# | Time | Function | Direction | Status | Data | Data (chars) | Data length |
9618 | 06/06/2014 16:27:19 | IRP_MJ_CREATE | DOWN | STATUS_SUCCESS | | C:\WINDOWS\system32\ntvdm.exe | |
9619 | 06/06/2014 16:27:19 | IRP_MJ_CREATE | UP | STATUS_SUCCESS | | C:\WINDOWS\system32\ntvdm.exe | |
9620 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | |
9621 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9622 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9623 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9624 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | |
9625 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 |
9626 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | |
9627 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 01 00 00 00 40 00 00 00 00 08 00 00 00 02 00 00 | ....@........... | 16 |
9628 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | |
9629 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9630 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9631 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9632 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | |
9633 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 |
9634 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | |
9635 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 01 00 00 00 40 00 00 00 00 08 00 00 00 02 00 00 | ....@........... | 16 |
9636 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9637 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | |
9638 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | |
9639 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | |
9640 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | |
9641 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | |
9642 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9643 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9644 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 11 13 | ...... | 6 |
9645 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | |
9646 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 08 00 00 00 02 00 00 | ................ | 16 |
9647 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | |
9648 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_LSRMST_INSERT) | DOWN | STATUS_SUCCESS | ff | ÿ | 1 |
9649 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_LSRMST_INSERT) | UP | STATUS_SUCCESS | | | |
9650 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE) | DOWN | STATUS_SUCCESS | 00 20 00 00 64 00 00 00 | . ..d... | 8 |
9651 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE) | UP | STATUS_SUCCESS | | | |
9652 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_TIMEOUTS) | DOWN | STATUS_SUCCESS | | | |
9653 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_TIMEOUTS) | UP | STATUS_SUCCESS | ff ff ff ff 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 | ÿÿÿÿ................ | 20 |
9654 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS) | DOWN | STATUS_SUCCESS | ff ff ff ff 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 | ÿÿÿÿ................ | 20 |
9655 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS) | UP | STATUS_SUCCESS | | | |
9656 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | DOWN | STATUS_SUCCESS | | | |
9657 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | UP | STATUS_SUCCESS | | | |
9658 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS) | DOWN | STATUS_SUCCESS | | | |
9659 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS) | UP | STATUS_SUCCESS | | | |
9660 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9661 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9662 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 |
9663 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK) | DOWN | STATUS_SUCCESS | b9 01 00 00 | ¹... | 4 |
9664 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK) | UP | STATUS_SUCCESS | | | |
9665 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9666 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9667 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9668 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 |
9669 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 02 00 08 | ... | 3 |
9670 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9671 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9672 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | |
9673 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BREAK_ON) | DOWN | STATUS_SUCCESS | | | |
9674 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BREAK_ON) | UP | STATUS_SUCCESS | | | |
9675 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 10 00 00 00 | .... | 4 |
9676 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS) | DOWN | STATUS_SUCCESS | | | |
9677 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS) | UP | STATUS_SUCCESS | 20 00 00 00 | ... | 4 |
9678 | 06/06/2014 16:27:19 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9679 | 06/06/2014 16:27:19 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9680 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | |
9681 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9682 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | |
9683 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | |
9684 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | |
9685 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 10 00 00 00 | .... | 4 |
9686 | 06/06/2014 16:27:19 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9687 | 06/06/2014 16:27:19 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9688 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9689 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9690 | 06/06/2014 16:27:19 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9691 | 06/06/2014 16:27:19 | IRP_MJ_READ | UP | STATUS_SUCCESS | fe | þ | 1 |
9692 | 06/06/2014 16:27:19 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9693 | 06/06/2014 16:27:19 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9694 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9695 | 06/06/2014 16:27:19 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9696 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9697 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 31 | 1 | 1 |
9698 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9699 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9700 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9701 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9702 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9703 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 36 | 6 | 1 |
9704 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9705 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9706 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9707 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9708 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9709 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 32 | 2 | 1 |
9710 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9711 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9712 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9713 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9714 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9715 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 36 | 6 | 1 |
9716 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9717 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9718 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9719 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9720 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9721 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 33 | 3 | 1 |
9722 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9723 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9724 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9725 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9726 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9727 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 39 | 9 | 1 |
9728 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9729 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9730 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9731 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9732 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9733 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 35 | 5 | 1 |
9734 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9735 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9736 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9737 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9738 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9739 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 30 | 0 | 1 |
9740 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9741 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9742 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9743 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9744 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9745 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 36 | 6 | 1 |
9746 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9747 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9748 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9749 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9750 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9751 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 30 | 0 | 1 |
9752 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9753 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9754 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9755 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9756 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9757 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 36 | 6 | 1 |
9758 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9759 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9760 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9761 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9762 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9763 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 31 | 1 | 1 |
9764 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9765 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9766 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9767 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9768 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9769 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 34 | 4 | 1 |
9770 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9771 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9772 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9773 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9774 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9775 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 35 | 5 | 1 |
9776 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9777 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9778 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9779 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9780 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9781 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 33 | 3 | 1 |
9782 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9783 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9784 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9785 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 |
9786 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9787 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | 0d | . | 1 |
9788 | 06/06/2014 16:27:20 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | |
9789 | 06/06/2014 16:27:20 | IRP_MJ_READ | UP | STATUS_SUCCESS | | | |
9790 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | |
9791 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BREAK_OFF) | DOWN | STATUS_SUCCESS | | | |
9792 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BREAK_OFF) | UP | STATUS_SUCCESS | | | |
9793 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9794 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 02 00 08 | ... | 3 |
9795 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 02 00 05 | ... | 3 |
9796 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_INVALID_PARAMETER | | | |
9797 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9798 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 02 00 08 | ... | 3 |
9799 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 |
9800 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9801 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9802 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | |
9803 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | |
9804 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9805 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9806 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 |
9807 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | |
9808 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 11 13 | ...... | 6 |
9809 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | |
9810 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 10 00 00 00 04 00 00 | ................ | 16 |
9811 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9812 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | |
9813 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS) | DOWN | STATUS_SUCCESS | | | |
9814 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS) | UP | STATUS_SUCCESS | | | |
9815 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | DOWN | STATUS_SUCCESS | | | |
9816 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | UP | STATUS_SUCCESS | | | |
9817 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9818 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9819 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 |
9820 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | |
9821 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 01 00 00 00 40 00 00 00 00 08 00 00 00 02 00 00 | ....@........... | 16 |
9822 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | |
9823 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | DOWN | STATUS_SUCCESS | | | |
9824 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | UP | STATUS_SUCCESS | | | |
9825 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS) | DOWN | STATUS_SUCCESS | | | |
9826 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS) | UP | STATUS_SUCCESS | | | |
9827 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9828 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | |
9829 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9830 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9831 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9832 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9833 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9834 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9835 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9836 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9837 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | |
9838 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9839 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 05 | ... | 3 |
9840 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | |
9841 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 2c 01 00 00 | ,... | 4 |
9842 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | |
9843 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK) | DOWN | STATUS_SUCCESS | 00 00 00 00 | .... | 4 |
9844 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 00 00 00 00 | .... | 4 |
9845 | 06/06/2014 16:27:20 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK) | UP | STATUS_SUCCESS | | | |
9846 | 06/06/2014 16:27:20 | IRP_MJ_CLOSE | DOWN | STATUS_SUCCESS | | | |
9847 | 06/06/2014 16:27:25 | IRP_MJ_CLOSE | UP | STATUS_SUCCESS | | | |
