Open On-Chip Debugger 0.3.1-snapshot (2009-12-08-16:09) $URL$ For bug reports, read http://openocd.berlios.de/doc/doxygen/bugs.html 500 kHz jtag_nsrst_delay: 100 jtag_ntrst_delay: 100 trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain Warn : stm32.bs: nonstandard IR mask Warn : use 'stm32.cpu' as target identifier, not '0' Info : device: 4 "2232C" Info : deviceID: 364511235 Info : SerialNumber: FTOO8MMMA Info : Description: Olimex OpenOCD JTAG A Info : clock speed 500 kHz Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3) Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0) Info : accepting 'gdb' connection from 0 Warn : acknowledgment received, but no packet pending undefined debug reason 6 - target needs reset Error: Target not halted Error: auto_probe failed -304 Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3) Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0) target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x00000a98 msp: 0x2000fffc requesting target halt and executing a soft reset target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x00000a98 msp: 0x2000fffc Info : device id = 0x10016414 Info : flash size = 256kbytes stm32x unlocked stm32x mass erase complete Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3) Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0) target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc Info : Padding image section 0 with 5376 bytes Warn : writing 262144 bytes only - as image section is 272008 bytes and bank is only 262144 bytes Warn : not enough working area available(requested 16384, free 16336) Error: No flash at address 0x08040000 Error: No flash at address 0x08042688 Error: No flash at address 0x28000000 wrote 262144 byte from file main.elf in 19.046875s (13.440525 kb/s) Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Warn : negative acknowledgment, but no packet pending Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3) Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0) Info : dropped 'gdb' connection - error -400 target state: halted target halted due to breakpoint, current mode: Handler BusFault xPSR: 0x21000005 pc: 0x0000ca00 msp: 0x2000ff4c
