-------------------------------------------------------------------------------------------------------------------------------------- README File for MCP2200 Driver Installation Tool -------------------------------------------------------------------------------------------------------------------------------------- Microchip Technology, Inc. -------------------------------------------------------------------------------------------------------------------------------------- System Requirements -------------------------------------------------------------------------------------------------------------------------------------- Operating System: Windows XP SP3 or later - (ADMIN PRIVILEGES ARE REQUIRED) -------------------------------------------------------------------------------------------------------------------------------------- Important Information -------------------------------------------------------------------------------------------------------------------------------------- **** Certain portions of the MCP2200 Driver Installation Tool are copyright Microsoft, Inc., and used under license **** -------------------------------------------------------------------------------------------------------------------------------------- How to Use -------------------------------------------------------------------------------------------------------------------------------------- ---- DRIVER INSTALLATION ---- Basic Usage: Start the driver installation (Normal install wizard window): 1. Double-click the executable file within the appropriate folder for your system (x86 for 32-bit OS and x64 for 64-bit OS). Advanced Usage: Run the driver installation in transparent/hidden mode: 1. Use the following command line options when running dpinst.exe: /sw How to check for success/failure when running this tool during another software installation: 1. Tool runs and attempts to install the driver. 2. Installation result is given in wizard window (in normal mode) 3. If the transparent/hidden mode is used, check the application return code or the dpinst log file created in the system directory. More on this at: http://msdn.microsoft.com/en-us/library/windows/hardware/ff544790%28v=VS.85%29.aspx and http://msdn.microsoft.com/en-us/library/windows/hardware/ff548674%28v=VS.85%29.aspx 4. If installation was successful, an entry is made under "Programs/Features" ("Add/Remove Programs" in Windows XP) for the driver. This can be avoided by using the following command line switch: /sa ---- DRIVER UNINSTALL ---- To uninstall this driver, simply double-click the entry in "Programs and Features" (Windows 7) or "Add/Remove Programs" (Windows XP) found in the Control Panel. -------------------------------------------------------------------------------------------------------------------------------------- Versioning History -------------------------------------------------------------------------------------------------------------------------------------- Version 1.3 (Released 10/09/2014): - Updated tool to include the new MCP2200/MCP2221 driver version (v1.4). Version 1.2 (Released 02/20/2013): - Updated tool to include the new MCP2200 driver version (v1.3). Version 1.1 (Released 08/29/2012): - Updated tool to include the new MCP2200 driver version (v1.2). Version 1.00 (Released 08/15/2012): - Initial Release -------------------------------------------------------------------------------------------------------------------------------------- Contact Information -------------------------------------------------------------------------------------------------------------------------------------- Main Website: http://www.microchip.com Technical Support: http://support.microchip.com
