pi@raspberrypi /tmp/delme.pi $ /home/pi/local/bin/avrdude -c usbasp -p atmega1284p -U flash:w:flash.raw:r avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9705 avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "flash.raw" avrdude: writing flash (125276 bytes): Writing | ################################################## | 100% 9.13s avrdude: 125276 bytes of flash written avrdude: verifying flash memory against flash.raw: avrdude: load data flash data from input file flash.raw: avrdude: input file flash.raw contains 125276 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 14.85s avrdude: verifying ... avrdude: 125276 bytes of flash verified avrdude: safemode: Fuses OK (E:FC, H:D0, L:D7) avrdude done. Thank you. pi@raspberrypi /tmp/delme.pi $ /home/pi/local/bin/avrdude -c usbasp -p atmega1284p -U flash:w:flash.raw:r avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9705 avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "flash.raw" avrdude: writing flash (125276 bytes): Writing | ################################################## | 100% 9.13s avrdude: 125276 bytes of flash written avrdude: verifying flash memory against flash.raw: avrdude: load data flash data from input file flash.raw: avrdude: input file flash.raw contains 125276 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 14.86s avrdude: verifying ... avrdude: 125276 bytes of flash verified avrdude: safemode: Fuses OK (E:FC, H:D0, L:D7) avrdude done. Thank you. pi@raspberrypi /tmp/delme.pi $ /home/pi/local/bin/avrdude -c usbasp -p atmega1284p -U flash:w:flash.raw:r avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9705 avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "flash.raw" avrdude: writing flash (125276 bytes): Writing | ################################################## | 100% 9.13s avrdude: 125276 bytes of flash written avrdude: verifying flash memory against flash.raw: avrdude: load data flash data from input file flash.raw: avrdude: input file flash.raw contains 125276 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 14.92s avrdude: verifying ... avrdude: 125276 bytes of flash verified avrdude: safemode: Fuses OK (E:FC, H:D0, L:D7) avrdude done. Thank you. pi@raspberrypi /tmp/delme.pi $ pi@raspberrypi /tmp/delme.pi $ pi@raspberrypi /tmp/delme.pi $ pi@raspberrypi /tmp/delme.pi $ pi@raspberrypi /tmp/delme.pi $ pi@raspberrypi /tmp/delme.pi $ pi@raspberrypi /tmp/delme.pi $ /home/pi/local/bin/avrdude -c usbasp -p atmega1284p -U flash:r:flash.raw:r avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9705 avrdude: reading flash memory: Reading | ################################################## | 100% 15.59s avrdude: writing output file "flash.raw" avrdude: safemode: Fuses OK (E:FC, H:D0, L:D7) avrdude done. Thank you. pi@raspberrypi /tmp/delme.pi $ /home/pi/local/bin/avrdude -c usbasp -p atmega1284p -U flash:r:flash.raw:r avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9705 avrdude: reading flash memory: Reading | ################################################## | 100% 15.60s avrdude: writing output file "flash.raw" avrdude: safemode: Fuses OK (E:FC, H:D0, L:D7) avrdude done. Thank you. pi@raspberrypi /tmp/delme.pi $ /home/pi/local/bin/avrdude -c usbasp -p atmega1284p -U flash:r:flash.raw:r avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9705 avrdude: reading flash memory: Reading | ################################################## | 100% 15.56s avrdude: writing output file "flash.raw" avrdude: safemode: Fuses OK (E:FC, H:D0, L:D7) avrdude done. Thank you. pi@raspberrypi /tmp/delme.pi $
