AVRETH1 winziger Webserver mit ENC28J60 und ATMEGA32 / ATMEGA644 avr.auctionant.de/avrETH1/ http://www.mikrocontroller.net/forum/read-1-310134.html http://www.mikrocontroller.net/forum/read-1-402627.html Conntections between ICs sorted by IC pins of each IC / Connector - = not connected | AT ENC 10 FL 5 1 7 1 5 PB5 MOSI 2 6 8 1 PB6 MISO 3 8 2 4 PB7 SCK 4 3 -Reset (PullUp) 5 Vdd 9 56 Vcc +3.6 6 Vss 2 7 2 Gnd 7 XTAL2 (Xtal+C) 8 XTAL1 (Xtal+C) 9 8 PD0 RxD (Camera TxD) 10 10 PD1 TxD (Camera RxD) 11- PD2 Int0 12 4 PD3 Int1 (ENC -INT) 13- PD4 OC1B 14- PD5 OC1A 15 5 PD6 ICP 16 3 PD7 OC2 (Servo) 17 Vdd 9 56 VCC +3.6 18 Vss 2 7 2 Gnd 19 4 PC0 SCL (PullUp 1k) 20 6 PC1 SDA (PullUp 1k) 21 7 PC2 TCK 22 PC3 TMS (330R+LEDgn) 23- PC4 TDO 24 3 PC5 TDI (Flash -RST) 25 4 PC6 TOSC1 (Flash -CS) 26- PC7 TOSC2 27 Vdd 9 56 AVCC +3.6 28 Vss 2 7 2 AGND Gnd 29 AREF (C auf Gnd) 30- PA7 31- PA6 32- PA5 33- PA4 34- PA3 35- PA2 36- PA1 37 1 PA0 38 Vdd 9 56 VCC +3.6 39 Vss 2 7 2 GND Gnd 40- PB0 T0 XCK 41- PB1 T1 42- PB2 AIN0 INT2 43 10 PB3 AIN1 OC0 (-Rst) 44 9 PB4 SS (-CS) ENC28J60-SO SOIC28 1 VCAP (10µF nach Gnd) 2 VSS 3 CLKOUT (nc) 4 INT (PD3 INT1) 5 WOL (nc) 6 SO (PB6 MISO) 7 SI (PB5 MOSI) 8 SCK (PB7 SCK) 9 CS (PB4 SS) 10 RESET (PB3 Ain1) 11 VSSRX 12 TPIN- 13 TPIN+ 14 RBIAS (2k7 nach Gnd) 15 VDDTX 16 TPOUT- 17 TPOUT+ 18 VSSTX 19 VDDRX 20 VDDPLL 21 VSSPLL 22 VSSOSC 23 OSC1 24 OSC2 25 VDDOSC 26 LEDB (rot) 27 LEDA (blau) 28 VDD 10-poliger Kamerastecker 37 1 PA0 18 Vss 2 7 2 Gnd 16 3 PD7 OC2 (Servo) 19 4 PC0 SCL (PullUp 1k) 15 5 PD6 ICP 20 6 PC1 SDA (PullUp 1k) 21 7 PC2 TCK 9 8 PD0 RxD (Camera TxD) 17 Vdd 9 56 2 Vcc +3.6 10 10 PD1 TxD (Camera RxD) AT45DB041B-SU 4MBit Dataflash SO8 1 7 1 5 PB5 MOSI (SI) 3 8 2 4 PB7 SCK (SCK) 24 3 PC5 TDI (Flash -RST) 25 4 PC6 TOSC1 (Flash -CS) 5 Vdd 9 5 Vcc +3.6 (Flash -WP) 5 Vdd 9 6 Vcc +3.6 6 Vss 2 7 2 Gnd 2 6 8 1 PB6 MISO (SO) 5-poliger Programmierstecker 2 6 8 1 PB6 MISO 6 Vss 2 7 2 Gnd 4 3 -Reset (PullUp) 3 8 2 4 PB7 SCK 1 7 1 5 PB5 MOSI
