TOSHIBA DOT MATRIX LCD MODULE TLX-711A TLX-711A-E0 TLX-711A and TLX-711A-E0 are 240x64 dots graphic LCD modules including an LCD controller, a display RAM, an EL backlight (TLX-711-E0) and driver circuit. These modules are suitable for copiers, facsimilies, PBXs, marine instruments, and a message display for various instruments. +----------------------------------------+ | TOSHIBA DOT MATRIX LCD MODULE | | | | ***** TLX-711A ***** | | | | >GRAPHICS DISPLAY : 240X64 DOT | | >CHARACTER DISPLAY : 40Chara.X 8 Lines| | *BUILT-IN LCD CONTROLLER T6963C | | *BUILT-IN DISPLAY RAM 8k Byte | +----------------------------------------+ FEATURES (1) Excellent readability and high contrast ratio. (2) 8-bit parallel bus for read/write data from CPU interface. (3) Built-in LCD controller T6963C and display RAM (8k byte). (4) Large graphic display for 240x64 dots. (5) Various attribute functons. (6) Built-in 128 words character generator ROM and 128 words character generator RAM, or 256 words character generator RAM. (7) Built-in EL backlight (TLX-711A-E0). (8) Wide operating temperature range (0 to 50C). (9) Compact and easily mountable on any equipment. 3. Interface 3.1 Interface Connection +-------+--------+------------------------------------------------------+ |Pin No.| Signal | Function | +-------+--------+------------------------------------------------------+ | 1 | FGND | Frame Ground (Connected to Metal Bezel) | +-------+--------+------------------------------------------------------+ | 2 | GND | Ground (Signal Ground) | +-------+--------+------------------------------------------------------+ | 3 | Vdd | Power Supply for Logic | +-------+--------+------------------------------------------------------+ | 4 | Vee | Power Supply for LCD Drive (Should be Variable) | +-------+--------+------------------------------------------------------+ | 5 | ~WR | Data Write (Write Data to the Module at "L") | +-------+--------+------------------------------------------------------+ | 6 | ~RD | Data Read (Read Data from the Module at "L") | +-------+--------+------------------------------------------------------+ | 7 | ~CE | Chip Enable for the Module (negiert) | +-------+--------+------------------------------------------------------+ | 8 | C/~D | ~WR="L"; C/~D="H":Command Write, C/~D="L":Data Write | | | | ~RD="L"; C/~D="H":Status Read , C/~D="L":Data Read | +-------+--------+------------------------------------------------------+ | 9 | NC | No Connection | +-------+--------+------------------------------------------------------+ | 10 | ~RESET | Module Reset (Controller Reset) | +-------+--------+------------------------------------------------------+ | 11 | D0 | Data Input/Output (LSB) | +-------+--------+------------------------------------------------------+ | 12 | D1 | Data Input/Output | +-------+--------+------------------------------------------------------+ | 13 | D2 | Data Input/Output | +-------+--------+------------------------------------------------------+ | 14 | D3 | Data Input/Output | +-------+--------+------------------------------------------------------+ | 15 | D4 | Data Input/Output | +-------+--------+------------------------------------------------------+ | 16 | D5 | Data Input/Output | +-------+--------+------------------------------------------------------+ | 17 | D6 | Data Input/Output | +-------+--------+------------------------------------------------------+ | 18 | D7 | Data Input/Output (MSB) | +-------+--------+------------------------------------------------------+ | 19 | FS | Font Select:Open or Connect to Vdd: 6 x 8 dot fonts | | | | Connect to GND: 8 x 8 dot fonts | +-------+--------+------------------------------------------------------+ | 20 | NC | No Connection | +-------+--------+------------------------------------------------------+ | 21 | Vel | Power Supply for EL Drive (only for TLX-711A-E0) | +-------+--------+------------------------------------------------------+ | 22 | Velg | Power Supply for EL Drive (only for TLX-711A-E0) | +-------+--------+------------------------------------------------------+
