/************ * I/O Ports * ************/ #define ENCP1_DDR DDRC // From Rotary Encoder, Phase 1 #define ENCP1_POUT PORTC #define ENCP1_PINP PINC #define ENCP1_PNUM PC0 #define ENCP2_DDR DDRC // From Rotary Encoder, Phase 2 #define ENCP2_POUT PORTC #define ENCP2_PINP PINC #define ENCP2_PNUM PC1 /********* * Macros * *********/ #define SetPinInp(pinname) ((pinname ## _DDR) &= ~(_BV(pinname ## _PNUM))) #define CheckHI(pinname) ((pinname ## _PINP) & (_BV(pinname ## _PNUM))) /************************* * Acceleration Constants * *************************/ #define ENCODER_ACCEL_TOP 1536 #define ENCODER_ACCEL_INC 96 #define ENCODER_ACCEL_DEC 1 /***************************** * Rotary Encoder State Table * *****************************/ uint8_t EncStates[16] PROGMEM = {0,2,1,3,1,0,3,2,2,3,0,1,3,1,2,0}; /******************* * Global Variables * *******************/ volatile int16_t EncSteps; static uint16_t EncAccel; static uint8_t LastEnc, NextEnc; uint8_t RotaryCount; /************* * Initialize * *************/ void Initialize() { SetPinInp(ENCP1); // Pin Encoder Phase 1 = Input SetPinInp(ENCP2); // Pin Encoder Phase 2 = Input LastEnc = 0; if (CheckHI(ENCP1)) LastEnc |= 2; if (CheckHI(ENCP2)) LastEnc |= 1; // Initial Encoder State RotaryCount = 0; TCCR0A = _BV(WGM01); // T/C-0 Mode = CTC, TOV Set on MAX TCCR0B = _BV(CS02) | _BV(CS00); // T/C-0 Clock = Prescaler/1024 OCR0A = 3; // T/C-0 Output Compare Register = 3 TIMSK0 |= _BV(OCIE0A); // T/C-0 Compare Match A Int every 4096 Clocks (all 256 us) } /************************** * Accumulate Rotary Count * **************************/ void AccumulateRotaryCount() { if (EncSteps) { cli(); RotaryCount += EncSteps; EncSteps = 0; sei(); } } /**************************** * Timer-A-Interrupt-Handler * ****************************/ ISR(TIMER0_COMPA_vect) { uint8_t CurrEnc; CurrEnc = 0; if (CheckHI(ENCP1)) CurrEnc |= 2; if (CheckHI(ENCP2)) CurrEnc |= 1; EncAccel -= ENCODER_ACCEL_DEC; if (EncAccel & 0b1000000000000000) EncAccel = 0; // Zero if overflowed LastEnc <<= 2; LastEnc |= CurrEnc; LastEnc &= 0b00001111; switch (pgm_read_word(&EncStates[LastEnc])) { case 0: break; // No Step case 1: EncSteps -= 1+(EncAccel >> 8); // Reverse if (EncAccel <= (ENCODER_ACCEL_TOP-ENCODER_ACCEL_INC)) EncAccel += ENCODER_ACCEL_INC; break; case 2: EncSteps += 1+(EncAccel >> 8); // Forward if (EncAccel <= (ENCODER_ACCEL_TOP-ENCODER_ACCEL_INC)) EncAccel += ENCODER_ACCEL_INC; break; case 3: LastEnc = CurrEnc; // Bad Step EncSteps = 0; EncAccel = 0; } }
