# | Time | Function | Direction | Status | Data | Data (chars) | Data length | Req. length | Port |
412 | 28/02/2015 14:42:22 | IRP_MJ_CREATE | DOWN | STATUS_SUCCESS | | D:\Projekte\Controller_AVR\_Tools\HTerm.exe | | | COM7 |
413 | 28/02/2015 14:42:22 | IRP_MJ_CREATE | UP | STATUS_SUCCESS | | D:\Projekte\Controller_AVR\_Tools\HTerm.exe | | | COM7 |
414 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS) | DOWN | STATUS_SUCCESS | ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ÿÿÿÿ................ | 20 | | COM7 |
415 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS) | UP | STATUS_SUCCESS | | | | | COM7 |
416 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
417 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
418 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
419 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
420 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
421 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
422 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
423 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 6c 86 00 00 9b 21 00 00 | ........l†..›!.. | 16 | | COM7 |
424 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
425 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | | | COM7 |
426 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
427 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
428 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
429 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
430 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
431 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | | | COM7 |
432 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
433 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | | | COM7 |
434 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
435 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | | | COM7 |
436 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE) | DOWN | STATUS_SUCCESS | 00 10 00 00 00 10 00 00 | ........ | 8 | | COM7 |
437 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE) | UP | STATUS_SUCCESS | | | | | COM7 |
438 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
439 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
440 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
441 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
442 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
443 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
444 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
445 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
446 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
447 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | | | COM7 |
448 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
449 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
450 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
451 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
452 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
453 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | | | COM7 |
454 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
455 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | | | COM7 |
456 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
457 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE) | DOWN | STATUS_SUCCESS | 0f 00 00 00 | .... | 4 | | COM7 |
458 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE) | UP | STATUS_SUCCESS | | | | | COM7 |
459 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK) | DOWN | STATUS_SUCCESS | b9 01 00 00 | ¹... | 4 | | COM7 |
460 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK) | UP | STATUS_SUCCESS | | | | | COM7 |
461 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
462 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | | | COM7 |
463 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
464 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
465 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
466 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
467 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
468 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
469 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
470 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
471 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
472 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
473 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
474 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
475 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
476 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
477 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
478 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
479 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
480 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | | | COM7 |
481 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
482 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
483 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
484 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
485 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
486 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 | .... | 4 | | COM7 |
487 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | | | COM7 |
488 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
489 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | | | COM7 |
490 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
491 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
492 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | | | COM7 |
493 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
494 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
495 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
496 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
497 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
498 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
499 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
500 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
501 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
502 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
503 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
504 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
505 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
506 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
507 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
508 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
509 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
510 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | | | COM7 |
511 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
512 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
513 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
514 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
515 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
516 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | | | COM7 |
517 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
518 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | | | COM7 |
519 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
520 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | | | COM7 |
521 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
522 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
523 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
524 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
525 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
526 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
527 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
528 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
529 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
530 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
531 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
532 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
533 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
534 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
535 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
536 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
537 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
538 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | | | COM7 |
539 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
540 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
541 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
542 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
543 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
544 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | | | COM7 |
545 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
546 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | | | COM7 |
547 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
548 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | | | COM7 |
549 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
550 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
551 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
552 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
553 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
554 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
555 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
556 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
557 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
558 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
559 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
560 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
561 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
562 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
563 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
564 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
565 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | DOWN | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
566 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE) | UP | STATUS_SUCCESS | | | | | COM7 |
567 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
568 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
569 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
570 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
571 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
572 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL) | UP | STATUS_SUCCESS | | | | | COM7 |
573 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
574 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS) | UP | STATUS_SUCCESS | | | | | COM7 |
575 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | DOWN | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
576 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW) | UP | STATUS_SUCCESS | | | | | COM7 |
577 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | DOWN | STATUS_SUCCESS | | | | | COM7 |
578 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE) | UP | STATUS_SUCCESS | 00 c2 01 00 | .Â.. | 4 | | COM7 |
579 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | DOWN | STATUS_SUCCESS | | | | | COM7 |
580 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL) | UP | STATUS_SUCCESS | 00 00 08 | ... | 3 | | COM7 |
581 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
582 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 | ...... | 6 | | COM7 |
583 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | DOWN | STATUS_SUCCESS | | | | | COM7 |
584 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ | 16 | | COM7 |
585 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
586 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
587 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
588 | 28/02/2015 14:42:22 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS) | UP | STATUS_SUCCESS | | | | | COM7 |
589 | 28/02/2015 14:42:32 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
590 | 28/02/2015 14:42:32 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
591 | 28/02/2015 14:42:33 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | DOWN | STATUS_SUCCESS | | | | | COM7 |
592 | 28/02/2015 14:42:33 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR) | UP | STATUS_SUCCESS | | | | | COM7 |
593 | 28/02/2015 14:42:34 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
594 | 28/02/2015 14:42:34 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
595 | 28/02/2015 14:42:34 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
596 | 28/02/2015 14:42:34 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
597 | 28/02/2015 14:42:34 | IRP_MJ_READ | UP | STATUS_SUCCESS | 0d 0a 47 72 62 6c 20 30 2e 39 67 20 5b 27 24 27 20 66 6f 72 20 68 65 6c 70 5d 0d 0a | ..Grbl 0.9g ['$' for help].. | 28 | | COM7 |
598 | 28/02/2015 14:42:34 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
599 | 28/02/2015 14:42:34 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
600 | 28/02/2015 14:42:34 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
601 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
602 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
603 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
604 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
605 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
606 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
607 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
608 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
609 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
610 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
611 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
612 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
613 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
614 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
615 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
616 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
617 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
618 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
619 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
620 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
621 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
622 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
623 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
624 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
625 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
626 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
627 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
628 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
629 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
630 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
631 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
632 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
633 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
634 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
635 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
636 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
637 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
638 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
639 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
640 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
641 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
642 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
643 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
644 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
645 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
646 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
647 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
648 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
649 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
650 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
651 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
652 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
653 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
654 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
655 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
656 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
657 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
658 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
659 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
660 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
661 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
662 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
663 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
664 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
665 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
666 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
667 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
668 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
669 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
670 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
671 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
672 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
673 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
674 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
675 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
676 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
677 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
678 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
679 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
680 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
681 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
682 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
683 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
684 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
685 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
686 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
687 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
688 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
689 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
690 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
691 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
692 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
693 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
694 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
695 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
696 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
697 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
698 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
699 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
700 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
701 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
702 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
703 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
704 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
705 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
706 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
707 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
708 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
709 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
710 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
711 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
712 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
713 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
714 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
715 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
716 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
717 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
718 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
719 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
720 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
721 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
722 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
723 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
724 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
725 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
726 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
727 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
728 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
729 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
730 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
731 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
732 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
733 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
734 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
735 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
736 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
737 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
738 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
739 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
740 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
741 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
742 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
743 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
744 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
745 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
746 | 28/02/2015 14:43:07 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
747 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
748 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
749 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
750 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
751 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
752 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
753 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
754 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
755 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
756 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
757 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
758 | 28/02/2015 14:43:07 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
759 | 28/02/2015 14:43:07 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
760 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
761 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
762 | 28/02/2015 14:43:07 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
763 | 28/02/2015 14:43:08 | IRP_MJ_WRITE | DOWN | STATUS_SUCCESS | | | | 1 | COM7 |
764 | 28/02/2015 14:43:08 | IRP_MJ_WRITE | UP | STATUS_SUCCESS | 3f | ? | 1 | | COM7 |
765 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
766 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
767 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
768 | 28/02/2015 14:43:08 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
769 | 28/02/2015 14:43:08 | IRP_MJ_READ | UP | STATUS_SUCCESS | 3c 49 64 6c 65 2c 4d 50 6f 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 2c 57 50 6f | <Idle,MPos:0.000,0.000,0.000,WPo | 32 | | COM7 |
770 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
771 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_SUCCESS | 01 00 00 00 | .... | 4 | | COM7 |
772 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | DOWN | STATUS_SUCCESS | | | | | COM7 |
773 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
774 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
775 | 28/02/2015 14:43:08 | IRP_MJ_READ | DOWN | STATUS_SUCCESS | | | | 1024 | COM7 |
776 | 28/02/2015 14:43:08 | IRP_MJ_READ | UP | STATUS_SUCCESS | 73 3a 30 2e 30 30 30 2c 30 2e 30 30 30 2c 30 2e 30 30 30 3e 0d 0a | s:0.000,0.000,0.000>.. | 22 | | COM7 |
777 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | DOWN | STATUS_SUCCESS | | | | | COM7 |
778 | 28/02/2015 14:43:08 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS) | UP | STATUS_SUCCESS | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | .................... | 20 | | COM7 |
779 | 28/02/2015 14:48:46 | IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK) | UP | STATUS_CANCELLED | | | | | COM7 |
780 | 28/02/2015 14:48:46 | IRP_MJ_CLOSE | DOWN | STATUS_SUCCESS | | | | | COM7 |
781 | 28/02/2015 14:48:46 | IRP_MJ_CLOSE | UP | STATUS_SUCCESS | | | | | COM7 |
