make -k all ------------------------------------------------------------------------------- Konfiguration: FlashLoader - RUN_FROM_RAM - RAM-Debug ------------------------------------------------------------------------------- Aktualisierung der TMS470-Register-Adressierung wird durchgeführt Kompilierung läuft... Linker-Vorgang läuft... Using built-in specs. Target: arm-elf Configured with: ../../gcc-4.0.2/configure --enable-languages=c,c++ --enable-interwork --enable-multilib --with-gcc --with-gnu-ld --with-gnu-as --with-stabs --disable-shared --disable-threads --disable-win32-registry --disable-nls --target=arm-elf --with-newlib --prefix=c:/WinARM -v Thread model: single gcc version 4.0.2 (WinARM) c:/winarm/bin/../libexec/gcc/arm-elf/4.0.2/cc1.exe -E -lang-asm -quiet -v -iprefix c:\winarm\bin\../lib/gcc/arm-elf/4.0.2/ -D__USES_INITFINI__ ../system_source/crt0.S -o C:/DOKUME~1/kbrandt/LOKALE~1/Temp/cc6Jaaaa.s ignoring nonexistent directory "c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/sys-include" ignoring nonexistent directory "c:/WinARM/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/sys-include" #include "..." search starts here: #include <...> search starts here: c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/include c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/include c:/WinARM/lib/gcc/arm-elf/4.0.2/include c:/WinARM/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/include End of search list. c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/bin/as.exe -o C:/DOKUME~1/kbrandt/LOKALE~1/Temp/cc2jbaaa.o C:/DOKUME~1/kbrandt/LOKALE~1/Temp/cc6Jaaaa.s c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/bin/ld.exe -X c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/crti.o c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/crtbegin.o c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/crt0.o -Lc:/winarm/bin/../lib/gcc/arm-elf/4.0.2 -Lc:/winarm/bin/../lib/gcc -Lc:/WinARM/lib/gcc/arm-elf/4.0.2 -Lc:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib -Lc:/WinARM/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib C:/DOKUME~1/kbrandt/LOKALE~1/Temp/cc2jbaaa.o FlashLoader.o TestClass.o -lstdc++ -lm -lgcc -lc -lgcc c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/crtend.o c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/crtn.o -T../system_source/TMS470R1B1M-RAM.ld -T../system_source/reg_map.ld C:/DOKUME~1/kbrandt/LOKALE~1/Temp/cc2jbaaa.o: In function `_start':../system_source/crt0.S:(.text+0xe0): multiple definition of `_start' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/crt0.o:c:/winarms/newlib-1.14.0/libgloss/arm/crt0.S:67: first defined here c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(mallocr.o): In function `_malloc_r':mallocr.c:(.text+0x430): undefined reference to `_sbrk_r' :mallocr.c:(.text+0x5ec): undefined reference to `_sbrk_r' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(freer.o): In function `_malloc_trim_r':mallocr.c:(.text+0x48): undefined reference to `_sbrk_r' :mallocr.c:(.text+0x70): undefined reference to `_sbrk_r' :mallocr.c:(.text+0xb4): undefined reference to `_sbrk_r' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(makebuf.o): In function `__smakebuf':makebuf.c:(.text+0x44): undefined reference to `_fstat_r' :makebuf.c:(.text+0xe4): undefined reference to `isatty' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(stdio.o): In function `__sread':stdio.c:(.text+0x1c): undefined reference to `_read_r' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(stdio.o): In function `__swrite':stdio.c:(.text+0x78): undefined reference to `_lseek_r' :stdio.c:(.text+0x9c): undefined reference to `_write_r' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(stdio.o): In function `__sseek':stdio.c:(.text+0xc0): undefined reference to `_lseek_r' c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libc.a(stdio.o): In function `__sclose':stdio.c:(.text+0xf8): undefined reference to `_close_r' make: *** [create_elf] Error 1 ------------------------------------------------------------------------------- c:\WinARM\bin\arm-elf-size.exe: 'FlashLoader.elf': No such file c:\WinARM\bin\arm-elf-size.exe: 'FlashLoader.elf': No such file ------------------------------------------------------------------------------- c:\WinARM\bin\arm-elf-size.exe: 'FlashLoader.hex': No such file make: Target `all' not remade because of errors.
