Chip erase? Make sure flash is not busy and halt CPU Block 1 @3310.184188ms: SWD Reset occured. @3310.459875ms:Read Buf(0x5000c01c)=0x00000000 <- read undocumented ISP register @3310.553875ms:Write BD (0xe000edf0)=0xa05f0003 <- Debug Halting Control Reg STOP @3310.583375ms:Read Buf(0xe000edf0)=0x00000000 Do something with debug access port 0xe0002000 Debug access port / Breakpoint unit Block2 @3312.198438ms:Write BD (0xe0002008)=0x00000000 @3312.227937ms:Read Buf(0xe0002008)=0xe00ff003 @3312.266625ms:Write BD (0xe000200c)=0x00000000 @3312.296125ms:Read Buf(0xe000200c)=0x04770021 @3312.420437ms:Write BD (0xe0002010)=0x00000000 @3312.449938ms:Read Buf(0xe0002010)=0x00000000 @3312.488438ms:Write BD (0xe0002014)=0x00000000 @3312.517938ms:Read Buf(0xe0002014)=0x00000000 @3312.677750ms:Read Buf(0xe0002008)=0x00000000 @3312.754000ms:Read Buf(0xe000200c)=0x00000000 @3312.915937ms:Read Buf(0xe0002010)=0x00000000 @3312.992125ms:Read Buf(0xe0002014)=0x00000000 Block3 Write Powercon. Oscillators enabled? @3315.189313ms:Write BD (0x50000100)=0x00000059 ; Unlock registers with magic sequence @3315.218813ms:Read Buf(0x50000100)=0x00000000 @3315.256750ms:Write BD (0x50000100)=0x00000016 @3315.286250ms:Read Buf(0x50000100)=0x00000000 @3315.324187ms:Write BD (0x50000100)=0x00000088 @3315.353688ms:Read Buf(0x50000100)=0x00000000 @3315.512938ms:Read Buf(0x50000200)=0x0000001c @3315.698313ms:Read Buf(0x5000c000)=0x00000032 ; ISP control @3315.738438ms:Write BD (0x5000c000)=0x00000033 ; ISP Control=0x33 Set bit 1= Enable ISP function... really? @3315.767938ms:Read Buf(0x5000c000)=0x00000000 @3315.927375ms:Read Buf(0x5000c01c)=0x00000000 @3315.967688ms:Write BD (0x5000c01c)=0x00000001 ; 0x5000C01C=1 Interesting. Undocumented register in Flash controller @3315.997188ms:Read Buf(0x5000c01c)=0x04770021 ; Buffer after write - "unpredictable" @3316.156188ms:Read Buf(0x5000c000)=0x00000033 @3316.232000ms:Read Buf(0x5000c000)=0x00000033 ; check ISPFF=0 @3316.400563ms:Read Buf(0x5000c010)=0x00000000 ; ISP not busy? @3316.527437ms:Write BD (0x5000c00c)=0x00000026 ; ISP Command=0x26. Undocumented combination. Enable page erase and program @3316.556938ms:Read Buf(0x5000c00c)=0x04770021 ; Buffer after write - "unpredictable" @3316.595000ms:Write BD (0x5000c004)=0x00000000 ; ISP Address=0x00000000 Start of APROM @3316.624500ms:Read Buf(0x5000c004)=0x00000000 @3316.748562ms:Write BD (0x5000c010)=0x00000001 ; ISP Trigger=1 -> Start ISP Operation @3316.778125ms:Read Buf(0x5000c010)=0x00000000 ; First read is invalid? better replicate or trouble looms @3316.852250ms:Read Buf(0x5000c010)=0x00000001 ; Operation is ongoing while ISP Trigger reads ... poll poll poll ... @3326.586938ms:Read Buf(0x5000c010)=0x00000001 @3326.664813ms:Read Buf(0x5000c010)=0x00000001 @3326.742625ms:Read Buf(0x5000c010)=0x00000001 @3326.820500ms:Read Buf(0x5000c010)=0x00000001 @3326.898375ms:Read Buf(0x5000c010)=0x00000000 ; and done. After ~10ms @3327.060438ms:Read Buf(0x5000c000)=0x00000033 ; check ISPFF=0 @3327.224875ms:Read Buf(0x5000c010)=0x00000000 Is LDROM empty? @3327.351688ms:Write BD (0x5000c00c)=0x00000000 ; ISP Command = Read @3327.381188ms:Read Buf(0x5000c00c)=0x04770021 ; Buffer after write - "unpredictable" @3327.419250ms:Write BD (0x5000c004)=0x00100000 ; ISP Address=0x00100000 LDROM @3327.448750ms:Read Buf(0x5000c004)=0x00000000 @3327.572875ms:Write BD (0x5000c010)=0x00000001 ; ISP Trigger=1 -> Start ISP Operation @3327.602375ms:Read Buf(0x5000c010)=0x00000000 @3327.676500ms:Read Buf(0x5000c010)=0x00000000 ; already done @3327.838563ms:Read Buf(0x5000c000)=0x00000033 ; check ISPFF=0 @3327.914625ms:Read Buf(0x5000c008)=0xffffffff ; ISP Data register ... looks empty @3328.078625ms:Read Buf(0x5000c010)=0x00000000 Is APROM empty? @3328.205438ms:Write BD (0x5000c00c)=0x00000000 ; ISP Command = Read @3328.234937ms:Read Buf(0x5000c00c)=0x04770021 ; Buffer after write - "unpredictable" @3328.273000ms:Write BD (0x5000c004)=0x00000000 ; ISP Address=0x00100000 APROM @3328.302500ms:Read Buf(0x5000c004)=0x00000000 @3328.426625ms:Write BD (0x5000c010)=0x00000001 ; ISP Trigger=1 -> Start ISP Operation @3328.456125ms:Read Buf(0x5000c010)=0x00000000 @3328.530250ms:Read Buf(0x5000c010)=0x00000000 ; done @3328.692375ms:Read Buf(0x5000c000)=0x00000033 @3328.768437ms:Read Buf(0x5000c008)=0xffffffff ; ISP Data register ... looks empty @3328.932375ms:Read Buf(0x5000c010)=0x00000000 Is config empty? @3329.059250ms:Write BD (0x5000c00c)=0x00000000 ; ISP Command = Read @3329.088750ms:Read Buf(0x5000c00c)=0x04770021 @3329.126813ms:Write BD (0x5000c004)=0x00300000 ; ISP Address=0x00100000 Config0 @3329.156313ms:Read Buf(0x5000c004)=0x00000000 @3329.280438ms:Write BD (0x5000c010)=0x00000001 @3329.309938ms:Read Buf(0x5000c010)=0x00000000 @3329.384063ms:Read Buf(0x5000c010)=0x00000000 @3329.546125ms:Read Buf(0x5000c000)=0x00000033 @3329.622188ms:Read Buf(0x5000c008)=0xffffffff ; Is empty,too @3329.787875ms:Read Buf(0x5000c010)=0x00000000 @3329.949625ms:Read Buf(0x5000c000)=0x00000033 @3329.989687ms:Write BD (0x5000c000)=0x00000032 ; Disable ISP @3330.019188ms:Read Buf(0x5000c000)=0x00000000 @3330.178625ms:Read Buf(0x5000c01c)=0x00000001 @3330.218938ms:Write BD (0x5000c01c)=0x00000000 ; Write 0 to undocumented register @3330.248437ms:Read Buf(0x5000c01c)=0x04770021 ... and done @3330.326938ms: SWD Reset occured. @3330.364250ms: SWD Reset occured. Reset CPU @3330.640000ms:Read Buf(0x5000c01c)=0x00000000 @3330.733938ms:Write BD (0xe000edf0)=0xa05f0003 ; Halt CPU @3330.763438ms:Read Buf(0xe000edf0)=0x00000000 @3330.922813ms:Read Buf(0xe000ed00)=0x410cc200 ; Read CPUID @3331.048938ms:Write BD (0xe000edfc)=0x00000001 @3331.078437ms:Read Buf(0xe000edfc)=0x04770021 @3331.152125ms:Read Buf(0xe000edf0)=0x03030003 @3331.228875ms:Read Buf(0xe000edf0)=0x00030003 @3331.270125ms:Write BD (0xe000edfc)=0x01000000 @3331.299625ms:Read Buf(0xe000edfc)=0x04770021 @3331.458750ms:Read Buf(0xe0002000)=0x00000041 ; Doing something with the debug port @3331.498813ms:Write BD (0xe0002000)=0x00000003 @3331.528313ms:Read Buf(0xe0002000)=0x00000000 @3331.566438ms:Write BD (0xe0002008)=0x00000000 @3331.595938ms:Read Buf(0xe0002008)=0xe00ff003 @3331.634125ms:Write BD (0xe000200c)=0x00000000 @3331.663625ms:Read Buf(0xe000200c)=0x04770021 @3331.787438ms:Write BD (0xe0002010)=0x00000000 @3331.817000ms:Read Buf(0xe0002010)=0x00000000 @3331.854938ms:Write BD (0xe0002014)=0x00000000 @3331.884437ms:Read Buf(0xe0002014)=0x00000000 @3332.044250ms:Read Buf(0xe0001000)=0x20000000 @3332.170125ms:Write BD (0xe0001024)=0x0000001f @3332.199625ms:Read Buf(0xe0001024)=0x00000000 @3332.272812ms:Read Buf(0xe0001024)=0x0000001f @3332.313250ms:Write BD (0xe0001028)=0x00000000 @3332.342750ms:Read Buf(0xe0001028)=0xe00ff003 @3332.466563ms:Write BD (0xe0001038)=0x00000000 @3332.496062ms:Read Buf(0xe0001038)=0xe00ff003 @3332.656063ms:Read Buf(0xe000edf0)=0x00030003 @3332.732875ms:Read Buf(0xe000edf0)=0x00030003 @3332.774000ms:Write BD (0xe000edfc)=0x00000001 @3332.803500ms:Read Buf(0xe000edfc)=0x04770021 @3332.876688ms:Read Buf(0xe000edf0)=0x00030003 @3333.038063ms:Read Buf(0x50000210)=0x0000003f @3333.078250ms:Write BD (0x50000210)=0x0000003f @3333.107750ms:Read Buf(0x50000210)=0x00000000 @3333.231813ms:Write BD (0xe000ed0c)=0x05fa0004 ; Request system level reset @3333.261313ms:Read Buf(0xe000ed0c)=0x04770021 @3333.420563ms:Read Buf(0xe000edf0)=0x03030003 ; cpu is halted @3333.498437ms:Read Buf(0xe000edf0)=0x00030003 @3333.538875ms:Write BD (0xe000edfc)=0x01000000 @3333.568375ms:Read Buf(0xe000edfc)=0x04770021 @3333.606313ms:Write BD (0xe000edf4)=0x00000010 @3333.751500ms:Read Buf(0xe000edf8)=0xc1000000 @3333.827438ms:Read Buf(0xe000edf0)=0x00030003 @3333.904188ms:Read Buf(0xe000edf0)=0x00030003 @3334.036562ms:Write BD (0x50000100)=0x00000059 ; unlock system registers @3334.066063ms:Read Buf(0x50000100)=0x00000000 @3334.104000ms:Write BD (0x50000100)=0x00000016 @3334.133500ms:Read Buf(0x50000100)=0x00000000 @3334.171375ms:Write BD (0x50000100)=0x00000088 @3334.200938ms:Read Buf(0x50000100)=0x00000000 @3334.360375ms:Read Buf(0x50000004)=0x00000061 @3334.400438ms:Write BD (0x50000004)=0x00000061 @3334.429938ms:Read Buf(0x50000004)=0x00000000 @3334.471562ms:Write BD (0x50000008)=0x00000001 ; Reset CPU Lots of SWD read errors here since SWD controller resets as well (140ms) @3334.550750ms: SWD Reset occured. @3334.602500ms: SWD Reset occured.
