# Makefile                                                         #
.SUFFIXES:				# ignore builtin rules
.PHONY: all debug release clean
# Definitions                                                      #
DEVICE = EFM32GG990F1024
PROJECTNAME = usbdmsd
OBJ_DIR = build
EXE_DIR = exe
LST_DIR = lst
# Definitions of toolchain.                                        #
# You might need to do changes to match your system setup          #
# Change path to CodeSourcery tools according to your system configuration
WINDOWSCS = CodeSourcery/Sourcery G++ Lite
LINUXCS   = /cad/codesourcery/arm-none-eabi/arm-2010q1
GCCVERSION = $(shell $(CC) -dumpversion)
ifeq ($(ComSpec),)
  ifeq ($(COMSPEC),)
    # Assume we are making on a linux platform
    TOOLDIR = $(LINUXCS)
    RM = rm -rf
  else
    TOOLDIR = $(PROGRAMFILES)/$(WINDOWSCS)
    RM = "$(TOOLDIR)/bin/cs-rm" -rf
    QUOTE ="
  endif
else
  TOOLDIR = $(ProgramFiles)/$(WINDOWSCS)
  QUOTE ="
endif
CC      = $(QUOTE)$(TOOLDIR)/bin/arm-none-eabi-gcc$(QUOTE)
LD      = $(QUOTE)$(TOOLDIR)/bin/arm-none-eabi-ld$(QUOTE)
AR      = $(QUOTE)$(TOOLDIR)/bin/arm-none-eabi-ar$(QUOTE)
OBJCOPY = $(QUOTE)$(TOOLDIR)/bin/arm-none-eabi-objcopy$(QUOTE)
DUMP    = $(QUOTE)$(TOOLDIR)/bin/arm-none-eabi-objdump$(QUOTE) --disassemble
# Flags                                                            #
# -MMD : Don't generate dependencies on system header files.
# -MP  : Add phony targets, useful when a h-file is removed from a project.
# -MF  : Specify a file to write the dependencies to.
DEPFLAGS = -MMD -MP -MF $(@:.o=.d)
# Add -Wa,-ahld=$(LST_DIR)/$(@F:.o=.lst) to CFLAGS to produce assembly list files
CFLAGS += -D$(DEVICE) -mcpu=cortex-m3 -mthumb -ffunction-sections -fdata-sections \
-mfix-cortex-m3-ldrd -fomit-frame-pointer -Wall -Wextra -fwide-exec-charset=UTF-16LE -fshort-wchar -DDEBUG_EFM_USER  $(DEPFLAGS)
ASMFLAGS += -x assembler-with-cpp
LDFLAGS += -Xlinker -Map=$(LST_DIR)/$(PROJECTNAME).map -mcpu=cortex-m3 -mthumb \
-T../../../../../Device/EnergyMicro/EFM32GG/Source/G++/efm32gg.ld \
-L"$(TOOLDIR)/arm-none-eabi/lib/thumb2" \
-L"$(TOOLDIR)/lib/gcc/arm-none-eabi/$(GCCVERSION)/thumb2" \
-Wl,--gc-sections,--no-wchar-size-warning
LIBS = -Wl,--start-group -lgcc -lc -lcs3 -lcs3unhosted -Wl,--end-group
INCLUDEPATHS += \
-I.. \
-I.. \
-I../../../../../CMSIS/Include \
-I../../../../../Device/EnergyMicro/EFM32GG/Include \
-I../../../../../emlib/inc \
-I../../../../../usb/inc \
-I../../../drivers \
-I../../../drivers/fatfs/src \
-I../../../bsp
# Files                                                            #
C_SRC +=  \
../../../../../Device/EnergyMicro/EFM32GG/Source/system_efm32gg.c \
../../../bsp/dvk.c \
../../../bsp/dvk_ebi.c \
../../../bsp/dvk_spi.c \
../../../bsp/trace.c \
../../../drivers/retargetio.c \
../../../drivers/retargetserial.c \
../../../drivers/msdd.c \
../../../drivers/microsd.c \
../../../drivers/norflash.c \
../../../drivers/fatfs/src/diskio.c \
../../../../../emlib/src/em_assert.c \
../../../../../emlib/src/em_cmu.c \
../../../../../emlib/src/em_ebi.c \
../../../../../emlib/src/em_emu.c \
../../../../../emlib/src/em_gpio.c \
../../../../../emlib/src/em_int.c \
../../../../../emlib/src/em_msc.c \
../../../../../emlib/src/em_system.c \
../../../../../emlib/src/em_timer.c \
../../../../../emlib/src/em_usart.c \
../../../../../usb/src/em_usbd.c \
../../../../../usb/src/em_usbdch9.c \
../../../../../usb/src/em_usbhal.c \
../../../../../usb/src/em_usbdep.c \
../../../../../usb/src/em_usbdint.c \
../../../../../usb/src/em_usbtimer.c \
../main.c \
../msddmedia.c
S_SRC +=  \
../../../../../Device/EnergyMicro/EFM32GG/Source/G++/startup_efm32gg.s
# Rules                                                            #
C_FILES = $(notdir $(C_SRC) )
S_FILES = $(notdir $(S_SRC) )
#make list of source paths, sort also removes duplicates
C_PATHS = $(sort $(dir $(C_SRC) ) )
S_PATHS = $(sort $(dir $(S_SRC) ) )
C_OBJS = $(addprefix $(OBJ_DIR)/, $(C_FILES:.c=.o))
S_OBJS = $(addprefix $(OBJ_DIR)/, $(S_FILES:.s=.o))
C_DEPS = $(addprefix $(OBJ_DIR)/, $(C_FILES:.c=.d))
vpath %.c $(C_PATHS)
vpath %.s $(S_PATHS)
# Default build is debug build
all:      debug
debug:    CFLAGS += -DDEBUG -O0 -g3
debug:    $(OBJ_DIR) $(LST_DIR) $(EXE_DIR) $(EXE_DIR)/$(PROJECTNAME).bin
release:  CFLAGS += -DNDEBUG -O0 -g3 
release:  $(OBJ_DIR) $(LST_DIR) $(EXE_DIR) $(EXE_DIR)/$(PROJECTNAME).bin
# Create directories
$(OBJ_DIR):
	mkdir $(OBJ_DIR)
	@echo "Created build directory."
$(EXE_DIR):
	mkdir $(EXE_DIR)
	@echo "Created executable directory."
$(LST_DIR):
	mkdir $(LST_DIR)
	@echo "Created list directory."
# Create objects from C SRC files
$(OBJ_DIR)/%.o: %.c
	@echo "Building file: $<"
	$(CC) $(CFLAGS) $(INCLUDEPATHS) -c -o $@ $<
# Assemble .s files
$(OBJ_DIR)/%.o: %.s
	@echo "Assembling $<"
	$(CC) $(ASMFLAGS) $(INCLUDEPATHS) -c -o $@ $<
# Link
$(EXE_DIR)/$(PROJECTNAME).out: $(C_OBJS) $(S_OBJS)
	@echo "Linking target: $@"
	$(CC) $(LDFLAGS) $(C_OBJS) $(S_OBJS) $(LIBS) -o $(EXE_DIR)/$(PROJECTNAME).out
# Create binary file
$(EXE_DIR)/$(PROJECTNAME).bin: $(EXE_DIR)/$(PROJECTNAME).out
	@echo "Creating binary file"
	$(OBJCOPY) -O binary $(EXE_DIR)/$(PROJECTNAME).out $(EXE_DIR)/$(PROJECTNAME).bin
# Uncomment next line to produce assembly listing of entire program
#	$(DUMP) $(EXE_DIR)/$(PROJECTNAME).out>$(LST_DIR)/$(PROJECTNAME)out.lst
clean:
	$(RM) $(OBJ_DIR) $(LST_DIR) $(EXE_DIR)
# include auto-generated dependency files (explicit rules)
ifneq (clean,$(findstring clean, $(MAKECMDGOALS)))
-include $(C_DEPS)
endif
