$regfile = "usb1287.dat" 'Definituonsdatei für Mega16 $crystal = 16000000 'Quarz: 16 MHz Dim Init1 As Byte Dim Init2 As Byte Dim Init3 As Byte Dim Init4 As Byte Dim Init5 As Byte Dim Init6 As Byte Dim Init7 As Byte Dim Init8 As Byte Dim Init9 As Byte Dim Text As String * 4 Config Pinf.1 = Output 'L= Command; H= Data Config Pinf.2 = Output 'Chip Select Reset Pinf.1 'Display auf Komandomodus schalten Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 0 , Clockrate = 16 Init1 = &H39 Init2 = &H1D Init3 = &H50 Init4 = &H6C Init5 = &H76 Init6 = &H38 Init7 = &H0F Init8 = &H01 Init9 = &H06 Text = "test" Spiinit Reset Pinf.2 'Chip Select Display Waitms 60 Spiout Init1 , 1 Waitms 60 Spiout Init2 , 1 Waitms 60 Spiout Init3 , 1 Waitms 60 Spiout Init4 , 1 Waitms 60 Spiout Init5 , 1 Waitms 60 Spiout Init6 , 1 Waitms 200 Spiout Init7 , 1 Waitms 60 Spiout Init8 , 1 Waitms 60 Spiout Init9 , 1 Waitms 60 Set Pinf.1 'Display auf Datenmodus schalten Spiout Text , 4 Anfang: Waitms 50 Goto Anfang End
