Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_i2c.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_i2c.c -quiet -dumpbase stm32f37x_i2c.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_i2c.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/cciYxPUB.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_i2c.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_i2c.lst -o obj/stm32f37x_i2c.o /tmp/cciYxPUB.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_iwdg.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_i2c.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_iwdg.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_iwdg.c -quiet -dumpbase stm32f37x_iwdg.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_iwdg.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccboQ9iO.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_iwdg.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_iwdg.lst -o obj/stm32f37x_iwdg.o /tmp/ccboQ9iO.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_misc.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_iwdg.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_misc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_misc.c -quiet -dumpbase stm32f37x_misc.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_misc.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/cciX1FmV.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_misc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_misc.lst -o obj/stm32f37x_misc.o /tmp/cciX1FmV.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_pwr.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_misc.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_pwr.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_pwr.c -quiet -dumpbase stm32f37x_pwr.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_pwr.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/cceGrEv2.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_pwr.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_pwr.lst -o obj/stm32f37x_pwr.o /tmp/cceGrEv2.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_rcc.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_pwr.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_rcc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_rcc.c -quiet -dumpbase stm32f37x_rcc.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_rcc.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccJJgcFc.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_rcc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_rcc.lst -o obj/stm32f37x_rcc.o /tmp/ccJJgcFc.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_rtc.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_rcc.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_rtc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_rtc.c -quiet -dumpbase stm32f37x_rtc.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_rtc.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccpk643e.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_rtc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_rtc.lst -o obj/stm32f37x_rtc.o /tmp/ccpk643e.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_sdadc.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_rtc.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_sdadc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_sdadc.c -quiet -dumpbase stm32f37x_sdadc.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_sdadc.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccgQ5HXK.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_sdadc.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_sdadc.lst -o obj/stm32f37x_sdadc.o /tmp/ccgQ5HXK.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_spi.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_sdadc.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_spi.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_spi.c -quiet -dumpbase stm32f37x_spi.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_spi.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/cczWl67Y.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_spi.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_spi.lst -o obj/stm32f37x_spi.o /tmp/cczWl67Y.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_syscfg.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_spi.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_syscfg.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_syscfg.c -quiet -dumpbase stm32f37x_syscfg.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_syscfg.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccaiKU3c.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_syscfg.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_syscfg.lst -o obj/stm32f37x_syscfg.o /tmp/ccaiKU3c.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_tim.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_syscfg.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_tim.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_tim.c -quiet -dumpbase stm32f37x_tim.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_tim.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccvHlYEk.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_tim.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_tim.lst -o obj/stm32f37x_tim.o /tmp/ccvHlYEk.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_usart.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_tim.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_usart.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_usart.c -quiet -dumpbase stm32f37x_usart.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_usart.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccBNTjVJ.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_usart.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_usart.lst -o obj/stm32f37x_usart.o /tmp/ccBNTjVJ.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [stm32f37x_wwdg.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_usart.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_wwdg.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/src/stm32f37x_wwdg.c -quiet -dumpbase stm32f37x_wwdg.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/stm32f37x_wwdg.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/ccehBMK6.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_wwdg.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/stm32f37x_wwdg.lst -o obj/stm32f37x_wwdg.o /tmp/ccehBMK6.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ +++ Compiling [system_stm32f37x.c] COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/stm32f37x_wwdg.o' Using built-in specs. COLLECT_GCC=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc Target: arm-none-eabi Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-native --libexecdir=/home/build/work/GCC-4-9-build/install-native/lib --infodir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-native/arm-none-eabi --build=i686-linux-gnu --host=i686-linux-gnu --with-gmp=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r Thread model: single gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (GNU Tools for ARM Embedded Processors) COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/system_stm32f37x.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1 -quiet -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -imultilib armv7e-m/fpu -iprefix /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/ -isysroot /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi -D__USES_INITFINI__ -D inline= -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -D USE_STDPERIPH_DRIVER -D HSE_VALUE=8000000 -D STM32F4XX -D GCC_ARMCM3 -D VECT_TAB_OFFSET=0x0000 /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Source/Templates/system_stm32f37x.c -quiet -dumpbase system_stm32f37x.c -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -auxbase-strip obj/system_stm32f37x.o -g -O1 -Wno-main -Wno-attributes -Wno-unused-variable -version -ffunction-sections -fdata-sections -o /tmp/cc91fxNb.s GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/local/include" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed" ignoring duplicate directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include" ignoring nonexistent directory "/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/usr/include" ignoring nonexistent directory "Trace" #include "..." search starts here: #include <...> search starts here: ./ /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include /home/tobias/Projects/fcounter/st-lib/CMSIS/Include /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/include-fixed /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include End of search list. GNU C (GNU Tools for ARM Embedded Processors) version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 224288] (arm-none-eabi) compiled by GNU C version 4.7.4, GMP version 4.3.2, MPFR version 2.4.2, MPC version 0.8.1 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: a5eb70d7ef1fa5d27c0436f543898d16 COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/system_stm32f37x.o' /home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/as -v -I ./ -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include -I /home/tobias/Projects/fcounter/st-lib/CMSIS/Include -I /home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc -I Trace -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -meabi=5 -adhlns=obj/system_stm32f37x.lst -o obj/system_stm32f37x.o /tmp/cc91fxNb.s GNU assembler version 2.24.0 (arm-none-eabi) using BFD version (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 COMPILER_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ LIBRARY_PATH=/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/armv7e-m/fpu/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/:/home/tobias/IDE/gcc-arm-none-eabi-4_9-2015q2/bin/../arm-none-eabi/lib/ COLLECT_GCC_OPTIONS='-g' '-D' 'inline=' '-mthumb' '-mcpu=cortex-m4' '-O1' '-T' 'STM32_FLASH.ld' '-D' 'PACK_STRUCT_END=__attribute((packed))' '-Wno-main' '-D' 'ALIGN_STRUCT_END=__attribute((aligned(4)))' '-ffunction-sections' '-fdata-sections' '-I' './' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Device/ST/STM32F37x/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/CMSIS/Include' '-I' '/home/tobias/Projects/fcounter/st-lib/STM32F37x_StdPeriph_Driver/inc' '-I' 'Trace' '-D' 'USE_STDPERIPH_DRIVER' '-D' 'HSE_VALUE=8000000' '-D' 'STM32F4XX' '-D' 'GCC_ARMCM3' '-D' 'VECT_TAB_OFFSET=0x0000' '-Wno-attributes' '-mfloat-abi=hard' '-mfpu=fpv4-sp-d16' '-Wno-unused-variable' '-v' '-c' '-o' 'obj/system_stm32f37x.o' +++ Linking [fcounter.elf] +++ Summary of memory consumption: text data bss dec hex filename 27392 2260 1892 31544 7b38 bin/fcounter.elf +++ Build complete [fcounter.srec]
