/************************************************************************/ /* */ /* Debouncing 8 Keys */ /* Sampling 4 Times */ /* With Repeat Function */ /* */ /* Author: Peter Dannegger */ /* danni@specs.de */ /* */ /************************************************************************/ #include #include #include #ifndef F_CPU #define F_CPU 1000000 // processor clock frequency #endif #define KEY_DDR DDRB #define KEY_PORT PORTB #define KEY_PIN PINB #define KEY0 0 #define KEY1 1 #define KEY2 2 #define ALL_KEYS (1<1: key press detect if( (key_state & REPEAT_MASK) == 0 ) // check repeat function rpt = REPEAT_START; // start delay if( --rpt == 0 ){ rpt = REPEAT_NEXT; // repeat delay key_rpt |= key_state & REPEAT_MASK; } } /////////////////////////////////////////////////////////////////// // // check if a key has been pressed. Each pressed key is reported // only once // uint8_t get_key_press( uint8_t key_mask ) { cli(); // read and clear atomic ! key_mask &= key_press; // read key(s) key_press ^= key_mask; // clear key(s) sei(); return key_mask; } /////////////////////////////////////////////////////////////////// // // check if a key has been pressed long enough such that the // key repeat functionality kicks in. After a small setup delay // the key is reported beeing pressed in subsequent calls // to this function. This simulates the user repeadiately // pressing and releasing the key. // uint8_t get_key_rpt( uint8_t key_mask ) { cli(); // read and clear atomic ! key_mask &= key_rpt; // read key(s) key_rpt ^= key_mask; // clear key(s) sei(); return key_mask; } /////////////////////////////////////////////////////////////////// // uint8_t get_key_short( uint8_t key_mask ) { cli(); // read key state and key press atomic ! return get_key_press( ~key_state & key_mask ); } /////////////////////////////////////////////////////////////////// // uint8_t get_key_long( uint8_t key_mask ) { return get_key_press( get_key_rpt( key_mask )); } int main( void ) { KEY_DDR &= ~ALL_KEYS; // konfigure key port for input KEY_PORT |= ALL_KEYS; // and turn on pull up resistors TCCR0 = (1<
