library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity test3 is port ( clk_i : in std_logic; reset_i : in std_logic; PWD_DN : in std_logic; tx_sync_o : out std_logic; o: out std_logic_vector(5 downto 0)); end test3; architecture test_arch of test3 is signal Input0 : std_logic_vector(5 downto 0); signal Input1 : std_logic_vector(5 downto 0); begin Input0 <= "000000"; Input1 <= "000000"; process(clk_i) begin if (clk_i'event and clk_i = '0') then -- fallende Taktflanke if reset_i = '0' then O <= Input0 + Input1; --else --o <= "000000"; --o <= "101101"; end if; end if; end process; end test_arch;
