;*************************************************************************** ;* ;* Title : AVR ISP (Auto adr inc, 115200bps, supports AVR109 commands) ;* Version : 3.8c ;* Last updated : Sep 22 2006 ;* Target : AT90S2313 ;* File : avr910_2313_v38c.asm ;* Author(s) : klaus@mikrocontroller-projekte.de ;* last Filename: avr910_2313_V38b.asm ;* initial File : avr910_31.asm, Author: wubblick@yahoo.com, source: www.mit8.ru/~mars/ ) ;* ;* This Code is free for private, noncommercial use only ;* ;* DESCRIPTION ;* The firmware on all programmers now support a unified protocol for ;* program and data memory programming. The host computer do not need ;* to know if the programmer operates in serial or parallel mode. ;* ;* The following commands are supported. All commands start with a ;* single letter. The programmer returns 13d (carriage return) or the ;* data read after the command is finished. ;* ;* +-------------------+-------------+------+ ;* Commands | Host writes | Host reads | | ;* -------- +-----------+-------+-------+-----+ | ;* | ID (hex ) | data | data | | Note | ;* +-----------------------------------+-----------+-------+-------+-----+------+ ;* | Enter programming mode | 'P'(0x50) | | | 13d | 1 | ;* | Report autoincrement address | 'a'(0x61) | | | 'Y' | | ;* | Set address | 'A'(0x41) | ah al | | 13d | 2 | ;* | Write program memory, low byte | 'c'(0x63) | dd | | 13d | 3 | ;* | Write program memory, high byte | 'C'(0x43) | dd | | 13d | 3 | ;* | Issue Page Write | 'm'(0x6d) | | | 13d | 13 | ;* | Read program memory | 'R'(0x52) | | dd(dd)| | 4 | ;* | Write data memory | 'D'(0x44) | dd | | 13d | | ;* | Read data memory | 'd'(0x64) | | dd | | | ;* | Chip erase | 'e'(0x65) | | | 13d | | ;* | Write lock bits | 'l'(0x6c) | dd | | 13d | | ;* | Leave programming mode | 'L'(0x4c) | | | 13d | 5 | ;* | Select device type | 'T'(0x54) | dd | | 13d | 6 | ;* | Read signature bytes | 's'(0x73) | | 3*dd | | | ;* | Return supported device codes | 't'(0x74) | | n*dd | 00d | 7 | ;* | Return software identifier | 'S'(0x53) | | s[7] | | 8 | ;* | Return sofware version | 'V'(0x56) | | dd dd | | 9 | ;* | Return hardware version | 'v'(0x76) | | dd dd | | 9 | ;* | Return programmer type | 'p'(0x70) | | dd | | 10 | ;* | Set LED | 'x'(0x78) | dd | | 13d | 12 | ;* | Clear LED | 'y'(0x79) | dd | | 13d | 12 | ;* | Universial command | ':'(0x3a) | 3*dd | dd | 13d | 15 | ;* | New universal command | '.'(0x2E) | 4*dd | dd | 13d | 15 | ;* |-----------------------------------+-----------+-------+-------+-----+------| ;* | New Commands since Version 3.3 | | | | | | ;* | Exit (AVR109, Bootloader) | 'E'(0x45) | | | 13d | 15 | ;* | Return Chip ID (Terminalmode only)| 'i'(0x69) | | s[n] | | 14 | ;* +-----------------------------------+-----------+-------+-------+-----+------+ ;* | New Commands since Version 3.5 | | | | | | ;* | Implemented Atmel Bootloader commands (Atmel Appl. Note 109) | | | ;* | Report Block write Mode | 'b'(0x62) | |'Y'2*nn| 13d | 16 | ;* | Block Write | 'B'(0x42) |2*nn'M'| n*dd | 13d | 16 | ;* | Block Read | 'g'(0x67) |2*nn'M'| n*dd | 13d | 16 | ;* +-----------------------------------+-----------+-------+-------+-----+------+ ;* | Commands to test (fully implemented since V3.8, Unverified) | | | | ;* | Return Lockbits | 'r'(0x72) | | dd | 13d | 17 | ;* | Return High Fusebits | 'N'(0x4E) | | dd | 13d | 17 | ;* | Return extendet Fusebits | 'Q'(0x51) | | dd | 13d | 17 | ;* | Write fuse bits (reserved) | 'f'(0x66) | dd | | 13d |11,17 | ;* | Read fuse and lock bits (reserved)| 'F'(0x46) | | dd | |11,17 | ;* +-----------------------------------+-----------+-------+-------+-----+------+ ;*'F ;* NOTE 1 ;* The Enter programming mode command MUST be sent one time prior to ;* the other commands, with the exception of the 't', 'S', 'V', 'v' ;* and 'T' commands. The 'T' command must be sent before this command ;* (see note 6). ;* ;* For programmers supporting both parallel and serial programming ;* mode this command enters parallel programming mode. For programmers ;* supporting only serial programming mode, this command enters serial ;* programming mode. ;* ;* NOTE 2 ;* The ah and al are the high and low order bytes of the address. For ;* parallel programmers this command issues the Load Address Low/High ;* Byte command. For serial programmers the address byte is stored for ;* use by the Read/Write commands. ;* ;* NOTE 3 ;* For parallel programmers this command issues the Program Flash ;* command. For serial programmers this command iussues the Write ;* Program Memory Command. For devices with byte-wide program memories ;* only the low byte command should be used. ;* ;* NOTE 4 ;* The contents of the program memory at the address given by the 'A' ;* command are written to the serial port in binary form. For byte ;* wide memories one byte is written. For 16 bit memories two bytes ;* are written,MSB first. ;* ;* NOTE 5 ;* This command must be executed after the programming is finished. ;* ;* NOTE 6 ;* The select device type command must be sent before the enter ;* programming command ;* ;* NOTE 7 ;* The supported device codes are returned in binary form terminated ;* by 0x00. ;* ;* NOTE 8 ;* This return a 7 character ASCII string identifying the programmer. ;* For the development board it is "AVR DEV", for the parallel ;* programmer it is "AVR PPR" and for the in-curcuit programmer it is ;* "AVR ISP". ;* ;* NOTE 9 ;* The software/hardware version are returned as two ASCII numbers. ;* ;* NOTE 10 ;* This command should be used to identify the programmer type. The ;* return value is 'S' for serial (or SPI) programmers or 'P' for ;* parallel programmers. ;* ;* NOTE 11 ;* The write fuse bits command are available only on parallel ;* programmers and only for AVR devices (device code < 0x80). The host ;* should use the return programmer type command to determine the ;* programmer type, do not use the "AVR PPR" idenifier because other ;* programmers may be available in the future. ;* ;* NOTE 12 ;* Currently only the AVR development board has LEDs. The other boards ;* must implement this commands as NOPs. ;* ;* NOTE 13 ;* Devices using Page Mode Programming write one page of flash memory ;* before issuing a Page Mode Write Pulse. ;* ;* NOTE 14 ;* The 'i' command is only used with a Terminal, for debug reasons. ;* Not used in any Programmer so far ;* ;* NOTE 15 ;* Lock and Fuse Bits are written using the "universal command" (:) and ;* "new universal command" (.) in AVRProg and AVRDUDE. ;* AVRProg has an Exit (E) command implemented, which switches AVRProg offline ;* ;* NOTE 16 ;* Atmel Bootloader commands described in Atmel Application Note 109 implemented. ;* Very useful if you use USB to serial converter. ;* AVRProg since Version 1.33 checks if Programmer supports Block Mode, ;* IF Programmer responds 'Y' and the size of the internal Buffer (nn nn), Bootloader commands ;* are used automatically from AVRProg. (faster Protocoll) ;* Block commands send size Buffersize (nn nn) and Type of Memory ('F'=Flash, 'E'=Data) ;* Compatibility to AVR Butterfly command set and Bootloader. Works with AVR911 Open Source ;* Programmer. ;* For avrdude use -c butterfly instead of -c avr910 and you get same behaviour. ;* Page Write for Data Memory (EEPROM) not implemented ;* ;* NOTE 17 ;* Commands implemented in V3.8 but not completely tested yet. ;* ;* NOTE 18 ;* Device 89S8252 was tested to programm with avrprog. Shows a avrprog bug in "block Mode". Works in "standart" ;* avr910 Programming Mode. To program this Device, disable the "Block Mode" by changing "w53: rjmp w6" ;* ;* HISTORY ;* v3.8c 22.09.06 (Clemens) Added support for swapped MISO/MOSI lines. Automatically detected on 'Enter Programming Mode' ;* V3.8b 26.02.06 (Klaus) Matched new Devices to avrdude.conf v5.1 ;* V3.8a 30.12.05 (Klaus) Corrected Devic entry for ATTiny13 ;* V3.8 06.11.05 (Klaus) New Devicecodes (inoffiacal) for Mega48/88/168 and others, ;* Lockbyte write enhanced for newer Devices. Commands in ;* Note 17 implemented. Not comletely tested. ;* Code cleanup to save some Bytes. ;* V3.7e 11.01.05 (Klaus) Matched Devicecodes to the new Atmel AVRProgV1.40 ;* V3.7d 05.01.05 (Klaus) Removed 1200A/B/C devicecodes, Polling 0x7F for AT90S4414, default PollcodeF = 0xFF ;* V3.7c 04.01.05 (Klaus/Micha) Some devicecodes changed (Bootloader and "default" mode). ;* V3.7b 03.01.05 (Klaus/Leo) Bugfix for Block read of Flash Mamory for AT89Snnnn Controllers. ;* V3.7a 29.12.04 (Klaus/Micha) addet devicecodes for m64, m162 and m169. ;* V3.7 15.12.04 (Klaus) Rewriting polled timing for "non Page Mode" Chips, reorganised Table for ;* different polling Codes. Skip 0xFF Byte polling. (was buggy for some Controllers) ;* Added ATTiny2313 (device Code 0x23), and ATMega8535 (0x6A)Support. ;* Not Supported from avrprog, avrdude Support possible. ;* Reorganised Table for Page Mode Chips with PROGRAMMER_PAGESIZE. Adding different PROGRAMMER_PAGESIZEs ;* Try to fix S89 write, BUG in avrprog detected. Firmware should be OK now. (NOTE 18) ;* After 256 unsuccesful polls for Flash wait additional standart time. ;* Modified "release_ports" so that RESET is released also. ;* V3.6 10.07.04 (Klaus) Changed Block Mode Commands to AVR109 compatibility. ;* Additional AVR109 Commands, not testet yet. ;* V3.4-V3.5 unreleased (Klaus) cleaning up, tests for Block Modes ;* V3.3 25.06.04 (Klaus, Thomas) added enhanced Block write commands ; with own Protocol. ; Add 0xFF, 0x7F (2313) check for polling Mode ;* V3.2.1 18.11.03 (Klaus) Commented out some Controller Types, which are ; not really Supported by the hardware, but from ; AVRProg Software. See Comments at the end. ;* V3.2 16.11.03 (Klaus) Correctet typo in Chrystal frequency. ;* V3.2 13.10.03 (Klaus) 7,3728 Mhz chrystal for 115.200 Baud. ;* Swap MOSI <-> MISO Pinnumbers. ;* Add dual color LED Support. ;* Add some new Dewices. ;* V3.0 02.01.23 (wubble) Ported from 1200 to 2313. ;* Serial IO modified to use hardware UART. ;* Added support for multiple new devices. ;* Used data polling to short write process. ;* Added LED support to indicate R/W process. ;* V2.2 00.03.10 (pkastnes) Added support for multiple new devices. ;* V2.1 98.10.26 (mlund) New date marking. ;* Removed support for AT90S1200C. ;* Added support for AT90S4433A. ;* V2.0 98.01.06 (mlund) ATmega103 support. ;* V1.7 97.11.06 (mlund) Universial command (':') implemented. ;* Releases all pins when not in ;* programming mode. ;* V1.6e 97.11.04 (mlund) mega103 rev D support ;* V1.6c 97.10.30 (mlund) Auto incrementing / SPI sync ;* also works for mega103. ;* V1.6 97.09.09 (hskar) Created Page Mode Version (mega103) ;* V1.5 97.08.21 (mlund) Modified / Bugfix / Major cleanup ;* ... ... (no records) ;* V?.? 97.03.15 (OS) Created ;* ;* ;* Device Support List: see table "Devices" at the end of this file. ;*************************************************************************** ;**** includes **** .include "tn2313def.inc" ;*************************************************************************** ;* ;* CONSTANTES ;* ;*************************************************************************** ;**** Constant declarations Data Rate **** .equ XTAL = 11059 .equ BAUD = 115200 .equ N = 5 ;******** Chrystals for maximum Baudrates ;.equ XTAL = 7373 ; XTAL frequency, Khz (7.3728 Mhz) ;******** ;.equ BAUD = 115200 ; Data rate, bauds ;.equ N = 3 ; for 7.3728 Mhz/115.200Baud ;******** ;.equ BAUD = 38400 ; Data rate, bauds ;.equ N = 11 ; for 7.3728 Mhz/38.400Baud ;******** ;.equ BAUD = 19200 ; Data rate, bauds ;.equ N = 23 ; for 7.3728 Mhz/19.200 Baud ;********* ;**** definitions for different chrystals and 115.200 baud **** ;.equ XTAL = 3686 ; XTAL frequency, Khz (3.6864 Mhz) ;********* ;.equ BAUD = 115200 ; Data rate, bauds ;.equ N = 1 ; for 3.6864 Mhz/115.200Baud ;********* ; ;********* Baudrates for 8 Mhz Chrystal ;.equ XTAL = 8000 ; XTAL frequency, Khz (8.000 Mhz) ;********* ;.equ BAUD = 38400 ; Data rate, bauds ;.equ N = 12 ; for 8.00 Mhz/38.400 Baud ;********* ;.equ BAUD = 19200 ;Data rate, bauds ;.equ N = 25 ; for 8.00 Mhz/19.200 Baud ;********* ;.equ BAUD = 9600 ; Data rate, bauds ! Not valid for AVRProg, use for avrdude only ! ;.equ N = 51 ; for 8.00 Mhz/9.600 Baud ;********* ;********* Baudrates for 4 Mhz Chrystal ;.equ XTAL = 4000 ; XTAL frequency, Khz (4.000 Mhz) ;********* ;.equ BAUD = 19200 ; Data rate, bauds ;.equ N = 12 ; for 4.00 Mhz/19.200 Baud ;********* ;.equ BAUD = 9600 ; Data rate, bauds ! Not valid for AVRProg, use for avrdude only ! ;.equ N = 25 ; for 4.00 Mhz/9.600 Baud ;********* .equ RAMSTART = 0x60 ; first SRAM Adress of 2313 .equ PROGRAMMER_PAGESIZE = 0x10 ; default Page size for Programming .equ BUFSIZE = 0x40 ; 64 bytes internal RAM for Buffer ;*************************************************************************** ;* ;* PORTS ;* Ports Definitions ;* ;* DESCRIPTION ;* Change the following definitions if the RESET pin to the ;* target moves and/or if the SCK/MISO/MISO/LED moves. ;* ;*************************************************************************** .equ LEDH = PB3 ; dual color LED output, anode green (output) .equ LED = PB0 ; LED output, active low, dual color LED Kathode green (output) .equ MISO = PB5 ; MISO pin of the target (input) .equ MOSI = PB6 ; MOSI pin of the target (output) this doesn't matter, anyhow ;-) .equ RESET = PB4 ; RESET pin of the target (output) .equ SCK = PB7 ; SCK pin of the target (output) .equ RXD = PD0 ; UART RXD line .equ TXD = PD1 ; UART TXD line ;*************************************************************************** ;* ;* MACROS ;* Program Macros ;* ;* DESCRIPTION ;* Change the following macros if the RESET pin to the ;* target moves and/or if the SCK/MISO/MISO/LED moves. ;* ;*************************************************************************** .macro init_ports ; init ports ldi temp2,0xff out PORTD,temp2 ldi temp2,0xff out PORTB,temp2 .endm .macro catch_ports ; catch ports ldi temp2,(1< Standart LED off, dual LED green sbi PORTB,LED cbi PORTB,LEDH ; added for dual color support .endm .macro clr_LED ; clear LED Port --> Standart LED on, dual LED red cbi PORTB,LED sbi PORTB,LEDH ; added for dual color support .endm .macro LED_off ; for dual color LED, not in use cbi PORTB,LED cbi PORTB,LEDH .endm .macro sbic_MISO ; skip if MISO cleared sbrc swapSIO, 0 rjmp pc+4 ;lines are not swapped sbic PINB, MISO rjmp pc+3 rjmp pc+3 ; pc+3: lines are swapped sbic PINB, MOSI .endm .macro set_MOSI ; set MOSI sbrc swapSIO, 0 sbi PORTB,MISO sbrs swapSIO, 0 sbi PORTB,MOSI .endm .macro clr_MOSI ; clear MOSI sbrc swapSIO, 0 cbi PORTB,MISO sbrs swapSIO, 0 cbi PORTB,MOSI .endm .macro clr_SCK ; clear SCK cbi PORTB,SCK .endm .macro pulse_SCK ; pulse SCK sbi PORTB,SCK ldi temp2,(XTAL/750+1) ; had to slow down for ATTiny2313 (internal clock) default was (XTAL/1500+1) m0: dec temp2 brne m0 cbi PORTB,SCK ldi temp2,(XTAL/1500+1) ; had to slow down for ATTiny2313 (internal clock) default was (XTAL/3000+1) m1: dec temp2 brne m1 .endm .macro table ; load Z pointer ldi ZL,low(@0*2) ; low ldi ZH,high(@0*2) ; high .endm ;*************************************************************************** ;* ;* Global Register Variables ;* ;*************************************************************************** ;r0 used with lpm instruction .def cmd1 = r1 ; Universal commands params .def cmd2 = r2 ; .. .def cmd3 = r3 ; .. .def pol_al = r4 ; Polling address low .def pol_ah = r5 ; Polling address high .def Bcnt1 = r6 ; Block Mode Counter1 .def Bcnt2 = r7 ; Block Mode Counter2 .def Bcnt3 = r8 ; Block Mode Counter2 .def B_Flag = r9 ; Flag for ws_del Routine .def B_Mode = r10 ; Marks Block Mode commands (See Note 16) .def Memtype = r11 ; Flag for Memorytype for Block Commands (See Note 16) .def Pagewords = r12 ; Size of Controller page to program in Page Mode (Words!) .def PollcodeF = r13 ; Code for Polling Flash .def swapSIO = r14 ; swap the serial io-lines MISO and MOSI .def temp1 = r16 ; Temporary register 1 .def temp2 = r17 ; Temporary register 2 .def temp3 = r18 ; Temporary register 3 .def s_data = r19 ; SPI data .def u_data = r20 ; UART data .def device = r21 ; Device code ;.def lockmode = r22 ; Param to set correct lockbit read/write mode .def rd_s_data = r23 ; Read data on SPI .def pol_cmd = r24 ; Polling command .def p_data = r25 ; Polling data ;r26,r27 used as X register .def addrl = r28 ; (YL) Low order byte of address .def addrh = r29 ; (YH) High order byte of address ;r30,r31 used as Z register ;*************************************************************************** ;* ;* Interrupt Vectors ;* ;*************************************************************************** .CSEG rjmp INIT ; Reset Handle ;*************************************************************************** ;* ;* FUNCTION ;* u_init ;* ;* DESCRIPTION ;* Initialize UART. ;* ;*************************************************************************** u_init: ldi temp1,N ; set baud rate out UBRR,temp1 ldi temp1,(1< main ;* ;* DESCRIPTION ;* Wait for and execute commands. ;* ;*************************************************************************** waitcmd: rcall getc ; while (getc() == ESC) {}; cpi u_data,0x1b breq waitcmd ;====== 'T' - Device Type ================================================== cpi u_data,'T' ; 'T' Device type brne w0 rcall getc mov device,u_data ; get device type table Dev_M ; prepare to set PROGRAMMER_PAGESIZE rcall set_PROGRAMMER_PAGESIZE ; If device has Page Mode support, set PROGRAMMER_PAGESIZE ldi temp1,0xFF mov PollcodeF,temp1 ; preset PollcodeF with 0xFF, will be overwritten if Pollcode known table Dev_S ; prepare to set Polling Code rcall set_pollcode ; If device has no Page Size support, set code for Polling Flash rjmp put_ret ;====== 'S' - Return Software Identifier =================================== w0: cpi u_data,'S' ; 'S' Return software identifier brne w1 table ID_Str rcall put_string ; put string "AVR ISP" rjmp waitcmd ;====== 'V' - Return Software Version ====================================== w1: cpi u_data,'V' ; 'V' Return software version brne w2 table SW_Ver rcall put_string ; put software version rjmp waitcmd ;====== 'v' - Return Hardware Version ====================================== w2: cpi u_data,'v' ; 'v' Return hardware version brne w3 table HW_Ver rcall put_string ; put hardware version rjmp waitcmd ;====== 't' - Show Supported Devices ======================================= w3: cpi u_data,'t' ; 't' Show supported devices brne w4 table Dev_S rcall put_table ; put supported devices codes table Dev_M rcall put_table ; put supported devices codes ldi u_data,0x00 ; putc(0x00) - end of device list rcall putc rjmp waitcmd ;====== 'p' - Return Programmer Type ======================================= w4: cpi u_data,'p' ; 'p' Return programmer type brne w5 ldi u_data,'S' ; putc('S') - serial programmer rcall putc rjmp waitcmd ;====== 'a' - Return autoincrement address support ========================= w5: cpi u_data,'a' ; 'a' Return address auto increment brne w51 ldi u_data,'Y' ; putc('Y') - supports autoinc rcall putc rjmp waitcmd ;====== 'M' - Return enhanced Mode support (Note 14) ======================== w51: ; cpi u_data,'M' ; 'M' Return enhanced mode Support ; brne w52 ; ldi u_data,'Y' ; putc('Y') - supports enhanced Mode ; rcall putc ; rjmp waitcmd ;====== 'i' - Return Chip ID (Note 14) ====================================== w52: cpi u_data,'i' ; 'i' Return Chip ID brne w53 table ChipID rcall put_string ; put Chip ID string ldi u_data,0x0a ; putc(LF) rcall putc rjmp put_ret ;====== 'b' - Return Block write Mode support (Note 17) ======================== w53: cpi u_data,'b' ; 'b' Return enhanced mode Support brne w6 ldi u_data,'Y' ; putc('Y') - supports enhanced Mode rcall putc ldi u_data,high(BUFSIZE); putc((BUFSIZE>>8) & 0xff); rcall putc ldi u_data,low(BUFSIZE) ; putc(BUFSIZE&0xff); rcall putc rjmp waitcmd ;====== 'x' - Set LED ====================================================== w6: cpi u_data,'x' ; 'x' Set LED (LED off or green) brne w61 rcall getc ; get parameter set_LED rjmp put_ret ;====== 'y' - Clear LED ==================================================== w61: cpi u_data,'y' ; 'y' Clear LED (LED on or red) brne w7 rcall getc ; get parameter clr_LED rjmp put_ret ;=========================================================================== ; We require that the device code be selected before any of the other commands w7: table Dev_S ; load pointer rcall bel_table brcc w71 ; device belongs to table table Dev_M rcall bel_table brcc w71 ; device belongs to table rjmp put_err ; not match, goto put_err(); ;====== 'P' - Enter Programming Mode ======================================= w71: cpi u_data,'P' ; 'P' Enter programming mode breq w70 rjmp w8 w70: clr swapSIO ; try unswapped io-lines s5: clr_LED ; LED on catch_ports ; catch ports clr_SCK ; clear SCK pas_RESET ; set RESET passive ldi temp1,50 ; delay 50mS; rcall delay act_RESET ; set RESET active ldi temp1,50 ; delay 50mS; rcall delay ldi s_data,0xac rcall wrser ; wrser(0xac) SPI write (byte 1) ldi s_data,0x53 rcall wrser ; wrser(0x53) SPI write (byte 2) ; SPI Synchronization (fix!) cpi device,0x20 ; if ( (device >= 0x20) && (device <= 0x7F) ) brlo s2 tst device brmi s2 ldi temp3,32 ; count = 32; s1: rcall rdser ; SPI read (byte 3) cpi s_data,0x53 ; if (rdser == 0x53) breq s3 ; break ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 4) pulse_SCK ; pulse SCK ldi s_data,0xac rcall wrser ; wrser(0xac) SPI write (byte 1) ldi s_data,0x53 rcall wrser ; wrser(0x53) SPI write (byte 2) dec temp3 ; count-1 brne s1 ; loop ; no success yet, try to swap io-lines (MISO and MOSI) inc swapSIO sbrc swapSIO, 1 ; if already both tested (0 and 1) report failure rjmp s3 ; else ; test the other io-lineswapping, ; and start from the beginning again rjmp s5 s2: ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 3) s3: tst device brmi s4 ; S89 device ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 4) s4: ldi temp1,4 ; delay 4mS; rcall delay rjmp put_ret ;====== 'c' - Write Program Memory, Low Byte =============================== w8: cpi u_data,'c' ; 'c' Write program memory, low byte brne w9 rcall getc ; get data byte w8b: ldi s_data,0x40 mov pol_cmd,s_data ; save command for polling tst device brmi w81 ; S89 device rcall wrser ; wrser(0x40) SPI write (byte 1) mov s_data,addrh rjmp w82 w81: mov s_data,addrh ; s_data = (addrh << 3) | 0x02; rcall shift_s_data3 ori s_data,0x02 w82: rcall wrser ; wrser(addrh) SPI write (byte 2) mov s_data,addrl rcall wrser ; wrser(addrl) SPI write (byte 3) mov s_data,u_data rcall wrser ; wrser(u_data) SPI write (byte 4) mov p_data,u_data ; save data for polling mov pol_al,addrl ; save address for polling mov pol_ah,addrh tst device brpl w83 adiw addrl,1 ; Auto increment address for S89 device w83: rjmp wait_S ; write FLASH delay ;====== 'C' - Write Program Memory, High Byte ============================== w9: cpi u_data,'C' ; 'C' Write program memory, high byte brne w92 rcall getc ; get data byte w9a: tst device brmi w91 ; S89 device ldi s_data,0x48 mov pol_cmd,s_data ; save command for polling rcall wrser ; wrser(0x48) SPI write (byte 1) mov s_data,addrh rcall wrser ; wrser(addrh) SPI write (byte 2) mov s_data,addrl rcall wrser ; wrser(addrl) SPI write (byte 3) mov s_data,u_data ; wrser(u_data) SPI write (byte 4) rcall wrser mov p_data,u_data ; save data for polling mov pol_al,addrl ; save address for polling mov pol_ah,addrh adiw addrl,1 ; Auto increment address rjmp wait_S ; write FLASH delay w91: rjmp put_err ; S89 device have byte wide program memory! ;====== 'B' Block Write Memory (see Note 17) ====================== w92: cpi u_data,'B' ; 'B' Block Write Program Memory breq w92a rjmp w10 w92a: rcall getc ; get count High Byte tst u_data breq w92b ldi u_data,1 rjmp put_err w92b: rcall getc ; get count Low Byte cpi u_data,BUFSIZE+1 ; check maximum count brlo w92c ldi u_data,2 rjmp put_err w92c: mov Bcnt1, u_data ; ignore BUFSIZE high Byte (must be 0 here) mov Bcnt2, u_data rcall getc ; get Memory type to write mov Memtype,u_data ; Flag for Memtype clr XH ldi XL, RAMSTART ; set X pointer to SRAM begin w93: rcall getc ; get data until Bcnt1 is reached st X+, u_data ; store data to SRAM dec Bcnt1 brne w93 clr XH ldi XL, RAMSTART ; set X pointer to SRAM begin ldi temp3,1 mov B_Mode,temp3 ; B_Mode != 0 mov u_data,Memtype ; restore Memtype cpi u_data,'F' ; 'F' Flash Memory ist to write breq w94a cpi u_data,'E' ; 'E' eeprom Memory ist to write breq w94 ; Entry Point for Data Memory Block write ldi u_data,3 rjmp put_err w94: ; write Data (EEPROM) Memory ld u_data,X+ rcall eeprom_write dec Bcnt2 brne w94 rjmp put_ret ;Entry Point for Flash Block write w94a: table Dev_M rcall bel_table brcc w95 ; device belongs to table rjmp w96 ; not match, goto "non Paged" Mode w95: ; Entry Point for AVRProg Block Flash write ldi s_data,0x40 ; write low byte rcall spi123 ld s_data, X+ rcall wrser ; wrser(s_data) SPI write (byte 4) ldi s_data,0x48 ; write high byte mov pol_cmd,s_data ; save command for polling rcall spi123 ld s_data, X+ mov p_data,s_data ; save data for polling mov pol_al,addrl ; save address for polling mov pol_ah,addrh rcall wrser ; wrser(u_data) SPI write (byte 4) adiw addrl,1 ; Auto increment address dec Bcnt2 breq w95b dec Bcnt2 breq w95b tst B_Mode breq w95 ; Loop for "Block Mode Commands" see Note 16 dec Bcnt3 ; count Bytes for PROGRAMMER_PAGESIZE brne w95 w95b: tst B_Mode brne w95c rjmp put_ret w95c: dec Bcnt3 ; Bcnt3 will be set correct after write ldi s_data,0x4c ; write Memory Page rcall wrser ; wrser(0x4c) SPI write (byte 1) mov s_data,pol_ah ; last written Adress is in Page to be programmed! rcall wrser ; wrser(addrh) SPI write (byte 2) mov s_data,pol_al ; last written Adress is in Page to be programmed! rcall wrser ; wrser(addrl) SPI write (byte 3) ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 4) mov Bcnt3,Pagewords ; reload Counter für PROGRAMMER_PAGESIZE rjmp wait_M ;#@KL4 test for 89S8252 Device w96: ; Non Page Mode Flash write tst device brmi w96b ; S89 device ld p_data, X+ ; load byte to Poll data cpi p_data,0xFF ; if (p_data == 0xFF) breq w961 ; skip burning ldi s_data,0x40 ; write low byte mov pol_cmd,s_data ; save command for polling rcall spi123 mov s_data,p_data ; reload data from Poll data rcall wrser ; wrser(s_data) SPI write (byte 4) mov pol_al,addrl ; save address for polling mov pol_ah,addrh rcall Bws_pol w961: dec Bcnt2 ld p_data, X+ ; load byte to Poll data cpi p_data,0xFF ; if (p_data == 0xFF) breq w962 ldi s_data,0x48 ; write high byte mov pol_cmd,s_data ; save command for polling rcall spi123 mov s_data,p_data ; reload data from Poll data rcall wrser ; wrser(u_data) SPI write (byte 4) w96a: mov pol_al,addrl ; save address for polling mov pol_ah,addrh rcall Bws_pol w962: adiw addrl,1 ; Auto increment address dec Bcnt2 brne w96 rjmp put_ret ; reply w96b: ; Code for 89S8252 ; ldi s_data,0x40 ; mov pol_cmd,s_data ; save command for polling mov s_data,addrh ; s_data = (addrh << 3) | 0x02; rcall shift_s_data3 ori s_data,0x02 rcall wrser ; wrser(addrh) SPI write (byte 1) mov s_data,addrl rcall wrser ; wrser(addrl) SPI write (byte 2) ld s_data, X+ mov p_data,s_data ; save data for polling rcall wrser ; wrser(u_data) SPI write (byte 3) rjmp w96a ;====== 'R' - Read Program Memory ========================================== w10: cpi u_data,'R' ; 'R' Read program memory brne w10B tst device brmi rpm1 ; S89 device ldi s_data,0x28 ; read high Byte (order is different from Block Read!) rcall wrser ; wrser(0x28) SPI write (byte 1) mov s_data,addrh rjmp rpm2 rpm1: mov s_data,addrh ; s_data = (addrh << 3) | 0x01; rcall shift_s_data3 ori s_data,0x01 rpm2: rcall wrser ; wrser(addrh) SPI write (byte 2) mov s_data,addrl rcall wrser ; wrser(addrl) SPI write (byte 3) rcall rdser ; SPI read (byte 4) mov u_data,s_data rcall putc ; send data tst device brmi rpm3 ; S89 device ldi s_data,0x20 ; read Low Byte rcall wrser ; wrser(0x20) SPI write (byte 1) mov s_data,addrh rcall wrser ; wrser(addrh) SPI write (byte 2) mov s_data,addrl rcall wrser ; wrser(addrl) SPI write (byte 3) rcall rdser ; SPI read (byte 4) mov u_data,s_data rcall putc ; send data rpm3: adiw addrl,1 ; Auto increment address rjmp waitcmd ; goto waitcmd(); ;====== 'g' - Block Read Memory (See Note 17) ====================== w10B: cpi u_data,'g' ; 'g' Block Read Program Memory brne w11 rcall getc ; XH = getc(); mov XH,u_data rcall getc ; XL = getc(); mov XL,u_data rcall getc ; getc(Memorytype); cpi u_data,'F' breq w10B2 cpi u_data,'E' breq w10B1 rjmp put_err w10B1: rcall read_send_datamem sbiw XL, 1 brne w10B1 rjmp waitcmd ; goto waitcmd(); w10B2: rcall read_send_progmem tst device brmi w10B3 sbiw XL, 2 brne w10B2 rjmp waitcmd w10B3: sbiw XL, 1 brne w10B2 rjmp waitcmd ; goto waitcmd(); ;====== 'A' - Load Address ================================================= w11: cpi u_data,'A' ; 'A' Load address brne w12 rcall getc ; addrh = getc(); mov addrh,u_data rcall getc ; addrl = getc(); mov addrl,u_data rjmp put_ret ; goto reply(); ;====== 'D' - Write Data Memory ============================================ w12: cpi u_data,'D' ; 'D' Write data memory brne w13 rcall getc ; get data rcall eeprom_write rjmp put_ret ;====== 'd' - Read Data Memory ============================================= w13: cpi u_data,'d' ; 'd' Read data memory brne w14 rcall read_send_datamem rjmp waitcmd ; goto waitcmd(); ;====== 'L' - Leave Programming Mode ======================================= w14: cpi u_data,'L' ; 'L' Leave programming mode brne w142 w141: pas_RESET ; set RESET passive release_ports ; release ports set_LED ; LED off rjmp put_ret ;====== 'E' - Exit , release all Ports, inhibit AVR910 ===================== w142: cpi u_data,'E' ; 'E' xit brne w15 rjmp w141 ; exit command for AVR Prog ;====== 'e' - Chip Erase =================================================== w15: cpi u_data,'e' ; 'e' Chip erase brne w16 ldi s_data,0xac rcall wrser ; wrser(0xac) SPI write (byte 1) tst device brmi w151 ; S89 device ldi s_data,0x80 rcall wrser ; wrser(0x80) SPI write (byte 2) w151: ldi s_data,0x04 rcall wrser ; wrser(0x04) SPI write (byte 3) ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 4) ldi temp1,40 ; delay 40mS rcall delay rjmp put_ret ;====== 'l' - Write Lockbits ============================================== ; writes Lockbits in SPI Byte 2 for old "classic" AVR Chips, and in addition ; writes Lockbits in SPI byte 4 for new Mega and Tiny Devices. ; One Type does not care about the other Byte... ; Some more different Adresses for other devices? w16: cpi u_data,'l' ; 'l' Write Lockbits brne w161 rcall getc ; get data ldi s_data,0xac rcall wrser ; wrser(0xac) SPI write (byte 1) tst device brmi w163 ; S89 device mov s_data,u_data ori s_data,0xe0 rcall wrser ; wrser(u_data) SPI write (byte 2) rjmp w162 ;====== 'f' - Write Fusebits ============================================== w161: cpi u_data,'f' ; 'f' Write Fusebits brne w17 rcall getc ; get data ldi s_data,0xac rcall wrser ; wrser(0xac) SPI write (byte 1) ldi s_data,0xa0 rcall wrser ; wrser(0xa0) SPI write (byte 2) w162: clr s_data rcall wrser ; wrser(0x00) SPI write (byte 3) mov s_data,u_data rcall wrser ; wrser(u_data) SPI write (byte 4) rjmp w164 w163: mov s_data,u_data andi s_data,0xe0 ; S89 device ori s_data,0x07 rcall wrser ; SPI write (byte3) ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 4) w164: ldi temp1,10 ; delay 10mS rcall delay rjmp put_ret ;====== 's' - Read Signature Bytes ========================================= w17: cpi u_data,'s' ; 's' Read signature bytes brne w18 tst device brmi w171 ; S89 device ldi temp3,0x30 mov cmd1,temp3 clr cmd2 ldi temp3,0x02 mov cmd3,temp3 rcall w123r4 dec cmd3 rcall w123r4 clr cmd3 rcall w123r4 rjmp waitcmd w171: rjmp put_err ;====== 'm' - Write Program Memory Page ==================================== w18: cpi u_data,'m' ; 'm' Write Program Memory Page brne w19 ldi s_data,0x4c rcall wrser ; wrser(0x4c) SPI write (byte 1) ; mov s_data,addrh ; original, reload address mov s_data,pol_ah ; for speeding up transfer rcall wrser ; wrser(addrh) SPI write (byte 2) ; mov s_data,addrl ; original, reload address mov s_data,pol_al ; for speeding up transfer rcall wrser ; wrser(addrl) SPI write (byte 3) ldi s_data,0x00 rcall wrser ; wrser(0x00) SPI write (byte 4) rjmp wait_M ; write FLASH delay ;====== ':' - Universal Command ============================================ w19: cpi u_data,':' ; ':' Universal Command brne w20 rcall getc ; get data1 mov cmd1,u_data ; cmd1 = data1 rcall getc ; get data2 mov cmd2,u_data ; cmd2 = data2 rcall getc ; get data3 mov cmd3,u_data ; cmd3 = data3 rcall w123r4 ldi temp1,50 ; delay 50mS rcall delay rjmp put_ret ;====== '.' - New Universal Command ======================================== w20: cpi u_data,'.' ; '.' New Universal Command brne w21 rcall getc ; get data1 mov cmd1,u_data ; cmd1 = data1 rcall getc ; get data2 mov cmd2,u_data ; cmd2 = data2 rcall getc ; get data3 mov cmd3,u_data ; cmd3 = data3 rcall getc ; get data4 rcall w1234 mov u_data,rd_s_data rcall putc ; send data ldi temp1,50 ; delay 50mS rcall delay rjmp put_ret ;====== 'r' - Read Lock Bits ============================================== w21: cpi u_data,'r' ; 'r' Read Lockbits brne w22 ldi s_data,0x58 ; SPI load (byte 1) rjmp w22a ;====== 'F' - Read Fusebits (lfuse) ========================================= w22: cpi u_data,'F' ; 'F' Read Fusebits brne w23 ldi s_data,0x50 ; SPI load (byte 1) w22a: rcall wrser ; wrser(0x5n) SPI write (byte 1) clr s_data ; SPI load (byte 2) rjmp w26 ;====== 'N' - Read high Fusebits ========================================== w23: cpi u_data,'N' ; 'N' Read high Fusebits brne w24 ldi s_data,0x58 rcall wrser ; wrser(0x58) SPI write (byte 1) rjmp w25 ;====== 'Q' - Read extendet Fusebits ============================================== w24: cpi u_data,'Q' ; 'Q' Read extendet Fusebits brne w30 ldi s_data,0x50 ; SPI load (byte 1) rcall wrser ; wrser(0x50) SPI write (byte 1) w25: ldi s_data,0x08 ; SPI load (byte 2) w26: rcall wrser ; wrser(0x00) SPI write (byte 2) clr s_data rcall wrser ; wrser(0x00) SPI write (byte 3) rcall rdser ; SPI read (byte 4) mov u_data,s_data rcall putc ; send data rjmp waitcmd ;====== Unknown Command ==================================================== w30: rjmp put_err ;====== Wait for FLASH write in avr910 mode ================================== wait_S: table Dev_M rcall bel_table brcs ws_pol ; No Page Mode, poll last Byte rjmp put_ret ; in Byte Mode time is long enougt to get next Byte... Bws_pol: ; entry adress for Block mode delay ldi temp3,1 mov B_Flag,temp3 ; set Flag that ws_poll comes back with ret ... ws_pol: tst PollcodeF ; if polling not applicable, standart delay breq ws_del ; polling not used ws_def: cp p_data,PollcodeF ; if (data == PollcodeF) breq ws_del ; wait default delay andi pol_cmd,0x0f ; write command: 0x48, 0x40 ori pol_cmd,0x20 ; read command: 0x28, 0x20 clr temp3 ; clear polling counter ws_cy: tst device brmi ws_89 ; S89 device mov s_data,pol_cmd rcall wrser ; wrser(pol_cmd) SPI write (byte 1) mov s_data,pol_ah rjmp ws_90 ws_89: mov s_data,pol_ah ; s_data = (pol_ah << 3) | 0x01; rcall shift_s_data3 ori s_data,0x01 ws_90: rcall wrser ; wrser(pol_ah) SPI write (byte 2) (S89=byte1) mov s_data,pol_al rcall wrser ; wrser(pol_al) SPI write (byte 3) (S89=byte2) rcall rdser ; SPI read (byte 4) (S89=byte3) tst device brpl ws_cb andi s_data,0x80 ; compare only MSB for S89 device andi p_data,0x80 ws_cb: cp s_data,p_data breq ws_ok ; s_data = p_data dec temp3 brne ws_cy ; loop ws_del: ; 256 polling cycles are over, give additional standart Time ldi temp1,10 ; delay 10mS rcall delay ws_ok: tst B_Flag breq put_ret clr B_Flag ; Reset B_Flag for normal operation ret ;====== Wait for FLASH write in page mode ================================== wait_M: cpi device,0x41 breq wm_del ; polling inapplicable for m103 cpi device,0x23 breq poll_t2313 ; polling different for t2313 cpi p_data, 0xFF ; if last Byte was 0xFF give standart delay breq wm_del andi pol_cmd,0x0f ; write command: 0x48, 0x40 ori pol_cmd,0x20 ; read command: 0x28, 0x20 clr temp3 ; clear polling counter wm_cy: mov s_data,pol_cmd rcall wrser ; wrser(pol_cmd) SPI write (byte 1) mov s_data,pol_ah rcall wrser ; wrser(pol_ah) SPI write (byte 2) mov s_data,pol_al rcall wrser ; wrser(pol_al) SPI write (byte 3) rcall rdser ; SPI read (byte 4) cp s_data,p_data breq wm_ok ; s_data = p_data dec temp3 breq wm_del ; 256 polling cycles are over, give another 50ms delay... rjmp wm_cy ; loop wm_del: ldi temp1,50 ; delay 50mS rcall delay wm_ok: tst B_Mode breq wm_end tst Bcnt2 breq wm_end rjmp w95 wm_end: clr B_Mode ; Reset Block Mode Flag rjmp put_ret poll_t2313: ; Polling ATTiny2313 is different ldi pol_cmd,0xf0 ; Byte1= 0xF0 clr temp3 ; clear polling counter mov pol_ah,temp3 ; Byte2= 0x00 p2313_1: mov s_data,pol_cmd rcall wrser ; wrser(pol_cmd) SPI write (byte 1) mov s_data,pol_ah rcall wrser ; wrser(pol_ah) SPI write (byte 2) mov s_data,pol_al rcall wrser ; wrser(pol_al) SPI write (byte 3) rcall rdser ; SPI read (byte 4) andi s_data,0x01 ; last Bit tells if polling OK breq wm_ok ; s_data = p_data dec temp3 breq wm_del ; 256 polling cycles are over, give another 50ms delay... rjmp p2313_1 ; loop ;====== Command Error ====================================================== put_debug: ; shows u_data on serial for debug reason rcall putc put_err: ldi u_data,'?' ; putc('?') rcall putc ; send '?' rjmp waitcmd ;====== Reply Command ====================================================== put_ret: ldi u_data,0x0d ; putc(0x0D) rcall putc ; send CR rjmp waitcmd ;*************************************************************************** ;* ;* TABLE ;* device codes ;* ;* DESCRIPTION ;* The following device codes must be used by the host computer. Note ;* that the device codes are arbitrary selected, they do not have any ;* thing in common with the signature bytes stored in the device. ;* This are the device Codes recognized by the AVRprog Software. Some ;* Devices may require special hardware or a different, not yet ;* implemented Protocol! Use at your own risk. ;* ;*************************************************************************** Dev_S: ; byte write ; avr910-devcode ,Code during polling Flash. 0x00: no polling supported, program default time ; .db 0x10 ,0x00 ;AT90S1200A No support for this type ; .db 0x11 ,0x00 ;AT90S1200B No support for this type ; .db 0x12 ,0x00 ;AT90S1200C No support for this type .db 0x13 ,0x00 ;AT90S1200 .db 0x20 ,0x7F ;AT90S2313A .db 0x28 ,0x7F ;AT90S4414A .db 0x30 ,0xFF ;AT90S4433A .db 0x34 ,0xFF ;AT90S2333A .db 0x38 ,0x7F ;AT90S8515A .db 0x48 ,0xFF ;AT90S2323A .db 0x4c ,0xFF ;AT90S2343A .db 0x51 ,0xFF ;tn10 .db 0x55 ,0xFF ;tn12 .db 0x56 ,0xFF ;tn15 .db 0x68 ,0xFF ;AT90S8535 .db 0x6c ,0xFF ;AT90S4434 .db 0x86 ,0xFF ;AT89S8252 bug in avrprog in Block write Mode!(See Note 18 for Workaround) .db 0x87 ,0xFF ;AT89S53 bug in avrprog .dw 0 ;End of table Dev_M: ; Devices which support Page Programming. Dont forget the Page Size ; of different Devices. ; Maximum ist 0x40 due to limitated RAM in 2313 Chip. ; (Pages with bigger Pages are programmed multiple times) ; unofficial Device Codes. Match avrdude.conf with tis "avr910-devcode" ; avr910-devcode ,Pagesite in Words .db 0x01 ,0x40 ;m640 avr910-Devicecode not official! ; .db 0x02 ,0x40 ;m644 avr910-Devicecode not official! ; .db 0x03 ,0x40 ;m645 avr910-Devicecode not official! .db 0x04 ,0x40 ;m649 avr910-Devicecode not official! .db 0x05 ,0x40 ;m6490 avr910-Devicecode not official! .db 0x06 ,0x40 ;90PWM2 avr910-Devicecode not official! .db 0x07 ,0x40 ;90PWM3 avr910-Devicecode not official! .db 0x08 ,0x40 ;m1280 avr910-Devicecode not official! .db 0x09 ,0x40 ;m1281 avr910-Devicecode not official! ; .db 0x0a ,0x40 ;m2560 avr910-Devicecode not official! ; .db 0x0b ,0x40 ;m2561 avr910-Devicecode not official! ; .db 0x0c ,0x40 ;m3250 avr910-Devicecode not official! ; .db 0x0d ,0x40 ;m6450 avr910-Devicecode not official! .db 0x0e ,0x10 ;tn24 avr910-Devicecode not official! .db 0x1a ,0x10 ;tn25 avr910-Devicecode not official! .db 0x0f ,0x20 ;tn44 avr910-Devicecode not official! .db 0x1b ,0x20 ;tn45 avr910-Devicecode not official! .db 0x14 ,0x20 ;tn84 avr910-Devicecode not official! .db 0x1c ,0x20 ;tn85 avr910-Devicecode not official! .db 0x1d ,0x40 ;CAN128 avr910-Devicecode not official! .db 0x23 ,0x10 ;tn2313 avr910-Devicecode not official! (STK500 Code used) .db 0x31 ,0x20 ;m48 avr910-Devicecode not official! .db 0x33 ,0x20 ;m88 avr910-Devicecode not official! .db 0x35 ,0x40 ;m168 avr910-Devicecode not official! ; .db 0x36 ,0x40 ;m165 avr910-Devicecode not official! .db 0x37 ,0x40 ;m164 avr910-Devicecode not official! .db 0x39 ,0x40 ;m324 avr910-Devicecode not official! ; .db 0x3c ,0x40 ;m325 avr910-Devicecode not official! .db 0x3d ,0x40 ;m329 avr910-Devicecode not official! .db 0x3e ,0x40 ;m3290 avr910-Devicecode not official! .db 0x57 ,0x10 ;tn13 avr910-Devicecode not official! ;Appearance of this Devicecodes does not mean this Devices are or will be fully supported ! ; official Devicecodes as matched in AVRProg V1.40 .db 0x3a ,0x20 ;m8515, PROGRAMMER_PAGESIZE 32 words (0x20) .db 0x3b ,0x20 ;m8515boot Bootloader Mode untested! .db 0x41 ,0x40 ;m103 .db 0x43 ,0x40 ;m128 .db 0x44 ,0x40 ;m128boot Bootloader Mode untested! .db 0x45 ,0x40 ;m64 .db 0x46 ,0x40 ;m64boot Bootloader Mode untested! .db 0x5e ,0x10 ;tn26 .db 0x60 ,0x40 ;m161 .db 0x61 ,0x40 ;m161boot Bootloader Mode untested! .db 0x62 ,0x40 ;m162 .db 0x63 ,0x40 ;m162boot Bootloader Mode untested! .db 0x64 ,0x40 ;m163 .db 0x66 ,0x40 ;m163boot Bootloader Mode untested! .db 0x69 ,0x20 ;m8535 .db 0x6a ,0x20 ;m8535boot Bootloader Mode untested! .db 0x72 ,0x40 ;m32 .db 0x73 ,0x40 ;m32boot Bootloader Mode untested! .db 0x74 ,0x40 ;m16 .db 0x75 ,0x40 ;m16boot Bootloader Mode untested! .db 0x76 ,0x20 ;m8 .db 0x77 ,0x20 ;m8boot Bootloader Mode untested! .db 0x78 ,0x40 ;m169 .db 0x79 ,0x40 ;m169boot Bootloader Mode untested! .dw 0 ;End of Table ; Devices with known avr910 Devicecodes, but not supported with this Programmer ; .db 0x42 ,0x40 ;m603 obsolete ; .db 0x50 ;tn11 Needs additional High Voltage Hardware and uses different Protocoll! No Support! ; .db 0x58 ;tn19 Obsolete ; .db 0x5c ;tn28 Only supported in parallel Programming Mode! ; .db 0x65 ,0x20 ;m83 obsolete ; .db 0x67 ,0x20 ;m83boot obsolete ; .db 0x70 ;AT90C8534 unknown Hardware, untested! ; .db 0x71 ;AT90C8544 unknown Hardware, untested! ; .db 0x80 ;AT89C1051 unknown Hardware, untested! ; .db 0x81 ;AT89C2051 unknown Hardware, untested! ;*************************************************************************** ;* ;* TABLE ;* revision codes ;* ;*************************************************************************** SW_Ver: .db "38",0,0 HW_Ver: .db "12",0,0 ;*************************************************************************** ;* ;* TABLE ;* ID string "AVR ISP" ;* ;*************************************************************************** ID_Str: .db "AVR ISP",0 ;*************************************************************************** ;* ;* TABLE ;* Chip ID string to identify the Firmware ;* ;*************************************************************************** ChipID: .db "Ver.3.8c (AVR109 Mode, 7.3728Mhz, 115.200 baud) for AN910, AT90S2313" .db "www.mikrocontroller-projekte.de 26.Feb.2006",0 ;**** End of File ****
