#include #include #include /* * hex_merge.c * * Merge two or more hex files into one big hex file * * Usefull for using bootloaders with AVR, and probably other uses. * * (c) 2011 Thomas Ilnseher (illth@gmx.de) * Licensed under the GPLv2. * * This comes with absolutely no warranty of any kind */ /* use at least a 2byte type here */ typedef unsigned int data_t; static data_t* data_buf = NULL; static int db_len = 0; static int real_len = 0; static inline unsigned int hex4(char c) { if (c >= '0' && c <= '9') return c - '0'; if (c >= 'a' && c <= 'f') return c - 'a' + 10; return (unsigned int)c - 'A' + 10; } static inline unsigned int get_hex8(char* line, int idx) { idx = idx * 2 + 1; return (hex4(line[idx]) << 4) | hex4(line[idx + 1]); } static inline int is_hex(char c) { if (c >= '0' && c <= '9') return 1; if (c >= 'a' && c <= 'f') return 1; if (c >= 'A' && c <= 'F') return 1; return 0; } void load_file(const char* file_name) { char line_buf[256]; int seg_offs = 0; int line_len; int total_hex_digits; int i; int checksum; int record_type; int address; FILE* fp; int over_write_warn_on = 0; int warn_start_addr = 0xdead; fp = fopen(file_name, "r"); if (! fp) { printf("Error: Failed to open %s for reading\n", file_name); exit(2); } line_buf[255] = '\0'; while (!feof(fp)) { if (fgets(line_buf, 255, fp) == NULL) break; /* Sanity check: first char must be a ':' */ if (line_buf[0] != ':') { printf("Warning: expected ':' as first char but got \"%s\" (File %s)\n", line_buf, file_name); continue; } /* sanity check: enough hex records, checksum, only hex chars */ line_len = get_hex8(line_buf, 0); total_hex_digits = 2 * (line_len + 5); for (i = 1; i <= total_hex_digits; i++) { if (! is_hex(line_buf[i])){ printf("Warning: non hexadezimal character at %d in line \"%s\" (File %s)\n", i, line_buf, file_name); break; } } if (i <= total_hex_digits) continue; /* hit the break in the loop above */ /* checksum check */ checksum = 0; for (i = 0; i < line_len + 5; i++) checksum += get_hex8(line_buf, i); if (checksum & 0xff) { printf("Warning: Checksum error in line \"%s\" (File %s)\n", line_buf, file_name); continue; } /* check for invalid record type */ record_type = get_hex8(line_buf, 3); if (record_type > 5) { printf("Warning: Invalid record type in line \"%s\" (File %s)\n", line_buf, file_name); continue; } /* don't give a shit about 03 and 05 */ if (record_type == 3 || record_type == 5) continue; if (record_type == 1) { if (over_write_warn_on) printf("Warning: overwriting data (range 0x%04x - 0x%04x) while loading file %s\n", warn_start_addr, real_len - 1, file_name); fclose(fp); return; /* EOF record */ } if (record_type == 2) { /* segment address */ if (line_len != 2) { printf("Warning: Invalid 02 record length in line \"%s\" (File %s)\n", line_buf, file_name); if (line_len < 2) continue; } seg_offs = (get_hex8(line_buf, 4) << 12) | ((get_hex8(line_buf, 5) & 0xf0) << 4); continue; } if (record_type == 4) { /* segment address */ if (line_len != 2) { printf("Warning: Invalid 04 record length in line \"%s\" (File %s)\n", line_buf, file_name); if (line_len < 2) continue; } seg_offs = (get_hex8(line_buf, 4) << 24) | (get_hex8(line_buf, 5) << 16); continue; } /* so, here we have a well formated data record with correct checksum */ address = seg_offs + (get_hex8(line_buf, 1) << 8) | get_hex8(line_buf, 2); while (address + line_len >= db_len) { data_t* new_buf = malloc(sizeof(data_t) * (db_len + 0x1000)); if (! new_buf) { printf("Error: Malloc failed for 0x%x bytes!\n", (int)sizeof(data_t) * (db_len + 0x1000)); exit(1); } if (data_buf) { memcpy(new_buf, data_buf, db_len * sizeof(data_t)); free(data_buf); } data_buf = new_buf; memset(data_buf + db_len, 0xff, 0x1000 * sizeof(data_t)); db_len += 0x1000; } real_len = address + line_len; for (i = 0; i < line_len; i++) { if ((data_buf[address + i] & 0xff00) == 0 && over_write_warn_on == 0) { over_write_warn_on = 1; warn_start_addr = address + i; } if ((data_buf[address + i] & 0xff00) != 0 && over_write_warn_on != 0) { over_write_warn_on = 0; printf("Warning: overwriting data (range 0x%04x - 0x%04x) while loading file %s\n", warn_start_addr, address + i, file_name); } data_buf[address + i] = get_hex8(line_buf, i + 4); } } fclose(fp); if (over_write_warn_on) printf("Warning: overwriting data (range 0x%04x - 0x%04x) while loading file %s\n", warn_start_addr, real_len - 1, file_name); printf("Warning: Leave parse loop due to no EOF record in file %s\n", file_name); } void write_file(FILE* fp, int strip_ff) { int i; int lba_flag = 0; int seg_offs = 0; int addr_out; int output_ptr = 0; int checksum; int segment; int record_len; if (real_len > 0xfffff) lba_flag = 1; while (output_ptr < real_len) { if (strip_ff) { /* the check: if this position was filled with the memset, * then all bytes are filled, so this is only possible * if this position was later overwritten by get_hex8 */ while ((data_buf[output_ptr] & 0xff00) != 0) output_ptr++; } addr_out = output_ptr - seg_offs; if (addr_out > 0xfff0) { /* need to adjust the segment */ if (lba_flag) { /* wrtie type 4 record */ segment = ((unsigned int)output_ptr >> 16) & 0xffff; checksum = - (2 + 0 + 4 + (segment >> 8) + segment); fprintf(fp, ":02000004%04X%02X\r\n", segment, checksum & 0xff); seg_offs = segment << 16; } else { /* write type 2 record */ segment = (((unsigned int)output_ptr >> 16) & 0xf) << 12; checksum = - (2 + 0 + 2 + (segment >> 8) + segment); fprintf(fp, ":02000002%04X%02X\r\n", segment, checksum & 0xff); seg_offs = segment << 4; } } addr_out = output_ptr - seg_offs; for (record_len = 1; record_len < 16 && ((data_buf[output_ptr + record_len] & 0xff00) == 0); record_len++) ; if (real_len - output_ptr < record_len) record_len = real_len - output_ptr; fprintf(fp, ":%02X%04X00", record_len, addr_out); checksum = -(record_len + (addr_out >> 8) + addr_out + 0); for (i = 0; i < record_len; i++) { fprintf(fp, "%02X", data_buf[output_ptr] & 0xff); checksum -= (unsigned int)(data_buf[output_ptr]); output_ptr++; } fprintf(fp, "%02X\r\n", checksum & 0xff); } /* print EOF record */ fprintf(fp, ":00000001FF\r\n"); } void usage(const char* prog) { printf("USAGE:\n\n%s [options] file1 [...] [output file]\n\nOptions:\n\t -o\t--output=FILE\tSte the output file (instead of the last file named)\n", prog); printf("\t -f\t--fill\t\tFill the empty spaces (default: off)\n"); printf("\t -F\t--fillbyte=0xXX\tFill the empty spaces with byte 0xXX (also enables fill)\n"); printf("\t\t\t\tDefault fill byte: 0xFF\n"); printf("\n\nEXAMPLES:\n\n"); printf("\t%s file1.hex file2.hex output.hex\t\t\tMerge file1.hex and file2.hex into output.hex (most basic example)\n", prog); printf("\t%s file1.hex file2.hex file3.hex output.hex\t\tMerge file1.hex, file2.hex and file3.hex into output.hex\n", prog); printf("\t%s --output=output.hex file1.hex file2.hex\t\tMerge file1.hex and file2.hex into output.hex\n", prog); printf("\t%s -oF output.hex 0x12 file1.hex file2.hex\t\tMerge file1.hex and file2.hex into output.hex, filling empty spaces with 0x12\n", prog); printf("\t%s --fillbyte=0x12 file1.hex file2.hex output.hex\tMerge file1.hex and file2.hex into output.hex, filling empty spaces with 0x12\n", prog); exit(3); } #define MATCH(x, str) (strncmp(x, str, sizeof(str) - 1) == 0) int main(int argc, char** argv) { int i, j; int fill_flag = 0; int fill_byte = 0xff; const char* output_file = NULL; const char* popt; int skip1 = 0; int skip2 = 0; FILE* output = NULL; if (argc < 2) usage(argv[0]); for (i = 1; i < argc; i++) { if (argv[i][0] != '-') continue; /* no option but file name */ if MATCH(argv[i], "--output=") { output_file = argv[i] + (sizeof("output=") - 1); continue; } if MATCH(argv[i], "--fillbyte=") { fill_flag = 1; fill_byte = strtoul(argv[i] + (sizeof("fillbyte=") - 1), NULL, 0); continue; } if MATCH(argv[i], "--fill") { fill_flag = 1; continue; } /* no recognized string option, but could be a single letter option */ /* here, we check for single letter options: o, f, F */ popt = argv[i]; for (j = 1; popt[j]; j++) { if (popt[j] == 'f') { fill_flag = 1; continue; /* inner loop, over j */ } if (popt[j] == 'F') { if (i + 1 >= argc) usage(argv[0]); fill_flag = 1; fill_byte = strtoul(argv[i + 1], NULL, 0); if (skip1 == 0) skip1 = i + 1; else if (skip2 == 0) skip2 = i + 1; else usage(argv[0]); i++; continue; /* j loop */ } if (popt[j] == 'o') { if (i + 1 >= argc) usage(argv[0]); output_file = argv[i + 1]; if (skip1 == 0) skip1 = i + 1; else if (skip2 == 0) skip2 = i + 1; else usage(argv[0]); i++; continue; /* j loop */ } /* here: no recognized single letter option */ usage(argv[0]); } } if (! output_file) { while (argv[argc - 1][0] == '-') argc--; output_file = argv[argc - 1]; argc--; } output = fopen(output_file, "w"); if (! output) { printf("Error: cannot open output file %s\n", output_file); exit(4); } /* now do the hard work */ for (i = 1; i < argc; i++) { if (argv[i][0] == '-') continue; /* option, no file */ if (i == skip1 || i == skip2) continue; load_file(argv[i]); } if (real_len == 0) printf("Warning: 0 bytes were read\n"); if (fill_flag && fill_byte != 0xff) { for (i = 0; i < real_len; i++) { if ((data_buf[i] & 0xff00) != 0) data_buf[i] = fill_byte; } } write_file(output, ! fill_flag); fclose(output); if (data_buf) free(data_buf); return 0; }
