#define EEPROM_I2C_ADDR 		0xA0
#define I2C_SELECTED			I2C1
void I2C_Configuration(void)
    I2C_InitTypeDef  I2C_InitStructure;
    GPIO_InitTypeDef  GPIO_InitStructure;
    /* I2C Periph clock enable */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
    /* GPIO Periph clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
    // /* GPIO_PinRemapConfig(GPIO_Remap_I2C1, ENABLE); */
    /* Configure I2C_EE pins: SCL and SDA */
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    I2C_DeInit(I2C1);
    /* I2C configuration */
    I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
    I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
    I2C_InitStructure.I2C_OwnAddress1 = 0x01;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_InitStructure.I2C_ClockSpeed = 200000;
    /* Apply I2C configuration after enabling it */
    I2C_Init(I2C1, &I2C_InitStructure);
    /* I2C Peripheral Enable */
    I2C_Cmd(I2C1, ENABLE);
 *   @brief
int
eeprom_wait_for_ready (void) {
	unsigned char SR1_Reg;
	while(1)
		// Send START condition
		I2C_GenerateSTART(I2C_SELECTED, ENABLE);
		// Test on EV5 and clear it
		while(!I2C_CheckEvent(I2C_SELECTED, I2C_EVENT_MASTER_MODE_SELECT));
		// Sent slave address for write
		I2C_Send7bitAddress(I2C_SELECTED, EEPROM_I2C_ADDR, I2C_Direction_Transmitter);
		SR1_Reg = I2C_SELECTED->SR1;
		if ((SR1_Reg & (I2C_SR1_ADDR | I2C_SR1_AF)) != 0)
		  // Clear ADDR Flag by reading SR1 then SR2 registers (SR1 have already been read)
		  (void)I2C_SELECTED->SR2;
		  // STOP condition
		  I2C_GenerateSTOP(I2C_SELECTED, ENABLE);
		  // Exit the function
		  return 1;
		else
		  // Clear AF flag
		  I2C_ClearFlag(I2C_SELECTED, I2C_FLAG_AF);
	 Delay(1); */
	return 0;
int eeprom_write_byte(unsigned int iAddress, char cByte, char cContinued) {
	while(I2C_GetFlagStatus(I2C_SELECTED, I2C_FLAG_BUSY));
	//eeprom_wait_for_ready();
    /* Send STRAT condition */
    /* Test on EV5 and clear it */
    /* Send Slave address for write */
    /* Test on EV6 and clear it */
    while(!I2C_CheckEvent(I2C_SELECTED, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
    // Sent Address MSByte
    I2C_SendData(I2C_SELECTED, (uint8_t)((iAddress & 0xFF00) >> 8));
    while(!I2C_CheckEvent(I2C_SELECTED, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
    // Sent Address LSByte
    I2C_SendData(I2C_SELECTED, (uint8_t)(iAddress & 0x00FF));
    // Sent Data Byte
    I2C_SendData(I2C_SELECTED, cByte);
    // Close Communication
char eeprom_read_byte (unsigned int iAddress) {
		char DataByte = 0;
		/* While the bus is busy */
		/* Send START condition */
		/* Send RTC address for write */
		/* Send the internal address pointer to the required register */
		/* Test on EV8 and clear it */
		/* Repeat STRAT condition */
		/* Send IC address for read */
		I2C_Send7bitAddress(I2C_SELECTED, EEPROM_I2C_ADDR, I2C_Direction_Receiver);
		while(!I2C_CheckEvent(I2C_SELECTED, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
		I2C_AcknowledgeConfig(I2C_SELECTED, DISABLE);
		while(!I2C_CheckEvent(I2C_SELECTED, I2C_EVENT_MASTER_BYTE_RECEIVED));
		DataByte = I2C_ReceiveData(I2C_SELECTED);
		/* Send STOP condition */
		I2C_AcknowledgeConfig(I2C_SELECTED, ENABLE);
	return DataByte;
int main(void)
    I2C_Configuration();
    printf("\r\nI2C Test");
	eeprom_write_byte(116, 0xBC, 0);
	Testbyte = eeprom_read_byte (116);
	printf("\r\nI2C End of Test %X", Testbyte);
    /* Infinite loop */
    while (1)
  return 0;
