14:43:40 --------- 14:43:40 01.07.16 Start program V3.0.16609-64 14:43:40 IDE: Lazarus LCL 1.4.4.0, Free Pascal FPC 2.6.4, Zeos 7.1.4-stable 14:43:40 Compile: 09.Jun.2016 10:26:48 SVN: 70M 14:43:40 Use INI file: C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\EleLa.ini 14:43:40 Parameter [DB] Protocol=mysql-5 14:43:40 Parameter [DB] HostName=codebase2.mpic.de 14:43:40 Parameter [DB] Port=3306 14:43:40 Parameter [DB] Database=elela 14:43:40 Parameter [DB] User=root 14:43:40 Parameter [DB] Password=***** 14:43:40 Error dir not found: Parameter [Programm] VorlageDir 14:43:40 Parameter [Programm] TempDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\ 14:43:40 Error: Path not Exists: Parameter [Programm] TableFile=Tables.txt 14:43:40 Parameter [Bauteil] DefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Handbuch 14:43:40 Parameter [Projekt] DefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Projekt 14:43:40 Parameter [Projekt] GeraetDefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Gerät 14:43:40 Parameter [Projekt] DokuDefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Doku 14:43:40 Connect database... 14:43:40 DB.Version: SQLite-DLL: 3.8.8.1 / MySQL: 5.7.12-0ubuntu1.1 14:43:40 Database Version: V2.2.13C01 14:43:40 Do Update 54 from Database. 14:43:40 RenameField (bauteillager,Menge,Menge,DOUBLE) 14:43:44 Error: Database-Update Nr. 54 error! Make the update manually. 14:43:44 SQL: ALTER IGNORE TABLE `bauteillager` CHANGE `Menge` `Menge` DOUBLE NULL DEFAULT NULL 14:45:25 --------- 14:45:25 01.07.16 Start program V3.0.16609-64 14:45:25 IDE: Lazarus LCL 1.4.4.0, Free Pascal FPC 2.6.4, Zeos 7.1.4-stable 14:45:25 Compile: 09.Jun.2016 10:26:48 SVN: 70M 14:45:25 Use INI file: C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\EleLa.ini 14:45:25 Parameter [DB] Protocol=mysql-5 14:45:25 Parameter [DB] HostName=codebase2.mpic.de 14:45:25 Parameter [DB] Port=3306 14:45:25 Parameter [DB] Database=elela 14:45:25 Parameter [DB] User=root 14:45:25 Parameter [DB] Password=***** 14:45:25 Error dir not found: Parameter [Programm] VorlageDir 14:45:25 Parameter [Programm] TempDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\ 14:45:25 Error: Path not Exists: Parameter [Programm] TableFile=Tables.txt 14:45:25 Parameter [Bauteil] DefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Handbuch 14:45:25 Parameter [Projekt] DefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Projekt 14:45:25 Parameter [Projekt] GeraetDefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Gerät 14:45:25 Parameter [Projekt] DokuDefHandbuchDir=C:\Users\rudolf\Downloads\EleLa_V3.0.16609_Win64\Doku 14:45:25 Connect database... 14:45:25 DB.Version: SQLite-DLL: 3.8.8.1 / MySQL: 5.7.12-0ubuntu1.1 14:45:25 Database Version: V2.2.13C01 14:45:25 Do Update 54 from Database. 14:45:25 RenameField (bauteillager,Menge,Menge,DOUBLE) 14:45:30 Error: Database-Update Nr. 54 error! Make the update manually. 14:45:30 SQL: ALTER IGNORE TABLE `bauteillager` CHANGE `Menge` `Menge` DOUBLE NULL DEFAULT NULL
