# Automatically-generated file. Do not edit!
-include ../makefile.init
RM := cs-rm -rf
# All of the sources participating in the build are defined here
-include sources.mk
-include usb/src/subdir.mk
-include emlib/src/subdir.mk
-include drivers/graphics/glib/subdir.mk
-include drivers/graphics/dmd/ssd2119/subdir.mk
-include drivers/fatfs/src/option/subdir.mk
-include drivers/fatfs/src/subdir.mk
-include drivers/subdir.mk
-include bsp/subdir.mk
-include EFM32GG/Source/IAR/subdir.mk
-include EFM32GG/Source/subdir.mk
-include subdir.mk
-include objects.mk
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C++_DEPS)),)
-include $(C++_DEPS)
endif
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
ifneq ($(strip $(ASM_DEPS)),)
-include $(ASM_DEPS)
endif
ifneq ($(strip $(CC_DEPS)),)
-include $(CC_DEPS)
endif
ifneq ($(strip $(CPP_DEPS)),)
-include $(CPP_DEPS)
endif
ifneq ($(strip $(CXX_DEPS)),)
-include $(CXX_DEPS)
endif
ifneq ($(strip $(C_UPPER_DEPS)),)
-include $(C_UPPER_DEPS)
endif
ifneq ($(strip $(S_UPPER_DEPS)),)
-include $(S_UPPER_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables 
SECONDARY_FLASH += \
test.hex \
SECONDARY_LIST += \
test.lst \
SECONDARY_SIZE += \
test.siz \
# All Target
all: test.elf secondary-outputs
# Tool invocations
test.elf: $(OBJS) $(USER_OBJS)
	@echo 'Building target: $@'
	@echo 'Invoking: ARM Sourcery Windows GCC C++ Linker'
	arm-none-eabi-g++ -T"C:/Users/csander/AppData/Roaming/energymicro/Device/EnergyMicro/EFM32GG/Source/G++/efm32gg.ld" -Xlinker --gc-sections -L"C:\Program Files (x86)\CodeSourcery\Sourcery G++ Lite\arm-none-eabi\lib\thumb2" -L"C:\Program Files (x86)\CodeSourcery\Sourcery G++ Lite\lib\gcc\arm-none-eabi\4.4.1\thumb2" -Wl,-Map,test.map -mcpu=cortex-m3 -mthumb -DNDEBUG -o "test.elf" $(OBJS) $(USER_OBJS) $(LIBS)
	@echo 'Finished building target: $@'
	@echo ' '
test.hex: test.elf
	@echo 'Invoking: ARM Sourcery Windows GNU Create Flash Image'
	arm-none-eabi-objcopy -O ihex test.elf  "test.hex"
	@echo 'Finished building: $@'
	@echo ' '
test.lst: test.elf
	@echo 'Invoking: ARM Sourcery Windows GNU Create Listing'
	arm-none-eabi-objdump -h -S test.elf > "test.lst"
	@echo ' '
test.siz: test.elf
	@echo 'Invoking: ARM Sourcery Windows GNU Print Size'
	arm-none-eabi-size  --format=berkeley test.elf
	@echo ' '
# Other Targets
clean:
	-$(RM) $(OBJS)$(C_DEPS)$(SECONDARY_FLASH)$(CXX_DEPS)$(S_UPPER_DEPS)$(SECONDARY_LIST)$(C++_DEPS)$(SECONDARY_SIZE)$(ASM_DEPS)$(CC_DEPS)$(CPP_DEPS)$(EXECUTABLES)$(C_UPPER_DEPS) test.elf
	-@echo ' '
secondary-outputs: $(SECONDARY_FLASH) $(SECONDARY_LIST) $(SECONDARY_SIZE)
.PHONY: all clean dependents
.SECONDARY:
-include ../makefile.targets
