KiCAD HTML-BOM Generator 16.07 by DI Klaus Weichinger snaky.1@gmx.at
Created:Sam 23 Jul 2016 22:06:48 CEST
Rev:16.07
Company:Firma
Source:projekt.sch
File:......projekt.sch
Count | Value | REFs | Footprint |
23 | 100nF | C1, C5, C4, C25, C16, C11, C17, C21, C27, C12, C18, C22, C28, C13, C19, C23, C29, C14, C20, C24, C30, C32, C31 | Capacitors_SMD:C_0805 |
1 | 10nF | C10 | Capacitors_SMD:C_0805 |
2 | 100uF | C26, C15 | Capacitors_SMD:c_elec_8x10.5 |
4 | 22pF | C6, C2, C3, C8 | Capacitors_SMD:C_0805 |
2 | 220pF...1nF | C7, C9 | Capacitors_SMD:C_0805 |
1 | RED | D1 | LEDs:LED-3MM |
1 | GRUEN | D2 | LEDs:LED-3MM |
9 | S1M | D3, D4, D8, D5, D9, D6, D10, D7, D11 | Diodes_SMD:SMA_Standard |
1 | ATMEGA8A-A | IC1 | Housings_QFP:TQFP-32_7x7mm_Pitch0.8mm |
2 | CONN_01X11 | P2, P1 | Pin_Headers:Pin_Header_Angled_1x11 |
1 | CONN_01X11 | P3 | Pin_Headers:Pin_Header_Straight_1x11 |
10 | BC847C | Q1, Q2, Q3, Q7, Q4, Q8, Q5, Q9, Q6, Q10 | TO_SOT_Packages_SMD:SOT-23 |
11 | d.n.p. | R1, R8, R22, R48, R23, R49, R24, R50, R25, R51, R34 | Resistors_SMD:R_0805 |
3 | 0R | R12, R9, R35 | Resistors_SMD:R_0805 |
10 | 1k | R15, R14, R37, R61, R39, R63, R41, R65, R43, R67 | Resistors_SMD:R_0805 |
1 | Rsens | R16 | Pin_Headers:Pin_Header_Straight_1x02 |
1 | 1M | R2 | Resistors_SMD:R_0805 |
2 | 4k7 | R3, R10 | Resistors_SMD:R_0805 |
8 | 33k | R30, R56, R31, R57, R32, R58, R33, R59 | Resistors_SMD:R_0805 |
8 | 220R | R36, R60, R38, R62, R40, R64, R42, R66 | Resistors_SMD:R_0805 |
20 | 10k | R5, R4, R11, R17, R18, R26, R44, R52, R19, R27, R45, R53, R20, R28, R46, R54, R21, R29, R47, R55 | Resistors_SMD:R_0805 |
2 | 3k3 | R6, R13 | Resistors_SMD:R_0805 |
1 | 470R | R7 | Resistors_SMD:R_0805 |
1 | MC78M05CDT | U1 | TO_SOT_Packages_SMD:TO-252-2Lead |
4 | Hole 3mm | U2, U5, U3, U4 | Mounting_Holes:MountingHole_3-5mm |
1 | 16MHz | Y1 | Crystals:Crystal_HC49-SD_SMD |
Value | REF | Footprint |
100nF | C1 | Capacitors_SMD:C_0805 |
100nF | C11 | Capacitors_SMD:C_0805 |
100nF | C12 | Capacitors_SMD:C_0805 |
100nF | C13 | Capacitors_SMD:C_0805 |
100nF | C14 | Capacitors_SMD:C_0805 |
100uF | C15 | Capacitors_SMD:c_elec_8x10.5 |
100nF | C16 | Capacitors_SMD:C_0805 |
100nF | C17 | Capacitors_SMD:C_0805 |
100nF | C18 | Capacitors_SMD:C_0805 |
100nF | C19 | Capacitors_SMD:C_0805 |
22pF | C2 | Capacitors_SMD:C_0805 |
100nF | C20 | Capacitors_SMD:C_0805 |
100nF | C21 | Capacitors_SMD:C_0805 |
100nF | C22 | Capacitors_SMD:C_0805 |
100nF | C23 | Capacitors_SMD:C_0805 |
100nF | C24 | Capacitors_SMD:C_0805 |
100nF | C25 | Capacitors_SMD:C_0805 |
100uF | C26 | Capacitors_SMD:c_elec_8x10.5 |
100nF | C27 | Capacitors_SMD:C_0805 |
100nF | C28 | Capacitors_SMD:C_0805 |
100nF | C29 | Capacitors_SMD:C_0805 |
22pF | C3 | Capacitors_SMD:C_0805 |
100nF | C30 | Capacitors_SMD:C_0805 |
100nF | C31 | Capacitors_SMD:C_0805 |
100nF | C32 | Capacitors_SMD:C_0805 |
100nF | C4 | Capacitors_SMD:C_0805 |
100nF | C5 | Capacitors_SMD:C_0805 |
22pF | C6 | Capacitors_SMD:C_0805 |
220pF...1nF | C7 | Capacitors_SMD:C_0805 |
22pF | C8 | Capacitors_SMD:C_0805 |
220pF...1nF | C9 | Capacitors_SMD:C_0805 |
S1M | D10 | Diodes_SMD:SMA_Standard |
S1M | D11 | Diodes_SMD:SMA_Standard |
S1M | D3 | Diodes_SMD:SMA_Standard |
S1M | D4 | Diodes_SMD:SMA_Standard |
S1M | D5 | Diodes_SMD:SMA_Standard |
S1M | D6 | Diodes_SMD:SMA_Standard |
S1M | D7 | Diodes_SMD:SMA_Standard |
S1M | D8 | Diodes_SMD:SMA_Standard |
S1M | D9 | Diodes_SMD:SMA_Standard |
CONN_01X11 | P1 | Pin_Headers:Pin_Header_Angled_1x11 |
CONN_01X11 | P2 | Pin_Headers:Pin_Header_Angled_1x11 |
BC847C | Q1 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q10 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q2 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q3 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q4 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q5 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q6 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q7 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q8 | TO_SOT_Packages_SMD:SOT-23 |
BC847C | Q9 | TO_SOT_Packages_SMD:SOT-23 |
d.n.p. | R1 | Resistors_SMD:R_0805 |
4k7 | R10 | Resistors_SMD:R_0805 |
10k | R11 | Resistors_SMD:R_0805 |
0R | R12 | Resistors_SMD:R_0805 |
3k3 | R13 | Resistors_SMD:R_0805 |
1k | R14 | Resistors_SMD:R_0805 |
1k | R15 | Resistors_SMD:R_0805 |
10k | R17 | Resistors_SMD:R_0805 |
10k | R18 | Resistors_SMD:R_0805 |
10k | R19 | Resistors_SMD:R_0805 |
10k | R20 | Resistors_SMD:R_0805 |
10k | R21 | Resistors_SMD:R_0805 |
d.n.p. | R22 | Resistors_SMD:R_0805 |
d.n.p. | R23 | Resistors_SMD:R_0805 |
d.n.p. | R24 | Resistors_SMD:R_0805 |
d.n.p. | R25 | Resistors_SMD:R_0805 |
10k | R26 | Resistors_SMD:R_0805 |
10k | R27 | Resistors_SMD:R_0805 |
10k | R28 | Resistors_SMD:R_0805 |
10k | R29 | Resistors_SMD:R_0805 |
4k7 | R3 | Resistors_SMD:R_0805 |
33k | R30 | Resistors_SMD:R_0805 |
33k | R31 | Resistors_SMD:R_0805 |
33k | R32 | Resistors_SMD:R_0805 |
33k | R33 | Resistors_SMD:R_0805 |
d.n.p. | R34 | Resistors_SMD:R_0805 |
0R | R35 | Resistors_SMD:R_0805 |
220R | R36 | Resistors_SMD:R_0805 |
1k | R37 | Resistors_SMD:R_0805 |
220R | R38 | Resistors_SMD:R_0805 |
1k | R39 | Resistors_SMD:R_0805 |
10k | R4 | Resistors_SMD:R_0805 |
220R | R40 | Resistors_SMD:R_0805 |
1k | R41 | Resistors_SMD:R_0805 |
220R | R42 | Resistors_SMD:R_0805 |
1k | R43 | Resistors_SMD:R_0805 |
10k | R44 | Resistors_SMD:R_0805 |
10k | R45 | Resistors_SMD:R_0805 |
10k | R46 | Resistors_SMD:R_0805 |
10k | R47 | Resistors_SMD:R_0805 |
d.n.p. | R48 | Resistors_SMD:R_0805 |
d.n.p. | R49 | Resistors_SMD:R_0805 |
10k | R5 | Resistors_SMD:R_0805 |
d.n.p. | R50 | Resistors_SMD:R_0805 |
d.n.p. | R51 | Resistors_SMD:R_0805 |
10k | R52 | Resistors_SMD:R_0805 |
10k | R53 | Resistors_SMD:R_0805 |
10k | R54 | Resistors_SMD:R_0805 |
10k | R55 | Resistors_SMD:R_0805 |
33k | R56 | Resistors_SMD:R_0805 |
33k | R57 | Resistors_SMD:R_0805 |
33k | R58 | Resistors_SMD:R_0805 |
33k | R59 | Resistors_SMD:R_0805 |
3k3 | R6 | Resistors_SMD:R_0805 |
220R | R60 | Resistors_SMD:R_0805 |
1k | R61 | Resistors_SMD:R_0805 |
220R | R62 | Resistors_SMD:R_0805 |
1k | R63 | Resistors_SMD:R_0805 |
220R | R64 | Resistors_SMD:R_0805 |
1k | R65 | Resistors_SMD:R_0805 |
220R | R66 | Resistors_SMD:R_0805 |
1k | R67 | Resistors_SMD:R_0805 |
d.n.p. | R8 | Resistors_SMD:R_0805 |
0R | R9 | Resistors_SMD:R_0805 |
Hole 3mm | U2 | Mounting_Holes:MountingHole_3-5mm |
Hole 3mm | U3 | Mounting_Holes:MountingHole_3-5mm |
Hole 3mm | U4 | Mounting_Holes:MountingHole_3-5mm |
Hole 3mm | U5 | Mounting_Holes:MountingHole_3-5mm |
