fet140_1.c - Software Toggle P1.0
fet140_adc12_01.c - ADC12 Sample A0 Set P1.0 if A0 > 0.5*AVcc
fet140_adc12_02.c - ADC12 Using the Internal Reference
fet140_adc12_03.c - ADC12 Sample A10 Temp Set P1.0 if temp ++ ~2c
fet140_adc12_04.c - ADC12 Extended sampling
fet140_adc12_05.c - ADC12 Using an External Reference
fet140_adc12_06.c - ADC12 Repeated Sequence of Conversions
fet140_adc12_07.c - ADC12 Repeated Single Channel Conversions
fet140_adc12_08.c - ADC12 Using 10 External Channels for Conversion
fet140_adc12_09.c - ADC12 Sequence of Conversions (non-repeated)
fet140_adc12_10.c - ADC12 Sample A10 Temp and Convert to oC and oF
fet140_clks.c - BasicClock Output buffered SMCLK, ACLK and MCLK
fet140_dac12_01.c - DAC12.0 Output 1V
fet140_dac12_02.c - DAC12.1 Output 2V
fet140_dac12_03.c - DAC12.0 Output Voltage Ramp
fet140_dma_01.c - DMA0 Repeated Burst to-from RAM, Software Trigger
fet140_dma_02.c - DMA0 Repeated Block To P1OUT, TACCR2, DCO
fet140_dma_03.c - DMA0 Repeated Block UART1 9600, TACCR2, ACLK
fet140_dma_04.c - DMA0 Block Mode UART1 9600, ACLK/li>
fet140_dma_05.c - DMA0 Repeated Block to DAC0 Sine Output, TACCR1, DCO
fet140_dma_06.c - DMA0 Repeated Block to DAC1 8-bit Sine Output, TBCCR2, DCO
fet140_dma_07.c - DMA0/1 Repeated Block to DAC0/1 Sin/Cos, TACCR1, XT2
fet140_dma_08.c - DMA0 Repeated Block, I2C Master Interface DAC8571
fet140_dma_09.c - DMA0 ADC12 A10 Block Transfer to RAM, TBCCR1, DCO
fet140_dma_10.c - DMA0 ADC12 A10 Block Transfer to Flash, TBCCR1, DCO
fet140_dma_11.c - DMA0/1 ADC12 A10 Block Transfer to MPY/RAM, TBCCR1, DCO
fet140_dma_12.c - DMA1/0 Block Mode UART1 9600 Auto RX/TX String, ACLK
fet140_dma_13.c - DMA2/1/0 USART0 UART 9600 Full-Duplex Transceiver, ACLK
fet140_dma_14.c - DMA2/1/0 USART0 SPI 3-Wire SPI Master P1.x Exchange
fet140_dma_15.c - DMA2/1/0 USART0 SPI 3-Wire SPI Slave P1.x Exchange
fet140_dma_16.c - DMA2/1/0 USART1 SPI 3-Wire SPI Master P1.x Exchange
fet140_flash_write.c - Flash In-System Programming
fet140_fll.c - BasicClock Implement Auto RSEL SW FLL
fet140_fll2.c - BasicClock Implement Continous SW FLL with Auto RSEL
fet140_hfxt2.c - BasicClock MCLK configured with HF XTAL XT2
fet140_hfxtal.c - BasicClock MCLK configured with HF XTAL
fet140_i2c_01.c - I2C Master Interface TMP100, Set P1.0 if Temp > 28c
fet140_i2c_02.c - I2C Master Interface PCF8574 Read / Write
fet140_i2c_03.c - I2C Master Interface DAC8571
fet140_i2c_04.c - I2C Slave TMP100 Emulation
fet140_i2c_mstr.c - I2C Master reads from MSP430 Slave
fet140_i2c_multi.c - I2C Multimaster Interface
fet140_i2c_slav.c - I2C Slave Read from MSP430 Master
fet140_lpm3.c - BasicClock LPM3 Using WDT ISR, 32kHz ACLK
fet140_nmi.c - BasicClock Configure RST/NMI as NMI
fet140_rosc.c - BasicClock DCOCLK Biased with External Resistor Rosc
fet140_spi0_016x.c - USART0 SPI Interface with HC165/164 Shift Registers
fet140_spi0_5616.c - USART0 SPI Interface to TLV5516 DAC
fet140_spi0_mstr.c - USART0 SPI 3-Wire SPI Master
fet140_spi0_mstr0.c - USART0 SPI 3-Wire SPI Master P1.x Exchange
fet140_spi0_slav.c - USART0 SPI 3-Wire SPI Slave
fet140_spi0_slav0.c - USART0 SPI 3-Wire SPI Slave P1.x Exchange
fet140_spi1_5616.c - USART1 SPI Interface to TLV5516 DAC
fet140_spi1_mstr1.c - USART1 SPI 3-Wire SPI Master P1.x Exchange
fet140_svs01.c - SVS POR @ 2.5V VCC
fet140_ta01.c - Timer_A Toggle P1.0, CCR0 Contmode ISR, DCO SMCLK
fet140_ta02.c - Timer_A Toggle P1.0, CCR0 upmode ISR, DCO SMCLK
fet140_ta03.c - Timer_A Toggle P1.0, overflow ISR, DCO SMCLK
fet140_ta04.c - Timer_A Toggle P1.0, overflow ISR, 32kHz ACLK
fet140_ta05.c - Timer_A Toggle P1.0, CCR0 upmode ISR, 32kHz ACLK
fet140_ta06.c - Timer_A Toggle P1.0, CCR1 Contmode ISR, DCO SMCLK
fet140_ta07.c - Timer_A Toggle P1.0-3 CCRx Contmode ISR, DCO SMCLK
fet140_ta08.c - Timer_A Toggle P1.0-3 CCRx Contmode ISR, 32kHz ACLK
fet140_ta09.c - Timer_A Toggle P1.0-3 CCRx Contmode ISR, HF XTAL ACLK
fet140_ta10.c - Timer_A Toggle P1.1 With TA0 upmode, DCO SMCLK
fet140_ta11.c - Timer_A Toggle P1.1 With TA0 upmode, 32kHz ACLK
fet140_ta12.c - Timer_A Toggle P1.1 With TA0 upmode, HF XTAL ACLK
fet140_ta13.c - Timer_A Toggle P1.1 With TA0 up-downmode, DCO SMCLK
fet140_ta14.c - Timer_A Toggle P1.1 With TA0 up-downmode, 32kHz ACLK
fet140_ta15.c - Timer_A Toggle P1.1 With TA0 up-downmode, HF XTAL ACLK
fet140_ta_pwm01.c - Timer_A PWM TA1-2 upmode, DCO SMCLK
fet140_ta_pwm02.c - Timer_A PWM TA1-2 upmode, 32kHz ACLK
fet140_ta_pwm03.c - Timer_A PWM TA1-2 upmode, HF XTAL ACLK
fet140_ta_pwm04.c - Timer_A PWM TA1-2 up-downmode, DCO SMCLK
fet140_ta_pwm05.c - Timer_A PWM TA1-2 up-downmode, 32kHz ACLK
fet140_ta_pwm06.c - Timer_A PWM TA1-2 up-downmode, HF XTAL ACLK
fet140_tb01.c - Timer_B Toggle P1.0, TBCCR0 Contmode ISR, DCO SMCLK
fet140_tb02.c - Timer_B Toggle P1.0, CCR0 upmode ISR, DCO SMCLK
fet140_tb03.c - Timer_B Toggle P1.0, overflow ISR, DCO SMCLK
fet140_tb04.c - Timer_B Toggle P1.0, overflow ISR, 32kHz ACLK
fet140_tb05.c - Timer_B Toggle P1.0, CCR0 upmode ISR, 32kHz ACLK
fet140_tb_pwm01.c - Timer_B PWM TB1-6 upmode, DCO SMCLK
fet140_tb_pwm02.c - Timer_B PWM TB1-6 upmode, 32kHz ACLK
fet140_tb_pwm03.c - Timer_B PWM TB1-2 upmode, HF XTAL ACLK
fet140_tb_pwm04.c - Timer_B PWM TB1-2 up-downmode, DCO SMCLK
fet140_tb_pwm05.c - Timer_B PWM TB1-2 up-downmode, 32kHz ACLK
fet140_tb_pwm06.c - Timer_B PWM TB1-2 up-downmode, HF XTAL ACLK
fet140_uart01_0115k.c - UART0 115200 Echo ISR, HF XTAL ACLK
fet140_uart01_0115k_2.c - UART0 115200 Echo ISR, XT2 HF XTAL SMCLK
fet140_uart01_02400.c - UART0 2400 Ultra-low Power Echo ISR, 32kHz ACLK
fet140_uart01_09600.c - UART0 9600 Echo ISR, HF XTAL ACLK
fet140_uart02_09600.c - UART0 9600 Ultra-low Echo ISR, 32kHz ACLK+ DCO
fet140_uart03_09600.c - UART0 9600 Echo ISR, 32kHz ACLK + DCO
fet140_uart04_09600.c - UART0 9600 Echo ISR, No XTAL, DCO Only
fet140_uart05_09600.c - UART0 9600 Ultra-low Power Echo ISR, 32kHz ACLK
fet120_uart06_09600.c - UART0 9600 Ultra-low Power String, 32kHz ACLK
fet120_uart07_09600.c - UART0 9600 Ultra-low Power RX/TX, 32kHz ACLK
fet140_uart08_09600.c - UART0 9600 Full-Duplex Transceiver, 32K ACLK
fet140_uart01_09600_2.c - UART0 9600 Ultra-low Power Echo ISR, 32kHz ACLK
fet140_uart01_19200.c - UART0 19200 Echo ISR, HF XTAL ACLK
fet140_uart01_19200_2.c - UART0 19200 Echo ISR, XT2 HF XTAL SMCLK
fet140_uart02_19200.c - UART0 19200 Ultra-low Echo ISR, 32kHz ACLK+ DCO
fet140_uart03_19200.c - UART0 19200 Echo ISR, 32kHz ACLK + DCO
fet140_uart04_19200.c - UART0 19200 Echo ISR, No XTAL, DCO Only
fet140_uart11_0115k_2.c - UART1 115200 Echo ISR, XT2 HF XTAL SMCLK
fet140_uart11_02400.c - UART1 2400 Ultra-low Power Echo ISR, 32kHz ACLK
fet140_uart15_09600.c - UART1 9600 Ultra-low Power Echo ISR, 32kHz ACLK
fet140_uart11_19200_2.c - UART1 19200 Echo ISR, XT2 HF XTAL SMCLK
fet140_wdt01.c - WDT Toggle P1.0 Interval overflow ISR, DCO SMCLK
fet140_wdt02.c - WDT Toggle P1.0 Interval overflow ISR, 32kHz ACLK
fet140_wdt03.c - WDT Toggle P1.0 Interval overflow ISR, HF XTAL ACLK
