set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=sendmail.lst -std=gnu99 sendmail.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > sendmail.d; \ [ -s sendmail.d ] || rm -f sendmail.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=auth.lst -std=gnu99 auth.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > auth.d; \ [ -s auth.d ] || rm -f auth.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=config.lst -std=gnu99 config.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > config.d; \ [ -s config.d ] || rm -f config.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=time.lst -std=gnu99 time.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > time.d; \ [ -s time.d ] || rm -f time.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ntp.lst -std=gnu99 ntp.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > ntp.d; \ [ -s ntp.d ] || rm -f ntp.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ftpclient.lst -std=gnu99 ftpclient.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > ftpclient.d; \ [ -s ftpclient.d ] || rm -f ftpclient.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=webcam/mca25.lst -std=gnu99 webcam/mca25.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > webcam/mca25.d; \ [ -s webcam/mca25.d ] || rm -f webcam/mca25.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=fat16.lst -std=gnu99 fat16.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > fat16.d; \ [ -s fat16.d ] || rm -f fat16.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=mmc.lst -std=gnu99 mmc.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > mmc.d; \ [ -s mmc.d ] || rm -f mmc.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=webpage.lst -std=gnu99 webpage.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > webpage.d; \ [ -s webpage.d ] || rm -f webpage.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=telnet.lst -std=gnu99 telnet.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > telnet.d; \ [ -s telnet.d ] || rm -f telnet.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=tcp.lst -std=gnu99 tcp.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > tcp.d; \ [ -s tcp.d ] || rm -f tcp.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=uart.lst -std=gnu99 uart.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > uart.d; \ [ -s uart.d ] || rm -f uart.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=clock.lst -std=gnu99 clock.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > clock.d; \ [ -s clock.d ] || rm -f clock.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=interrupt4.lst -std=gnu99 interrupt4.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > interrupt4.d; \ [ -s interrupt4.d ] || rm -f interrupt4.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=icmp.lst -std=gnu99 icmp.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > icmp.d; \ [ -s icmp.d ] || rm -f icmp.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ip.lst -std=gnu99 ip.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > ip.d; \ [ -s ip.d ] || rm -f ip.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=httpd.lst -std=gnu99 httpd.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > httpd.d; \ [ -s httpd.d ] || rm -f httpd.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ftpd.lst -std=gnu99 ftpd.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > ftpd.d; \ [ -s ftpd.d ] || rm -f ftpd.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=checksum.lst -std=gnu99 checksum.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > checksum.d; \ [ -s checksum.d ] || rm -f checksum.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=arp.lst -std=gnu99 arp.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > arp.d; \ [ -s arp.d ] || rm -f arp.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=analog.lst -std=gnu99 analog.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > analog.d; \ [ -s analog.d ] || rm -f analog.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=rtl8019.lst -std=gnu99 rtl8019.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > rtl8019.d; \ [ -s rtl8019.d ] || rm -f rtl8019.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=3c5x9.lst -std=gnu99 3c5x9.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > 3c5x9.d; \ [ -s 3c5x9.d ] || rm -f 3c5x9.d set -e; avr-gcc -MM -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst -std=gnu99 main.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > main.d; \ [ -s main.d ] || rm -f main.d make: Warning: File `httpd.d' has modification time 0.3 s in the future -------- begin -------- avr-gcc.exe (GCC) 4.1.1 (WinAVR 20070122) Copyright (C) 2006 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Compiling: main.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst -std=gnu99 main.c -o main.o main.c: In function 'InitFat': main.c:140: warning: pointer targets in assignment differ in signedness main.c: In function 'SaveCamToSD': main.c:156: warning: pointer targets in assignment differ in signedness main.c:165: warning: pointer targets in passing argument 1 of 'FileOpen' differ in signedness main.c: In function 'ShowConfig': main.c:212: warning: suggest parentheses around comparison in operand of & main.c: In function 'test': main.c:260: warning: pointer targets in assignment differ in signedness main.c:263: warning: pointer targets in passing argument 1 of 'FileOpen' differ in signedness main.c:259: warning: unused variable 't' main.c: In function 'main': main.c:307: warning: pointer targets in assignment differ in signedness main.c:277: warning: unused variable 'Minuten_Timer' Compiling: 3c5x9.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=3c5x9.lst -std=gnu99 3c5x9.c -o 3c5x9.o Compiling: rtl8019.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=rtl8019.lst -std=gnu99 rtl8019.c -o rtl8019.o Compiling: analog.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=analog.lst -std=gnu99 analog.c -o analog.o Compiling: arp.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=arp.lst -std=gnu99 arp.c -o arp.o Compiling: checksum.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=checksum.lst -std=gnu99 checksum.c -o checksum.o Compiling: ftpd.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ftpd.lst -std=gnu99 ftpd.c -o ftpd.o Compiling: httpd.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=httpd.lst -std=gnu99 httpd.c -o httpd.o httpd.c: In function 'httpd': httpd.c:82: warning: pointer targets in assignment differ in signedness httpd.c:86: warning: pointer targets in assignment differ in signedness httpd.c:100: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:103: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:106: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:109: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:109: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:113: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:115: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:115: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c:133: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness httpd.c:135: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness httpd.c:132: warning: suggest explicit braces to avoid ambiguous 'else' httpd.c:139: warning: pointer targets in passing argument 1 of 'printf' differ in signedness httpd.c:221: warning: pointer targets in passing argument 1 of 'strcasecmp' differ in signedness httpd.c:224: warning: pointer targets in passing argument 1 of 'strcasecmp' differ in signedness httpd.c:227: warning: pointer targets in passing argument 1 of 'strcasecmp' differ in signedness httpd.c:255:1: warning: "BLOCK_SIZE" redefined httpd.c:16:1: warning: this is the location of the previous definition httpd.c:262: warning: pointer targets in initialization differ in signedness httpd.c:326: warning: pointer targets in passing argument 1 of 'atoi' differ in signedness httpd.c: In function 'substitute': httpd.c:440: warning: pointer targets in passing argument 1 of 'snprintf' differ in signedness httpd.c:440: warning: pointer targets in passing argument 3 of 'snprintf' differ in signedness httpd.c:443: warning: pointer targets in passing argument 1 of 'snprintf' differ in signedness httpd.c:443: warning: pointer targets in passing argument 3 of 'snprintf' differ in signedness httpd.c:448: warning: pointer targets in passing argument 1 of 'snprintf' differ in signedness httpd.c:449: warning: pointer targets in passing argument 1 of 'snprintf' differ in signedness httpd.c:435: warning: 'length' may be used uninitialized in this function Compiling: ip.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ip.lst -std=gnu99 ip.c -o ip.o Compiling: icmp.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=icmp.lst -std=gnu99 icmp.c -o icmp.o Compiling: interrupt4.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=interrupt4.lst -std=gnu99 interrupt4.c -o interrupt4.o interrupt4.c: In function 'get': interrupt4.c:87: warning: pointer targets in passing argument 2 of 'ARP_Reply' differ in signedness interrupt4.c:109: warning: pointer targets in passing argument 2 of 'ntpc' differ in signedness interrupt4.c:119: warning: pointer targets in passing argument 2 of 'httpd' differ in signedness interrupt4.c:123: warning: pointer targets in passing argument 2 of 'smtp' differ in signedness interrupt4.c:126: warning: pointer targets in passing argument 2 of 'auth' differ in signedness interrupt4.c:139: warning: pointer targets in passing argument 2 of 'ftpc' differ in signedness interrupt4.c:144: warning: pointer targets in passing argument 2 of 'ftp_store' differ in signedness Compiling: clock.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=clock.lst -std=gnu99 clock.c -o clock.o clock.c: In function '__vector_15': clock.c:22: warning: unused variable 't2' Compiling: uart.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=uart.lst -std=gnu99 uart.c -o uart.o Compiling: tcp.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=tcp.lst -std=gnu99 tcp.c -o tcp.o tcp.c: In function 'tcp_make': tcp.c:230: warning: pointer targets in passing argument 1 of 'checksum' differ in signedness Compiling: telnet.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=telnet.lst -std=gnu99 telnet.c -o telnet.o Compiling: webpage.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=webpage.lst -std=gnu99 webpage.c -o webpage.o Compiling: mmc.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=mmc.lst -std=gnu99 mmc.c -o mmc.o Compiling: fat16.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=fat16.lst -std=gnu99 fat16.c -o fat16.o fat16.c: In function 'FileWriteSector': fat16.c:542: warning: pointer targets in passing argument 2 of 'mmc_write_sector' differ in signedness Compiling: ftpclient.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ftpclient.lst -std=gnu99 ftpclient.c -o ftpclient.o ftpclient.c: In function 'ftpc': ftpclient.c:58: warning: pointer targets in passing argument 2 of 'sprintf' differ in signedness ftpclient.c:69: warning: pointer targets in passing argument 2 of 'sprintf' differ in signedness Compiling: ntp.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=ntp.lst -std=gnu99 ntp.c -o ntp.o ntp.c: In function 'ntpc': ntp.c:43: warning: pointer targets in assignment differ in signedness ntp.c:44: warning: pointer targets in assignment differ in signedness ntp.c:154:7: warning: no newline at end of file Compiling: time.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=time.lst -std=gnu99 time.c -o time.o Compiling: config.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=config.lst -std=gnu99 config.c -o config.o config.c: In function 'ReadConfigFile': config.c:31: warning: pointer targets in passing argument 1 of 'FileOpen' differ in signedness config.c:89: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness config.c:89: warning: embedded '\0' in format config.c:90: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness config.c:90: warning: embedded '\0' in format config.c:91: warning: embedded '\0' in format config.c:92: warning: embedded '\0' in format config.c:28: warning: unused variable 'c' Compiling: auth.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=auth.lst -std=gnu99 auth.c -o auth.o Compiling: sendmail.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=sendmail.lst -std=gnu99 sendmail.c -o sendmail.o sendmail.c: In function 'Encode_Base64': sendmail.c:57: warning: pointer targets in passing argument 1 of 'Encodeblock' differ in signedness sendmail.c:57: warning: pointer targets in passing argument 2 of 'Encodeblock' differ in signedness sendmail.c: In function 'smtp': sendmail.c:144: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness sendmail.c:145: warning: pointer targets in passing argument 1 of 'printf' differ in signedness sendmail.c:148: warning: pointer targets in assignment differ in signedness Compiling: webcam/mca25.c avr-gcc -c -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=webcam/mca25.lst -std=gnu99 webcam/mca25.c -o webcam/mca25.o webcam/mca25.c: In function 'mca25_copy_image_data_to_buffer': webcam/mca25.c:78: warning: pointer targets in passing argument 3 of 'mca25_grab_data' differ in signedness webcam/mca25.c:122: warning: pointer targets in passing argument 3 of 'mca25_grab_data' differ in signedness webcam/mca25.c: In function 'mca25_pgm_send': webcam/mca25.c:988: warning: 'old[2]' may be used uninitialized in this function webcam/mca25.c:988: warning: 'old[1]' may be used uninitialized in this function webcam/mca25.c:988: warning: 'old[0]' may be used uninitialized in this function Linking: main.elf avr-gcc -mmcu=atmega644 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o -std=gnu99 main.o 3c5x9.o rtl8019.o analog.o arp.o checksum.o ftpd.o httpd.o ip.o icmp.o interrupt4.o clock.o uart.o tcp.o telnet.o webpage.o mmc.o fat16.o webcam/mca25.o ftpclient.o ntp.o time.o config.o auth.o sendmail.o --output main.elf -Wl,-Map=main.map,--cref -lm Creating load file for Flash: main.hex avr-objcopy -O ihex -R .eeprom main.elf main.hex Creating load file for EEPROM: main.eep avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 -O ihex main.elf main.eep d:\WINAVR\BIN\avr-objcopy.exe: there are no sections to be copied! d:\WINAVR\BIN\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used make: [main.eep] Error 1 (ignored) Creating Extended Listing: main.lss avr-objdump -h -S main.elf > main.lss Creating Symbol Table: main.sym avr-nm -n main.elf > main.sym Size after: main.elf : section size addr .data 1582 8388864 .text 41666 0 .bss 1478 8390446 .stab 876 0 .stabstr 132 0 .debug_aranges 672 0 .debug_pubnames 3872 0 .debug_info 30614 0 .debug_abbrev 7805 0 .debug_line 22230 0 .debug_frame 1984 0 .debug_str 4693 0 .debug_loc 9946 0 .debug_ranges 112 0 Total 127662 Errors: none -------- end -------- make: warning: Clock skew detected. Your build may be incomplete.
