; main loop ; ; r28,r29,r30,r31 is the phase accumulator ; r24,r25,r26,r27 is the adder value determining frequency ; ; add value to accumulator ; load byte from current table in RAM ; output byte to port ; repeat ; clear accumulator clr r27 ; zero < 150 kHz , 1 max clr r28 clr r29 clr r30 ldi r31 ,8 ; base of sine table (400 *2) add r28,r24 LOOP1: adc r29,r25 ; 1 adc r30,r26 ; 1 adc r31,r27 ; 1 cbr r31,4 ; 1 limit banks to 0..3 lpm r0,z ; 3 out PORTD,r0 ; 1 add r28,r24 ; 1 adc r29,r25 ; 1 adc r30,r26 ; 1 adc r31,r27 ; 1 cbr r31,4 ; 1 limit banks to 0..3 lpm r0,z ; 3 add r28,r24 ; 1 timeing out PORTD,r0 ; 1 rjmp LOOP1 ; 2 => 20 / 2 = 10 cycles ;****************************************************************************** ; data tables ;****************************************************************************** ; force table to begin at 256 byte boundary .org 0x400 ; sine table 2 x 1024 Byte .db 128,128,129,130,131,131,132,133,134,135,135,136,137,138,138,139 .db 140,141,142,142,143,144,145,146,146,147,148,149,149,150,151,152 .db 152,153,154,155,156,156,157,158,159,159,160,161,162,162,163,164 .db 165,165,166,167,168,168,169,170,171,171,172,173,174,174,175,176 .db 176,177,178,179,179,180,181,182,182,183,184,184,185,186,186,187 .db 188,189,189,190,191,191,192,193,193,194,195,195,196,197,197,198 .db 199,199,200,201,201,202,202,203,204,204,205,206,206,207,207,208 .db 209,209,210,211,211,212,212,213,213,214,215,215,216,216,217,217 .db 218,219,219,220,220,221,221,222,222,223,223,224,224,225,225,226 .db 226,227,227,228,228,229,229,230,230,231,231,232,232,233,233,233 .db 234,234,235,235,236,236,236,237,237,238,238,238,239,239,240,240 .db 240,241,241,241,242,242,243,243,243,244,244,244,245,245,245,245 .db 246,246,246,247,247,247,247,248,248,248,249,249,249,249,250,250 .db 250,250,250,251,251,251,251,251,252,252,252,252,252,253,253,253 .db 253,253,253,253,254,254,254,254,254,254,254,254,255,255,255,255 .db 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255 .db 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255 .db 255,255,255,255,255,254,254,254,254,254,254,254,254,253,253,253 .db 253,253,253,253,252,252,252,252,252,251,251,251,251,251,250,250 .db 250,250,250,249,249,249,249,248,248,248,247,247,247,247,246,246 .db 246,245,245,245,245,244,244,244,243,243,243,242,242,241,241,241 .db 240,240,240,239,239,238,238,238,237,237,236,236,236,235,235,234 .db 234,233,233,233,232,232,231,231,230,230,229,229,228,228,227,227 .db 226,226,225,225,224,224,223,223,222,222,221,221,220,220,219,219 .db 218,217,217,216,216,215,215,214,213,213,212,212,211,211,210,209 .db 209,208,207,207,206,206,205,204,204,203,202,202,201,201,200,199 .db 199,198,197,197,196,195,195,194,193,193,192,191,191,190,189,189 .db 188,187,186,186,185,184,184,183,182,182,181,180,179,179,178,177 .db 176,176,175,174,174,173,172,171,171,170,169,168,168,167,166,165 .db 165,164,163,162,162,161,160,159,159,158,157,156,156,155,154,153 .db 152,152,151,150,149,149,148,147,146,146,145,144,143,142,142,141 .db 140,139,138,138,137,136,135,135,134,133,132,131,131,130,129,128 .db 128,127,126,125,124,124,123,122,121,120,120,119,118,117,117,116 .db 115,114,113,113,112,111,110,109,109,108,107,106,106,105,104,103 .db 103,102,101,100,99,99,98,97,96,96,95,94,93,93,92,91 .db 90,90,89,88,87,87,86,85,84,84,83,82,81,81,80,79 .db 79,78,77,76,76,75,74,73,73,72,71,71,70,69,69,68 .db 67,66,66,65,64,64,63,62,62,61,60,60,59,58,58,57 .db 56,56,55,54,54,53,53,52,51,51,50,49,49,48,48,47 .db 46,46,45,44,44,43,43,42,42,41,40,40,39,39,38,38 .db 37,36,36,35,35,34,34,33,33,32,32,31,31,30,30,29 .db 29,28,28,27,27,26,26,25,25,24,24,23,23,22,22,22 .db 21,21,20,20,19,19,19,18,18,17,17,17,16,16,15,15 .db 15,14,14,14,13,13,12,12,12,11,11,11,10,10,10,10 .db 9,9,9,8,8,8,8,7,7,7,6,6,6,6,5,5 .db 5,5,5,4,4,4,4,4,3,3,3,3,3,2,2,2 .db 2,2,2,2,1,1,1,1,1,1,1,1,0,0,0,0 .db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 .db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 .db 0,0,0,0,0,1,1,1,1,1,1,1,1,2,2,2 .db 2,2,2,2,3,3,3,3,3,4,4,4,4,4,5,5 .db 5,5,5,6,6,6,6,7,7,7,8,8,8,8,9,9 .db 9,10,10,10,10,11,11,11,12,12,12,13,13,14,14,14 .db 15,15,15,16,16,17,17,17,18,18,19,19,19,20,20,21 .db 21,22,22,22,23,23,24,24,25,25,26,26,27,27,28,28 .db 29,29,30,30,31,31,32,32,33,33,34,34,35,35,36,36 .db 37,38,38,39,39,40,40,41,42,42,43,43,44,44,45,46 .db 46,47,48,48,49,49,50,51,51,52,53,53,54,54,55,56 .db 56,57,58,58,59,60,60,61,62,62,63,64,64,65,66,66 .db 67,68,69,69,70,71,71,72,73,73,74,75,76,76,77,78 .db 79,79,80,81,81,82,83,84,84,85,86,87,87,88,89,90 .db 90,91,92,93,93,94,95,96,96,97,98,99,99,100,101,102 .db 103,103,104,105,106,106,107,108,109,109,110,111,112,113,113,114 .db 115,116,117,117,118,119,120,120,121,122,123,124,124,125,126,127 .db 128,128,129,130,131,131,132,133,134,135,135,136,137,138,138,139 .db 140,141,142,142,143,144,145,146,146,147,148,149,149,150,151,152 .db 152,153,154,155,156,156,157,158,159,159,160,161,162,162,163,164 .db 165,165,166,167,168,168,169,170,171,171,172,173,174,174,175,176 .db 176,177,178,179,179,180,181,182,182,183,184,184,185,186,186,187 .db 188,189,189,190,191,191,192,193,193,194,195,195,196,197,197,198 .db 199,199,200,201,201,202,202,203,204,204,205,206,206,207,207,208 .db 209,209,210,211,211,212,212,213,213,214,215,215,216,216,217,217 .db 218,219,219,220,220,221,221,222,222,223,223,224,224,225,225,226 .db 226,227,227,228,228,229,229,230,230,231,231,232,232,233,233,233 .db 234,234,235,235,236,236,236,237,237,238,238,238,239,239,240,240 .db 240,241,241,241,242,242,243,243,243,244,244,244,245,245,245,245 .db 246,246,246,247,247,247,247,248,248,248,249,249,249,249,250,250 .db 250,250,250,251,251,251,251,251,252,252,252,252,252,253,253,253 .db 253,253,253,253,254,254,254,254,254,254,254,254,255,255,255,255 .db 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255 .db 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255 .db 255,255,255,255,255,254,254,254,254,254,254,254,254,253,253,253 .db 253,253,253,253,252,252,252,252,252,251,251,251,251,251,250,250 .db 250,250,250,249,249,249,249,248,248,248,247,247,247,247,246,246 .db 246,245,245,245,245,244,244,244,243,243,243,242,242,241,241,241 .db 240,240,240,239,239,238,238,238,237,237,236,236,236,235,235,234 .db 234,233,233,233,232,232,231,231,230,230,229,229,228,228,227,227 .db 226,226,225,225,224,224,223,223,222,222,221,221,220,220,219,219 .db 218,217,217,216,216,215,215,214,213,213,212,212,211,211,210,209 .db 209,208,207,207,206,206,205,204,204,203,202,202,201,201,200,199 .db 199,198,197,197,196,195,195,194,193,193,192,191,191,190,189,189 .db 188,187,186,186,185,184,184,183,182,182,181,180,179,179,178,177 .db 176,176,175,174,174,173,172,171,171,170,169,168,168,167,166,165 .db 165,164,163,162,162,161,160,159,159,158,157,156,156,155,154,153 .db 152,152,151,150,149,149,148,147,146,146,145,144,143,142,142,141 .db 140,139,138,138,137,136,135,135,134,133,132,131,131,130,129,128 .db 128,127,126,125,124,124,123,122,121,120,120,119,118,117,117,116 .db 115,114,113,113,112,111,110,109,109,108,107,106,106,105,104,103 .db 103,102,101,100,99,99,98,97,96,96,95,94,93,93,92,91 .db 90,90,89,88,87,87,86,85,84,84,83,82,81,81,80,79 .db 79,78,77,76,76,75,74,73,73,72,71,71,70,69,69,68 .db 67,66,66,65,64,64,63,62,62,61,60,60,59,58,58,57 .db 56,56,55,54,54,53,53,52,51,51,50,49,49,48,48,47 .db 46,46,45,44,44,43,43,42,42,41,40,40,39,39,38,38 .db 37,36,36,35,35,34,34,33,33,32,32,31,31,30,30,29 .db 29,28,28,27,27,26,26,25,25,24,24,23,23,22,22,22 .db 21,21,20,20,19,19,19,18,18,17,17,17,16,16,15,15 .db 15,14,14,14,13,13,12,12,12,11,11,11,10,10,10,10 .db 9,9,9,8,8,8,8,7,7,7,6,6,6,6,5,5 .db 5,5,5,4,4,4,4,4,3,3,3,3,3,2,2,2 .db 2,2,2,2,1,1,1,1,1,1,1,1,0,0,0,0 .db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 .db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 .db 0,0,0,0,0,1,1,1,1,1,1,1,1,2,2,2 .db 2,2,2,2,3,3,3,3,3,4,4,4,4,4,5,5 .db 5,5,5,6,6,6,6,7,7,7,8,8,8,8,9,9 .db 9,10,10,10,10,11,11,11,12,12,12,13,13,14,14,14 .db 15,15,15,16,16,17,17,17,18,18,19,19,19,20,20,21 .db 21,22,22,22,23,23,24,24,25,25,26,26,27,27,28,28 .db 29,29,30,30,31,31,32,32,33,33,34,34,35,35,36,36 .db 37,38,38,39,39,40,40,41,42,42,43,43,44,44,45,46 .db 46,47,48,48,49,49,50,51,51,52,53,53,54,54,55,56 .db 56,57,58,58,59,60,60,61,62,62,63,64,64,65,66,66 .db 67,68,69,69,70,71,71,72,73,73,74,75,76,76,77,78 .db 79,79,80,81,81,82,83,84,84,85,86,87,87,88,89,90 .db 90,91,92,93,93,94,95,96,96,97,98,99,99,100,101,102 .db 103,103,104,105,106,106,107,108,109,109,110,111,112,113,113,114 .db 115,116,117,117,118,119,120,120,121,122,123,124,124,125,126,127
