/* * File: datei_code.c * * Real-Time Workshop code generated for Simulink model 'datei_code'. * * Model version : 1.34 * Real-Time Workshop file version : 6.4 (R2006a) 03-Feb-2006 * Real-Time Workshop file generated on : Thu Jan 11 10:33:34 2007 * TLC version : 6.4 (Jan 31 2006) * C source code generated on : Thu Jan 11 10:33:37 2007 */ #include "datei_code.h" #include "datei_code_private.h" /* Block states (auto storage) */ D_Work_datei_code datei_code_DWork; /* External inputs (root inport signals with auto storage) */ ExternalInputs_datei_code datei_code_U; /* External outputs (root outports fed by signals with auto storage) */ ExternalOutputs_datei_code datei_code_Y; /* Real-time model */ RT_MODEL_datei_code datei_code_M_; RT_MODEL_datei_code *datei_code_M = &datei_code_M_; static void rate_scheduler(void); /* This function implements a singletasking scheduler for a system with 2 * rates. This function is called by the generated step function, hence the * generated code self-manages all its subrates. */ static void rate_scheduler(void) { /* Compute which subrates run during the next base time step. Subrates * are an integer multiple of the base rate counter. Therefore, the subtask * counter is reset when it reaches its limit (zero means run). */ if (++datei_code_M->Timing.TaskCounters.TID[1] == 10) { /* Sample time: [1.0s, 0.0s] */ datei_code_M->Timing.TaskCounters.TID[1] = 0; } } /* Model step function */ void datei_code_step(int_T tid) { /* local block i/o variables*/ real_T rtb_Elastizittsmodul; if(datei_code_M->Timing.TaskCounters.TID[1] == 0) { /* Gain: '/Elastizitäts- modul' incorporates: * Gain: '/Eingangs- spannung' * Gain: '/Fläche' * Gain: '/Konstant' * Inport: '/Ud' */ rtb_Elastizittsmodul = datei_code_U.Ud * 0.5 * 8.3333333333333329E-002 * 0.005 * 2.1E+011; /* Outport: '/Uin' incorporates: * DiscreteIntegrator: '/Discrete-Time Integrator' * Sum: '/Sum' */ datei_code_Y.Uin = rtb_Elastizittsmodul + datei_code_DWork.DiscreteTimeIntegrator_DSTATE; /* Update for DiscreteIntegrator: '/Discrete-Time Integrator' */ datei_code_DWork.DiscreteTimeIntegrator_DSTATE = datei_code_DWork.DiscreteTimeIntegrator_DSTATE + rtb_Elastizittsmodul; } rate_scheduler(); UNUSED_PARAMETER(tid); } /* Model initialize function */ void datei_code_initialize(boolean_T firstTime) { (void)firstTime; /* (no initialization code required) */ } /* File trailer for Real-Time Workshop generated code. * * [EOF] */
