;***** STK500 LEDS and SWITCH demonstration .include "8515def.inc" .def Temp=r16 ; Temporary register .def Delay=r17 ; Delay variable 1 .def Delay2=r18 ; Delay variable 2 ;***** Initialization RESET: ser Temp out DDRB,Temp ; Set PORTB to output ;**** Test input/output LOOP: out PORTB,temp ; Update LEDS sbis PIND,0x00 ; If (Port D, pin0 == 0) inc Temp ; then count LEDS one down sbis PIND,0x01 ; If (Port D, pin1 == 0) dec Temp ; then count LEDS one up sbis PIND,0x02 ; If (Port D, pin2 == 0) ror Temp ; then rotate LEDS one right sbis PIND,0x03 ; If (Port D, pin3 == 0) rol Temp ; then rotate LEDS one left sbis PIND,0x04 ; If (Port D, pin4 == 0) com Temp ; then invert all LEDS sbis PIND,0x05 ; If (Port D, pin5 == 0) neg Temp ; then invert all LEDS and ad sbis PIND,0x06 ; If (Port D, pin6 == 0) swap Temp ; then swap nibbles of LEDS ;**** Now wait a while to make LED changes visible. DLY: dec Delay brne DLY dec Delay2 brne DLY rjmp LOOP ; Repeat loop forever
