[ 77%] Building CXX object pcbnew/CMakeFiles/_pcbnew.dir/tools/size_menu.cpp.o [ 77%] Building CXX object pcbnew/CMakeFiles/_pcbnew.dir/__/common/dialogs/dialog_page_settings.cpp.o [ 78%] Building CXX object pcbnew/CMakeFiles/_pcbnew.dir/__/common/base_units.cpp.o [ 78%] Linking CXX shared module _pcbnew.so /usr/local/lib/libpython2.7.a(posixmodule.o): In function `posix_tmpnam': /Daten/Downloads/Python-2.7.11/./Modules/posixmodule.c:7631: warning: the use of `tmpnam_r' is dangerous, better use `mkstemp' /usr/local/lib/libpython2.7.a(posixmodule.o): In function `posix_tempnam': /Daten/Downloads/Python-2.7.11/./Modules/posixmodule.c:7578: warning: the use of `tempnam' is dangerous, better use `mkstemp' /usr/bin/ld: /usr/local/lib/libpython2.7.a(abstract.o): relocation R_X86_64_32S against symbol `_Py_NotImplementedStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(boolobject.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(capsule.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(classobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(cobject.o): relocation R_X86_64_32 against symbol `PyCObject_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(exceptions.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(floatobject.o): relocation R_X86_64_32S against symbol `PyFloat_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(intobject.o): relocation R_X86_64_32S against symbol `PyInt_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(iterobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(listobject.o): relocation R_X86_64_32 against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(longobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(dictobject.o): relocation R_X86_64_32S against symbol `PyDict_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(moduleobject.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(object.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(obmalloc.o): relocation R_X86_64_32S against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(rangeobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(setobject.o): relocation R_X86_64_32S against symbol `PyString_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(sliceobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(stringobject.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(structseq.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(tupleobject.o): relocation R_X86_64_32 against symbol `_PyEval_SliceIndex' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(typeobject.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(weakrefobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(unicodeobject.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(unicodectype.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(_warnings.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(ceval.o): relocation R_X86_64_32S against symbol `PyMethod_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(compile.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(codecs.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(errors.o): relocation R_X86_64_32S against symbol `PyTraceBack_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(future.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getargs.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(import.o): relocation R_X86_64_32 against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(importdl.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(marshal.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(modsupport.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(mystrtoul.o): relocation R_X86_64_32S against symbol `_PyLong_DigitValue' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(peephole.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(pystate.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(pythonrun.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(random.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(symtable.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(sysmodule.o): relocation R_X86_64_32 against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(traceback.o): relocation R_X86_64_32S against symbol `PyTraceBack_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(pystrtod.o): relocation R_X86_64_32S against symbol `_Py_ctype_tolower' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(dtoa.o): relocation R_X86_64_32S against `.bss' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(formatter_unicode.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(formatter_string.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(dynload_shlib.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(thread.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getpath.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(gcmodule.o): relocation R_X86_64_32 against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(threadmodule.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(signalmodule.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(posixmodule.o): relocation R_X86_64_32S against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(errnomodule.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(pwdmodule.o): relocation R_X86_64_32 against `.bss' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(_sre.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(_codecsmodule.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(_weakref.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(zipimport.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(symtablemodule.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(xxsubtype.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getbuildinfo.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(acceler.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(grammar1.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(parsetok.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(tokenizer.o): relocation R_X86_64_32S against symbol `PyString_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(bufferobject.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(bytearrayobject.o): relocation R_X86_64_32 against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(cellobject.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(codeobject.o): relocation R_X86_64_32S against symbol `PyString_Type' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(complexobject.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(descrobject.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(enumobject.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(genobject.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(fileobject.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(frameobject.o): relocation R_X86_64_32 against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(funcobject.o): relocation R_X86_64_32S against symbol `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(memoryobject.o): relocation R_X86_64_32 against symbol `_Py_NotImplementedStruct' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(methodobject.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(Python-ast.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(ast.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(bltinmodule.o): relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getcopyright.o): relocation R_X86_64_32 against `.data' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getplatform.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getversion.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(structmember.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(parser.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(myreadline.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(bytes_methods.o): relocation R_X86_64_32S against symbol `_Py_ctype_table' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: /usr/local/lib/libpython2.7.a(getcompiler.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: final link failed: Nonrepresentable section on output collect2: Fehler: ld gab 1 als Ende-Status zurück make[2]: *** [pcbnew/CMakeFiles/_pcbnew.dir/build.make:6721: pcbnew/_pcbnew.so] Fehler 1 make[1]: *** [CMakeFiles/Makefile2:1421: pcbnew/CMakeFiles/_pcbnew.dir/all] Fehler 2 make: *** [Makefile:150: all] Fehler 2 ==> FEHLER: Ein Fehler geschah in build(). Breche ab... ==> FEHLER:Makepkg konnte kicad-git nicht erstellen. ==> Erstellen von kicad-git neu starten?[j/N] ==> ----------------------------------------- ==>
