/****************************************************************************** * @file main.c * @author Erik Herkenrath * @version V1.0.0 * @date Apr 11. 2012 * @brief hardware init for RC-Servo PWM signal input and output * tested on STM32 value line discovery Board * µC: STM32F100RB @24 MHz ******************************************************************************/ /* RC-receiver input */ __IO int32_t TIM3_IC1 = 0; /* Timer3, Input Compare Channel1, PA6 */ __IO int32_t TIM3_IC2 = 0; /* Timer3, Input Compare Channel2, PA7 */ __IO int32_t TIM3_IC3 = 0; /* Timer3, Input Compare Channel3, PB0 */ __IO int32_t TIM3_IC4 = 0; /* Timer3, Input Compare Channel4, PB1 */ /* Main function -------------------------------------------------------------*/ int main(void) { /*******************/ /* Hardware Init */ /*******************/ /* HW init structures */ GPIO_InitTypeDef GPIO_InitStructure; /* Structure for port init */ TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; /* Structure for basic Timer init */ TIM_OCInitTypeDef TIM_OCInitStructure; /* Structure for Timer Output Compare init */ TIM_ICInitTypeDef TIM_ICInitStructure; /* Structure for Timer Input Capture init */ NVIC_InitTypeDef NVIC_InitStructure; /* NVIC priority grouping */ /* Enable clocks */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM3, ENABLE); /* Enable clocking of Timer Periperials */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC, ENABLE); /* Enable clocking of Ports */ /* Configure IO-pins */ /* PWM output */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; /* Push-Pull Output Alternate-Function */ GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; /* = lowest output impedance */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3; /* PA0: TIM2 CHN1, PA1: TIM2 CHN2 */ GPIO_Init(GPIOA, &GPIO_InitStructure); /* PWM input */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; /* Input Floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; /* PA6: TIM3 CHN1, PA7: TIM3 CHN2 */ GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1; /* PB0: TIM3 CHN3, PB1: TIM3 CHN4 */ GPIO_Init(GPIOB, &GPIO_InitStructure); /* Initialize timer2 - output compare PWM */ // GPIO_PinRemapConfig(GPIO_FullRemap_TIM2, ENABLE); /* Remap Pins if necessary */ TIM_TimeBaseStructure.TIM_Period = 20000 - 1; /* PWM signal length 20 ms */ TIM_TimeBaseStructure.TIM_Prescaler = 24 - 1; /* counter increments every 1 µs */ TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); /* initialize timer */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; /* PWM generation */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; /* enable PWM-output */ TIM_OC1Init(TIM2, &TIM_OCInitStructure); /* initialize channel1 (PA0) */ TIM_OC2Init(TIM2, &TIM_OCInitStructure); /* initialize channel2 (PA1) */ TIM_OC3Init(TIM2, &TIM_OCInitStructure); /* initialize channel3 (PA2) */ TIM_OC4Init(TIM2, &TIM_OCInitStructure); /* initialize channel4 (PA3) */ TIM_Cmd(TIM2, ENABLE); /* start timer */ // zur Laufzeit festlegen: RC-Servo Ansteuerung (hier testweise) TIM2->CCR1 = 1000; /* set puls length: 1.0 ms = 0 % */ TIM2->CCR2 = 1333; /* set puls length: 1.3 ms = 33 % */ TIM2->CCR3 = 1666; /* set puls length: 1.7 ms = 66 % */ TIM2->CCR4 = 2000; /* set puls length: 2.0 ms = 100 % */ /* Initialize Timer3 - input capture PWM */ TIM_TimeBaseStructure.TIM_Period = 0xFFFF; /* overflow after ~65 ms */ TIM_TimeBaseStructure.TIM_Prescaler = 24 - 1; /* counter increments every 1 µs */ TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); /* initialize timer */ TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; /* trigger capture event on rising edge */ TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; /* input pins directly connected */ TIM_ICInitStructure.TIM_ICFilter = 0x3; /* input must be stable for 8 ticks */ TIM_ICInitStructure.TIM_Channel = TIM_Channel_1; /* configure channel1 (PA6) */ TIM_ICInit(TIM3, &TIM_ICInitStructure); /* configure input capture */ TIM_ICInitStructure.TIM_Channel = TIM_Channel_2; /* configure channel2 (PA7) */ TIM_ICInit(TIM3, &TIM_ICInitStructure); /* configure input capture */ TIM_ICInitStructure.TIM_Channel = TIM_Channel_3; /* configure channel3 (PB0) */ TIM_ICInit(TIM3, &TIM_ICInitStructure); /* configure input capture */ TIM_ICInitStructure.TIM_Channel = TIM_Channel_4; /* configure channel4 (PB1) */ TIM_ICInit(TIM3, &TIM_ICInitStructure); /* configure input capture */ TIM_ITConfig(TIM3, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE); /* enable CC-interrupts */ TIM_Cmd(TIM3, ENABLE); /* start timer */ /* Configure Nested Interrupt Controller (Int-Enable should be the last point in Hardware Init!) */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); /* 1 bit for pre-emption priority, 3 bits for subpriority */ NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; /* second highest preemption-priority */ /* Enable the Timer3 Interrupts - input capture */ NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; /* highest sub-priority */ NVIC_Init(&NVIC_InitStructure); while(1) { } } /****************************************************************************** * @file stm32f10x_it.c * @author Erik Herkenrath * @version V1.0.0 * @date Apr 11. 2012 * @brief Interrupt Service Routine for input capture of RC-Servo PWM signal ******************************************************************************/ void TIM3_IRQHandler(void) { static uint16_t CCR1_rise; static uint16_t CCR2_rise; static uint16_t CCR3_rise; static uint16_t CCR4_rise; if(TIM3->SR & TIM_IT_CC1) { /* input capture channel1? */ if(TIM3->CCER & TIM_CCER_CC1P) { /* captured falling edge? */ TIM3_IC1 = TIM3->CCR1 - CCR1_rise; /* Get the Input Capture value, calculate high pulse length */ TIM3->CCER &= ~TIM_CCER_CC1P; /* select rising edge as capture event */ } else { /* captured rising edge? */ CCR1_rise = TIM3->CCR1; /* Get the Input Capture value */ TIM3->CCER |= TIM_CCER_CC1P; /* select falling edge as capture event */ } TIM3->SR = ~TIM_IT_CC1; /* Clear interrupt pending bit */ } if(TIM3->SR & TIM_IT_CC2) { /* input capture channel2? */ if(TIM3->CCER & TIM_CCER_CC2P) { /* captured falling edge? */ TIM3_IC2 = TIM3->CCR2 - CCR2_rise; /* Get the Input Capture value, calculate high pulse length */ TIM3->CCER &= ~TIM_CCER_CC2P; /* select rising edge as capture event */ } else { /* captured rising edge? */ CCR2_rise = TIM3->CCR2; /* Get the Input Capture value */ TIM3->CCER |= TIM_CCER_CC2P; /* select falling edge as capture event */ } TIM3->SR = ~TIM_IT_CC2; /* Clear interrupt pending bit */ } if(TIM3->SR & TIM_IT_CC3) { /* input capture channel3? */ if(TIM3->CCER & TIM_CCER_CC3P) { /* captured falling edge? */ TIM3_IC3 = TIM3->CCR3 - CCR3_rise; /* Get the Input Capture value, calculate high pulse length */ TIM3->CCER &= ~TIM_CCER_CC3P; /* select rising edge as capture event */ } else { /* captured rising edge? */ CCR3_rise = TIM3->CCR3; /* Get the Input Capture value */ TIM3->CCER |= TIM_CCER_CC3P; /* select falling edge as capture event */ } TIM3->SR = ~TIM_IT_CC3; /* Clear interrupt pending bit */ } if(TIM3->SR & TIM_IT_CC4) { /* input capture channel4? */ if(TIM3->CCER & TIM_CCER_CC4P) { /* captured falling edge? */ TIM3_IC4 = TIM3->CCR4 - CCR4_rise; /* Get the Input Capture value, calculate high pulse length */ TIM3->CCER &= ~TIM_CCER_CC4P; /* select rising edge as capture event */ } else { /* captured rising edge? */ CCR4_rise = TIM3->CCR4; /* Get the Input Capture value */ TIM3->CCER |= TIM_CCER_CC4P; /* select falling edge as capture event */ } TIM3->SR = ~TIM_IT_CC4; /* Clear interrupt pending bit */ } }
