (%): % # Auszuf³hrende Kommandos (eingebaut): $(AR) $(ARFLAGS) $@ $< %.out: % # Auszuf³hrende Kommandos (eingebaut): @rm -f $@ cp $< $@ %.c: %.w %.ch # Auszuf³hrende Kommandos (eingebaut): $(CTANGLE) $^ $@ %.tex: %.w %.ch # Auszuf³hrende Kommandos (eingebaut): $(CWEAVE) $^ $@ %:: %,v # Auszuf³hrende Kommandos (eingebaut): $(CHECKOUT,v) %:: RCS/%,v # Auszuf³hrende Kommandos (eingebaut): $(CHECKOUT,v) %:: RCS/% # Auszuf³hrende Kommandos (eingebaut): $(CHECKOUT,v) %:: s.% # Auszuf³hrende Kommandos (eingebaut): $(GET) $(GFLAGS) $(SCCS_OUTPUT_OPTION) $< %:: SCCS/s.% # Auszuf³hrende Kommandos (eingebaut): $(GET) $(GFLAGS) $(SCCS_OUTPUT_OPTION) $< # 87 implizite Regeln, 5 (5,7%) Terminal. # Dateien main.elf: /main.o /lcd_routines.o /soft_spi.o /project_func.o /comando_routines.o /comando_func.o # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +main½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/20=0% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 539): @echo @echo $(MSG_LINKING) $@ $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS) # Dies ist kein Ziel: libmain.a: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .web.p: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(TANGLE) $< program: main.hex main.eep # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 444): $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM) # Dies ist kein Ziel: .l.r: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LEX.l) $< > $@ mv -f lex.yy.r $@ # Dies ist kein Ziel: .dvi: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. all: begin gccversion sizebefore build sizeafter end # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/28=0% # Dies ist kein Ziel: .y.ln: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(YACC.y) $< $(LINT.c) -C$* y.tab.c $(RM) y.tab.c # Dies ist kein Ziel: .o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.o) $^ $(LOADLIBES) $(LDLIBS) -o $@ # Dies ist kein Ziel: .y: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .def.sym: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.def) -o $@ $< # Dies ist kein Ziel: .p.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.p) $(OUTPUT_OPTION) $< # Dies ist kein Ziel: .p: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.p) $^ $(LOADLIBES) $(LDLIBS) -o $@ # Dies ist kein Ziel: .txinfo.dvi: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(TEXI2DVI) $(TEXI2DVI_FLAGS) $< .PHONY: all begin finish end sizebefore sizeafter gccversion build elf hex eep lss sym coff extcoff clean clean_list program debug gdb-config # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: main.c: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-02-08 13:26:17 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% sizebefore: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # Dies ist kein Ziel: .a: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .DEFAULT: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .l.ln: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): @$(RM) $*.c $(LEX.l) $< > $*.c $(LINT.c) -i $*.c -o $@ $(RM) $*.c # Dies ist kein Ziel: .w.c: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(CTANGLE) $< - $@ # Dies ist kein Ziel: .texi.dvi: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(TEXI2DVI) $(TEXI2DVI_FLAGS) $< # Dies ist kein Ziel: .sh: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): cat $< >$@ chmod a+x $@ /project_func.o: project_func.c # Wertvolle Datei (Voraussetzung von .PRECIOUS). # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +project_func½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ # Dies ist kein Ziel: .cc: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.cc) $^ $(LOADLIBES) $(LDLIBS) -o $@ # Dies ist kein Ziel: .cc.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.cc) $(OUTPUT_OPTION) $< # Dies ist kein Ziel: .def: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. elf: main.elf # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/20=0% # Dies ist kein Ziel: comando_routines.c: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-02-07 18:40:00 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Dies ist kein Ziel: .r.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.r) $(OUTPUT_OPTION) $< # Dies ist kein Ziel: .r: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.r) $^ $(LOADLIBES) $(LDLIBS) -o $@ begin: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +½ # Die Datei existiert nicht. # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # automatisch # @ := begin # automatisch # % := # automatisch # * := # automatisch # + := # automatisch # | := # automatisch # < := # automatisch # ^ := # automatisch # ? := # variable set hash-table stats: # Load=8/32=25%, Rehash=0, Collisions=1/13=8% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 420): @echo @echo $(MSG_BEGIN) sizeafter: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. /comando_routines.o: comando_routines.c # Wertvolle Datei (Voraussetzung von .PRECIOUS). # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +comando_routines½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ clean_list: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 584): @echo @echo $(MSG_CLEANING) $(REMOVE) $(TARGET).hex $(REMOVE) $(TARGET).eep $(REMOVE) $(TARGET).cof $(REMOVE) $(TARGET).elf $(REMOVE) $(TARGET).map $(REMOVE) $(TARGET).sym $(REMOVE) $(TARGET).lss $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.o) $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.lst) $(REMOVE) $(SRC:.c=.s) $(REMOVE) $(SRC:.c=.d) $(REMOVE) $(SRC:.c=.i) $(REMOVEDIR) .dep debug: gdb-config main.elf # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 464): @echo Starting AVaRICE - Press enter when "waiting to connect" message displays. @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \ $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT) @$(WINSHELL) /c pause @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE) # Dies ist kein Ziel: soft_spi.c: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-01-26 06:52:42 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Dies ist kein Ziel: makefile: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-02-09 12:41:13 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% gccversion: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +½ # Die Datei existiert nicht. # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # automatisch # @ := gccversion # automatisch # % := # automatisch # * := # automatisch # + := # automatisch # | := # automatisch # < := # automatisch # ^ := # automatisch # ? := # variable set hash-table stats: # Load=8/32=25%, Rehash=0, Collisions=1/11=9% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 438): @$(CC) --version build: elf hex eep lss sym # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/20=0% eep: main.eep # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .info: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: comando_func.c: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-02-07 18:44:26 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Dies ist kein Ziel: .elc: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .l.c: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): @$(RM) $@ $(LEX.l) $< > $@ /comando_func.o: comando_func.c # Wertvolle Datei (Voraussetzung von .PRECIOUS). # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +comando_func½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ /lcd_routines.o: lcd_routines.c # Wertvolle Datei (Voraussetzung von .PRECIOUS). # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +lcd_routines½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ # Dies ist kein Ziel: .out: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. coff: main.elf # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 488): @echo @echo $(MSG_COFF) $(TARGET).cof $(COFFCONVERT) -O coff-avr $< $(TARGET).cof # Dies ist kein Ziel: .r.f: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(PREPROCESS.r) $(OUTPUT_OPTION) $< extcoff: main.elf # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 494): @echo @echo $(MSG_EXTENDED_COFF) $(TARGET).cof $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof # Dies ist kein Ziel: .texinfo.info: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@ # Dies ist kein Ziel: .c: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.c) $^ $(LOADLIBES) $(LDLIBS) -o $@ # Dies ist kein Ziel: .w.tex: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(CWEAVE) $< - $@ # Dies ist kein Ziel: .c.ln: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINT.c) -C$* $< # Dies ist kein Ziel: .s.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.s) -o $@ $< # Dies ist kein Ziel: .s: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.s) $^ $(LOADLIBES) $(LDLIBS) -o $@ gdb-config: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 451): @$(REMOVE) $(GDBINIT_FILE) @echo define reset >> $(GDBINIT_FILE) @echo SIGNAL SIGHUP >> $(GDBINIT_FILE) @echo end >> $(GDBINIT_FILE) @echo file $(TARGET).elf >> $(GDBINIT_FILE) @echo target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE) @echo break main >> $(GDBINIT_FILE) lib: libmain.a # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: main.eep: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: project_func.c: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-02-07 22:29:32 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Dies ist kein Ziel: .texinfo.dvi: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(TEXI2DVI) $(TEXI2DVI_FLAGS) $< # Dies ist kein Ziel: .SUFFIXES: .out .a .ln .o .c .cc .c .cpp .p .f .f .r .y .l .s .s .mod .sym .def .h .info .dvi .tex .texinfo .texi .txinfo .w .ch .web .sh .elc .el # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .el: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .texinfo: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .y.c: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(YACC.y) $< mv -f y.tab.c $@ # Dies ist kein Ziel: main.lss: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .web.tex: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(WEAVE) $< # Dies ist kein Ziel: .texi.info: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@ # Dies ist kein Ziel: .h: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. sym: main.sym # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. hex: main.hex # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .tex.dvi: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(TEX) $< finish: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .cpp.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.cpp) $(OUTPUT_OPTION) $< # Dies ist kein Ziel: .cpp: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.cpp) $^ $(LOADLIBES) $(LDLIBS) -o $@ # Dies ist kein Ziel: main.sym: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. clean: begin clean_list end # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .ln: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .texi: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .txinfo: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .tex: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .txinfo.info: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@ # Dies ist kein Ziel: lcd_routines.c: # Suche nach impliziten Regeln wurde durchgef³hrt. # Zuletzt geõndert 2011-01-18 11:16:32 # Datei wurde aktualisiert. # Erfolgreich aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Dies ist kein Ziel: .ch: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. end: # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (aus +makefile½, Zeile 424): @echo $(MSG_END) @echo /main.o: main.c # Wertvolle Datei (Voraussetzung von .PRECIOUS). # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +main½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde aktualisiert. # Aktualisierung fehlgeschlagen. # automatisch # @ := /main.o # automatisch # % := # automatisch # * := main # automatisch # + := main.c # automatisch # | := # automatisch # < := main.c # automatisch # ^ := main.c # automatisch # ? := main.c # variable set hash-table stats: # Load=8/32=25%, Rehash=0, Collisions=2/33=6% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ .PRECIOUS: /main.o /lcd_routines.o /soft_spi.o /project_func.o /comando_routines.o /comando_func.o /main.o /lcd_routines.o /soft_spi.o /project_func.o /comando_routines.o /comando_func.o # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: main.hex: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .S.s: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(PREPROCESS.S) $< > $@ # Dies ist kein Ziel: .mod: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.mod) -o $@ -e $@ $^ .SECONDARY: main.a main.elf # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .mod.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.mod) -o $@ $< # Dies ist kein Ziel: .F.f: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(PREPROCESS.F) $(OUTPUT_OPTION) $< lss: main.lss # Vorgetõuschtes Ziel (Voraussetzung von .PHONY). # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. /soft_spi.o: soft_spi.c # Wertvolle Datei (Voraussetzung von .PRECIOUS). # Suche nach impliziten Regeln wurde durchgef³hrt. # Ersetzung f³r implizites/statisches Muster: +soft_spi½ # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Die Datei existiert nicht. # Datei wurde nicht aktualisiert. # variable set hash-table stats: # Load=0/32=0%, Rehash=0, Collisions=0/0=0% # Auszuf³hrende Kommandos (aus +makefile½, Zeile 546): @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ # Dies ist kein Ziel: .w: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .c.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.c) $(OUTPUT_OPTION) $< # Dies ist kein Ziel: main.a: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Datei ist ein Zwischenschritt in den Abhõngigkeiten. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .l: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .web: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .sym: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Dies ist kein Ziel: .f: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(LINK.f) $^ $(LOADLIBES) $(LDLIBS) -o $@ # Dies ist kein Ziel: .f.o: # Suche nach impliziten Regeln wurde nicht durchgef³hrt. # Zeit der letzten -nderung wurde nicht ³berpr³ft. # Datei wurde nicht aktualisiert. # Auszuf³hrende Kommandos (eingebaut): $(COMPILE.f) $(OUTPUT_OPTION) $< # files hash-table stats: # Load=104/1024=10%, Rehash=0, Collisions=315/1516=21% # VPATH-Suchpfade # Keine +vpath½-Suchpfade. # Kein allgemeiner Suchpfad (Variable +VPATH½). # # of strings in strcache: 1 # # of strcache buffers: 1 # strcache size: total = 4096 / max = 4096 / min = 4096 / avg = 4096 # strcache free: total = 4087 / max = 4087 / min = 4087 / avg = 4087 # +Make½-Datenbank; beendet am: Wed Feb 09 13:16:51 2011
