/* save in a bit stream */
uint8_t save(uint32_t value, int8_t length_in_bit, struct fat16_file_struct* fd){
static uint8_t data_block;
static uint8_t current_bit = 7;
// while still bytes to copy
    while ( length_in_bit > 0 )
        // if next input bit is set, set destination bit 7
        if ( value & (uint32_t)0x01 << (length_in_bit-1))
            data_block |= 0x01 << current_bit;
length_in_bit--;
// byte boundary hit?
        if ( current_bit == 0 ){
            // goto next byte
            current_bit = 7;
if(fat16_write_file(fd, &data_block, 1) != 1){ //retry writing in case of error
               SPI_Disable();
lcd_print("error writing file!",6,115,0,Rot,Blau);
SPI_Enable();
while(1){
fd = reopen_sdcard();
if(fat16_write_file(fd, &data_block, 1) == 1) //check number of bytes written
break;
SPI_Disable();
lcd_print("                    ",6,115,0,Rot,Blau);
SPI_Enable();
data_block = 0x00;
else
current_bit--;
return 1;
// Exemplarischer Aufruf:
save(descriptor,2,fd);
save(gps_converted.utc_in_sec,bit_time_comp,fd);
save(gps_converted.date,bit_date_comp,fd);
save(gps_converted.lat,bit_lat_comp,fd);
save(gps_converted.lon,bit_lon_comp,fd);
save(gps_converted.altitude,bit_alt_comp,fd);
save(gps_converted.satellites,bit_sat_comp,fd);
