#include // Alphanumeric LCD Module functions #asm .equ __lcd_port=0x12 #endasm #include #define ADC_VREF_TYPE 0x00 // Read the AD conversion result unsigned int read_adc(unsigned char adc_input) { ADMUX=adc_input|ADC_VREF_TYPE; // Start the AD conversion ADCSRA|=0x40; // Wait for the AD conversion to complete while ((ADCSRA & 0x10)==0); ADCSRA|=0x10; return ADCW; } // Declare your global variables here int i,t_ein,t_aus,counter,wert; void main(void) { // Declare your local variables here // Input/Output Ports initialization // Port A initialization // Func0=In Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In // State0=T State1=T State2=T State3=T State4=T State5=T State6=T State7=T PORTA=0x00; DDRA=0x00; // Port B initialization // Func0=In Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In // State0=T State1=T State2=T State3=T State4=T State5=T State6=T State7=T PORTB=0x00; DDRB=0x00; // Port C initialization // Func0=Out Func1=Out Func2=Out Func3=Out Func4=Out Func5=Out Func6=Out Func7=Out // State0=0 State1=0 State2=0 State3=0 State4=0 State5=0 State6=0 State7=0 PORTC=0x00; DDRC=0xFF; // Port D initialization // Func0=In Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In // State0=T State1=T State2=T State3=T State4=T State5=T State6=T State7=T PORTD=0x00; DDRD=0x00; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=FFh // OC0 output: Disconnected TCCR0=0x00; TCNT0=0x00; OCR0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer 1 Stopped // Mode: Normal top=FFFFh // OC1A output: Discon. // OC1B output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer 2 Stopped // Mode: Normal top=FFh // OC2 output: Disconnected ASSR=0x00; TCCR2=0x00; TCNT2=0x00; OCR2=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off // INT2: Off GICR|=0x00; MCUCR=0x00; MCUCSR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off // Analog Comparator Output: Off ACSR=0x80; SFIOR=0x00; // ADC initialization // ADC Clock frequency: 135,781 kHz // ADC Voltage Reference: AREF pin // ADC High Speed Mode: Off // ADC Auto Trigger Source: None ADMUX=ADC_VREF_TYPE; ADCSRA=0x86; SFIOR&=0xEF; // LCD module initialization //lcd_init(16); t_ein = 500; t_aus = 500; counter = 0; PORTC.0=1; wert=read_adc(0); while (1) { // Place your code here PORTC.0 = 0; for (i=0;i=10) { counter = 0; if(t_ein<1000) { t_ein++; t_aus--; } else { t_ein=0; t_aus=1000; } } } }
