#ifndef SD_RAW_CONFIG_H #define SD_RAW_CONFIG_H /** * \addtogroup sd_raw * * @{ */ /** * \file * MMC/SD support configuration. */ /** * \ingroup sd_raw_config * Controls MMC/SD write support. * * Set to 1 to enable MMC/SD write support, set to 0 to disable it. */ #define SD_RAW_WRITE_SUPPORT 1 /** * \ingroup sd_raw_config * Controls MMC/SD write buffering. * * Set to 1 to buffer write accesses, set to 0 to disable it. * * \note This option has no effect when SD_RAW_WRITE_SUPPORT is 0. */ #define SD_RAW_WRITE_BUFFERING 1 /** * \ingroup sd_raw_config * Controls MMC/SD access buffering. * * Set to 1 to save static RAM, but be aware that you will * lose performance. * * \note When SD_RAW_WRITE_SUPPORT is 1, SD_RAW_SAVE_RAM will * be reset to 0. */ #define SD_RAW_SAVE_RAM 1 /* defines for customisation of sd/mmc port access */ #if defined(__AVR_ATmega8__) || \ defined(__AVR_ATmega48__) || \ defined(__AVR_ATmega88__) || \ defined(__AVR_ATmega168__) #define configure_pin_mosi() DDRB |= (1 << DDB3) #define configure_pin_sck() DDRB |= (1 << DDB5) #define configure_pin_ss() DDRB |= (1 << DDB2) #define configure_pin_miso() DDRB &= ~(1 << DDB4) #define select_card() PORTB &= ~(1 << PB2) #define unselect_card() PORTB |= (1 << PB2) #elif defined(__AVR_ATmega16__) || \ defined(__AVR_ATmega32__) #define configure_pin_mosi() DDRB |= (1 << DDB5) #define configure_pin_sck() DDRB |= (1 << DDB7) #define configure_pin_ss() DDRB |= (1 << DDB4) #define configure_pin_miso() DDRB &= ~(1 << DDB6) #define select_card() PORTB &= ~(1 << PB4) #define unselect_card() PORTB |= (1 << PB4) #elif defined(__AVR_ATmega64__) || \ defined(__AVR_ATmega128__) #define configure_pin_mosi() DDRB |= (1 << DDB2) #define configure_pin_sck() DDRB |= (1 << DDB1) #define configure_pin_ss() DDRB |= (1 << DDB0) #define configure_pin_miso() DDRB &= ~(1 << DDB3) #define select_card() PORTB &= ~(1 << PB0) #define unselect_card() PORTB |= (1 << PB0) #else #error "no sd/mmc pin mapping available!" #endif #define configure_pin_available() DDRC &= ~(1 << DDC4) #define configure_pin_locked() DDRC &= ~(1 << DDC5) #define get_pin_available() ((PINC >> PC4) & 0x01) #define get_pin_locked() ((PINC >> PC5) & 0x01) /** * @} */ /* configuration checks */ #if SD_RAW_WRITE_SUPPORT #undef SD_RAW_SAVE_RAM #define SD_RAW_SAVE_RAM 0 #else #undef SD_RAW_WRITE_BUFFERING #define SD_RAW_WRITE_BUFFERING 0 #endif #endif
