VLC media player 2.0.3 Twoflower (revision 2.0.2-93-g77aa89e) [0x130c8] main libvlc debug: VLC media player - 2.0.3 Twoflower [0x130c8] main libvlc debug: Copyright © 1996-2012 VLC authors and VideoLAN [0x130c8] main libvlc debug: revision 2.0.2-93-g77aa89e [0x130c8] main libvlc debug: configured with ./configure '--enable-static' '--build=arm-linux-gnueabihf' 'CFLAGS=-g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security' 'CPPFLAGS=-D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security' 'LDFLAGS=-Wl,-z,relro' '--config-cache' '--disable-maintainer-mode' '--disable-silent-rules' '--disable-update-check' '--enable-fast-install' '--prefix=/usr' '--docdir=/usr/share/doc/vlc-nox' '--sysconfdir=/etc' '--with-binary-version=5+deb7u1' '--enable-a52' '--enable-aa' '--enable-bluray' '--enable-bonjour' '--enable-caca' '--enable-dbus' '--enable-dca' '--enable-dirac' '--enable-directfb' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freetype' '--enable-fribidi' '--enable-gnutls' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libproxy' '--enable-libxml2' '--enable-lirc' '--enable-live555' '--enable-mad' '--enable-mkv' '--enable-mod' '--enable-mpc' '--enable-mtp' '--enable-mux_ogg' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-oss' '--enable-pulse' '--enable-qt4' '--enable-realrtsp' '--enable-samplerate' '--enable-schroedinger' '--enable-sdl' '--enable-shout' '--enable-skins2' '--enable-smb' '--enable-speex' '--enable-svg' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vcd' '--enable-vcdx' '--enable-vorbis' '--enable-x264' '--enable-zvbi' '--with-kde-solid=/usr/share/kde4/apps/solid/actions/' '--disable-dxva2' '--disable-gnomevfs' '--disable-goom' '--disable-portaudio' '--disable-projectm' '--disable-sqlite' '--disable-telx' '--enable-alsa' '--enable-atmo' '--enable-dc1394' '--enable-dv' '--enable-fbosd' '--enable-libva' '--enable-linsys' '--enable-omxil' '--enable-pvr' '--enable-udev' '--enable-v4l2' '--disable-crystalhd' '--disable-mmx' '--disable-sse' '--disable-neon' '--disable-altivec' 'build_alias=arm-linux-gnueabihf' [0x130c8] main libvlc debug: searching plug-in modules [0x130c8] main libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat [0x130c8] main libvlc debug: recursively browsing `/usr/lib/vlc/plugins' [0x130c8] main libvlc debug: saving plugins cache /usr/lib/vlc/plugins/plugins.dat [0x130c8] main libvlc debug: plug-ins loaded: 410 modules [0x130c8] main libvlc debug: opening config file (/home/debian/.config/vlc/vlcrc) [0x130c8] main libvlc debug: translation test: code is "C" [0x130c8] main libvlc debug: CPU has capabilities FPU [0x130c8] main libvlc debug: looking for memcpy module: 1 candidate [0x130c8] main libvlc debug: using memcpy module "memcpy" [0x33980] main input debug: Creating an input for 'Media Library' [0x33980] main input debug: Input is a meta file: disabling unneeded options [0x33980] main input debug: using timeshift granularity of 50 MiB, in path '/tmp' [0x33980] main input debug: `file/xspf-open:///home/debian/.local/share/vlc/ml.xspf' gives access `file' demux `xspf-open' path `/home/debian/.local/share/vlc/ml.xspf' [0x33980] main input debug: creating demux: access='file' demux='xspf-open' location='/home/debian/.local/share/vlc/ml.xspf' file='/home/debian/.local/share/vlc/ml.xspf' [0x261d8] main demux debug: looking for access_demux module: 3 candidates [0x261d8] main demux debug: no access_demux module matching "file" could be loaded [0x261d8] main demux debug: TIMER module_need() : 8.644 ms - Total 8.644 ms / 1 intvls (Avg 8.644 ms) [0x33980] main input debug: creating access 'file' location='/home/debian/.local/share/vlc/ml.xspf', path='/home/debian/.local/share/vlc/ml.xspf' [0xa98a8] main access debug: looking for access module: 2 candidates [0xa98a8] filesystem access debug: opening file `/home/debian/.local/share/vlc/ml.xspf' [0xa98a8] main access debug: using access module "filesystem" [0xa98a8] main access debug: TIMER module_need() : 5.858 ms - Total 5.858 ms / 1 intvls (Avg 5.858 ms) [0xaa740] main stream debug: Using stream method for AStream* [0xaa740] main stream debug: starting pre-buffering [0xaa740] main stream debug: received first data after 0 ms [0xaa740] main stream debug: pre-buffering done 296 bytes in 0s - 256 KiB/s [0xa9fc0] main stream debug: looking for stream_filter module: 7 candidates [0xa9fc0] main stream debug: no stream_filter module matching "any" could be loaded [0xa9fc0] main stream debug: TIMER module_need() : 7.565 ms - Total 7.565 ms / 1 intvls (Avg 7.565 ms) [0xa9fc0] main stream debug: looking for stream_filter module: 1 candidate [0xa9fc0] main stream debug: using stream_filter module "stream_filter_record" [0xa9fc0] main stream debug: TIMER module_need() : 3.599 ms - Total 3.599 ms / 1 intvls (Avg 3.599 ms) [0x33980] main input debug: creating demux: access='file' demux='xspf-open' location='/home/debian/.local/share/vlc/ml.xspf' file='/home/debian/.local/share/vlc/ml.xspf' [0xaa800] main demux debug: looking for demux module: 1 candidate [0xaa800] playlist demux debug: using XSPF playlist reader [0xaa800] main demux debug: using demux module "playlist" [0xaa800] main demux debug: TIMER module_need() : 5.249 ms - Total 5.249 ms / 1 intvls (Avg 5.249 ms) [0xaaf38] main demux meta debug: looking for meta reader module: 2 candidates [0xaaf38] lua demux meta debug: Trying Lua scripts in /home/debian/.local/share/vlc/lua/meta/reader [0xaaf38] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader [0xaaf38] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac [0xaaf38] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader [0xaaf38] main demux meta debug: no meta reader module matching "any" could be loaded [0xaaf38] main demux meta debug: TIMER module_need() : 23.328 ms - Total 23.328 ms / 1 intvls (Avg 23.328 ms) [0x33980] main input debug: `file/xspf-open:///home/debian/.local/share/vlc/ml.xspf' successfully opened [0x9e470] main xml reader debug: looking for xml reader module: 1 candidate [0x9e470] main xml reader debug: using xml reader module "xml" [0x9e470] main xml reader debug: TIMER module_need() : 7.761 ms - Total 7.761 ms / 1 intvls (Avg 7.761 ms) [0xaa800] playlist demux debug: parsed 0 tracks successfully [0x33980] main input debug: EOF reached [0xaa800] main demux debug: removing module "playlist" [0xa9fc0] main stream debug: removing module "stream_filter_record" [0xa98a8] main access debug: removing module "filesystem" [0x33980] main input debug: TIMER input launching for 'Media Library' : 73.447 ms - Total 73.447 ms / 1 intvls (Avg 73.447 ms) [0x9d3d0] main interface debug: looking for interface module: 1 candidate [0x9d3d0] main interface debug: using interface module "hotkeys" [0x9d3d0] main interface debug: TIMER module_need() : 4.202 ms - Total 4.202 ms / 1 intvls (Avg 4.202 ms) [0x33980] main interface debug: looking for interface module: 1 candidate [0x33980] inhibit interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11 [0x33980] main interface debug: no interface module matching "inhibit,none" could be loaded [0x33980] main interface debug: TIMER module_need() : 5.054 ms - Total 5.054 ms / 1 intvls (Avg 5.054 ms) [0x33980] main interface error: no suitable interface module [0x221f8] main playlist debug: playlist threads correctly activated [0x221f8] main playlist debug: adding item `http://mp3channels.webradio.antenne.de:80/rockantenne' ( http://mp3channels.webradio.antenne.de:80/rockantenne ) [0x34220] main interface debug: looking for interface module: 1 candidate [0x221f8] main playlist debug: rebuilding array of current - root Playlist [0x221f8] main playlist debug: rebuild done - 1 items, index -1 [0x221f8] main playlist debug: no fetch required for (null) (art currently (null)) [0x34220] main interface debug: no interface module matching "globalhotkeys,none" could be loaded [0x34220] main interface debug: TIMER module_need() : 7.574 ms - Total 7.574 ms / 1 intvls (Avg 7.574 ms) [0x34220] main interface error: no suitable interface module [0x130c8] main libvlc error: interface "globalhotkeys,none" initialization failed [0x34220] main interface debug: looking for interface module: 1 candidate [0x34220] dummy interface: using the dummy interface module... [0x34220] main interface debug: using interface module "dummy" [0x34220] main interface debug: TIMER module_need() : 4.156 ms - Total 4.156 ms / 1 intvls (Avg 4.156 ms) [0x221f8] main playlist debug: processing request item: null, node: Playlist, skip: 0 [0x221f8] main playlist debug: starting playback of the new playlist item [0x221f8] main playlist debug: resyncing on http://mp3channels.webradio.antenne.de:80/rockantenne [0x221f8] main playlist debug: http://mp3channels.webradio.antenne.de:80/rockantenne is at 0 [0x221f8] main playlist debug: creating new input thread [0x34438] main input debug: Creating an input for 'http://mp3channels.webradio.antenne.de:80/rockantenne' [0x34438] main input debug: using timeshift granularity of 50 MiB, in path '/tmp' [0x34438] main input debug: `http://mp3channels.webradio.antenne.de:80/rockantenne' gives access `http' demux `' path `mp3channels.webradio.antenne.de:80/rockantenne' [0x34438] main input debug: creating demux: access='http' demux='' location='mp3channels.webradio.antenne.de:80/rockantenne' file='(null)' [0x9e188] main demux debug: looking for access_demux module: 0 candidates [0x9e188] main demux debug: no access_demux module matched "http" [0x9e188] main demux debug: TIMER module_need() : 1.647 ms - Total 1.647 ms / 1 intvls (Avg 1.647 ms) [0x34438] main input debug: creating access 'http' location='mp3channels.webradio.antenne.de:80/rockantenne', path='(null)' [0x9e470] main access debug: looking for access module: 2 candidates [0x9e470] access_http access debug: asking libproxy about url 'http://mp3channels.webradio.antenne.de:80/rockantenne' [0x9e470] access_http access debug: libproxy suggest to use 'direct://' [0x9e470] access_http access debug: http: server='mp3channels.webradio.antenne.de' port=80 file='/rockantenne' [0x9e470] main access debug: net: connecting to mp3channels.webradio.antenne.de port 80 [0x9e470] main access debug: connection succeeded (socket = 4) [0x9e470] access_http access debug: protocol 'HTTP' answer code 200 [0x9e470] access_http access debug: Content-Type: audio/mpeg [0x9e470] access_http access debug: Meta-Info: icy-br: 128 [0x9e470] access_http access debug: Meta-Info: ice-audio-info: ice-samplerate=44100;ice-bitrate=128;ice-channels=2 [0x9e470] access_http access debug: Meta-Info: icy-br: 128 [0x9e470] access_http access debug: Meta-Info: icy-description: ROCK ANTENNE [0x9e470] access_http access debug: Icy-Genre: Rock [0x9e470] access_http access debug: Icy-Name: ROCK ANTENNE [0x9e470] access_http access debug: Meta-Info: icy-pub: 0 [0x9e470] access_http access debug: Meta-Info: icy-url: http://rockantenne.de/rockantenne [0x9e470] access_http access debug: Server: Icecast 2.3.2-kh31 [0x9e470] access_http access debug: Pragma: no-cache [0x9e470] access_http access debug: Icy-MetaInt: 16000 [0x9e470] access_http access warning: ICY metaint=16000 [0x9e470] access_http access: Raw-audio server found, mp3 demuxer selected [0x9e470] access_http access debug: auto re-connect enabled [0x9e470] main access debug: using access module "access_http" [0x9e470] main access debug: TIMER module_need() : 615.096 ms - Total 615.096 ms / 1 intvls (Avg 615.096 ms) [0x44658] main stream debug: Using stream method for AStream* [0x44658] main stream debug: starting pre-buffering [0x44658] main stream debug: received first data after 144 ms [0x44658] main stream debug: pre-buffering done 1024 bytes in 0s - 6 KiB/s [0xa82e0] main stream debug: looking for stream_filter module: 7 candidates [0xa82e0] main stream debug: no stream_filter module matching "any" could be loaded [0xa82e0] main stream debug: TIMER module_need() : 3.818 ms - Total 3.818 ms / 1 intvls (Avg 3.818 ms) [0xa82e0] main stream debug: looking for stream_filter module: 1 candidate [0xa82e0] main stream debug: using stream_filter module "stream_filter_record" [0xa82e0] main stream debug: TIMER module_need() : 3.924 ms - Total 3.924 ms / 1 intvls (Avg 3.924 ms) [0x34438] main input debug: creating demux: access='http' demux='mp3' location='mp3channels.webradio.antenne.de:80/rockantenne' file='(null)' [0x41ad0] main demux debug: looking for demux module: 1 candidate [0x41ad0] es demux debug: detected format mpga [0x43908] main demux packetizer debug: looking for packetizer module: 21 candidates [0x43908] main demux packetizer debug: using packetizer module "mpeg_audio" [0x43908] main demux packetizer debug: TIMER module_need() : 61.714 ms - Total 61.714 ms / 1 intvls (Avg 61.714 ms) [0x43908] mpeg_audio demux packetizer debug: MPGA channels:2 samplerate:44100 bitrate:128 [0x34438] main input debug: selecting program id=0 [0x41ad0] main demux debug: using demux module "es" [0x41ad0] main demux debug: TIMER module_need() : 90.018 ms - Total 90.018 ms / 1 intvls (Avg 90.018 ms) [0x3fd00] main decoder debug: looking for decoder module: 30 candidates [0x3fd00] main decoder debug: using decoder module "mpeg_audio" [0x3fd00] main decoder debug: TIMER module_need() : 55.747 ms - Total 55.747 ms / 1 intvls (Avg 55.747 ms) [0x3d918] main demux meta debug: looking for meta reader module: 2 candidates [0x3d918] lua demux meta debug: Trying Lua scripts in /home/debian/.local/share/vlc/lua/meta/reader [0x3d918] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader [0x3d918] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac [0x3d918] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader [0x3d918] main demux meta debug: no meta reader module matching "any" could be loaded [0x3d918] main demux meta debug: TIMER module_need() : 31.802 ms - Total 31.802 ms / 1 intvls (Avg 31.802 ms) [0x34438] main input debug: `http://mp3channels.webradio.antenne.de:80/rockantenne' successfully opened [0x34438] main input debug: Buffering 0% [0x34438] main input debug: Buffering 2% [0x3fd00] mpeg_audio decoder debug: MPGA channels:2 samplerate:44100 bitrate:128 [0x221f8] main playlist debug: creating audio output [0x39d60] main audio output debug: looking for audio output module: 3 candidates [0x39d60] alsa audio output debug: keeping 2 channels [0x34438] main input debug: Buffering 5% [0x34438] main input debug: Buffering 7% [0x34438] main input debug: Buffering 10% [0x34438] main input debug: Buffering 13% [0x34438] main input debug: Buffering 15% [0x34438] main input debug: Buffering 18% [0x34438] main input debug: Buffering 20% [0x34438] main input debug: Buffering 23% [0x34438] main input debug: Buffering 26% [0x34438] main input debug: Buffering 28% [0x34438] main input debug: Buffering 31% [0x34438] main input debug: Buffering 33% [0x34438] main input debug: Buffering 36% [0x34438] main input debug: Buffering 39% [0x34438] main input debug: Buffering 41% [0x34438] main input debug: Buffering 44% [0x34438] main input debug: Buffering 47% [0x34438] main input debug: Buffering 49% [0x34438] main input debug: Buffering 52% [0x34438] main input debug: Buffering 54% [0x34438] main input debug: Buffering 57% [0x34438] main input debug: Buffering 60% [0x39d60] alsa audio output debug: using ALSA device: hw:1,0 [0x39d60] alsa audio output debug: Hardware PCM card 1 'USB Sound Device' device 0 subdevice 0 [0x39d60] alsa audio output debug: device name : USB Audio [0x39d60] alsa audio output debug: device ID : USB Audio [0x39d60] alsa audio output debug: subdevice name: subdevice #0 [0x39d60] alsa audio output debug: initial hardware setup: ACCESS: MMAP_INTERLEAVED RW_INTERLEAVED FORMAT: S16_LE SUBFORMAT: STD SAMPLE_BITS: 16 FRAME_BITS: [32 128] CHANNELS: [2 8] RATE: [44100 96000] PERIOD_TIME: [1000 2972155) PERIOD_SIZE: [45 131072] PERIOD_BYTES: [180 524288] PERIODS: [2 1024] BUFFER_TIME: (937 5944309) BUFFER_SIZE: [90 262144] BUFFER_BYTES: [360 1048576] TICK_TIME: ALL [0x34438] main input debug: Buffering 62% [0x34438] main input debug: Buffering 65% [0x34438] main input debug: Buffering 67% [0x34438] main input debug: Buffering 70% [0x34438] main input debug: Buffering 73% [0x34438] main input debug: Buffering 75% [0x34438] main input debug: Buffering 78% [0x34438] main input debug: Buffering 80% [0x34438] main input debug: Buffering 83% [0x34438] main input debug: Buffering 86% [0x34438] main input debug: Buffering 88% [0x34438] main input debug: Buffering 91% [0x39d60] alsa audio output debug: final HW setup: ACCESS: RW_INTERLEAVED FORMAT: S16_LE SUBFORMAT: STD SAMPLE_BITS: 16 FRAME_BITS: 32 CHANNELS: 2 RATE: 44100 PERIOD_TIME: 40000 PERIOD_SIZE: 1764 PERIOD_BYTES: 7056 PERIODS: 75 BUFFER_TIME: 3000000 BUFFER_SIZE: 132300 BUFFER_BYTES: 529200 TICK_TIME: 0 [0x39d60] alsa audio output debug: initial software parameters: tstamp_mode: NONE period_step: 1 avail_min: 1764 start_threshold: 1 stop_threshold: 132300 silence_threshold: 0 silence_size: 0 boundary: 1083801600 [0x39d60] alsa audio output debug: final software parameters: tstamp_mode: NONE period_step: 1 avail_min: 1764 start_threshold: 1 stop_threshold: 132300 silence_threshold: 0 silence_size: 0 boundary: 1083801600 [0x9e470] access_http access debug: New Title=Goo Goo Dolls - Iris [0x34438] main input debug: Buffering 94% [0x34438] main input debug: Buffering 96% [0x39d60] alsa audio output debug: Available ALSA PCM devices: [0x34438] main input debug: Buffering 99% [0x34438] main input debug: Stream buffering done (1018 ms in 122 ms) [0x39d60] alsa audio output debug: Discard all samples (playback) or generate zero samples (capture) (null) [0x39d60] alsa audio output debug: TI BeagleBone Black, Default Audio Device (default:CARD=Black) [0x39d60] alsa audio output debug: TI BeagleBone Black, Default Audio Device (sysdefault:CARD=Black) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio Default Audio Device (default:CARD=Device) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio Default Audio Device (sysdefault:CARD=Device) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio Front speakers (front:CARD=Device,DEV=0) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio 4.0 Surround output to Front and Rear speakers (surround40:CARD=Device,DEV=0) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio 4.1 Surround output to Front, Rear and Subwoofer speakers (surround41:CARD=Device,DEV=0) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio 5.0 Surround output to Front, Center and Rear speakers (surround50:CARD=Device,DEV=0) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio 5.1 Surround output to Front, Center, Rear and Subwoofer speakers (surround51:CARD=Device,DEV=0) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers (surround71:CARD=Device,DEV=0) [0x39d60] alsa audio output debug: USB Sound Device, USB Audio IEC958 (S/PDIF) Digital Audio Output (iec958:CARD=Device,DEV=0) [0x39d60] main audio output debug: using audio output module "alsa" [0x39d60] main audio output debug: TIMER module_need() : 425.326 ms - Total 425.326 ms / 1 intvls (Avg 425.326 ms) [0x39d60] main audio output debug: output 's16l' 44100 Hz Stereo frame=1 samples/4 bytes [0x39d60] main audio output debug: mixer 'f32l' 44100 Hz Stereo frame=1 samples/8 bytes [0x39d60] main audio output debug: filter(s) 'f32l'->'s16l' 44100 Hz->44100 Hz Stereo->Stereo [0x3c4a8] main audio filter debug: looking for audio filter module: 14 candidates [0x3c4a8] audio_format audio filter debug: f32l->s16l, bits per sample: 32->16 [0x3c4a8] main audio filter debug: using audio filter module "audio_format" [0x3c4a8] main audio filter debug: TIMER module_need() : 64.669 ms - Total 64.669 ms / 1 intvls (Avg 64.669 ms) [0x39d60] main audio output debug: conversion pipeline completed [0x5d680] main mixer debug: looking for audio mixer module: 2 candidates [0x5d680] main mixer debug: using audio mixer module "float32_mixer" [0x5d680] main mixer debug: TIMER module_need() : 8.907 ms - Total 8.907 ms / 1 intvls (Avg 8.907 ms) [0x39d60] main audio output debug: input 'mpga' 44100 Hz Stereo frame=1152 samples/1053 bytes [0x5a6e8] main audio filter debug: looking for audio filter module: 1 candidate [0x5a6e8] scaletempo audio filter debug: format: 44100 rate, 2 nch, 4 bps, fl32 [0x5a6e8] scaletempo audio filter debug: params: 30 stride, 0.200 overlap, 14 search [0x5a6e8] scaletempo audio filter debug: 1.000 scale, 1323.000 stride_in, 1323 stride_out, 1059 standing, 264 overlap, 617 search, 2204 queue, fl32 mode [0x5a6e8] main audio filter debug: using audio filter module "scaletempo" [0x5a6e8] main audio filter debug: TIMER module_need() : 20.342 ms - Total 20.342 ms / 1 intvls (Avg 20.342 ms) [0x39d60] main audio output debug: filter(s) 'mpga'->'f32l' 44100 Hz->44100 Hz Stereo->Stereo [0x5afb0] main audio filter debug: looking for audio filter module: 14 candidates [0x5afb0] mpgatofixed32 audio filter debug: mpga->f32l, bits per sample: 32 [0x5afb0] main audio filter debug: using audio filter module "mpgatofixed32" [0x5afb0] main audio filter debug: TIMER module_need() : 4.482 ms - Total 4.482 ms / 1 intvls (Avg 4.482 ms) [0x39d60] main audio output debug: conversion pipeline completed [0x39d60] main audio output debug: filter(s) 'f32l'->'f32l' 44100 Hz->44100 Hz Stereo->Stereo [0x39d60] main audio output debug: conversion pipeline completed [0x39d60] main audio output debug: filter(s) 'f32l'->'f32l' 48510 Hz->44100 Hz Stereo->Stereo [0x5db90] main audio filter debug: looking for audio filter module: 14 candidates [0x5db90] main audio filter debug: using audio filter module "samplerate" [0x5db90] main audio filter debug: TIMER module_need() : 7.225 ms - Total 7.225 ms / 1 intvls (Avg 7.225 ms) [0x39d60] main audio output debug: conversion pipeline completed [0x3fd00] main decoder debug: End of audio preroll [0x34438] main input debug: Decoder buffering done in 434 ms [0x39d60] main audio output warning: PTS is out of range (-8865), dropping buffer [0x39d60] main audio output warning: PTS is out of range (-32069), dropping buffer [0x5afb0] mpgatofixed32 audio filter debug: libmad error: bad main_data_begin pointer [0x39d60] alsa audio output debug: prepending 1759 zeroes ^C[0x130c8] main libvlc debug: deactivating the playlist [0x221f8] main playlist debug: deactivating the playlist [0x221f8] main playlist debug: incoming request - stopping current input [0x9e470] main access debug: waitpipe: object killed [0x221f8] main playlist debug: dying input [0x34438] main input debug: control: stopping input [0x221f8] main playlist debug: dying input [0x3fd00] main decoder debug: removing module "mpeg_audio" [0x3fd00] main decoder debug: killing decoder fourcc `mpga', 0 PES in FIFO [0x5afb0] main audio filter debug: removing module "mpgatofixed32" [0x5a6e8] main audio filter debug: removing module "scaletempo" [0x5db90] main audio filter debug: removing module "samplerate" [0x39d60] main audio output debug: removing module "alsa" [0x3c4a8] main audio filter debug: removing module "audio_format" [0x5d680] main mixer debug: removing module "float32_mixer" [0x221f8] main playlist debug: releasing audio output [0x41ad0] main demux debug: removing module "es" [0x43908] main demux packetizer debug: removing module "mpeg_audio" [0xa82e0] main stream debug: removing module "stream_filter_record" [0x9e470] main access debug: removing module "access_http" [0x34438] main input debug: Program doesn't contain anymore ES [0x221f8] main playlist debug: dead input [0x34438] main input debug: TIMER input launching for 'http://mp3channels.webradio.antenne.de:80/rockantenne' : 979.205 ms - Total 979.205 ms / 1 intvls (Avg 979.205 ms) [0x5d680] main playlist export debug: saving Media Library to file /home/debian/.local/share/vlc/ml.xspf [0x5d680] main playlist export debug: looking for playlist export module: 1 candidate [0x5d680] main playlist export debug: using playlist export module "export" [0x5d680] main playlist export debug: TIMER module_need() : 5.163 ms - Total 5.163 ms / 1 intvls (Avg 5.163 ms) [0x5d680] main playlist export debug: removing module "export" [0x221f8] main playlist debug: playlist correctly deactivated [0x130c8] main libvlc debug: removing all services discovery tasks [0x130c8] main libvlc debug: removing all interfaces [0x130c8] main libvlc debug: exiting [0x34220] main interface debug: removing module "dummy" [0x9d3d0] main interface debug: removing module "hotkeys" [0x221f8] main playlist debug: destroying [0x130c8] main libvlc debug: TIMER ML Load : Total 90.621 ms / 1 intvls (Avg 90.621 ms) [0x130c8] main libvlc debug: TIMER Items array build : Total 1.920 ms / 1 intvls (Avg 1.920 ms) [0x130c8] main libvlc debug: TIMER ML Dump : Total 8.468 ms / 1 intvls (Avg 8.468 ms) [0x130c8] main libvlc debug: removing stats [0x130c8] main libvlc debug: removing module "memcpy"
