Release 6.2.03i - Par G.31a Copyright (c) 1995-2004 Xilinx, Inc. All rights reserved. Mon Jul 12 10:32:17 2004 INPUT FILE: s3demo_map.ncd OUTPUT FILE: s3demo_pad.txt PART TYPE: xc3s200 SPEED GRADE: -5 PACKAGE: ft256 Pinout by Pin Number: ----- |----- |----- |----- |----- |----- |----- |----- |----- |----- |----- |----- |----- | Pin Number|Signal Name|Pin Usage|Pin Name |Direction|IO Standard|IO Bank Number|Drive (mA)|Slew Rate|Termination|IOB Delay|Voltage|Constraint| A1 | | |GND | | | | | | | | | | A2 | | |TDI | | | | | | | | | | A3 | |IOB |IO/VREF_0 |UNUSED | |0 | | | | | | | A4 | |IOB |IO_L01P_0/VRN_0 |UNUSED | |0 | | | | | | | A5 | |IOB |IO |UNUSED | |0 | | | | | | | A6 | | |VCCAUX | | | | | | | |2.5 | | A7 | |IOB |IO |UNUSED | |0 | | | | | | | A8 | |IOB |IO_L32P_0/GCLK6 |UNUSED | |0 | | | | | | | A9 | |IOB |IO |UNUSED | |1 | | | | | | | A10 | |IOB |IO_L31N_1/VREF_1 |UNUSED | |1 | | | | | | | A11 | | |VCCAUX | | | | | | | |2.5 | | A12 | |IOB |IO |UNUSED | |1 | | | | | | | A13 | |IOB |IO_L10N_1/VREF_1 |UNUSED | |1 | | | | | | | A14 | |IOB |IO_L01N_1/VRP_1 |UNUSED | |1 | | | | | | | A15 | | |TDO | | | | | | | | | | A16 | | |GND | | | | | | | | | | B1 | |IOB |IO_L01P_7/VRN_7 |UNUSED | |7 | | | | | | | B2 | | |GND | | | | | | | | | | B3 | | |PROG_B | | | | | | | | | | B4 | |IOB |IO_L01N_0/VRP_0 |UNUSED | |0 | | | | | | | B5 | |IOB |IO_L25P_0 |UNUSED | |0 | | | | | | | B6 | |IOB |IO_L28P_0 |UNUSED | |0 | | | | | | | B7 | |IOB |IO_L30P_0 |UNUSED | |0 | | | | | | | B8 | |IOB |IO_L32N_0/GCLK7 |UNUSED | |0 | | | | | | | B9 | | |GND | | | | | | | | | | B10 | |IOB |IO_L31P_1 |UNUSED | |1 | | | | | | | B11 | |IOB |IO_L29N_1 |UNUSED | |1 | | | | | | | B12 | |IOB |IO_L27N_1 |UNUSED | |1 | | | | | | | B13 | |IOB |IO_L10P_1 |UNUSED | |1 | | | | | | | B14 | |IOB |IO_L01P_1/VRN_1 |UNUSED | |1 | | | | | | | B15 | | |GND | | | | | | | | | | B16 | |IOB |IO_L01N_2/VRP_2 |UNUSED | |2 | | | | | | | C1 | |IOB |IO_L01N_7/VRP_7 |UNUSED | |7 | | | | | | | C2 | |IOB |IO_L16N_7 |UNUSED | |7 | | | | | | | C3 | |IOB |IO_L16P_7/VREF_7 |UNUSED | |7 | | | | | | | C4 | | |HSWAP_EN | | | | | | | | | | C5 | |IOB |IO_L25N_0 |UNUSED | |0 | | | | | | | C6 | |IOB |IO_L28N_0 |UNUSED | |0 | | | | | | | C7 | |IOB |IO_L30N_0 |UNUSED | |0 | | | | | | | C8 | |IOB |IO_L31P_0/VREF_0 |UNUSED | |0 | | | | | | | C9 | |IOB |IO_L32N_1/GCLK5 |UNUSED | |1 | | | | | | | C10 | |IOB |IO |UNUSED | |1 | | | | | | | C11 | |IOB |IO_L29P_1 |UNUSED | |1 | | | | | | | C12 | |IOB |IO_L27P_1 |UNUSED | |1 | | | | | | | C13 | | |TMS | | | | | | | | | | C14 | | |TCK | | | | | | | | | | C15 | |IOB |IO_L16N_2 |UNUSED | |2 | | | | | | | C16 | |IOB |IO_L01P_2/VRN_2 |UNUSED | |2 | | | | | | | D1 | |IOB |IO_L17N_7 |UNUSED | |7 | | | | | | | D2 | |IOB |IO_L17P_7 |UNUSED | |7 | | | | | | | D3 | |IOB |IO_L19P_7 |UNUSED | |7 | | | | | | | D4 | | |VCCINT | | | | | | | |1.2 | | D5 | |IOB |IO/VREF_0 |UNUSED | |0 | | | | | | | D6 | |IOB |IO_L27P_0 |UNUSED | |0 | | | | | | | D7 | |IOB |IO_L29P_0 |UNUSED | |0 | | | | | | | D8 | |IOB |IO_L31N_0 |UNUSED | |0 | | | | | | | D9 | |IOB |IO_L32P_1/GCLK4 |UNUSED | |1 | | | | | | | D10 | |IOB |IO_L30N_1 |UNUSED | |1 | | | | | | | D11 | |IOB |IO_L28N_1 |UNUSED | |1 | | | | | | | D12 | |IOB |IO/VREF_1 |UNUSED | |1 | | | | | | | D13 | | |VCCINT | | | | | | | |1.2 | | D14 |an<3> |IOB |IO_L16P_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | D15 | |IOB |IO_L17N_2 |UNUSED | |2 | | | | | | | D16 | |IOB |IO_L17P_2/VREF_2 |UNUSED | |2 | | | | | | | E1 | |IOB |IO_L20N_7 |UNUSED | |7 | | | | | | | E2 | |IOB |IO_L20P_7 |UNUSED | |7 | | | | | | | E3 | |IOB |IO_L19N_7/VREF_7 |UNUSED | |7 | | | | | | | E4 | |IOB |IO_L21P_7 |UNUSED | |7 | | | | | | | E5 | | |VCCINT | | | | | | | |1.2 | | E6 | |IOB |IO_L27N_0 |UNUSED | |0 | | | | | | | E7 | |IOB |IO_L29N_0 |UNUSED | |0 | | | | | | | E8 | | |VCCO_0 | | |0 | | | | |na | | E9 | | |VCCO_1 | | |1 | | | | |na | | E10 | |IOB |IO_L30P_1 |UNUSED | |1 | | | | | | | E11 | |IOB |IO_L28P_1 |UNUSED | |1 | | | | | | | E12 | | |VCCINT | | | | | | | |1.2 | | E13 |an<0> |IOB |IO_L19N_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | E14 |ssg<0> |IOB |IO_L19P_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | E15 | |IOB |IO_L20N_2 |UNUSED | |2 | | | | | | | E16 | |IOB |IO_L20P_2 |UNUSED | |2 | | | | | | | F1 | | |VCCAUX | | | | | | | |2.5 | | F2 | |IOB |IO_L22N_7 |UNUSED | |7 | | | | | | | F3 | |IOB |IO_L22P_7 |UNUSED | |7 | | | | | | | F4 | |IOB |IO_L21N_7 |UNUSED | |7 | | | | | | | F5 | |IOB |IO_L23P_7 |UNUSED | |7 | | | | | | | F6 | | |GND | | | | | | | | | | F7 | | |VCCO_0 | | |0 | | | | |na | | F8 | | |VCCO_0 | | |0 | | | | |na | | F9 | | |VCCO_1 | | |1 | | | | |na | | F10 | | |VCCO_1 | | |1 | | | | |na | | F11 | | |GND | | | | | | | | | | F12 |swt<0> |IOB |IO_L21N_2 |INPUT |LVCMOS25 |2 | | | |NONE | |LOCATED | F13 |ssg<5> |IOB |IO_L21P_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | F14 |an<1> |IOB |IO_L22N_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | F15 | |IOB |IO_L22P_2 |UNUSED | |2 | | | | | | | F16 | | |VCCAUX | | | | | | | |2.5 | | G1 | |IOB |IO_L40P_7 |UNUSED | |7 | | | | | | | G2 | |IOB |IO |UNUSED | |7 | | | | | | | G3 | |IOB |IO_L24N_7 |UNUSED | |7 | | | | | | | G4 | |IOB |IO_L24P_7 |UNUSED | |7 | | | | | | | G5 | |IOB |IO_L23N_7 |UNUSED | |7 | | | | | | | G6 | | |VCCO_7 | | |7 | | | | |na | | G7 | | |GND | | | | | | | | | | G8 | | |GND | | | | | | | | | | G9 | | |GND | | | | | | | | | | G10 | | |GND | | | | | | | | | | G11 | | |VCCO_2 | | |2 | | | | |2.50 | | G12 |swt<1> |IOB |IO_L23N_2/VREF_2 |INPUT |LVCMOS25 |2 | | | |NONE | |LOCATED | G13 |ssg<1> |IOB |IO_L23P_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | G14 |an<2> |IOB |IO_L24N_2 |OUTPUT |LVCMOS25 |2 |12 |SLOW |NONE** | | |LOCATED | G15 | |IOB |IO_L24P_2 |UNUSED | |2 | | | | | | | G16 | |IOB |IO |UNUSED | |2 | | | | | | | H1 | |IOB |IO_L40N_7/VREF_7 |UNUSED | |7 | | | | | | | H2 | | |GND | | | | | | | | | | H3 | |IOB |IO_L39N_7 |UNUSED | |7 | | | | | | | H4 | |IOB |IO_L39P_7 |UNUSED | |7 | | | | | | | H5 | | |VCCO_7 | | |7 | | | | |na | | H6 | | |VCCO_7 | | |7 | | | | |na | | H7 | | |GND | | | | | | | | | | H8 | | |GND | | | | | | | | | | H9 | | |GND | | | | | | | | | | H10 | | |GND | | | | | | | | | | H11 | | |VCCO_2 | | |2 | | | | |2.50 | | H12 | | |VCCO_2 | | |2 | | | | |2.50 | | H13 |swt<3> |IOB |IO_L39N_2 |INPUT |LVCMOS25 |2 | | | |NONE | |LOCATED | H14 |swt<2> |IOB |IO_L39P_2 |INPUT |LVCMOS25 |2 | | | |NONE | |LOCATED | H15 | |IOB |IO_L40N_2 |UNUSED | |2 | | | | | | | H16 | |IOB |IO_L40P_2/VREF_2 |UNUSED | |2 | | | | | | | J1 | |IOB |IO_L40P_6/VREF_6 |UNUSED | |6 | | | | | | | J2 | |IOB |IO_L40N_6 |UNUSED | |6 | | | | | | | J3 | |IOB |IO_L39P_6 |UNUSED | |6 | | | | | | | J4 | |IOB |IO_L39N_6 |UNUSED | |6 | | | | | | | J5 | | |VCCO_6 | | |6 | | | | |na | | J6 | | |VCCO_6 | | |6 | | | | |na | | J7 | | |GND | | | | | | | | | | J8 | | |GND | | | | | | | | | | J9 | | |GND | | | | | | | | | | J10 | | |GND | | | | | | | | | | J11 | | |VCCO_3 | | |3 | | | | |2.50 | | J12 | | |VCCO_3 | | |3 | | | | |2.50 | | J13 |swt<5> |IOB |IO_L39P_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | J14 |swt<4> |IOB |IO_L39N_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | J15 | | |GND | | | | | | | | | | J16 | |IOB |IO_L40N_3/VREF_3 |UNUSED | |3 | | | | | | | K1 | |IOB |IO |UNUSED | |6 | | | | | | | K2 | |IOB |IO_L24P_6 |UNUSED | |6 | | | | | | | K3 | |IOB |IO_L24N_6/VREF_6 |UNUSED | |6 | | | | | | | K4 | |IOB |IO_L23P_6 |UNUSED | |6 | | | | | | | K5 | |IOB |IO_L23N_6 |UNUSED | |6 | | | | | | | K6 | | |VCCO_6 | | |6 | | | | |na | | K7 | | |GND | | | | | | | | | | K8 | | |GND | | | | | | | | | | K9 | | |GND | | | | | | | | | | K10 | | |GND | | | | | | | | | | K11 | | |VCCO_3 | | |3 | | | | |2.50 | | K12 |led<0> |IOB |IO_L23N_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | K13 |swt<7> |IOB |IO_L24P_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | K14 |swt<6> |IOB |IO_L24N_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | K15 | |IOB |IO |UNUSED | |3 | | | | | | | K16 | |IOB |IO_L40P_3 |UNUSED | |3 | | | | | | | L1 | | |VCCAUX | | | | | | | |2.5 | | L2 | |IOB |IO_L22P_6 |UNUSED | |6 | | | | | | | L3 | |IOB |IO_L22N_6 |UNUSED | |6 | | | | | | | L4 | |IOB |IO_L21P_6 |UNUSED | |6 | | | | | | | L5 | |IOB |IO_L21N_6 |UNUSED | |6 | | | | | | | L6 | | |GND | | | | | | | | | | L7 | | |VCCO_5 | | |5 | | | | |na | | L8 | | |VCCO_5 | | |5 | | | | |na | | L9 | | |VCCO_4 | | |4 | | | | |2.50 | | L10 | | |VCCO_4 | | |4 | | | | |2.50 | | L11 | | |GND | | | | | | | | | | L12 |led<2> |IOB |IO_L23P_3/VREF_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | L13 |btn<2> |IOB |IO_L21N_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | L14 |btn<3> |IOB |IO_L22P_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | L15 | |IOB |IO_L22N_3 |UNUSED | |3 | | | | | | | L16 | | |VCCAUX | | | | | | | |2.5 | | M1 | |IOB |IO_L20P_6 |UNUSED | |6 | | | | | | | M2 | |IOB |IO_L20N_6 |UNUSED | |6 | | | | | | | M3 | |IOB |IO_L19P_6 |UNUSED | |6 | | | | | | | M4 | |IOB |IO_L19N_6 |UNUSED | |6 | | | | | | | M5 | | |VCCINT | | | | | | | |1.2 | | M6 | |IOB |IO_L28P_5/D7 |UNUSED | |5 | | | | | | | M7 | |IOB |IO_L30P_5 |UNUSED | |5 | | | | | | | M8 | | |VCCO_5 | | |5 | | | | |na | | M9 | | |VCCO_4 | | |4 | | | | |2.50 | | M10 | |IOB |IO_L29N_4 |UNUSED | |4 | | | | | | | M11 | |IOB |IO_L27N_4/DIN/D0 |UNUSED | |4 | | | | | | | M12 | | |VCCINT | | | | | | | |1.2 | | M13 |btn<0> |IOB |IO_L21P_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | M14 |btn<1> |IOB |IO_L19N_3 |INPUT |LVCMOS25 |3 | | | |NONE | |LOCATED | M15 |kd |IOB |IO_L20P_3 |INPUT |LVCMOS25 |3 | | | |IFD | |LOCATED | M16 |kc |IOB |IO_L20N_3 |INPUT |LVCMOS25 |3 | | | |IFD | |LOCATED | N1 | |IOB |IO_L17P_6/VREF_6 |UNUSED | |6 | | | | | | | N2 | |IOB |IO_L17N_6 |UNUSED | |6 | | | | | | | N3 | |IOB |IO_L16P_6 |UNUSED | |6 | | | | | | | N4 | | |VCCINT | | | | | | | |1.2 | | N5 | |IOB |IO |UNUSED | |5 | | | | | | | N6 | |IOB |IO_L28N_5/D6 |UNUSED | |5 | | | | | | | N7 | |IOB |IO_L30N_5 |UNUSED | |5 | | | | | | | N8 | |IOB |IO_L32P_5/GCLK2 |UNUSED | |5 | | | | | | | N9 | |IOB |IO_L31N_4/INIT_B |UNUSED | |4 | | | | | | | N10 | |IOB |IO_L29P_4 |UNUSED | |4 | | | | | | | N11 | |IOB |IO_L27P_4/D1 |UNUSED | |4 | | | | | | | N12 |led<5> |IOB |IO/VREF_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | N13 | | |VCCINT | | | | | | | |1.2 | | N14 |led<3> |IOB |IO_L19P_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | N15 |ssg<2> |IOB |IO_L17P_3/VREF_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | N16 |ssg<6> |IOB |IO_L17N_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | P1 | |IOB |IO_L01P_6/VRN_6 |UNUSED | |6 | | | | | | | P2 | |IOB |IO_L16N_6 |UNUSED | |6 | | | | | | | P3 | | |M0 | | | | | | | | | | P4 | | |M2 | | | | | | | | | | P5 | |IOB |IO_L27P_5 |UNUSED | |5 | | | | | | | P6 | |IOB |IO_L29P_5/VREF_5 |UNUSED | |5 | | | | | | | P7 | |IOB |IO |UNUSED | |5 | | | | | | | P8 | |IOB |IO_L32N_5/GCLK3 |UNUSED | |5 | | | | | | | P9 | |IOB |IO_L31P_4/DOUT/BUSY|UNUSED | |4 | | | | | | | P10 | |IOB |IO_L30N_4/D2 |UNUSED | |4 | | | | | | | P11 |led<7> |IOB |IO_L28N_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | P12 |led<6> |IOB |IO_L25N_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | P13 |led<4> |IOB |IO/VREF_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | P14 |led<1> |IOB |IO_L16P_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | P15 |ssg<3> |IOB |IO_L16N_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | P16 |ssg<7> |IOB |IO_L01N_3/VRP_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | R1 | |IOB |IO_L01N_6/VRP_6 |UNUSED | |6 | | | | | | | R2 | | |GND | | | | | | | | | | R3 | |IOB |IO_L01P_5/CS_B |UNUSED | |5 | | | | | | | R4 | |IOB |IO_L10P_5/VRN_5 |UNUSED | |5 | | | | | | | R5 | |IOB |IO_L27N_5/VREF_5 |UNUSED | |5 | | | | | | | R6 | |IOB |IO_L29N_5 |UNUSED | |5 | | | | | | | R7 | |IOB |IO_L31P_5/D5 |UNUSED | |5 | | | | | | | R8 | | |GND | | | | | | | | | | R9 |hs |IOB |IO_L32N_4/GCLK1 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | R10 | |IOB |IO_L30P_4/D3 |UNUSED | |4 | | | | | | | R11 |blu |IOB |IO_L28P_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | R12 |red |IOB |IO_L25P_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | R13 | |IOB |IO_L01N_4/VRP_4 |UNUSED | |4 | | | | | | | R14 | | |DONE | | | | | | | | | | R15 | | |GND | | | | | | | | | | R16 |ssg<4> |IOB |IO_L01P_3/VRN_3 |OUTPUT |LVCMOS25 |3 |12 |SLOW |NONE** | | |LOCATED | T1 | | |GND | | | | | | | | | | T2 | | |M1 | | | | | | | | | | T3 | |IOB |IO_L01N_5/RDWR_B |UNUSED | |5 | | | | | | | T4 | |IOB |IO_L10N_5/VRP_5 |UNUSED | |5 | | | | | | | T5 | |IOB |IO |UNUSED | |5 | | | | | | | T6 | | |VCCAUX | | | | | | | |2.5 | | T7 | |IOB |IO_L31N_5/D4 |UNUSED | |5 | | | | | | | T8 | |IOB |IO/VREF_5 |UNUSED | |5 | | | | | | | T9 |mclk |IOB |IO_L32P_4/GCLK0 |INPUT |LVCMOS25 |4 | | | |NONE | |LOCATED | T10 |vs |IOB |IO/VREF_4 |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | T11 | | |VCCAUX | | | | | | | |2.5 | | T12 |grn |IOB |IO |OUTPUT |LVCMOS25 |4 |12 |SLOW |NONE** | | |LOCATED | T13 | |IOB |IO_L01P_4/VRN_4 |UNUSED | |4 | | | | | | | T14 | |IOB |IO |UNUSED | |4 | | | | | | | T15 | | |CCLK | | | | | | | | | | T16 | | |GND | | | | | | | | | | ----- |----- |----- |----- |----- |----- |----- |----- |----- |----- |----- |----- |----- | * Default value. ** This default Pullup/Pulldown value can be overridden in Bitgen.
