EDID report generated by SwitchResX Version 4.5.0 (Intel - 64-bit) for display BOE TV ----------------------------------------------------- ------------------- RAW DATA ------------------------ ----------------------------------------------------- 0 1 2 3 4 5 6 7 8 9 A B C D E F ----------------------------------------------------- 0 | 00 FF FF FF FF FF FF 00 09 E5 1A 00 0B 00 00 00 1 | 02 17 01 03 80 A0 5A 78 0A 01 C1 A0 57 47 98 27 2 | 12 4C 4C A5 4E 00 31 40 45 40 61 40 81 80 01 01 3 | 01 01 01 01 01 01 98 21 50 B0 51 00 1B 30 40 70 4 | 36 00 40 84 63 00 00 1E 4C 1D 00 72 51 D0 1E 20 5 | 6E 28 55 00 40 84 63 00 00 1E 00 00 00 FC 00 42 6 | 4F 45 20 54 56 0A 20 20 20 20 20 20 00 00 00 FD 7 | 00 30 3E 0E 44 06 00 0A 20 20 20 20 20 20 01 00 ----------------------------------------------------- 0 1 2 3 4 5 6 7 8 9 A B C D E F ----------------------------------------------------- 0 | 02 03 25 70 51 01 02 03 04 05 06 07 10 11 12 13 1 | 14 15 16 1D 1E 1F 23 09 07 07 83 01 00 00 66 03 2 | 0C 00 10 00 80 01 1D 80 D0 72 1C 16 20 10 2C 25 3 | 80 40 84 63 00 00 9F 01 1D 80 18 71 1C 16 20 58 4 | 2C 25 00 40 84 63 00 00 99 01 1D 00 BC 52 D0 1E 5 | 20 B8 28 55 40 40 84 63 00 00 1E 02 3A 80 D0 72 6 | 38 2D 40 10 2C 45 80 40 84 63 00 00 1E 02 3A 80 7 | 18 71 38 2D 40 58 2C 45 00 40 84 63 00 00 1E C7 ----------------------------------------------------- < 00FFFFFF FFFFFF00 09E51A00 0B000000 02170103 80A05A78 0A01C1A0 57479827 124C4CA5 4E003140 45406140 81800101 01010101 01019821 50B05100 1B304070 36004084 6300001E 4C1D0072 51D01E20 6E285500 40846300 001E0000 00FC0042 4F452054 560A2020 20202020 000000FD 00303E0E 4406000A 20202020 20200100 02032570 51010203 04050607 10111213 1415161D 1E1F2309 07078301 00006603 0C001000 80011D80 D0721C16 20102C25 80408463 00009F01 1D801871 1C162058 2C250040 84630000 99011D00 BC52D01E 20B82855 40408463 00001E02 3A80D072 382D4010 2C458040 84630000 1E023A80 1871382D 40582C45 00408463 00001EC7 > ----------------------------------------------------- { 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x09, 0xE5, 0x1A, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x02, 0x17, 0x01, 0x03, 0x80, 0xA0, 0x5A, 0x78, 0x0A, 0x01, 0xC1, 0xA0, 0x57, 0x47, 0x98, 0x27, 0x12, 0x4C, 0x4C, 0xA5, 0x4E, 0x00, 0x31, 0x40, 0x45, 0x40, 0x61, 0x40, 0x81, 0x80, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x98, 0x21, 0x50, 0xB0, 0x51, 0x00, 0x1B, 0x30, 0x40, 0x70, 0x36, 0x00, 0x40, 0x84, 0x63, 0x00, 0x00, 0x1E, 0x4C, 0x1D, 0x00, 0x72, 0x51, 0xD0, 0x1E, 0x20, 0x6E, 0x28, 0x55, 0x00, 0x40, 0x84, 0x63, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x42, 0x4F, 0x45, 0x20, 0x54, 0x56, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xFD, 0x00, 0x30, 0x3E, 0x0E, 0x44, 0x06, 0x00, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x01, 0x00, 0x02, 0x03, 0x25, 0x70, 0x51, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x1D, 0x1E, 0x1F, 0x23, 0x09, 0x07, 0x07, 0x83, 0x01, 0x00, 0x00, 0x66, 0x03, 0x0C, 0x00, 0x10, 0x00, 0x80, 0x01, 0x1D, 0x80, 0xD0, 0x72, 0x1C, 0x16, 0x20, 0x10, 0x2C, 0x25, 0x80, 0x40, 0x84, 0x63, 0x00, 0x00, 0x9F, 0x01, 0x1D, 0x80, 0x18, 0x71, 0x1C, 0x16, 0x20, 0x58, 0x2C, 0x25, 0x00, 0x40, 0x84, 0x63, 0x00, 0x00, 0x99, 0x01, 0x1D, 0x00, 0xBC, 0x52, 0xD0, 0x1E, 0x20, 0xB8, 0x28, 0x55, 0x40, 0x40, 0x84, 0x63, 0x00, 0x00, 0x1E, 0x02, 0x3A, 0x80, 0xD0, 0x72, 0x38, 0x2D, 0x40, 0x10, 0x2C, 0x45, 0x80, 0x40, 0x84, 0x63, 0x00, 0x00, 0x1E, 0x02, 0x3A, 0x80, 0x18, 0x71, 0x38, 0x2D, 0x40, 0x58, 0x2C, 0x45, 0x00, 0x40, 0x84, 0x63, 0x00, 0x00, 0x1E, 0xC7 } ----------------------------------------------------- Valid EDID block #0: checksum ok Valid EDID block #1: checksum ok ----------------------------------------------------- ------------------- MAIN EDID BLOCK ----------------- ----------------------------------------------------- EDID Version........1.3 Manufacturer........BOE (09E5) Product ID..........26 (001A) Serial Number.......0000000B Manufactured........Week 2 of year 2013 Max H Size..........160 cm Max V Size..........90 cm Gamma...............2,20 Display Supported Features: --------------------------- Display type: ------------- RGB 4:4:4 & YCrCb 4:4:4 Color Encoding Formats Display is non continuous frequency Default color space is not sRGB standard Preferred timing mode includes Native Pixel Format Input signal & sync: -------------------- Digital Input Color Bit Depth is undefined Digital Interface is not defined Color info: ----------- Red x = 0,625 Green x = 0,277 Blue x = 0,155 White x = 0,297 Red y = 0,340 Green y = 0,595 Blue y = 0,070 White y = 0,298 Established Timings: -------------------- 720 x 400 @ 70Hz 640 x 480 @ 60Hz 640 x 480 @ 75Hz 800 x 600 @ 60Hz 800 x 600 @ 75Hz 1024 x 768 @ 60Hz 1024 x 768 @ 70Hz 1024 x 768 @ 75Hz Manufacturer Reserved Timings: ------------------------------ Standard Timing Identification: ------------------------------- #0: 640 x 480 @ 60Hz (3140) #1: 800 x 600 @ 60Hz (4540) #2: 1024 x 768 @ 60Hz (6140) #3: 1280 x 1024 @ 60Hz (8180) Monitor Description blocks: --------------------------- Descriptor #0 - Timing definition: Mode = 1360 x 768 @ 60,366Hz Pixel Clock............. 86,00 MHz Non-Interlaced Horizontal Vertical Active.................. 1360 pixels 768 lines Front Porch............. 64 pixels 3 lines Sync Width.............. 112 pixels 6 lines Back Porch.............. 256 pixels 18 lines Blanking................ 432 pixels 27 lines Total................... 1792 pixels 795 lines Scan Rate............... 47,991 kHz 60,366 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Descriptor #1 - Timing definition: Mode = 1280 x 720 @ 60,606Hz Pixel Clock............. 75,00 MHz Non-Interlaced Horizontal Vertical Active.................. 1280 pixels 720 lines Front Porch............. 110 pixels 5 lines Sync Width.............. 40 pixels 5 lines Back Porch.............. 220 pixels 20 lines Blanking................ 370 pixels 30 lines Total................... 1650 pixels 750 lines Scan Rate............... 45,455 kHz 60,606 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Descriptor #2 - Monitor name: BOE TV Descriptor #3 - Monitor limits: Horizontal frequency range.......14-68 kHz Vertical frequency range.........48-62 Hz Maximum bandwidth range..........60 MHz GTF supported ----------------------------------------------------- ------------ EXTENSION EDID BLOCK 1 --------------- ----------------------------------------------------- CEA-EXT: CEA 861 Series Extension: ---------------------------------- Revision:..............................3 First DTD block at offset..............33 Display Supports: Basic audio YCbCr 4:4:4 YCbCr 4:2:2 Data Block Collection #1 - Type 2 Video Type: standard CEA Timings #1: 640 x 480p @ 59.94/60Hz - 4:3 - 'DMT0659' (1) #2: 720 x 480p @ 59.94/60Hz - 4:3 - '480p' (2) #3: 720 x 480p @ 59.94/60Hz - 16:9 - '480pH' (3) #4: 1280 x 720p @ 59.94/60Hz - 16:9 - '720p' (4) #5: 1920 x 1080i @ 59.94/60Hz - 16:9 - '1080i' (5) #6: 720(1440) x 480i @ 59.94/60Hz - 4:3 - '480i' (6) #7: 720(1440) x 480i @ 59.94/60Hz - 16:9 - '480iH' (7) #8: 1920 x 1080p @ 59.94/60Hz - 16:9 - '1080p' (16) #9: 720 x 576p @ 50Hz - 4:3 - '576p' (17) #10: 720 x 576p @ 50Hz - 16:9 - '576pH' (18) #11: 1280 x 720p @ 50Hz - 16:9 - '720p50' (19) #12: 1920 x 1080i @ 50Hz - 16:9 - '1080i25' (20) #13: 720(1440) x 576i @ 50Hz - 4:3 - '576i' (21) #14: 720(1440) x 576i @ 50Hz - 16:9 - '576iH' (22) #15: 1440 x 576p @ 50Hz - 4:3 - '576p2x' (29) #16: 1440 x 576p @ 50Hz - 16:9 - '576p2xH' (30) #17: 1920 x 1080p @ 50Hz - 16:9 - '1080p50' (31) Data Block Collection #2 - Type 1 Audio Type Block Supported format: Linear Pulse Code Modulation (LPCM), on 2 channels Supported freq: 32kHz, 44.1kHz, 48kHz Supported sample sizes: 16 bit, 20 bit, 24 bit Data Block Collection #3 - Type 4 Speaker allocation data block Front Left / Front Right Front Left High / Front Right High Data Block Collection #4 - Type 3 Vendor specific Identifier Found HDMI IEEE Registration Identifier CEC physical address........... 1.0.0.0 Supports AI (ACP, ISRC)........ Yes Supports 48bpp color depth..... No Supports 36bpp color depth..... No Supports 30bpp color depth..... No Supports YCbCr 4:4:4........... No Supports dual-link DVI......... No Maximum TMDS clock............. 5 MHz Detailed Timing Blocks - 0 is native Detailed Timing Block #1 - Timing definition: Mode = 1920 x 540 @ 50,044Hz Pixel Clock............. 74,25 MHz Interlaced Horizontal Vertical Active.................. 1920 pixels 540 lines Front Porch............. 528 pixels 2 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 15 lines Blanking................ 720 pixels 22 lines Total................... 2640 pixels 562 lines Scan Rate............... 28,125 kHz 50,044 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Detailed Timing Block #2 - Timing definition: Mode = 1920 x 540 @ 60,053Hz Pixel Clock............. 74,25 MHz Interlaced Horizontal Vertical Active.................. 1920 pixels 540 lines Front Porch............. 88 pixels 2 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 15 lines Blanking................ 280 pixels 22 lines Total................... 2200 pixels 562 lines Scan Rate............... 33,750 kHz 60,053 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Negative vertical polarity * Negative horizontal polarity Detailed Timing Block #3 - Timing definition: Mode = 1280 x 720 @ 50,000Hz Pixel Clock............. 74,25 MHz Non-Interlaced Horizontal Vertical Active.................. 1280 pixels 720 lines Front Porch............. 440 pixels 5 lines Sync Width.............. 40 pixels 5 lines Back Porch.............. 220 pixels 20 lines Blanking................ 700 pixels 30 lines Total................... 1980 pixels 750 lines Scan Rate............... 37,500 kHz 50,000 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Detailed Timing Block #4 - Timing definition: Mode = 1920 x 1080 @ 50,000Hz Pixel Clock............. 148,50 MHz Non-Interlaced Horizontal Vertical Active.................. 1920 pixels 1080 lines Front Porch............. 528 pixels 4 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 36 lines Blanking................ 720 pixels 45 lines Total................... 2640 pixels 1125 lines Scan Rate............... 56,250 kHz 50,000 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Detailed Timing Block #5 - Timing definition: Mode = 1920 x 1080 @ 60,000Hz Pixel Clock............. 148,50 MHz Non-Interlaced Horizontal Vertical Active.................. 1920 pixels 1080 lines Front Porch............. 88 pixels 4 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 36 lines Blanking................ 280 pixels 45 lines Total................... 2200 pixels 1125 lines Scan Rate............... 67,500 kHz 60,000 Hz Image Size.............. 1600 mm 900 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity
