ATMEL DataFlash LOADER VER 1.02 Aug 21 2008 18:04:03 *--------------------------------------* DataFlash[5Mhz]:AT45DB642 Nb pages: 8192 Page Size: 1056 Size= 8650752 bytes Logical address: 0xC0000000 *--------------------------------------* 1: Download Dataflash [addr] 2: Read Dataflash [addr] 3: Start UBOOT [C0008000 => 21F00000] *--------------------------------------* Enter: Load UBOOT from dataflash[c0008000] to SDRAM[21f00000] PLLA[180MHz], MCK[60Mhz] ==> Start UBOOTÿ U-Boot 1.0.0 (Aug 22 2008 - 09:00:35) U-Boot code: 21F00000 -> 21F14BF0 BSS: -> 21F185C8 DRAM Configuration: Bank #0: 20000000 32 MB Atmel: AT49BV1614 (16Mbit) Flash: 2 MB DataFlash:AT45DB642 Nb pages: 8192 Page Size: 1056 Size= 8650752 bytes Logical address: 0xC0000000 Area 0: C0000000 to C0007FFF (RO) Area 1: C0008000 to C001FFFF (RO) Area 2: C0020000 to C0027FFF Area 3: C0028000 to C083FFFF In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 ## Booting image at 21000000 ... Image Name: Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 601255 Bytes = 587.2 kB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Eth_Init Starting kernel ... Linux version 2.4.27-vrs1 (root@rd3) (gcc version 2.95.3 20010315 (release)) #34 Èý 1ÔÂ 2 11:22:54 HKT 2008 CPU: Arm920Tid(wb) revision 0 Machine: ATMEL AT91RM9200 On node 0 totalpages: 8192 zone(0): 8192 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/ram rw initrd=0x21100000,6000000 ramdisk_size=15360 console=ttyS0,115200,mem=32M Calibrating delay loop... 89.70 BogoMIPS Memory: 32MB = 32MB total Memory: 25080KB available (1153K code, 229K data, 56K init) Dentry cache hash table entries: 4096 (order: 3, 32768 bytes) Inode cache hash table entries: 2048 (order: 2, 16384 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 8192 (order: 3, 32768 bytes) CPU: Testing write buffer: pass POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x1 JFFS version 1.0, (C) 1999, 2000 Axis Communications AB Starting USB Keyboard Driver... Done RAMDISK driver initialized: 16 RAM disks of 15360K size 1024 blocksize ttyS%d0 at MMIO 0xfefff200 (irq = 1) is a AT91_SERIAL ttyS%d1 at MMIO 0xfefc4000 (irq = 7) is a AT91_SERIAL ttyS%d2 at MMIO 0xfefc0000 (irq = 6) is a AT91_SERIAL ttyS%d3 at MMIO 0xfefc8000 (irq = 8) is a AT91_SERIAL ttyS%d4 at MMIO 0xfefcc000 (irq = 9) is a AT91_SERIAL eth0: Link now 100-FullDuplex eth0: AT91 ethernet at 0xfefbc000 int=24 100-FullDuplex (00:18:8a:23:00:21) eth0: Davicom 9196 PHY (Copper) AT91 SPI driver loaded at91_dataflash: Atmel AT45DB642 detected [spi0] (8650752 bytes) Creating 4 MTD partitions on "Atmel AT45DB642": 0x00000000-0x00067200 : "Loader&Boot" 0x00067200-0x00135600 : "Kernel" 0x00135600-0x001b9600 : "JFFS2" 0x001b9600-0x00840000 : "Ramdisk" NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 2048 bind 2048) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. Fast Floating Point Emulator V0.94 by Peter Teichmann. RAMDISK: Compressed image found at block 0 Freeing initrd memory: 5859K EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). Mounted devfs on /dev Freeing init memory: 56K INIT: version 2.74 booting INIT: /etc/inittab[9]: missing id field INIT: /etc/inittab[10]: missing id field INIT: Entering runlevel: 3 grep: /proc/cmdline: No such file or directory Starting system logger: syslogdUsing fallback suid method Using fallback suid method Starting interfaces eth0: Link now 100-FullDuplex Starting INET services: inetd Using fallback suid method Starting mouse Using fallback suid method Using fallback suid method Starting tty Using fallback suid method Starting console mouse services: (no mouse is configured) Using fallback suid method Using fallback suid method warning: cannot change to home directory Using fallback suid method WARNING: detected MinSpareServers set to non-positive. Resetting to 1 to avoid almost certain Apache failure. Please read the documentation. Using fallback suid method eth0: Setting MAC address to 00:18:8a:25:02:21 Using fallback suid method Using fallback suid method Using fallback suid method Using fallback suid method Using fallback suid method listen uses obsolete (PF_INET,SOCK_PACKET) Accpting connetions...... =======server version : 1.2========= Using fallback suid method MPG440: install module......MPG-440 driver version 2.3.2 Video source : TI 5150 TI 5150 video decoder configuration done Using fallback suid method DRAM clock phase testing: 0, ADDR TEST failed, DATA TEST failed DRAM clock phase testing: 1, ADDR TEST failed, DATA TEST failed DRAM clock phase testing: 2, ADDR TEST failed, DATA TEST passed DRAM clock phase testing: 3, ADDR TEST failed, DATA TEST passed DRAM clock phase testing: 4, ADDR TEST failed, DATA TEST passed DRAM clock phase testing: 5, ADDR TEST failed, DATA TEST passed DRAM clock phase testing: 6, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 7, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 8, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 9, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 10, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 11, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 12, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 13, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 14, ADDR TEST passed, DATA TEST passed DRAM clock phase testing: 15, ADDR TEST failed, DATA TEST failed DRAMC clock phase : 10 VIDEO detecting camera... PAL Camera [root@Set to mode 352*288 (none) enable_irq(28) unbalanced from c281407c cenable_irq(25) unbalanced from c2814084 gi-bin]$******infinova**2.3.1***** IP Ratio: 29 Frame Ratio: 30 Frame Ratio: Failure IP Frame Ratio: 8 Graphic Mode : 3 pthread id :2051 waiting for new client. pthread id :3076 waiting for new client. Set to mode 720*576 pthread id :4101 waiting for new client. pthread id :5126 waiting for new client. pthread id :6151 waiting for new client. pthread id :7176 waiting for new client. pthread id :8201 waiting for new client. pthread id :9226 waiting for new client. pthread id :10251 waiting for new client. pthread id :11276 waiting for new client.
