@3330.292625ms: Reset found. Entering reset state. @3330.307375ms: SWJ-DP Switch @3330.312438ms: Reset found. Entering reset state. @3330.326938ms: 4 Idle cycles. Quitting reset state. @3330.330000ms: Reset found. Entering reset state. @3330.344688ms: SWJ-DP Switch @3330.349750ms: Reset found. Entering reset state. @3330.364250ms: 4 Idle cycles. Quitting reset state. @3330.366375ms: OK (1)-Debug port -Read at ADR=0 DAT=0bb11477 - IDCODE @3330.398375ms: OK (1)-Debug port -Write at ADR=0 DAT=0000001f - ABORT @3330.427250ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3330.454938ms: OK (1)-Debug port -Write at ADR=1 DAT=50000000 - CTRL/STAT @3330.483750ms: OK (1)-Debug port -Read at ADR=1 DAT=f0000040 - CTRL/STAT @3330.517063ms: OK (1)-Debug port -Write at ADR=1 DAT=54000000 - CTRL/STAT @3330.546188ms: OK (1)-Debug port -Write at ADR=1 DAT=50000f00 - CTRL/STAT @3330.575563ms: OK (1)-Debug port -Read at ADR=1 DAT=f0000040 - CTRL/STAT @3330.610813ms: OK (1)-Access port-Write at ADR=0 DAT=23000052 - CSW - Control/Status @3330.640000ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3330.676188ms: OK (1)-Access port-Write at ADR=1 DAT=e000edf0 - TAR - Transfer Address @3330.706375ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3330.733938ms: OK (1)-Access port-Write at ADR=0 DAT=a05f0003 - BD0 - Banked Data 0 @3330.763438ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3330.802187ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3330.829750ms: OK (1)-Access port-Write at ADR=1 DAT=e000ed00 - TAR - Transfer Address @3330.860125ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3330.887875ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3330.922813ms: OK (1)-Debug port -Read at ADR=3 DAT=410cc200 - READBUFFER @3330.963375ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3330.991000ms: OK (1)-Access port-Write at ADR=1 DAT=e000edf0 - TAR - Transfer Address @3331.021125ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3331.048938ms: OK (1)-Access port-Write at ADR=3 DAT=00000001 - BD3 - Banked Data 3 @3331.078437ms: OK (1)-Debug port -Read at ADR=3 DAT=04770021 - READBUFFER @3331.117188ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3331.152125ms: OK (1)-Debug port -Read at ADR=3 DAT=03030003 - READBUFFER @3331.193938ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3331.228875ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3331.270125ms: OK (1)-Access port-Write at ADR=3 DAT=01000000 - BD3 - Banked Data 3 @3331.299625ms: OK (1)-Debug port -Read at ADR=3 DAT=04770021 - READBUFFER @3331.338125ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3331.365750ms: OK (1)-Access port-Write at ADR=1 DAT=e0002000 - TAR - Transfer Address @3331.396063ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3331.423813ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3331.458750ms: OK (1)-Debug port -Read at ADR=3 DAT=00000041 - READBUFFER @3331.498813ms: OK (1)-Access port-Write at ADR=0 DAT=00000003 - BD0 - Banked Data 0 @3331.528313ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3331.566438ms: OK (1)-Access port-Write at ADR=2 DAT=00000000 - BD2 - Banked Data 2 @3331.595938ms: OK (1)-Debug port -Read at ADR=3 DAT=e00ff003 - READBUFFER @3331.634125ms: OK (1)-Access port-Write at ADR=3 DAT=00000000 - BD3 - Banked Data 3 @3331.663625ms: OK (1)-Debug port -Read at ADR=3 DAT=04770021 - READBUFFER @3331.702125ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3331.729750ms: OK (1)-Access port-Write at ADR=1 DAT=e0002010 - TAR - Transfer Address @3331.759875ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3331.787438ms: OK (1)-Access port-Write at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3331.817000ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3331.854938ms: OK (1)-Access port-Write at ADR=1 DAT=00000000 - BD1 - Banked Data 1 @3331.884437ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3331.923625ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3331.951187ms: OK (1)-Access port-Write at ADR=1 DAT=e0001000 - TAR - Transfer Address @3331.981563ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3332.009312ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3332.044250ms: OK (1)-Debug port -Read at ADR=3 DAT=20000000 - READBUFFER @3332.084750ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3332.112375ms: OK (1)-Access port-Write at ADR=1 DAT=e0001020 - TAR - Transfer Address @3332.142500ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3332.170125ms: OK (1)-Access port-Write at ADR=1 DAT=0000001f - BD1 - Banked Data 1 @3332.199625ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3332.237875ms: OK (1)-Access port-Read at ADR=1 DAT=00000000 - BD1 - Banked Data 1 @3332.272812ms: OK (1)-Debug port -Read at ADR=3 DAT=0000001f - READBUFFER @3332.313250ms: OK (1)-Access port-Write at ADR=2 DAT=00000000 - BD2 - Banked Data 2 @3332.342750ms: OK (1)-Debug port -Read at ADR=3 DAT=e00ff003 - READBUFFER @3332.381250ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3332.408875ms: OK (1)-Access port-Write at ADR=1 DAT=e0001030 - TAR - Transfer Address @3332.439000ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3332.466563ms: OK (1)-Access port-Write at ADR=2 DAT=00000000 - BD2 - Banked Data 2 @3332.496062ms: OK (1)-Debug port -Read at ADR=3 DAT=e00ff003 - READBUFFER @3332.535500ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3332.563062ms: OK (1)-Access port-Write at ADR=1 DAT=e000edf0 - TAR - Transfer Address @3332.593438ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3332.621187ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3332.656063ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3332.697938ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3332.732875ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3332.774000ms: OK (1)-Access port-Write at ADR=3 DAT=00000001 - BD3 - Banked Data 3 @3332.803500ms: OK (1)-Debug port -Read at ADR=3 DAT=04770021 - READBUFFER @3332.841812ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3332.876688ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3332.917438ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3332.945062ms: OK (1)-Access port-Write at ADR=1 DAT=50000210 - TAR - Transfer Address @3332.975438ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3333.003125ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3333.038063ms: OK (1)-Debug port -Read at ADR=3 DAT=0000003f - READBUFFER @3333.078250ms: OK (1)-Access port-Write at ADR=0 DAT=0000003f - BD0 - Banked Data 0 @3333.107750ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3333.146313ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3333.173875ms: OK (1)-Access port-Write at ADR=1 DAT=e000ed00 - TAR - Transfer Address @3333.204000ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3333.231813ms: OK (1)-Access port-Write at ADR=3 DAT=05fa0004 - BD3 - Banked Data 3 @3333.261313ms: OK (1)-Debug port -Read at ADR=3 DAT=04770021 - READBUFFER @3333.300000ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3333.327563ms: OK (1)-Access port-Write at ADR=1 DAT=e000edf0 - TAR - Transfer Address @3333.357937ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3333.385688ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3333.420563ms: OK (1)-Debug port -Read at ADR=3 DAT=03030003 - READBUFFER @3333.463500ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3333.498437ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3333.538875ms: OK (1)-Access port-Write at ADR=3 DAT=01000000 - BD3 - Banked Data 3 @3333.568375ms: OK (1)-Debug port -Read at ADR=3 DAT=04770021 - READBUFFER @3333.606313ms: OK (1)-Access port-Write at ADR=1 DAT=00000010 - BD1 - Banked Data 1 @3333.637250ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3333.675313ms: OK (1)-Access port-Read at ADR=0 DAT=00030003 - BD0 - Banked Data 0 @3333.716688ms: OK (1)-Access port-Read at ADR=2 DAT=00030003 - BD2 - Banked Data 2 @3333.751500ms: OK (1)-Debug port -Read at ADR=3 DAT=c1000000 - READBUFFER @3333.792500ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3333.827438ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3333.869313ms: OK (1)-Access port-Read at ADR=0 DAT=00000000 - BD0 - Banked Data 0 @3333.904188ms: OK (1)-Debug port -Read at ADR=3 DAT=00030003 - READBUFFER @3333.951187ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3333.978813ms: OK (1)-Access port-Write at ADR=1 DAT=50000100 - TAR - Transfer Address @3334.008938ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3334.036562ms: OK (1)-Access port-Write at ADR=0 DAT=00000059 - BD0 - Banked Data 0 @3334.066063ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3334.104000ms: OK (1)-Access port-Write at ADR=0 DAT=00000016 - BD0 - Banked Data 0 @3334.133500ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3334.171375ms: OK (1)-Access port-Write at ADR=0 DAT=00000088 - BD0 - Banked Data 0 @3334.200938ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3334.239562ms: OK (1)-Debug port -Write at ADR=2 DAT=00000000 - SELECT @3334.267188ms: OK (1)-Access port-Write at ADR=1 DAT=50000000 - TAR - Transfer Address @3334.297500ms: OK (1)-Debug port -Write at ADR=2 DAT=00000010 - SELECT @3334.325438ms: OK (1)-Access port-Read at ADR=1 DAT=00000000 - BD1 - Banked Data 1 @3334.360375ms: OK (1)-Debug port -Read at ADR=3 DAT=00000061 - READBUFFER @3334.400438ms: OK (1)-Access port-Write at ADR=1 DAT=00000061 - BD1 - Banked Data 1 @3334.429938ms: OK (1)-Debug port -Read at ADR=3 DAT=00000000 - READBUFFER @3334.471562ms: OK (1)-Access port-Write at ADR=2 DAT=00000001 - BD2 - Banked Data 2 @3334.501063ms: ERROR(7)-Debug port -Read at ADR=3 DAT=------------ READBUFFER @3334.516437ms: Reset found. Entering reset state. @3334.531125ms: SWJ-DP Switch @3334.536187ms: Reset found. Entering reset state. @3334.550750ms: 4 Idle cycles. Quitting reset state. @3334.552875ms: ERROR(7)-Debug port -Read at ADR=3 DAT=------------ READBUFFER @3334.568250ms: Reset found. Entering reset state. @3334.582937ms: SWJ-DP Switch @3334.588000ms: Reset found. Entering reset state. @3334.602500ms: 4 Idle cycles. Quitting reset state. @3334.604625ms: ERROR(7)-Debug port -Read at ADR=3 DAT=------------ READBUFFER
