-- main.vhd library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; library APA; entity function_test is port (clock : in std_logic; clk_out : out std_logic; TS : out std_logic_vector(3 downto 0)); end function_test; architecture behavior of function_test is signal clk : std_logic; signal clk_last : std_logic; signal count : integer range 0 to 40000000; begin process (clock,clk) is variable A : std_logic_vector(3 downto 0); begin if rising_edge(clock) then -- slower clock if count = 40000000 then count <= 0; else count <= count + 1; end if; if count = 0 then clk <= '0'; elsif count = 20000000 then clk <= '1'; end if; -- generate TS / A clk_last <= clk; if clk_last = '0' and clk = '1' then -- rising clk edge A := A + 1; if A = 10 then A := (others => '0'); end if; end if; end if; clk_out <= clk; TS <= A; end process; end behavior;
