Hi all i listed all programs and hardwares what need to run Motorola VIP19xx ---list---- Programs 1.putty http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html 2.windows logclient http://www.mikrocontroller.net/attachment/175928/http_example.rar 3.TFTP http://tftpd32.jounin.net/ 4.VLC(for capture Motorola VIP19xx output) http://www.videolan.org/vlc/index.html 5.firmware(OS) http://www.mikrocontroller.net/attachment/253812/kreatv-bi-eval_4.3.IAP30.3_st40_vip19x3.bin 6.TVportal http://www.mikrocontroller.net/attachment/162036/TVportal.tar.gz 7.HFS http://www.rejetto.com/hfs/ Hardware 1.PC 2.Display PC-output 3.Motorola VIP19xx 4.Display Motorola VIP19xx output(TV or Easycap) 5.RJ-45 cables 6.Router/switch Display: 1.PC -> Display PC-output(HMDI/DVI) 2.Motorola VIP19xx -> Display Motorola VIP19xx output(multiple displayoutput) 2.1.TV(scart/video[yellow]) 2.2.Monitor(HMDI) 2.3.Easycap(USB->Video[yellow]->Scart) RJ-45 cables 1.PC -> Router/switch 2.Router/switch -> Motorola VIP19xx 3.Router/switch(WAN) -> ADSL/3g-router ¤for internet ---list---- ---setups----- Motorola VIP19xx setup: 1.VLC or watch tv/monitor Motorola VIP19xx-output 2.press remote contorl "Menu" 3.press code [7532] Advanced 4.goto Advanced with remote contorl usage 5.Set Slash/Kernel Protocol to 323 6.goto System-> Remove Software(OLD)->ask permission remove firmware->press yes 7.goto Exit-> Save and reboot 8.now router checking if PC has FW so loop called PC setup: 1.check all cables are connected 2.startup tftp 3.GLOBAL ->[x]TFTP Server and [x]DHCP Server 4.TFTP ->Bind TFTP to this address choice PC ip-address 5.1DHCP ->IP pool starting address[192.168.2.200] 5.2.DHCP ->Size of pool[10] 5.3.DHCP ->Boot File[kreatv-bi-vdr.config_4.3.IAP30.3_st40_vip19x3.bin] put same folder as TFTP 5.4.DHCP ->WINS/DNS server[empty] for internet if need 5.5.DHCP ->Default router[empty] for internet if need 5.6.DHCP ->Mask[255.255.255.0] 6.OK cloce TFTP program 7.restart it 8.wait when motorola boot file Kernel setup: 1.run logclient.exe 192.168.2.200 2.run putty -telnet 192.168.2.200 3.vi /usr/applications/ekioh/ekioh.cfg 5.export portal=192.168.2.131 4.add line application.homepage:http://$portal 5.killall ekioh portal setup: 1.download TVportal and HFS 2.run HFS 3.open file index.html and put back.js and channels.js to one file. 4.change var ServerAdres = "http://192.168.2.131:8080/" //youtube,netflix,etc 5.change var channels = ["channels","test.mpg","test2.mpg"];//channel path 6.save and close file index.html 7.drag and drop index.html to HFS 8.now press remote control up button so channel goes up VLC setup: 1.open VLC 2.CTRL-S(Stream) 3.File->choice what you want to watch->Add 4.Stream 5.Destination Setup 6.port 8080 7.path:"/test.mpg" 8.Profile video-MPEG-2+MPGA(TS) 9.Stream 10.Enjoy ---setups----- Writed by claude
