Stand: v1.7.2 Ps Numerischer, optionaler Parameter. bestehend aus einer oder mehrerer Ziffern. Pm Durch ; getrennte Folge von numerischen Parametern Ps. Control characters ------------------ BEL Generates bell tone. BS Moves cursor to the left one character position; if cursor is at left margin, no action occurs. HT Moves cursor to next tab stop, or to right margin if there are no more tab stops. CR Moves cursor to left margin on current line. LF Causes a linefeed. VT Processed as LF. FF Processed as LF. SO Invoke G1 character set. SI Invoke G0 character set. (default) CAN If received during an escape or control sequence, cancels the sequence. SUB Processed as CAN. ESC Processed as a sequence introducer. Escape sequences ---------------- ESC D IND Linefeed. ESC E NEL Newline. ESC M RI Reverse linefeed. (Curser up) ESC Z DECID DEC private identification. The terminal returns ESC [ ? 6 c, claiming that it is a VT102. ESC c RIS Reset to Initial State (Power Up) ESC ( A SCS Select Character Set UK --> G0 ESC ( B SCS Select Character Set US ASCII --> G0 ESC ( 0 SCS Select Character Set DEC special characters and line drawing set --> G0 ESC ) A SCS Select Character Set UK --> G1 ESC ) B SCS Select Character Set US ASCII --> G1 ESC ) 0 SCS Select Character Set DEC special characters and line drawing set --> G1 ESC 7 DECSC Save current state (cursor coordinates, attributes, character sets pointed at by G0, G1). ESC 8 DECRC Restore state most recently saved by ESC 7. ESC # 8 DECALN DEC screen alignment test - fill screen with E's. ESC # 9 Show Font (Debug) Control sequences ----------------- ESC [ Ps @ ICH Insert Ps blank characters (defaut = 1) (VT220) ESC [ Ps A CUU Move cursor up ESC [ Ps B CUD Move cursor down ESC [ Ps C CUF Move cursor right ESC [ Ps D CUB Move cursor left ESC [ Ps ; Ps H CUP Move cursor to [row; column] (default = [1,1]) ESC [ Ps J ED Erase in Display Ps = 0 Erase below (default) Ps = 1 Erase above Ps = 2 Erase all ESC [ Ps K EL Erase in line PS = 0 EL Erase to right (default) PS = 1 EL Erase to left PS = 2 EL Erase all ESC [ Ps L IL Insert Ps lines (defaut = 1) ESC [ Ps M DL Delete Ps lines (defaut = 1) ESC [ Ps P DCH Delete Ps characters (defaut = 1) ESC [ Ps X ECH Erase Ps characters (defaut = 1) (VT220) ESC [ Ps c DA Send device attributes PS = 0 or ommitted Request attributes from terminal Answer ESC [ ? 6 c: "I am a VT102") ESC [ Ps ; Ps f HVP Move cursor to [row; column] (default = [1,1]) ESC [ Pm h SM Set Mode Ps = 4 IRM Set insert mode ESC [ ? Pm h DECSET DEC Private Set Mode Set PS = 7 DECAWM Set autowrap on (default) PS = 25 DECTECM Cursor visible ESC [ Pm l RM Reset Mode Ps = 4 IRM Set replace mode (default) ESC [ ? Pm l DECRST DEC Private Mode Reset PS = 7 DECAWM Set autowrap off PS = 25 DECTECM Cursor not visible ESC [ Pm m SGR Set character attributes Ps = 0 All attributes off Ps = 1 bold (increased intensity) Ps = 4 underline (simulated with color) Ps = 7 negative (reverse) image Ps = 10 Select font 0 (Debug/experimental) Ps = 11 Select font 1 (Debug/experimental) Ps = 22 bold off (normal intensity) Ps = 24 not underlined Ps = 27 positive image Ps = 30 Set foreground colorto black Ps = 31 Set foreground colorto red Ps = 32 Set foreground colorto green Ps = 33 Set foreground colorto yellow Ps = 34 Set foreground colorto blue Ps = 35 Set foreground colorto magenta Ps = 36 Set foreground colorto cyan Ps = 37 Set foreground colorto white Ps = 40 Set background colorto black Ps = 41 Set background colorto red Ps = 42 Set background colorto green Ps = 43 Set background colorto yellow Ps = 44 Set background colorto blue Ps = 45 Set background colorto magenta Ps = 46 Set background colorto cyan Ps = 47 Set background colorto white ESC [ Ps n DSR Device Status report Ps = 5 DSR Device status report: Answer is ESC [ 0 n (Terminal OK). Ps = 6 CPR Cursor position report: Answer is ESC [ y ; x R
