##################################################################################################################################################################################### library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity write_c is Port ( write_start, clk, reset : in std_logic; db : in std_logic_vector (7 downto 0); write_done, lcd_e_w, lcd_rw : out std_logic; lcd_db_w : out std_logic_vector (3 downto 0)); end write_c; architecture Behavioral of write_c is type state_sequence is (idle, s1, s2, s3, s4, s5, s6, s7, s8, done); signal state : state_sequence := idle; signal i: integer range 0 to 7500000:=0; begin process(clk, reset) begin if reset = '1' then state <= idle; elsif (clk'event and clk = '1') then case state is when idle => if write_start = '1' then state <= s1; i <= 2; end if; when s1 => if i = 0 then state <= s2; i <= 12; else i <= i-1; end if; when s2 => if i = 0 then state <= s3; i <=1; else i <= i-1; end if; when s3 => if i = 0 then state <= s4; i <=50; else i <= i-1; end if; when s4 => if i = 0 then state <= s5; i <=2; else i <= i-1; end if; when s5 => if i = 0 then state <= s6; i <=12; else i <= i-1; end if; when s6 => if i = 0 then state <= s7; i <=1; else i <= i-1; end if; when s7 => if i = 0 then state <= s8; i <=2; else i <= i-1; end if; when s8 => if i = 0 then state <= done; else i <= i-1; end if; when done => state <= idle; end case; end if; end process; with state select write_done <= '1' when done, '0' when others; with state select lcd_e_w <= '1' when s2|s6, '0' when others; with state select lcd_rw <= '1' when idle|s4|s8|done, '0' when others; with state select lcd_db_w <= db(7 downto 4) when s1|s2|s3, db(3 downto 0) when s5|s6|s7, "0000" when others; end Behavioral; ############################################################################################################################################################### library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; use IEEE.STD_LOGIC_ARITH.ALL; entity power_on_init is Port ( init_start : in STD_LOGIC; init_done : out STD_LOGIC; clk : in STD_LOGIC; reset : in STD_LOGIC; lcd_db_i : out STD_LOGIC_VECTOR (3 downto 0); lcd_e_i : out STD_LOGIC); end power_on_init; architecture Behavioral of power_on_init is type state_sequence is (idle,s1,s2,s3,s4,s5,s6,s7,s8,s9,done); signal state : state_sequence := idle; signal i : integer range 0 to 750000; begin asm: process(clk,reset,init_start) begin if (reset='1') then State <= idle; elsif clk'event and (clk='1') then case state is when idle=> if (init_start='1')then state <= s1; i<=0; else i<=i+1; end if; when s1=> if (i=750000)then state <= s2; i<=0; else i<=i+1; end if; when s2=> if (i=12)then state <= s3; i<=0; else i<=i+1; end if; when s3=> if (i=205000)then state <= s4; i<=0; else i<=i+1; end if; when s4=> if (i=12)then state <= s5; i<=0; else i<=i+1; end if; when s5=> if (i=5000)then state <= s6; i<=0; else i<=i+1; end if; when s6=> if (i=12)then state <= s7; i<=0; else i<=i+1; end if; when s7=> if (i=2000)then state <= s8; i<=0; else i<=i+1; end if; when s8=> if (i=12)then state <= s9; i<=0; else i<=i+1; end if; when s9=> if (i=2000)then state <= done; i<=0; else i<=i+1; end if; when done=> if (i=1)then state <= idle; i<=0; else i<=i+1; end if; end case; end if; end process; with state select lcd_e_i <= '1' when s2|s4|s6|s8, '0' when others; with state select lcd_db_i <= "0011" when s2|s4|s6, "0010" when s8, "0000" when others; with state select init_done <= '1' when done, '0' when others; end Behavioral; ####################################################################################################################################################################### library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity Mux1 is Port ( lcd_e_i : in STD_LOGIC; lcd_e_w : in STD_LOGIC; MuxS : in STD_LOGIC; lcd_e : out STD_LOGIC); end Mux1; architecture Mux1_a of Mux1 is begin with MuxS select lcd_e <= lcd_e_i when '0', lcd_e_w when others; end Mux1_a; ####################################################################################################################################################################### library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Mux4 is Port ( lcd_db_i : in STD_LOGIC_VECTOR(3 downto 0); lcd_db_w : in STD_LOGIC_VECTOR(3 downto 0); MuxS : in STD_LOGIC; lcd_db : out STD_LOGIC_VECTOR(3 downto 0)); end Mux4; architecture Mux4_a of Mux4 is begin with MuxS select lcd_db <= lcd_db_i when '0', lcd_db_w when others; end Mux4_a;
