-------------------------------------------------------------------------------- -- Mycron® DDR SDRAM - MT46V32M16 - 8 Meg x 16 x 4 banks -- -------------------------------------------------------------------------------- -- Copyright (C)2012 Mathias Hörtnagl -- -- -- -- This program is free software: you can redistribute it and/or modify -- -- it under the terms of the GNU General Public License as published by -- -- the Free Software Foundation, either version 3 of the License, or -- -- (at your option) any later version. -- -- -- -- This program is distributed in the hope that it will be useful, -- -- but WITHOUT ANY WARRANTY; without even the implied warranty of -- -- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -- -- GNU General Public License for more details. -- -- -- -- You should have received a copy of the GNU General Public License -- -- along with this program. If not, see . -- -------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity ddr_init is port ( clk0 : in std_logic; rst : in std_logic; SD_CKE : out std_logic; SD_BA : out std_logic_vector(1 downto 0); SD_A : out std_logic_vector(12 downto 0); SD_CMD : out std_logic_vector(3 downto 0); init_done : out boolean ); end ddr_init; architecture rtl of ddr_init is ----------------------------------------------------------------------------- -- Controller Commands -- ----------------------------------------------------------------------------- constant CMD_LMR : std_logic_vector(3 downto 0) := "0000"; constant CMD_AUTO_REFRESH : std_logic_vector(3 downto 0) := "0001"; constant CMD_PRECHARGE : std_logic_vector(3 downto 0) := "0010"; constant CMD_NOP : std_logic_vector(3 downto 0) := "0111"; ----------------------------------------------------------------------------- -- Mode Rgister Addresses -- ----------------------------------------------------------------------------- -- Addresses for the two mode registers, selected via SD_BA. constant BMR_ADDR : std_logic_vector(1 downto 0) := "00"; constant EMR_ADDR : std_logic_vector(1 downto 0) := "01"; ----------------------------------------------------------------------------- -- Base Mode Rgister -- ----------------------------------------------------------------------------- -- Operating modes. constant OP_NORMAL : std_logic_vector(5 downto 0) := "000000"; constant OP_DLL_RST : std_logic_vector(5 downto 0) := "000010"; -- CAS latency. constant CAS_2 : std_logic_vector(2 downto 0) := "010"; -- Burst type. constant BT_S : std_logic := '0'; -- Sequential. -- Burst lengths. constant BL_2 : std_logic_vector(2 downto 0) := "001"; ----------------------------------------------------------------------------- -- Extended Mode Rgister -- ----------------------------------------------------------------------------- -- DLL. constant DLL_ENABLE : std_logic := '0'; constant DLL_DISABLE : std_logic := '1'; -- Drive strength. constant DS_NORMAL : std_logic := '0'; ----------------------------------------------------------------------------- -- Initialization -- ----------------------------------------------------------------------------- type init_state_t is ( Wait20000, -- Wait for 200µs. CKE_High, -- Assert CKE. Precharge0, Precharge0Wait, -- First precharge. ProgramEMR, ProgramEMRWait, -- Set Extended Mode Register. ProgramMR, ProgramMRWait, -- Set Base Mode Register. Precharge1, Precharge1Wait, -- second precharge. AutoRefresh0, AutoRefresh0Wait, -- First autorefresh. AutoRefresh1, AutoRefresh1Wait, -- Second autorefresh. ProgramMR1, ProgramMR1Wait, -- Set Base Mode Register. Wait200, -- Wait for 200 cycles. Done -- Initialization done! ); type init_t is record s : init_state_t; c : natural range 0 to 19999; end record; constant init_d : init_t := init_t'( Wait20000, 0); signal i, iin : init_t := init_d; begin ----------------------------------------------------------------------------- -- Initialization -- ----------------------------------------------------------------------------- initial : process(i) begin iin <= i; SD_CKE <= '1'; SD_BA <= "00"; SD_CMD <= CMD_NOP; SD_A <= (others => '0'); init_done <= false; case i.s is ----------------------------------------------------------------------- -- 5. Wait for 200µs. -- ----------------------------------------------------------------------- when Wait20000 => SD_CKE <= '0'; if i.c = 19999 then iin.c <= 0; iin.s <= CKE_High; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 6. Bring CKE high. -- ----------------------------------------------------------------------- when CKE_High => iin.s <= Precharge0; ----------------------------------------------------------------------- -- 7. Precharge all banks. -- ----------------------------------------------------------------------- when Precharge0 => SD_CMD <= CMD_PRECHARGE; SD_A(10) <= '1'; -- Precharge all operation. iin.s <= Precharge0Wait; -- PRECHARGE command period tRP: 15ns when Precharge0Wait => if i.c = 1 then iin.c <= 0; iin.s <= ProgramEMR; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 9. Program the Extended Mode Register. -- ----------------------------------------------------------------------- when ProgramEMR => SD_CMD <= CMD_LMR; SD_BA <= EMR_ADDR; -- Select Extended Mode Register. SD_A <= "00000000000" & DS_NORMAL & DLL_DISABLE; iin.s <= ProgramEMRWait; -- LOAD MODE REGISTER command cycle time tMRD: 12ns when ProgramEMRWait => if i.c = 1 then iin.c <= 0; iin.s <= ProgramMR; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 11. Program the Mode Rgister -- ----------------------------------------------------------------------- when ProgramMR => SD_CMD <= CMD_LMR; SD_BA <= BMR_ADDR; -- Select Base Mode Register. SD_A <= OP_NORMAL & CAS_2 & BT_S & BL_2; iin.s <= ProgramMRWait; -- LOAD MODE REGISTER command cycle time tMRD: 12ns when ProgramMRWait => if i.c = 1 then iin.c <= 0; iin.s <= Precharge1; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 13. Precharge all banks. -- ----------------------------------------------------------------------- when Precharge1 => SD_CMD <= CMD_PRECHARGE; SD_A(10) <= '1'; -- Precharge all operation. iin.s <= Precharge1Wait; -- PRECHARGE command period tRP: 15ns when Precharge1Wait => if i.c = 1 then iin.c <= 0; iin.s <= AutoRefresh0; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 15. Auto Refresh. -- ----------------------------------------------------------------------- when AutoRefresh0 => SD_CMD <= CMD_AUTO_REFRESH; iin.s <= AutoRefresh0Wait; -- AUTO REFRESH command period tRFC: 72ns when AutoRefresh0Wait => if i.c = 7 then iin.c <= 0; iin.s <= AutoRefresh1; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 17. Auto Refresh. -- ----------------------------------------------------------------------- when AutoRefresh1 => SD_CMD <= CMD_AUTO_REFRESH; iin.s <= AutoRefresh1Wait; -- AUTO REFRESH command period tRFC: 72ns when AutoRefresh1Wait => if i.c = 7 then iin.c <= 0; iin.s <= ProgramMR1; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 19. Program the Mode Rgister (Clear DLL Bit) -- ----------------------------------------------------------------------- when ProgramMR1 => SD_CMD <= CMD_LMR; SD_BA <= BMR_ADDR; -- Select Base Mode Register. SD_A <= OP_NORMAL & CAS_2 & BT_S & BL_2; iin.s <= ProgramMR1Wait; -- LOAD MODE REGISTER command cycle time tMRD: 12ns when ProgramMR1Wait => if i.c = 1 then iin.c <= 0; iin.s <= Wait200; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- 21. Wait for 200 cycles. -- ----------------------------------------------------------------------- when Wait200 => if i.c = 199 then iin.c <= 0; iin.s <= Done; else iin.c <= i.c + 1; end if; ----------------------------------------------------------------------- -- Initialization done. -- ----------------------------------------------------------------------- when Done => init_done <= true; end case; end process; ----------------------------------------------------------------------------- -- Register -- ----------------------------------------------------------------------------- reg : process(clk0) begin if rising_edge(clk0) then if rst = '1' then i <= init_d; else i <= iin; end if; end if; end process; end rtl;
