library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library UNISIM; use UNISIM.VComponents.all; entity x_blockram is Port( DOA : out std_logic_vector(1 to 32); -- Port A 32-bit Data Output DOB : out std_logic_vector(1 to 32); -- Port B 32-bit Data Output DOPA : out std_logic_vector(1 to 4); -- Port A 4-bit Parity Output DOPB : out std_logic_vector(1 to 4); -- Port B 4-bit Parity Output ADDRA : in std_logic_vector(8 downto 0); -- Port A 9-bit Address Input ADDRB : in std_logic_vector(8 downto 0); -- Port B 9-bit Address Input CLKA : in std_logic; CLKB : in std_logic; -- Port B Clock DIA : in std_logic_vector(1 to 32); -- Port A 32-bit Data Input DIB : in std_logic_vector(1 to 32); -- Port B 32-bit Data Input DIPA : in std_logic_vector(1 to 4); -- Port A 4-bit parity Input DIPB : out std_logic_vector(1 to 4); -- Port-B 4-bit parity Input ENA : in std_logic; -- Port A RAM Enable Input ENB : in std_logic; -- PortB RAM Enable Input SSRA : in std_logic; -- Port A Synchronous Set/Reset Input SSRB : in std_logic; -- Port B Synchronous Set/Reset Input WEA : in std_logic; -- Port A Write Enable Input WEB : in std_logic); end x_blockram; architecture Behavioral of x_blockram is -- RAMB16_S36_S36: Virtex-II/II-Pro, Spartan-3/3E 512 x 32 + 4 Parity bits Dual-Port RAM -- Xilinx HDL Language Template version 7.1i --RAMB16_S36_S36_inst : RAMB16_S36_S36 generic map ( INIT_A => X"000000000", -- Value of output RAM registers on Port A at startup INIT_B => X"000000000", -- Value of output RAM registers on Port B at startup SRVAL_A => X"000000000", -- Port A ouput value upon SSR assertion SRVAL_B => X"000000000", -- Port B ouput value upon SSR assertion WRITE_MODE_A => "WRITE_FIRST", -- WRITE_FIRST, READ_FIRST or NO_CHANGE WRITE_MODE_B => "WRITE_FIRST", -- WRITE_FIRST, READ_FIRST or NO_CHANGE SIM_COLLISION_CHECK => "ALL", -- "NONE", "WARNING", "GENERATE_X_ONLY", "ALL" INIT_00 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_01 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_02 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_03 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_04 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_05 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_06 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_07 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_08 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_09 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0F => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_10 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_11 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_12 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_13 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_14 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_15 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_16 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_17 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_18 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_19 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1F => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_20 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_21 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_22 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_23 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_24 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_25 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_26 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_27 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_28 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_29 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2F => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_30 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_31 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_32 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_33 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_34 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_35 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_36 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_37 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_38 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_39 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3F => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_00 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_01 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_02 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_03 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_04 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_05 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_06 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_07 => X"0000000000000000000000000000000000000000000000000000000000000000") port map ( DOA => DOA, -- Port A 32-bit Data Output DOB => DOB, -- Port B 32-bit Data Output DOPA => DOPA, -- Port A 4-bit Parity Output DOPB => DOPB, -- Port B 4-bit Parity Output ADDRA => ADDRA, -- Port A 9-bit Address Input ADDRB => ADDRB, -- Port B 9-bit Address Input CLKA => CLKA, -- Port A Clock CLKB => CLKB, -- Port B Clock DIA => DIA, -- Port A 32-bit Data Input DIB => DIB, -- Port B 32-bit Data Input DIPA => DIPA, -- Port A 4-bit parity Input DIPB => DIPB, -- Port-B 4-bit parity Input ENA => ENA, -- Port A RAM Enable Input ENB => ENB, -- PortB RAM Enable Input SSRA => SSRA, -- Port A Synchronous Set/Reset Input SSRB => SSRB, -- Port B Synchronous Set/Reset Input WEA => WEA, -- Port A Write Enable Input WEB => WEB -- Port B Write Enable Input ); end Behavioral;
