#TARGET3001 Version 12; EAGLE-Script Version 2.1; für EAGLE Version 4.11
#Die folgenden Arbeitsschritte sind für die AUSFÜHRUNG des Scripts in EAGLE notwendig:
#Scripte können in EAGLE mit File\Open\Script\*.scr angezeigt werden.
#1) Datei *.scr (z.B. test.scr) in das SCR-Verzeichnis von EAGLE kopieren.
#2) Ein neues schematic in EAGLE öffnen.
#3) In der Befehlszeile "script test" eingeben.
#2008-06-30-DMX-Dimmer.lbr
REMOVE 2008-06-30-DMX-Dimmer.lbr;
Open 2008-06-30-DMX-Dimmer.lbr;
Grid MIC;
SET WIRE_BEND 2;
#Hier alle Bauteile/Symbole und Gehaeuse im TARGET3001-Projekt:
Edit IC1.sym;
LAYER Pins;
PIN 'PD3' 0 I/O None R90 Short Off (-8890 -20320);
LAYER Symbols;
CHANGE FONT VECTOR;
CHANGE SIZE 1500;
CHANGE RATIO 13;
TEXT 'PD3' R90.0 (-8140 -17280);
LAYER Pins;
PIN 'PD4' 0 I/O None R90 Short Off (-6350 -20320);
LAYER Symbols;
TEXT 'PD4' R90.0 (-5600 -17280);
LAYER Pins;
PIN 'GND@1' 0 Pwr None R90 Short Off (-3810 -20320);
LAYER Symbols;
TEXT 'GND' R90.0 (-3060 -17280);
LAYER Pins;
PIN 'VCC@1' 0 Pwr None R90 Short Off (-1270 -20320);
LAYER Symbols;
TEXT 'VCC' R90.0 (-520 -17280);
LAYER Pins;
PIN 'GND@2' 0 Pwr None R90 Short Off (1270 -20320);
LAYER Symbols;
TEXT 'GND' R90.0 (2020 -17280);
LAYER Pins;
PIN 'VCC@2' 0 Pwr None R90 Short Off (3810 -20320);
LAYER Symbols;
TEXT 'VCC' R90.0 (4560 -17280);
LAYER Pins;
PIN 'PB6' 0 I/O None R90 Short Off (6350 -20320);
LAYER Symbols;
TEXT 'PB6' R90.0 (7100 -17280);
LAYER Pins;
PIN 'PB7' 0 I/O None R90 Short Off (8890 -20320);
LAYER Symbols;
TEXT 'PB7' R90.0 (9640 -17280);
LAYER Pins;
PIN 'PD5' 0 I/O None R180 Short Off (13970 -8890);
LAYER Symbols;
TEXT 'PD5' R0.0 (7420 -9640);
LAYER Pins;
PIN 'PD6' 0 I/O None R180 Short Off (13970 -6350);
LAYER Symbols;
TEXT 'PD6' R0.0 (7420 -7100);
LAYER Pins;
PIN 'PD7' 0 I/O None R180 Short Off (13970 -3810);
LAYER Symbols;
TEXT 'PD7' R0.0 (7420 -4560);
LAYER Pins;
PIN 'PB0' 0 I/O None R180 Short Off (13970 -1270);
LAYER Symbols;
TEXT 'PB0' R0.0 (7525 -2020);
LAYER Pins;
PIN 'PB1' 0 I/O None R180 Short Off (13970 1270);
LAYER Symbols;
TEXT 'PB1' R0.0 (7525 520);
LAYER Pins;
PIN 'PB2' 0 I/O None R180 Short Off (13970 3810);
LAYER Symbols;
TEXT 'PB2' R0.0 (7525 3060);
LAYER Pins;
PIN 'PB3' 0 I/O None R180 Short Off (13970 6350);
LAYER Symbols;
TEXT 'PB3' R0.0 (7525 5600);
LAYER Pins;
PIN 'PB4' 0 I/O None R180 Short Off (13970 8890);
LAYER Symbols;
TEXT 'PB4' R0.0 (7525 8140);
LAYER Pins;
PIN 'PC1' 0 I/O None R270 Short Off (-8890 20320);
LAYER Symbols;
TEXT 'PC1' R90.0 (-8140 13770);
LAYER Pins;
PIN 'PC0' 0 I/O None R270 Short Off (-6350 20320);
LAYER Symbols;
TEXT 'PC0' R90.0 (-5600 13770);
LAYER Pins;
PIN 'ADC7' 0 In None R270 Short Off (-3810 20320);
LAYER Symbols;
TEXT 'ADC7' R90.0 (-3060 12445);
LAYER Pins;
PIN 'GND@3' 0 Pwr None R270 Short Off (-1270 20320);
LAYER Symbols;
TEXT 'GND' R90.0 (-520 13285);
LAYER Pins;
PIN 'AREF' 0 Pas None R270 Short Off (1270 20320);
LAYER Symbols;
TEXT 'AREF' R90.0 (2020 12480);
LAYER Pins;
PIN 'ADC6' 0 In None R270 Short Off (3810 20320);
LAYER Symbols;
TEXT 'ADC6' R90.0 (4560 12445);
LAYER Pins;
PIN 'AVCC' 0 Pas None R270 Short Off (6350 20320);
LAYER Symbols;
TEXT 'AVCC' R90.0 (7100 12270);
LAYER Pins;
PIN 'PB5' 0 I/O None R270 Short Off (8890 20320);
LAYER Symbols;
TEXT 'PB5' R90.0 (9640 13875);
LAYER Pins;
PIN 'PD2' 0 I/O None R0 Short Off (-13970 -8890);
LAYER Symbols;
TEXT 'PD2' R0.0 (-10930 -9640);
LAYER Pins;
PIN 'PD1' 0 I/O None R0 Short Off (-13970 -6350);
LAYER Symbols;
TEXT 'PD1' R0.0 (-10930 -7100);
LAYER Pins;
PIN 'PD0' 0 I/O None R0 Short Off (-13970 -3810);
LAYER Symbols;
TEXT 'PD0' R0.0 (-10930 -4560);
LAYER Pins;
PIN 'RC6' 0 I/O None R0 Short Off (-13970 -1270);
LAYER Symbols;
TEXT 'RC6' R0.0 (-10950 -2020);
LAYER Pins;
PIN 'PC5' 0 I/O None R0 Short Off (-13970 1270);
LAYER Symbols;
TEXT 'PC5' R0.0 (-10930 520);
LAYER Pins;
PIN 'PC4' 0 I/O None R0 Short Off (-13970 3810);
LAYER Symbols;
TEXT 'PC4' R0.0 (-10930 3060);
LAYER Pins;
PIN 'PC3' 0 I/O None R0 Short Off (-13970 6350);
LAYER Symbols;
TEXT 'PC3' R0.0 (-10930 5600);
LAYER Pins;
PIN 'PC2' 0 I/O None R0 Short Off (-13970 8890);
LAYER Symbols;
TEXT 'PC2' R0.0 (-10930 8140);
WIRE 300 ROUND (-11430 -17780) (-11430 17780);
WIRE 300 ROUND (-11430 17780) (11430 17780);
WIRE 300 ROUND (11430 17780) (11430 -17780);
WIRE 300 ROUND (11430 -17780) (-11430 -17780);
LAYER Names;
CHANGE SIZE 2000;
TEXT >NAME R90.0 (-15105 -18415);
LAYER Values;
TEXT >VALUE R90.0 (17105 -17780);
EDIT IC1.pac;
DESCRIPTION 'TQFP32';
LAYER tPlace;
WIRE 300 ROUND (3500 -3500) (3500 3500);
WIRE 300 ROUND (3500 3500) (-3500 3500);
WIRE 300 ROUND (-3500 3500) (-3500 -3500);
WIRE 300 ROUND (-3500 -3500) (3500 -3500);
LAYER Top;
SMD 900 600 -0 R180.0 '1' (4050 -2800);
SMD 900 600 -0 R180.0 '2' (4050 -2000);
SMD 900 600 -0 R180.0 '3' (4050 -1200);
SMD 900 600 -0 R180.0 '4' (4050 -400);
SMD 900 600 -0 R180.0 '5' (4050 400);
SMD 900 600 -0 R180.0 '6' (4050 1200);
SMD 900 600 -0 R180.0 '7' (4050 2000);
SMD 900 600 -0 R180.0 '8' (4050 2800);
SMD 600 900 -0 R180.0 '9' (2800 4050);
SMD 600 900 -0 R180.0 '10' (2000 4050);
SMD 600 900 -0 R180.0 '11' (1200 4050);
SMD 600 900 -0 R180.0 '12' (400 4050);
SMD 600 900 -0 R180.0 '13' (-400 4050);
SMD 600 900 -0 R180.0 '14' (-1200 4050);
SMD 600 900 -0 R180.0 '15' (-2000 4050);
SMD 600 900 -0 R0.0 '16' (-2800 4050);
SMD 900 600 -0 R180.0 '17' (-4050 2800);
SMD 900 600 -0 R180.0 '18' (-4050 2000);
SMD 900 600 -0 R180.0 '19' (-4050 1200);
SMD 900 600 -0 R180.0 '20' (-4050 400);
SMD 900 600 -0 R180.0 '21' (-4050 -400);
SMD 900 600 -0 R180.0 '22' (-4050 -1200);
SMD 900 600 -0 R180.0 '23' (-4050 -2000);
SMD 900 600 -0 R180.0 '24' (-4050 -2800);
SMD 600 900 -0 R180.0 '25' (-2800 -4050);
SMD 600 900 -0 R180.0 '26' (-2000 -4050);
SMD 600 900 -0 R180.0 '27' (-1200 -4050);
SMD 600 900 -0 R180.0 '28' (-400 -4050);
SMD 600 900 -0 R180.0 '29' (400 -4050);
SMD 600 900 -0 R180.0 '30' (1200 -4050);
SMD 600 900 -0 R180.0 '31' (2000 -4050);
SMD 600 900 -0 R180.0 '32' (2800 -4050);
LAYER tGlue;
CIRCLE 0 (-2000 -1701) (-1700 -1701);
CIRCLE 0 (2070 1944) (2370 1944);
LAYER tPlace;
CIRCLE 0 (3009 -2891) (3209 -2891);
TEXT >NAME R0.0 (-4558 -7170);
TEXT >VALUE R0.0 (-2355 4985);
Edit IC1.dev;
Prefix 'IC';
Description '';
Value on;
Add IC1 Next 0 (0 0);
Package IC1;
CONNECT PD3 1 PD4 2 GND@1 3 VCC@1 4 GND@2 5 VCC@2 6 PB6 7 PB7 8 PD5 9 PD6 10 PD7 11 PB0 12 PB1 13 PB2 14 PB3 15 PB4 16 PC1 24 PC0 23 ADC7 22 GND@3 21 AREF 20 ADC6 19 AVCC 18 PB5 17 PD2 32 PD1 31 PD0 30 RC6 29 PC5 28 PC4 27 PC3 26 PC2 25;
Edit IC2.sym;
LAYER Symbols;
WIRE 300 ROUND (-669 -3041) (-669 -8121);
WIRE 300 ROUND (-669 -8121) (3776 -5581);
WIRE 300 ROUND (3776 -5581) (-669 -3041);
WIRE 300 ROUND (3776 1404) (3776 6484);
WIRE 300 ROUND (3776 6484) (-669 3944);
WIRE 300 ROUND (-669 3944) (3776 1404);
WIRE 300 ROUND (8856 5849) (3776 5849);
WIRE 300 ROUND (8856 -5581) (3776 -5581);
WIRE 300 ROUND (-669 3944) (-2574 3944);
WIRE 300 ROUND (-2574 3944) (-2574 -6851);
WIRE 300 ROUND (-2574 -6851) (-669 -6851);
WIRE 300 ROUND (-2574 2039) (-9559 2039);
WIRE 300 ROUND (-669 -4311) (-4479 -4311);
WIRE 300 ROUND (-4479 -4311) (-4479 5214);
WIRE 300 ROUND (-4479 -1771) (-9559 -1771);
WIRE 300 ROUND (1871 -1771) (1871 -4311);
WIRE 300 ROUND (8856 2039) (5046 2039);
WIRE 300 ROUND (5046 2039) (5046 134);
WIRE 300 ROUND (5046 134) (1236 134);
WIRE 300 ROUND (1236 134) (1236 2674);
WIRE 300 ROUND (1236 5214) (-4479 5214);
CIRCLE 0 (-5114 -1771) (-4614 -1771);
CIRCLE 0 (-2574 2039) (-2074 2039);
CIRCLE 0 (1236 5214) (1736 5214);
CIRCLE 0 (1871 -4311) (2371 -4311);
CIRCLE 0 (-669 -4311) (-169 -4311);
WIRE 300 ROUND (8856 -1771) (1871 -1771);
LAYER Pins;
PIN 'gnd' 0 Pwr None R0 Short Off (-12099 5849);
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 10;
TEXT 'gnd' R0.0 (-9059 5099);
LAYER Pins;
PIN '+Vs' 0 Pwr None R0 Short Off (-12099 -5581);
LAYER Symbols;
TEXT '+Vs' R0.0 (-9069 -6331);
WIRE 300 ROUND (8856 9024) (-9559 9024);
WIRE 300 ROUND (-9559 9024) (-9559 -8756);
WIRE 300 ROUND (-9559 -8756) (8856 -8756);
LAYER Pins;
PIN 'RO' 0 Out None R180 Short Off (11396 -5581);
LAYER Symbols;
TEXT 'RO' R0.0 (5836 -7601);
LAYER Pins;
PIN 'DE' 0 I/O None R180 Short Off (11396 2039);
LAYER Symbols;
TEXT 'DE' R0.0 (5836 19);
LAYER Pins;
PIN 'RE/' 0 I/O None R180 Short Off (11396 -1771);
LAYER Symbols;
TEXT 'RE/' R0.0 (4576 -3791);
LAYER Pins;
PIN 'B' 0 I/O None R0 Short Off (-12099 -1771);
LAYER Symbols;
TEXT 'B' R0.0 (-8454 -3791);
LAYER Pins;
PIN 'A' 0 Out None R0 Short Off (-12099 2039);
LAYER Symbols;
TEXT 'A' R0.0 (-8454 19);
LAYER Pins;
PIN 'DI' 0 In None R180 Short Off (11396 5849);
LAYER Symbols;
TEXT 'DI' R0.0 (5836 3829);
LAYER Names;
CHANGE SIZE 2000;
TEXT >NAME R0.0 (916 -14566);
LAYER Values;
TEXT >VALUE R0.0 (-10519 -11391);
LAYER Symbols;
WIRE 300 ROUND (8856 -8756) (8856 9024);
EDIT IC2.pac;
DESCRIPTION 'SO8';
LAYER tGlue;
CIRCLE 0 (2000 -2500) (2300 -2500);
LAYER tPlace;
WIRE 300 ROUND (300 0) (4000 0);
WIRE 300 ROUND (4000 0) (4000 -5000);
WIRE 300 ROUND (4000 -5000) (0 -5000);
WIRE 300 ROUND (0 -5000) (0 -300);
CHANGE SIZE 1000;
CHANGE RATIO 13;
TEXT >NAME R90.0 (6715 -7560);
LAYER Top;
SMD 490 1000 -0 R270.0 '1' (-600 -595);
SMD 490 1000 -0 R270.0 '2' (-600 -1865);
SMD 490 1000 -0 R270.0 '3' (-600 -3135);
SMD 490 1000 -0 R270.0 '4' (-600 -4405);
SMD 490 1000 -0 R270.0 '5' (4600 -4405);
SMD 490 1000 -0 R270.0 '6' (4600 -3135);
SMD 490 1000 -0 R270.0 '7' (4600 -1865);
SMD 490 1000 -0 R270.0 '8' (4600 -595);
LAYER tPlace;
WIRE 300 ROUND (300 0) (0 -300);
WIRE 200 ROUND (300 0) (300 -5000);
Edit IC2.dev;
Prefix 'IC';
Description 'RS485 Schnittstellentreiber (DIL8)';
Value on;
Add IC2 Next 0 (0 0);
Package IC2;
CONNECT gnd 5 +Vs 8 RO 1 DE 3 RE/ 2 B 7 A 6 DI 4;
Edit REF4.sym;
LAYER Symbols;
RECT (-1905 -2540) (1905 -3175);
LAYER Pins;
PIN 'GND' 0 Sup None R270 Short Off (0 0);
Edit REF4.dev;
Prefix 'REF';
Description 'Referenz GND';
Value on;
Add REF4 Next 0 (0 0);
Edit REF49.sym;
LAYER Symbols;
LAYER Pins;
Edit REF49.dev;
Prefix 'REF';
Value on;
Add REF49 Next 0 (0 0);
Edit REF8.sym;
PIN '+5V' 0 Sup None R0 Short Off (0 0);
LAYER Symbols;
CHANGE SIZE 1500;
TEXT '+5V' R90.0 (5830 -5025);
WIRE 300 ROUND (3810 635) (3810 -635);
WIRE 300 ROUND (4445 0) (3175 0);
CIRCLE 300 (3810 0) (3810 -1270);
Edit REF8.dev;
Prefix 'REF';
Description 'Referenz +5V';
Value on;
Add REF8 Next 0 (0 0);
Edit BR1.sym;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
TEXT >NAME R0.0 (2540 8255);
LAYER Pins;
PIN '+' 0 Pas None R180 Short Off (10160 0);
LAYER Symbols;
CHANGE RATIO 12;
TEXT '+' R0.0 (9670 -2655);
LAYER Pins;
PIN '~@1' 0 Pas None R270 Short Off (0 10160);
LAYER Symbols;
TEXT '~' R0.0 (1135 8775);
LAYER Pins;
PIN '~@2' 0 Pas None R90 Short Off (0 -10160);
LAYER Symbols;
TEXT '~' R0.0 (-2385 -10910);
LAYER Pins;
PIN '-' 0 Pas None R0 Short Off (-10160 0);
LAYER Symbols;
TEXT '-' R0.0 (-10295 1155);
WIRE 300 ROUND (-2540 -5080) (-6604 -4064);
WIRE 300 ROUND (-2540 -5080) (-3556 -1016);
WIRE 300 ROUND (-3988 -6579) (-940 -3531);
WIRE 300 ROUND (-2540 5080) (-6604 4064);
WIRE 300 ROUND (-2540 5080) (-3556 1016);
WIRE 300 ROUND (-3988 6579) (-940 3531);
WIRE 300 ROUND (5080 2540) (4064 6604);
WIRE 300 ROUND (5080 2540) (1016 3556);
WIRE 300 ROUND (3632 1016) (6680 4064);
WIRE 300 ROUND (5080 -2540) (4064 -6604);
WIRE 300 ROUND (5080 -2540) (1016 -3556);
WIRE 300 ROUND (3632 -1067) (6680 -4115);
WIRE 300 ROUND (-7620 0) (0 -7620);
WIRE 300 ROUND (-6604 -4064) (-3556 -1016);
WIRE 300 ROUND (-6604 4064) (-3556 1016);
WIRE 300 ROUND (-7620 0) (0 7620);
WIRE 300 ROUND (1016 3556) (4064 6604);
WIRE 300 ROUND (0 7620) (7620 0);
WIRE 300 ROUND (0 -7620) (7620 0);
WIRE 300 ROUND (1016 -3556) (4064 -6604);
CHANGE SIZE 1000;
CHANGE RATIO 8;
TEXT 'D3' R0.0 (-5715 5080);
TEXT 'D1' R0.0 (5080 5080);
TEXT 'D4' R0.0 (-5715 -5715);
TEXT 'D2' R0.0 (5080 -5715);
EDIT BR1.pac;
DESCRIPTION 'BRUECKE-SMD';
LAYER tPlace;
CHANGE SIZE 2000;
CHANGE RATIO 13;
TEXT '~' R0.0 (886 -434);
TEXT '~' R0.0 (6012 -548);
TEXT '+' R0.0 (6126 4308);
TEXT '-' R0.0 (909 4308);
LAYER Top;
SMD 1200 1520 -0 R0.0 '1' (1650 -1120);
SMD 1200 1520 -0 R0.0 '2' (6850 -1120);
SMD 1200 1520 -0 R0.0 '3' (6850 7620);
SMD 1200 1520 -0 R0.0 '4' (1650 7620);
LAYER tPlace;
CHANGE RATIO 10;
TEXT >NAME R0.0 (0 8890);
WIRE 300 ROUND (8500 0) (0 0);
WIRE 300 ROUND (0 0) (0 2500);
WIRE 300 ROUND (0 2500) (1588 3250);
WIRE 300 ROUND (1588 3250) (0 4000);
WIRE 300 ROUND (0 4000) (0 6500);
WIRE 300 ROUND (0 6500) (8500 6500);
WIRE 300 ROUND (8500 6500) (8500 0);
Edit BR1.dev;
Prefix 'BR';
Description 'B600C500 SMD 5J GLEICHRICHTER SMD-Brückengleichrichter, 1 A * Spitzensperrspannung/Nennstrom V/A* 1000 V/0,8 A ; Abb.';
Value on;
Add BR1 Next 0 (0 0);
Package BR1;
CONNECT + 3 ~@1 1 ~@2 2 - 4;
Edit REF9.sym;
LAYER Symbols;
LAYER Pins;
Edit REF9.dev;
Prefix 'REF';
Value on;
Add REF9 Next 0 (0 0);
Edit L1.sym;
LAYER Values;
TEXT >VALUE R0.0 (-5080 -4445);
Edit L1.dev;
Prefix 'L';
Description 'Drossel von Neosid stehend 0.55 Ohm 0.66A RM 5 mm (Neosid5-7.5)';
Value on;
Add L1 Next 0 (0 0);
Edit IC3.sym;
LAYER Pins;
PIN 'CB' 0 In None R0 Short Off (-8890 3810);
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
TEXT 'CB' R0.0 (-5850 3060);
LAYER Pins;
PIN 'NC@1' 0 NC None R0 Short Off (-8890 1270);
LAYER Symbols;
TEXT 'NC' R0.0 (-5850 520);
LAYER Pins;
PIN 'NC@2' 0 NC None R0 Short Off (-8890 -1270);
LAYER Symbols;
TEXT 'NC' R0.0 (-5850 -2020);
LAYER Pins;
PIN 'FB' 0 In None R0 Short Off (-8890 -3810);
LAYER Symbols;
TEXT 'FB' R0.0 (-5850 -4560);
LAYER Pins;
PIN 'VSW' 0 Pas None R180 Short Off (13970 3810);
LAYER Symbols;
TEXT 'VSW' R0.0 (6835 3060);
LAYER Pins;
PIN 'VIN' 0 Pwr None R180 Short Off (13970 1270);
LAYER Symbols;
TEXT 'VIN' R0.0 (7930 520);
LAYER Pins;
PIN 'GND' 0 Pwr None R180 Short Off (13970 -1270);
LAYER Symbols;
TEXT 'GND' R0.0 (6925 -2020);
LAYER Pins;
PIN 'ON/OFF' 0 In None R180 Short Off (13970 -3810);
LAYER Symbols;
TEXT 'ON/OFF' R0.0 (4150 -4560);
WIRE 300 ROUND (-6350 6350) (11430 6350);
WIRE 300 ROUND (11430 6350) (11430 -6350);
WIRE 300 ROUND (11430 -6350) (-6350 -6350);
WIRE 300 ROUND (-6350 -6350) (-6350 6350);
LAYER Values;
CHANGE SIZE 2000;
TEXT >VALUE R0.0 (-6350 -8850);
EDIT IC3.pac;
DESCRIPTION 'SO8_SOT96-1';
LAYER tPlace;
WIRE 200 ROUND (-2500 2000) (-2500 -2000);
WIRE 200 ROUND (-2500 -2000) (2500 -2000);
WIRE 200 ROUND (2500 -2000) (2500 2000);
WIRE 200 ROUND (2500 2000) (-2500 2000);
WIRE 200 ROUND (-2500 -1500) (2500 -1500);
LAYER Top;
SMD 600 1200 -0 R0.0 '1' (-1905 -2500);
SMD 600 1200 -0 R0.0 '2' (-635 -2500);
SMD 600 1200 -0 R0.0 '3' (635 -2500);
SMD 600 1200 -0 R0.0 '4' (1905 -2500);
SMD 600 1200 -0 R0.0 '5' (1905 2500);
SMD 600 1200 -0 R0.0 '6' (635 2500);
SMD 600 1200 -0 R0.0 '7' (-635 2500);
SMD 600 1200 -0 R0.0 '8' (-1905 2500);
LAYER tPlace;
CHANGE SIZE 1500;
TEXT >NAME R0.0 (-2540 3810);
TEXT >VALUE R0.0 (-2540 -5080);
LAYER tGlue;
CIRCLE 0 (0 0) (500 0);
LAYER tPlace;
CIRCLE 0 (-2064 -1111) (-1864 -1111);
Edit IC3.dev;
Prefix 'IC';
Description 'SIMPLE SWITCHER; Power Converter High Efficiency 500mA Step-Down Voltage Regulator';
Value on;
Add IC3 Next 0 (0 0);
Package IC3;
CONNECT CB 1 NC@1 2 NC@2 3 FB 4 VSW 8 VIN 7 GND 6 ON/OFF 5;
Edit C3.sym;
LAYER Symbols;
WIRE 300 ROUND (2858 -2540) (-2858 -2540);
WIRE 300 ROUND (-2858 -2540) (-2858 -4128);
WIRE 300 ROUND (-2858 -4128) (2858 -4128);
WIRE 300 ROUND (2858 -4128) (2858 -2540);
WIRE 300 ROUND (2858 -5080) (-2858 -5080);
CHANGE SIZE 2000;
TEXT '+' R90.0 (2635 -1305);
LAYER Pins;
PIN '+' 0 Pas None R270 Short Off (0 0);
PIN '-' 0 Pas None R90 Short Off (0 -7620);
LAYER Names;
TEXT >NAME R90.0 (5492 -2865);
LAYER Values;
TEXT >VALUE R90.0 (-3715 -3900);
EDIT C3.pac;
DESCRIPTION '1206_ELKO';
LAYER tPlace;
CHANGE SIZE 1500;
TEXT '-' R0.0 (2540 -635);
LAYER tGlue;
CIRCLE 0 (0 0) (200 0);
LAYER Top;
SMD 1000 1600 -0 R0.0 '2' (1500 0);
SMD 1000 1600 -0 R0.0 '1' (-1500 0);
LAYER tPlace;
WIRE 300 ROUND (-1600 800) (1600 800);
WIRE 300 ROUND (1600 800) (1600 -800);
WIRE 300 ROUND (1600 -800) (-1600 -800);
WIRE 300 ROUND (-1600 -800) (-1600 800);
TEXT >NAME R0.0 (-2208 1200);
TEXT >VALUE R0.0 (-1905 -1905);
Edit C3.dev;
Prefix 'C';
Description 'Tantal-Elektrolyt-Kondensator 1µF, 16V';
Value on;
Add C3 Next 0 (0 0);
Package C3;
CONNECT + 1 - 2;
Edit C2.sym;
LAYER Pins;
PIN '1' 0 Pas None R0 Short Off (-3810 0);
PIN '2' 0 Pas None R180 Short Off (3810 0);
LAYER Symbols;
RECT (-952 1905) (-318 -1905);
RECT (318 1905) (952 -1905);
LAYER Names;
CHANGE SIZE 2000;
TEXT >NAME R0.0 (-3493 3175);
LAYER Values;
TEXT >VALUE R0.0 (-3493 -5080);
EDIT C2.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
SMD 1000 1250 -0 R90.0 '2' (0 1000);
SMD 1000 1250 -0 R90.0 '1' (0 -1000);
LAYER tPlace;
WIRE 300 ROUND (-625 -1000) (-625 1000);
WIRE 300 ROUND (-625 1000) (625 1000);
WIRE 300 ROUND (625 1000) (625 -1000);
WIRE 300 ROUND (-625 -1000) (625 -1000);
CHANGE SIZE 800;
TEXT >NAME R90.0 (-1072 -938);
TEXT >VALUE R90.0 (1905 -1270);
Edit C2.dev;
Prefix 'C';
Description 'Keramik-Vielschicht-Kondensator 10nF, 50V';
Value on;
Add C2 Next 0 (0 0);
Package C2;
CONNECT 1 1 2 2;
Edit REF6.sym;
LAYER Symbols;
LAYER Pins;
Edit REF6.dev;
Prefix 'REF';
Value on;
Add REF6 Next 0 (0 0);
Edit L2.sym;
LAYER Symbols;
WIRE 300 ROUND (-2540 1905) (2540 1905);
WIRE 300 ROUND (-2540 2540) (2540 2540);
WIRE 300 ROUND (-2540 3175) (2540 3175);
LAYER Pins;
PIN '2' 0 Pas None R180 Short Off (5080 635);
LAYER Symbols;
CIRCLE 300 (-1905 635) (-1270 635);
CIRCLE 300 (-635 635) (0 635);
CIRCLE 300 (635 635) (1270 635);
CIRCLE 300 (1905 635) (2540 635);
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
TEXT >NAME R0.0 (-7620 2540);
LAYER Values;
LAYER Pins;
PIN '1' 0 Pas None R0 Short Off (-5080 635);
EDIT L2.pac;
DESCRIPTION 'EPCOS INDUCTOR 220UH 800MA';
LAYER Top;
SMD 2790 2920 -0 R270.0 '1' (-5123 33);
SMD 2790 2920 -0 R270.0 '2' (5099 65);
LAYER tPlace;
WIRE 300 ROUND (6314 1959) (1714 4529);
WIRE 300 ROUND (1714 4529) (-1703 4529);
WIRE 300 ROUND (-1703 4529) (-6274 1995);
WIRE 300 ROUND (-6274 1995) (-6274 -1920);
WIRE 300 ROUND (-6274 -1920) (-1748 -4636);
WIRE 300 ROUND (-1748 -4636) (1737 -4636);
WIRE 300 ROUND (1737 -4636) (6308 -1898);
WIRE 300 ROUND (6308 -1898) (6314 1959);
WIRE 300 ROUND (3909 3262) (3909 -3233);
WIRE 300 ROUND (-3853 3285) (-3853 -3369);
CIRCLE 300 (17 -84) (17 3486);
CIRCLE 300 (17 2015) (17 2273);
CIRCLE 300 (2066 51) (2066 309);
CIRCLE 300 (30 -2102) (30 -1844);
CHANGE SIZE 1000;
CHANGE RATIO 13;
TEXT >NAME R90.0 (7968 -3457);
TEXT >VALUE R90.0 (-6947 -2706);
Edit L2.dev;
Prefix 'L';
Description '# Induktivitätstyp:Power Inductor
# Induktivität:220µH
# Tolerance, inductance:±20%
# Widerstand:0.53R
# Strom, DC max.:800mA
# Frequenz, Resonanz:20MHz
# Gehäusetyp:SMD
# Material, core:Ferrite
# Toleranz +:20%
# Toleranz -:20%
# Anschlussart:SMD
# Frequenz, Induktanzmessung:100kHz
# Klimakategorie:40/085/56';
Value on;
Add L2 Next 0 (0 0);
Package L2;
CONNECT 2 2 1 1;
Edit D3.sym;
LAYER Symbols;
WIRE 300 ROUND (-1905 1270) (-1905 2508);
WIRE 300 ROUND (1905 2508) (1905 3746);
WIRE 300 ROUND (0 -1270) (0 2540);
LAYER Pins;
PIN 'A' 0 Pas None R90 Short Off (0 -3810);
LAYER Symbols;
CHANGE SIZE 1500;
TEXT 'A' R90.0 (2655 -4580);
LAYER Pins;
PIN 'K' 0 Pas None R270 Short Off (0 5080);
LAYER Symbols;
TEXT 'K' R90.0 (2655 4650);
WIRE 300 ROUND (1905 -1270) (0 2540);
WIRE 300 ROUND (0 2540) (-1905 -1270);
WIRE 300 ROUND (-1905 -1270) (1905 -1270);
WIRE 300 ROUND (-1905 2508) (1905 2508);
LAYER Names;
CHANGE SIZE 2000;
TEXT >NAME R90.0 (-3175 -4445);
LAYER Values;
TEXT >VALUE R90.0 (5715 -4445);
EDIT D3.pac;
DESCRIPTION 'SMA';
LAYER tPlace;
CHANGE SIZE 1500;
TEXT 'Gehäuse bitte überprüfen!!!' R0.0 (-15650 2945);
WIRE 300 ROUND (-1270 1350) (-1270 -1350);
TEXT >VALUE R0.0 (-2735 1205);
WIRE 300 ROUND (2300 -1350) (2300 1350);
WIRE 300 ROUND (2300 1350) (-2300 1350);
WIRE 300 ROUND (-2300 1350) (-2300 -1350);
WIRE 300 ROUND (-2300 -1350) (2300 -1350);
LAYER tGlue;
CIRCLE 0 (0 0) (225 0);
LAYER Top;
SMD 2000 2000 -0 R0.0 '2' (-2224 0);
SMD 2000 2000 -0 R0.0 '1' (2221 0);
LAYER tPlace;
TEXT >NAME R0.0 (-4270 -3082);
Edit D3.dev;
Prefix 'D';
Description 'Features
# Small Compact Surface Mountable Package with J-Bent Leads
# Rectangular Package for Automated Handling
# Highly Stable Oxide Passivated Junction
# Very Low Forward Voltage Drop
# Guard-ring for Stress Protection
# Pb-Free Package is Available
Mechanical Characteristics:
# Case: Epoxy, Molded
# Weight: 70 mg (Approximately)
# Finish: All External Surfaces Corrosion Resistant and Terminal
Leads are Readily Solderable
# Lead and Mounting Surface Temperature for Soldering Purposes:
260°C Max. for 10 Seconds
# Shipped in 12 mm tape, 5000 units per 13 inch reel
# Polarity: Cathode Lead Indicated by Polarity Band
# ESD Ratings: Machine Model = C
Human Body Model = 3B';
Value on;
Add D3 Next 0 (0 0);
Package D3;
CONNECT A 1 K 2;
Edit C4.sym;
LAYER Symbols;
CHANGE SIZE 2000;
TEXT '+' R90.0 (2635 -1940);
LAYER Pins;
LAYER Names;
TEXT >NAME R90.0 (5175 -3182);
LAYER Values;
TEXT >VALUE R90.0 (-3715 -5462);
EDIT C4.pac;
DESCRIPTION '2817_ELKO';
LAYER tPlace;
TEXT '-' R90.0 (1905 1270);
LAYER tGlue;
CIRCLE 0 (0 0) (300 0);
LAYER Top;
SMD 4300 1500 -0 R0.0 '1' (0 -3500);
SMD 4300 1500 -0 R0.0 '2' (0 3500);
LAYER tPlace;
WIRE 300 ROUND (2150 3650) (2150 -3650);
WIRE 300 ROUND (2150 -3650) (-2150 -3650);
WIRE 300 ROUND (-2150 3650) (-2150 -3650);
WIRE 300 ROUND (-2150 3650) (2150 3650);
TEXT >NAME R90.0 (-2540 -3810);
TEXT >VALUE R90.0 (4445 -3810);
Edit C4.dev;
Prefix 'C';
Description 'Tantal-Elektrolyt-Kondensator 22µF, 16V';
Value on;
Add C4 Next 0 (0 0);
Package C4;
CONNECT + 1 - 2;
Edit REF7.sym;
LAYER Symbols;
LAYER Pins;
Edit REF7.dev;
Prefix 'REF';
Value on;
Add REF7 Next 0 (0 0);
Edit REF10.sym;
PIN '+5V' 0 Sup None R180 Short Off (0 0);
LAYER Symbols;
CHANGE SIZE 1500;
TEXT '+5V' R90.0 (-4330 1770);
WIRE 300 ROUND (-3810 -635) (-3810 635);
WIRE 300 ROUND (-4445 0) (-3175 0);
CIRCLE 300 (-3810 0) (-3810 1270);
Edit REF10.dev;
Prefix 'REF';
Value on;
Add REF10 Next 0 (0 0);
Edit IC4.sym;
LAYER Pins;
PIN 'K' 0 Pas None R90 Short Off (8255 -13970);
LAYER Symbols;
TEXT 'K' R90.0 (7100 -10085);
WIRE 300 ROUND (-635 -9525) (3175 -7620);
WIRE 300 ROUND (3175 -7620) (-635 -5715);
WIRE 300 ROUND (-635 -5715) (-635 -9525);
WIRE 300 ROUND (3302 -5715) (3302 -9525);
WIRE 300 ROUND (-1906 -3493) (-1271 -953);
POLYGON (-953 317) 0 (-953 -1905) 0 (-1992 -1665) 0 (-953 317);
LAYER Pins;
PIN 'NC@1' 0 NC None R90 Short Off (-8255 -13970);
LAYER Symbols;
WIRE 300 ROUND (-5715 -11430) (-5715 -7620);
WIRE 300 ROUND (-5715 -7620) (8255 -7620);
WIRE 300 ROUND (8255 -7620) (8255 -11430);
WIRE 300 ROUND (10795 -11430) (-10795 -11430);
LAYER Pins;
PIN 'MainTerm@1' 0 Pas None R270 Short Off (8255 13494);
LAYER Names;
CHANGE SIZE 2000;
TEXT >NAME R90.0 (-12065 -11430);
LAYER Values;
TEXT >VALUE R90.0 (14605 -11430);
LAYER Symbols;
WIRE 300 ROUND (-319 -3811) (317 -1271);
LAYER Pins;
PIN 'MainTerm@2' 0 Pas None R270 Short Off (-8255 13335);
PIN 'NC@2' 0 NC None R270 Short Off (1905 13335);
LAYER Symbols;
POLYGON (634 -1) 0 (634 -2223) 0 (-380 -2037) 0 (634 -1);
WIRE 300 FLAT (1429 477) (1429 9367);
WIRE 300 FLAT (-2381 477) (-2381 9367);
POLYGON (1429 9050) 0 (-2381 6827) 0 (1429 4604) 0 (1429 9050);
POLYGON (-2381 5240) 0 (-2381 794) 0 (1429 3017) 0 (-2381 5240);
WIRE 300 ROUND (8255 5080) (8255 10795);
WIRE 300 ROUND (-10795 -11430) (-10795 10795);
WIRE 300 ROUND (-10795 10795) (10795 10795);
WIRE 300 ROUND (10795 10795) (10795 -11430);
WIRE 300 ROUND (-2381 5239) (-8245 5250);
WIRE 300 ROUND (8255 4921) (1429 4921);
LAYER Pins;
PIN 'A' 0 Pas None R90 Short Off (-5715 -13970);
LAYER Symbols;
CHANGE SIZE 1500;
TEXT 'A' R90.0 (-3060 -10295);
WIRE 300 ROUND (-8245 5250) (-8255 10636);
EDIT IC4.pac;
DESCRIPTION 'DIL6';
LAYER tPlace;
WIRE 300 ROUND (3810 635) (3175 1905);
WIRE 300 ROUND (3810 635) (4445 1905);
LAYER Vias;
CHANGE DRILL 800;
PAD '1' 1250 R360.0 Long (0 0);
CHANGE DRILL 800;
PAD '2' 1250 R360.0 Long (0 -2540);
CHANGE DRILL 800;
PAD '3' 1250 R360.0 Long (0 -5080);
CHANGE DRILL 800;
PAD '4' 1250 R360.0 Long (7620 -5080);
CHANGE DRILL 800;
PAD '5' 1250 R360.0 Long (7620 -2540);
CHANGE DRILL 800;
PAD '6' 1250 R360.0 Long (7620 0);
LAYER tPlace;
WIRE 300 ROUND (760 -6985) (6860 -6985);
WIRE 300 ROUND (6860 -6985) (6860 1905);
CHANGE SIZE 2000;
TEXT >NAME R90.0 (11220 -7841);
WIRE 300 ROUND (760 -6985) (760 1905);
WIRE 300 ROUND (760 1905) (3175 1905);
WIRE 300 ROUND (6860 1905) (4445 1905);
TEXT >VALUE R90.0 (-1175 -5530);
Edit IC4.dev;
Prefix 'IC';
Description 'Optokoppler, TRIAC-Ausgang, MOC..., Optokoppler, MOC 3052M [DIL6]';
Value on;
Add IC4 Next 0 (0 0);
Package IC4;
CONNECT K 2 NC@1 3 MainTerm@1 4 MainTerm@2 6 NC@2 5 A 1;
Edit R1.sym;
LAYER Pins;
PIN '1' 0 Pas None R90 Short Off (0 -5080);
PIN '2' 0 Pas None R270 Short Off (0 5080);
LAYER Symbols;
WIRE 300 ROUND (-1270 -2540) (1270 -2540);
WIRE 300 ROUND (1270 -2540) (1270 2540);
WIRE 300 ROUND (1270 2540) (-1270 2540);
WIRE 300 ROUND (-1270 2540) (-1270 -2540);
LAYER Names;
CHANGE RATIO 10;
TEXT >NAME R90.0 (-2540 -2540);
LAYER Values;
TEXT >VALUE R90.0 (4445 -3175);
EDIT R1.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
SMD 1000 1250 -0 R0.0 '2' (1000 0);
SMD 1000 1250 -0 R0.0 '1' (-1000 0);
LAYER tPlace;
WIRE 300 ROUND (-1000 625) (1000 625);
WIRE 300 ROUND (1000 625) (1000 -625);
WIRE 300 ROUND (1000 -625) (-1000 -625);
WIRE 300 ROUND (-1000 625) (-1000 -625);
CHANGE SIZE 800;
CHANGE RATIO 9;
TEXT >NAME R0.0 (-938 1072);
Edit R1.dev;
Prefix 'R';
Description 'Chip SMD Widerstand Bauform 0805';
Value on;
Add R1 Next 0 (0 0);
Package R1;
CONNECT 1 1 2 2;
Edit TRIAC1.sym;
LAYER Pins;
PIN 'A2' 0 Pas None R270 Short Off (0 4445);
LAYER Symbols;
CHANGE RATIO 10;
TEXT 'A2' R0.0 (-2159 2413);
LAYER Pins;
PIN 'A1' 0 Pas None R90 Short Off (0 -4445);
LAYER Symbols;
TEXT 'A1' R0.0 (-2159 -3175);
LAYER Pins;
PIN 'G' 0 Pas None R180 Short Off (7620 -3175);
LAYER Symbols;
TEXT 'G' R0.0 (5461 -2286);
LAYER Values;
CHANGE SIZE 2000;
TEXT >VALUE R0.0 (1854 -7468);
LAYER Names;
TEXT >NAME R0.0 (1880 3200);
LAYER Symbols;
WIRE 300 ROUND (3175 -3175) (5080 -3175);
WIRE 300 FLAT (4445 1905) (-4445 1905);
WIRE 300 FLAT (4445 -1905) (-4445 -1905);
WIRE 300 ROUND (3175 -3175) (2222 -1905);
POLYGON (-4128 1905) 0 (-1905 -1905) 0 (318 1905) 0 (-4128 1905);
POLYGON (-318 -1905) 0 (4128 -1905) 0 (1905 1905) 0 (-318 -1905);
EDIT TRIAC1.pac;
DESCRIPTION 'TO-220';
LAYER Vias;
HOLE 3650 (-5291 0);
CHANGE DRILL 1000;
PAD '1' 1950 R90.0 Octagon (10795 -2540);
CHANGE DRILL 1000;
PAD '2' 1950 R90.0 Octagon (10795 0);
CHANGE DRILL 1000;
PAD '3' 1950 R90.0 Octagon (10795 2540);
LAYER tPlace;
TEXT >NAME R90.0 (3962 -4089);
CIRCLE 300 (-5309 0) (-5309 1905);
WIRE 300 ROUND (6960 5105) (-8026 5105);
WIRE 300 ROUND (-8026 5105) (-8026 -5055);
WIRE 300 ROUND (-8026 -5055) (6960 -5055);
WIRE 300 FLAT (10922 -2921) (10922 -2134);
WIRE 300 FLAT (10947 -381) (10947 406);
WIRE 300 FLAT (10947 2159) (10947 2946);
WIRE 300 ROUND (-1676 -5029) (-1676 5080);
WIRE 300 ROUND (6960 5105) (6960 -5055);
WIRE 500 FLAT (10795 -2540) (6985 -2540);
WIRE 500 FLAT (10795 0) (6985 0);
WIRE 500 FLAT (10795 2540) (6985 2540);
Edit TRIAC1.dev;
Prefix 'TRIAC';
Description 'Triac Umax=600V Imax=12,0A (TO-220)';
Value on;
Add TRIAC1 Next 0 (0 0);
Package TRIAC1;
CONNECT A2 2 A1 1 G 3;
Edit R2.sym;
LAYER Symbols;
WIRE 300 ROUND (1767 3175) (2807 3175);
WIRE 300 ROUND (2540 1270) (2540 -1270);
WIRE 300 ROUND (2540 -1270) (-2540 -1270);
WIRE 300 ROUND (-2540 -1270) (-2540 1270);
WIRE 300 ROUND (-1905 -3299) (1767 3175);
WIRE 300 ROUND (-1938 -3299) (-3000 -3299);
LAYER Pins;
PIN '1' 0 Pas None R0 Short Off (-5080 0);
PIN '2' 0 Pas None R180 Short Off (5080 0);
LAYER Symbols;
WIRE 300 ROUND (-2540 1270) (2540 1270);
CHANGE SIZE 1000;
CHANGE RATIO 8;
TEXT ' ' R90.0 (0 1905);
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
TEXT >NAME R0.0 (-5080 5080);
LAYER Values;
TEXT >VALUE R0.0 (-5080 -6985);
EDIT R2.pac;
DESCRIPTION 'S05K';
LAYER Vias;
CHANGE DRILL 1000;
PAD '1' 2500 R90.0 Octagon (0 -2540);
CHANGE DRILL 1000;
PAD '2' 2500 R90.0 Octagon (0 2540);
LAYER tPlace;
WIRE 300 ROUND (-3175 -3810) (-3175 3810);
WIRE 300 ROUND (-3175 3810) (3175 3810);
WIRE 300 ROUND (3175 3810) (3175 -3810);
WIRE 300 ROUND (3175 -3810) (-3175 -3810);
CHANGE SIZE 1500;
TEXT >NAME R90.0 (2540 -1905);
Edit R2.dev;
Prefix 'R';
Description 'VDR Widerstand mit 275V (S05K)';
Value on;
Add R2 Next 0 (0 0);
Package R2;
CONNECT 1 1 2 2;
Edit F1.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
TEXT >NAME R90.0 (-1905 -5715);
LAYER Symbols;
WIRE 300 ROUND (0 -2540) (0 2540);
EDIT F1.pac;
DESCRIPTION 'SICHERUNG-HALTER_5X22';
LAYER tPlace;
TEXT >VALUE R0.0 (-11430 -6985);
WIRE 300 ROUND (-11000 4500) (-11000 -4500);
WIRE 300 ROUND (-11000 -4500) (11000 -4500);
WIRE 300 ROUND (11000 -4500) (11000 4500);
WIRE 300 ROUND (11000 4500) (-11000 4500);
CIRCLE 200 (0 0) (635 0);
LAYER Vias;
CHANGE DRILL 1500;
PAD '1' 2500 R0.0 Octagon (-11300 0);
CHANGE DRILL 1500;
PAD '2' 2500 R0.0 Octagon (11300 0);
LAYER tPlace;
TEXT >NAME R0.0 (-11430 5080);
Edit F1.dev;
Prefix 'F';
Description 'Sicherungshalter Spannung: 250V, Strom: 6,3A';
Value on;
Add F1 Next 0 (0 0);
Package F1;
CONNECT 1 1 2 2;
Edit L3.sym;
LAYER Pins;
PIN '2' 0 Pas None R270 Short Off (0 10160);
LAYER Symbols;
ARC 300 CCW (0 3810) (0 2540) (0 2540);
ARC 300 CCW (0 5080) (0 3810) (0 3810);
ARC 300 CCW (0 6350) (0 5080) (0 5080);
ARC 300 CCW (0 7620) (0 6350) (0 6350);
LAYER Names;
TEXT >NAME R90.0 (-1905 0);
LAYER Values;
TEXT >VALUE R90.0 (3810 0);
LAYER Pins;
PIN '1' 0 Pas None R90 Short Off (0 0);
EDIT L3.pac;
DESCRIPTION '7X26R40,64';
LAYER tPlace;
WIRE 300 ROUND (13000 3500) (13000 -3500);
WIRE 300 ROUND (13000 -3500) (-13000 -3500);
WIRE 300 ROUND (-13000 -3500) (-13000 3500);
WIRE 300 ROUND (-13000 3500) (13000 3500);
LAYER Vias;
CHANGE DRILL 1000;
PAD '1' 2000 R180.0 Octagon (20320 0);
CHANGE DRILL 1000;
PAD '2' 2000 R180.0 Octagon (-20320 0);
LAYER tPlace;
WIRE 300 ROUND (-13000 0) (-20320 0);
WIRE 300 ROUND (20320 0) (13000 0);
TEXT >NAME R180.0 (3360 6445);
Edit L3.dev;
Prefix 'L';
Description 'UKW-Drossel, 500VAC/DC, +/- 20%, 2A, 40µH, 0,18 Ohm';
Value on;
Add L3 Next 0 (0 0);
Package L3;
CONNECT 2 2 1 1;
Edit R5.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R5.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
TEXT >NAME R0.0 (3664 1072);
Edit R5.dev;
Prefix 'R';
Value on;
Add R5 Next 0 (0 0);
Package R5;
CONNECT 1 1 2 2;
Edit REF1.sym;
LAYER Symbols;
LAYER Pins;
Edit REF1.dev;
Prefix 'REF';
Value on;
Add REF1 Next 0 (0 0);
Edit IC5.sym;
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
EDIT IC5.pac;
DESCRIPTION 'DIL6';
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
CHANGE SIZE 2000;
Edit IC5.dev;
Prefix 'IC';
Value on;
Add IC5 Next 0 (0 0);
Package IC5;
Edit R3.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R3.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R3.dev;
Prefix 'R';
Value on;
Add R3 Next 0 (0 0);
Package R3;
CONNECT 1 1 2 2;
Edit TRIAC2.sym;
LAYER Pins;
LAYER Symbols;
CHANGE RATIO 10;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Values;
CHANGE SIZE 2000;
LAYER Names;
LAYER Symbols;
EDIT TRIAC2.pac;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit TRIAC2.dev;
Prefix 'TRIAC';
Value on;
Add TRIAC2 Next 0 (0 0);
Package TRIAC2;
Edit R6.sym;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1000;
CHANGE RATIO 8;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R6.pac;
DESCRIPTION 'S05K';
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
CHANGE SIZE 1500;
Edit R6.dev;
Prefix 'R';
Value on;
Add R6 Next 0 (0 0);
Package R6;
CONNECT 1 1 2 2;
Edit F2.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
LAYER Symbols;
EDIT F2.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1500;
CHANGE DRILL 1500;
LAYER tPlace;
Edit F2.dev;
Prefix 'F';
Value on;
Add F2 Next 0 (0 0);
Package F2;
CONNECT 1 1 2 2;
Edit L4.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L4.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit L4.dev;
Prefix 'L';
Value on;
Add L4 Next 0 (0 0);
Package L4;
CONNECT 2 2 1 1;
Edit R7.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R7.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R7.dev;
Prefix 'R';
Value on;
Add R7 Next 0 (0 0);
Package R7;
CONNECT 1 1 2 2;
Edit REF2.sym;
LAYER Symbols;
LAYER Pins;
Edit REF2.dev;
Prefix 'REF';
Value on;
Add REF2 Next 0 (0 0);
Edit IC6.sym;
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
EDIT IC6.pac;
DESCRIPTION 'DIL6';
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
CHANGE SIZE 2000;
Edit IC6.dev;
Prefix 'IC';
Value on;
Add IC6 Next 0 (0 0);
Package IC6;
Edit R8.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R8.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R8.dev;
Prefix 'R';
Value on;
Add R8 Next 0 (0 0);
Package R8;
CONNECT 1 1 2 2;
Edit TRIAC3.sym;
LAYER Pins;
LAYER Symbols;
CHANGE RATIO 10;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Values;
CHANGE SIZE 2000;
LAYER Names;
LAYER Symbols;
EDIT TRIAC3.pac;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit TRIAC3.dev;
Prefix 'TRIAC';
Value on;
Add TRIAC3 Next 0 (0 0);
Package TRIAC3;
Edit R9.sym;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1000;
CHANGE RATIO 8;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R9.pac;
DESCRIPTION 'S05K';
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
CHANGE SIZE 1500;
Edit R9.dev;
Prefix 'R';
Value on;
Add R9 Next 0 (0 0);
Package R9;
CONNECT 1 1 2 2;
Edit F3.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
LAYER Symbols;
EDIT F3.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1500;
CHANGE DRILL 1500;
LAYER tPlace;
Edit F3.dev;
Prefix 'F';
Value on;
Add F3 Next 0 (0 0);
Package F3;
CONNECT 1 1 2 2;
Edit L5.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L5.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit L5.dev;
Prefix 'L';
Value on;
Add L5 Next 0 (0 0);
Package L5;
CONNECT 2 2 1 1;
Edit R10.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R10.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R10.dev;
Prefix 'R';
Value on;
Add R10 Next 0 (0 0);
Package R10;
CONNECT 1 1 2 2;
Edit REF3.sym;
LAYER Symbols;
LAYER Pins;
Edit REF3.dev;
Prefix 'REF';
Value on;
Add REF3 Next 0 (0 0);
Edit IC7.sym;
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
EDIT IC7.pac;
DESCRIPTION 'DIL6';
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
CHANGE SIZE 2000;
Edit IC7.dev;
Prefix 'IC';
Value on;
Add IC7 Next 0 (0 0);
Package IC7;
Edit R11.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R11.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R11.dev;
Prefix 'R';
Value on;
Add R11 Next 0 (0 0);
Package R11;
CONNECT 1 1 2 2;
Edit TRIAC4.sym;
LAYER Pins;
LAYER Symbols;
CHANGE RATIO 10;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Values;
CHANGE SIZE 2000;
LAYER Names;
LAYER Symbols;
EDIT TRIAC4.pac;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit TRIAC4.dev;
Prefix 'TRIAC';
Value on;
Add TRIAC4 Next 0 (0 0);
Package TRIAC4;
Edit R12.sym;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1000;
CHANGE RATIO 8;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R12.pac;
DESCRIPTION 'S05K';
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
CHANGE SIZE 1500;
Edit R12.dev;
Prefix 'R';
Value on;
Add R12 Next 0 (0 0);
Package R12;
CONNECT 1 1 2 2;
Edit F4.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
LAYER Symbols;
EDIT F4.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1500;
CHANGE DRILL 1500;
LAYER tPlace;
Edit F4.dev;
Prefix 'F';
Value on;
Add F4 Next 0 (0 0);
Package F4;
CONNECT 1 1 2 2;
Edit L6.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L6.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit L6.dev;
Prefix 'L';
Value on;
Add L6 Next 0 (0 0);
Package L6;
CONNECT 2 2 1 1;
Edit R13.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R13.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R13.dev;
Prefix 'R';
Value on;
Add R13 Next 0 (0 0);
Package R13;
CONNECT 1 1 2 2;
Edit REF5.sym;
LAYER Symbols;
LAYER Pins;
Edit REF5.dev;
Prefix 'REF';
Value on;
Add REF5 Next 0 (0 0);
Edit IC8.sym;
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
EDIT IC8.pac;
DESCRIPTION 'DIL6';
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
CHANGE SIZE 2000;
Edit IC8.dev;
Prefix 'IC';
Value on;
Add IC8 Next 0 (0 0);
Package IC8;
Edit R14.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R14.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R14.dev;
Prefix 'R';
Value on;
Add R14 Next 0 (0 0);
Package R14;
CONNECT 1 1 2 2;
Edit TRIAC5.sym;
LAYER Pins;
LAYER Symbols;
CHANGE RATIO 10;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Values;
CHANGE SIZE 2000;
LAYER Names;
LAYER Symbols;
EDIT TRIAC5.pac;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit TRIAC5.dev;
Prefix 'TRIAC';
Value on;
Add TRIAC5 Next 0 (0 0);
Package TRIAC5;
Edit R15.sym;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1000;
CHANGE RATIO 8;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R15.pac;
DESCRIPTION 'S05K';
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
CHANGE SIZE 1500;
Edit R15.dev;
Prefix 'R';
Value on;
Add R15 Next 0 (0 0);
Package R15;
CONNECT 1 1 2 2;
Edit F5.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
LAYER Symbols;
EDIT F5.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1500;
CHANGE DRILL 1500;
LAYER tPlace;
Edit F5.dev;
Prefix 'F';
Value on;
Add F5 Next 0 (0 0);
Package F5;
CONNECT 1 1 2 2;
Edit L7.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L7.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 1000;
CHANGE DRILL 1000;
LAYER tPlace;
Edit L7.dev;
Prefix 'L';
Value on;
Add L7 Next 0 (0 0);
Package L7;
CONNECT 2 2 1 1;
Edit R16.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE RATIO 10;
LAYER Values;
EDIT R16.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R16.dev;
Prefix 'R';
Value on;
Add R16 Next 0 (0 0);
Package R16;
CONNECT 1 1 2 2;
Edit REF11.sym;
LAYER Symbols;
LAYER Pins;
Edit REF11.dev;
Prefix 'REF';
Value on;
Add REF11 Next 0 (0 0);
Edit Tr1.sym;
LAYER Symbols;
WIRE 600 FLAT (0 8255) (0 -9525);
ARC 300 CCW (4445 -4445) (4445 -8255) (4445 -8255);
ARC 300 CCW (4445 -635) (4445 -4445) (4445 -4445);
ARC 300 CCW (4445 3175) (4445 -635) (4445 -635);
ARC 300 CCW (4445 6985) (4445 3175) (4445 3175);
ARC 300 CCW (-3810 3175) (-3810 6985) (-3810 6985);
ARC 300 CCW (-3810 -635) (-3810 3175) (-3810 3175);
ARC 300 CCW (-3810 -4445) (-3810 -635) (-3810 -635);
ARC 300 CCW (-3810 -8255) (-3810 -4445) (-3810 -4445);
CHANGE SIZE 2000;
CHANGE RATIO 13;
TEXT 'primär' R90.0 (-5715 -5715);
TEXT 'sekundär' R90.0 (6985 -6985);
LAYER Pins;
PIN '1' 0 Pas None R0 Short Off (-7620 6985);
PIN '9' 0 Pas None R180 Short Off (7620 6985);
LAYER Names;
TEXT >NAME R0.0 (-5080 11430);
LAYER Values;
TEXT >VALUE R0.0 (-5080 -14605);
LAYER Pins;
PIN '7' 0 Pas None R180 Short Off (7620 -8255);
PIN '5' 0 Pas None R0 Short Off (-7620 -8255);
LAYER Symbols;
WIRE 300 ROUND (5080 -8255) (3810 -8255);
WIRE 300 ROUND (5080 6985) (3810 6985);
WIRE 300 ROUND (-3810 -8255) (-5080 -8255);
WIRE 300 ROUND (-3810 6985) (-5080 6985);
WIRE 300 ROUND (-5080 10795) (-5080 -12065);
WIRE 300 ROUND (5080 10795) (5080 -12065);
WIRE 300 ROUND (5080 -12065) (-5080 -12065);
WIRE 300 ROUND (5080 10795) (-5080 10795);
EDIT Tr1.pac;
DESCRIPTION 'TRAFO-EI30_1PRI-1SEK';
LAYER tPlace;
TEXT >VALUE R90.0 (19050 -13971);
LAYER Vias;
CHANGE DRILL 1000;
PAD '1' 2200 R90.0 Octagon (-10160 -10161);
LAYER tPlace;
WIRE 300 ROUND (-16250 -13750) (-16250 13750);
WIRE 300 ROUND (-16250 13750) (16250 13750);
WIRE 300 ROUND (16250 13750) (16250 -13750);
WIRE 300 ROUND (16250 -13750) (-16250 -13750);
TEXT >NAME R90.0 (-17145 -13971);
RECT (-11430 -477) (11430 475);
RECT (10160 -1906) (-10319 -6351);
WIRE 300 ROUND (10160 -2065) (10160 -7780);
WIRE 300 ROUND (-10319 -7939) (-10319 -2065);
RECT (-10319 1745) (10319 6190);
WIRE 300 ROUND (-10319 1904) (-10319 7301);
WIRE 300 ROUND (-10319 7301) (-5080 7301);
WIRE 300 ROUND (-5080 7301) (-5080 8413);
WIRE 300 ROUND (10319 7143) (10319 1905);
WIRE 300 ROUND (10319 7143) (5080 7143);
WIRE 300 ROUND (5080 8254) (5080 7142);
LAYER Vias;
CHANGE DRILL 1000;
PAD '5' 2200 R90.0 Octagon (10160 -10160);
CHANGE DRILL 1000;
PAD '9' 2200 R90.0 Octagon (-5080 10159);
CHANGE DRILL 1000;
PAD '7' 2200 R90.0 Octagon (5080 10159);
HOLE 800 (10160 10160);
HOLE 800 (-10160 10159);
Edit Tr1.dev;
Prefix 'Tr';
Description 'Transformator EI30 Primär: 230V, Sekundär: 6V/166mA';
Value on;
Add Tr1 Next 0 (0 0);
Package Tr1;
CONNECT 1 1 9 9 7 7 5 5;
Edit KL1.sym;
LAYER Values;
TEXT >VALUE R0.0 (-6595 6255);
LAYER Names;
TEXT >NAME R0.0 (-9475 -8255);
LAYER Pins;
PIN '1' 0 Pas None R0 Short Off (-4445 -3810);
PIN '2' 0 Pas None R0 Short Off (-4445 3810);
LAYER Symbols;
ARC 300 CCW (0 5810) (0 1810) (0 1810);
ARC 300 CCW (0 -1810) (0 -5810) (0 -5810);
EDIT KL1.pac;
DESCRIPTION 'KLEMME2';
LAYER Vias;
CHANGE DRILL 1300;
PAD '1' 2300 R0.0 Octagon (-2540 0);
CHANGE DRILL 1300;
PAD '2' 2300 R0.0 Octagon (2540 0);
LAYER tPlace;
WIRE 300 ROUND (-5080 4050) (5080 4050);
CIRCLE 300 (-2540 0) (-2540 1905);
CIRCLE 300 (2540 0) (2540 1905);
WIRE 300 ROUND (5080 -3000) (-5080 -3000);
WIRE 300 ROUND (-5080 3000) (5080 3000);
WIRE 300 ROUND (1588 -1589) (4128 951);
WIRE 300 ROUND (952 -953) (3492 1587);
WIRE 300 ROUND (-3492 -1589) (-952 951);
WIRE 300 ROUND (-4128 -953) (-1588 1587);
WIRE 300 ROUND (-5080 -4050) (5080 -4050);
WIRE 300 ROUND (-5080 4050) (-5080 -4050);
WIRE 300 ROUND (5080 4050) (5080 -4050);
TEXT >NAME R0.0 (-5715 4445);
TEXT >VALUE R0.0 (-5080 -6350);
Edit KL1.dev;
Prefix 'KL';
Description 'Schraubklemme 2-polig RM5,08';
Value on;
Add KL1 Next 0 (0 0);
Package KL1;
CONNECT 1 1 2 2;
Edit REF12.sym;
LAYER Symbols;
LAYER Pins;
Edit REF12.dev;
Prefix 'REF';
Value on;
Add REF12 Next 0 (0 0);
Edit REF13.sym;
LAYER Symbols;
RECT (1905 2540) (-1905 3175);
LAYER Pins;
PIN 'GND' 0 Sup None R90 Short Off (0 0);
Edit REF13.dev;
Prefix 'REF';
Value on;
Add REF13 Next 0 (0 0);
Edit REF14.sym;
PIN '+5V' 0 Sup None R90 Short Off (0 0);
LAYER Symbols;
CHANGE SIZE 1500;
TEXT '+5V' R0.0 (1770 4330);
WIRE 300 ROUND (-635 3810) (635 3810);
WIRE 300 ROUND (0 4445) (0 3175);
CIRCLE 300 (0 3810) (1270 3810);
Edit REF14.dev;
Prefix 'REF';
Value on;
Add REF14 Next 0 (0 0);
Edit REF15.sym;
LAYER Pins;
PIN '+5V' 0 Sup None R270 Short Off (0 0);
LAYER Symbols;
TEXT '+5V' R0.0 (-5025 -5830);
WIRE 300 ROUND (635 -3810) (-635 -3810);
WIRE 300 ROUND (0 -4445) (0 -3175);
CIRCLE 300 (0 -3810) (-1270 -3810);
Edit REF15.dev;
Prefix 'REF';
Value on;
Add REF15 Next 0 (0 0);
Edit K7.sym;
LAYER Pins;
PIN '2' 0 Pas None R180 Point Off (1270 2540);
PIN '3' 0 Pas None R0 Point Off (-1270 0);
PIN '4' 0 Pas None R180 Point Off (1270 0);
PIN '5' 0 Pas None R0 Point Off (-1270 -2540);
PIN '6' 0 Pas None R180 Point Off (1270 -2540);
LAYER Symbols;
WIRE 300 ROUND (-3175 5080) (-3175 -5080);
WIRE 300 ROUND (-3175 -5080) (3175 -5080);
WIRE 300 ROUND (3175 -5080) (3175 5080);
WIRE 300 ROUND (3175 5080) (-3175 5080);
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
TEXT >NAME R0.0 (-3175 6350);
LAYER Values;
TEXT >VALUE R0.0 (-3175 -8890);
LAYER Pins;
PIN '1' 0 Pas None R0 Point Off (-1270 2540);
EDIT K7.pac;
DESCRIPTION '2X03';
LAYER Vias;
CHANGE DRILL 900;
PAD '1' 1400 R270.0 Octagon (0 0);
CHANGE DRILL 900;
PAD '2' 1400 R270.0 Octagon (2540 0);
CHANGE DRILL 900;
PAD '3' 1400 R270.0 Octagon (0 -2540);
CHANGE DRILL 900;
PAD '4' 1400 R270.0 Octagon (2540 -2540);
CHANGE DRILL 900;
PAD '5' 1400 R270.0 Octagon (0 -5080);
CHANGE DRILL 900;
PAD '6' 1400 R270.0 Octagon (2540 -5080);
LAYER tPlace;
WIRE 300 ROUND (-635 1270) (-1270 635);
WIRE 300 ROUND (-1270 -635) (-635 -1270);
WIRE 300 ROUND (-635 -1270) (-1270 -1905);
WIRE 300 ROUND (-1270 -3175) (-635 -3810);
WIRE 300 ROUND (-635 1270) (3175 1270);
WIRE 300 ROUND (3175 1270) (3810 635);
WIRE 300 ROUND (3810 -635) (3175 -1270);
WIRE 300 ROUND (3175 -1270) (3810 -1905);
WIRE 300 ROUND (3810 -1905) (3810 -3175);
WIRE 300 ROUND (3810 -3175) (3175 -3810);
WIRE 300 ROUND (3175 -1270) (-635 -1270);
WIRE 300 ROUND (3175 -3810) (-635 -3810);
TEXT >NAME R90.0 (-1810 -12495);
WIRE 300 ROUND (-1270 -1905) (-1270 -3175);
WIRE 300 ROUND (-1270 635) (-1270 -635);
WIRE 300 ROUND (-635 -3810) (-1270 -4445);
WIRE 300 ROUND (-1270 -5715) (-635 -6350);
WIRE 300 ROUND (3175 -3810) (3810 -4445);
WIRE 300 ROUND (3810 -4445) (3810 -5715);
WIRE 300 ROUND (3810 -5715) (3175 -6350);
WIRE 300 ROUND (3175 -6350) (-635 -6350);
WIRE 300 ROUND (-1270 -4445) (-1270 -5715);
Edit K7.dev;
Prefix 'K';
Description 'Typ: F/P2, M/P2 ( VG-16...)';
Value on;
Add K7 Next 0 (0 0);
Package K7;
CONNECT 2 2 3 3 4 4 5 5 6 6 1 1;
Edit REF16.sym;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
Edit REF16.dev;
Prefix 'REF';
Value on;
Add REF16 Next 0 (0 0);
Edit REF17.sym;
RECT (2540 -1905) (3175 1905);
LAYER Pins;
PIN 'GND' 0 Sup None R0 Short Off (0 0);
Edit REF17.dev;
Prefix 'REF';
Value on;
Add REF17 Next 0 (0 0);
Edit IC9a.sym;
PIN 'A' 0 Pas None R180 Short Off (12065 -6985);
LAYER Symbols;
TEXT 'A' R0.0 (7190 -5830);
LAYER Pins;
PIN 'K' 0 Pas None R180 Short Off (12065 6985);
LAYER Symbols;
TEXT 'K' R0.0 (6980 4330);
WIRE 300 ROUND (7620 -1905) (5715 1905);
WIRE 300 ROUND (5715 1905) (3810 -1905);
WIRE 300 ROUND (3810 -1905) (7620 -1905);
WIRE 300 ROUND (3810 2032) (7620 2032);
WIRE 300 ROUND (3810 -636) (1270 -1);
POLYGON (0 317) 0 (2222 317) 0 (1982 -722) 0 (0 317);
LAYER Pins;
PIN 'C' 0 Pas None R0 Short Off (-11430 -6985);
LAYER Symbols;
TEXT 'C' R0.0 (-7765 -5830);
RECT (-2286 2858) (-3048 -2222);
WIRE 300 ROUND (-5080 -2222) (-3048 -1206);
WIRE 300 ROUND (-5080 2858) (-3048 1842);
POLYGON (-3492 2858) 0 (-5080 2858) 0 (-3810 1588) 0 (-3492 2858);
WIRE 300 ROUND (9525 -6985) (5715 -6985);
WIRE 300 ROUND (5715 -6985) (5715 6985);
WIRE 300 ROUND (5715 6985) (9525 6985);
WIRE 300 ROUND (-5080 -2222) (-5080 -6985);
WIRE 300 ROUND (-5080 -6985) (-8890 -6985);
WIRE 300 ROUND (-5080 2858) (-5080 6985);
WIRE 300 ROUND (-5080 6985) (-8890 6985);
WIRE 300 ROUND (9525 9525) (9525 -9525);
WIRE 300 ROUND (9525 -9525) (-8890 -9525);
WIRE 300 ROUND (-8890 -9525) (-8890 9525);
LAYER Pins;
PIN 'E' 0 Pas None R0 Short Off (-11430 6985);
LAYER Symbols;
TEXT 'E' R0.0 (-7785 4330);
WIRE 300 ROUND (4128 951) (1588 1587);
POLYGON (318 1904) 0 (2540 1904) 0 (2354 890) 0 (318 1904);
LAYER Values;
CHANGE SIZE 2000;
TEXT >VALUE R0.0 (2295 10065);
LAYER Symbols;
WIRE 300 ROUND (9525 9525) (-8890 9525);
LAYER Names;
TEXT >GATE R0.0 (4785 -12160);
Edit IC9b.sym;
EDIT IC9.pac;
DESCRIPTION 'DIL8';
LAYER Vias;
CHANGE DRILL 800;
PAD '1' 1250 R90.0 Long (0 0);
CHANGE DRILL 800;
PAD '2' 1250 R90.0 Long (2540 0);
CHANGE DRILL 800;
PAD '3' 1250 R90.0 Long (5080 0);
CHANGE DRILL 800;
PAD '4' 1250 R90.0 Long (7620 0);
CHANGE DRILL 800;
PAD '5' 1250 R90.0 Long (7620 7620);
CHANGE DRILL 800;
PAD '6' 1250 R90.0 Long (5080 7620);
CHANGE DRILL 800;
PAD '7' 1250 R90.0 Long (2540 7620);
CHANGE DRILL 800;
PAD '8' 1250 R90.0 Long (0 7620);
LAYER tPlace;
WIRE 300 ROUND (-1090 570) (8710 570);
WIRE 300 ROUND (8710 570) (8710 7050);
WIRE 300 ROUND (8710 7050) (-1090 7050);
WIRE 300 ROUND (-1090 7050) (-1090 4445);
WIRE 300 ROUND (-1090 3175) (-1090 570);
TEXT >NAME R0.0 (-762 9119);
TEXT >VALUE R0.0 (-813 -3861);
WIRE 300 ROUND (-1090 4445) (635 3810);
WIRE 300 ROUND (635 3810) (-1090 3175);
Edit IC9.dev;
Prefix 'IC';
Description 'Mehrfach-Optokoppler mit Transistorausgang 50mA Ausg.Strom, 5000V Isol.Spg., 35V Ausg.Spg.';
Value on;
Add IC9a 'a' Next 0 (0 0);
Add IC9b 'b' Next 0 (0 0);
Package IC9;
CONNECT a.A 1 a.K 2 a.C 8 a.E 7 b.A 3 b.K 4 b.C 6 b.E 5;
Edit IC10a.sym;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
LAYER Values;
CHANGE SIZE 2000;
LAYER Symbols;
LAYER Names;
Edit IC10b.sym;
EDIT IC10.pac;
DESCRIPTION 'DIL8';
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
Edit IC10.dev;
Prefix 'IC';
Value on;
Add IC10a 'a' Next 0 (0 0);
Add IC10b 'b' Next 0 (0 0);
Package IC10;
Edit R17.sym;
LAYER Pins;
LAYER Symbols;
WIRE 300 ROUND (-2540 1270) (-2540 -1270);
WIRE 300 ROUND (-2540 -1270) (2540 -1270);
WIRE 300 ROUND (2540 -1270) (2540 1270);
WIRE 300 ROUND (2540 1270) (-2540 1270);
LAYER Names;
CHANGE RATIO 10;
TEXT >NAME R0.0 (-2540 2540);
LAYER Values;
TEXT >VALUE R0.0 (-3175 -4445);
EDIT R17.pac;
DESCRIPTION '1206';
LAYER tGlue;
LAYER Top;
SMD 1000 1600 -0 R180.0 '2' (-1500 0);
SMD 1000 1600 -0 R180.0 '1' (1500 0);
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
TEXT >NAME R0.0 (-5198 -2000);
Edit R17.dev;
Prefix 'R';
Description 'Chip SMD Widerstand Bauform 1206';
Value on;
Add R17 Next 0 (0 0);
Package R17;
CONNECT 1 1 2 2;
Edit J1.sym;
LAYER Symbols;
WIRE 300 ROUND (0 0) (0 -7620);
WIRE 300 ROUND (0 -7620) (-5080 -7620);
WIRE 300 ROUND (-5080 -7620) (-5080 0);
WIRE 300 ROUND (-5080 0) (0 0);
LAYER Pins;
PIN '1' 0 Pas None R180 Short Off (2540 -5080);
LAYER Symbols;
CHANGE SIZE 1560;
CHANGE RATIO 11;
TEXT '1' R0.0 (-1580 -5890);
LAYER Pins;
PIN '2' 0 Pas None R180 Short Off (2540 -2540);
LAYER Symbols;
TEXT '2' R0.0 (-1580 -3350);
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
TEXT >NAME R0.0 (-15105 -10255);
LAYER Values;
TEXT >VALUE R0.0 (-10950 540);
EDIT J1.pac;
DESCRIPTION '1X02';
LAYER Vias;
CHANGE DRILL 900;
PAD '1' 1400 R180.0 Octagon (0 0);
CHANGE DRILL 900;
PAD '2' 1400 R180.0 Octagon (-2540 0);
LAYER tPlace;
CHANGE SIZE 1500;
TEXT >NAME R0.0 (-5659 -3329);
WIRE 300 ROUND (635 -1270) (-635 -1270);
WIRE 300 ROUND (-635 -1270) (-1270 -635);
WIRE 300 ROUND (-1270 -635) (-1270 635);
WIRE 300 ROUND (-1270 635) (-635 1270);
WIRE 300 ROUND (1270 -635) (1270 635);
WIRE 300 ROUND (635 -1270) (1270 -635);
WIRE 300 ROUND (1270 635) (635 1270);
WIRE 300 ROUND (-635 1270) (635 1270);
WIRE 300 ROUND (-1270 -635) (-1905 -1270);
WIRE 300 ROUND (-1905 -1270) (-3175 -1270);
WIRE 300 ROUND (-3175 -1270) (-3810 -635);
WIRE 300 ROUND (-3810 635) (-3175 1270);
WIRE 300 ROUND (-3175 1270) (-1905 1270);
WIRE 300 ROUND (-1905 1270) (-1270 635);
TEXT >VALUE R0.0 (-3830 2310);
Edit J1.dev;
Prefix 'J';
Description 'Jumper 2pol';
Value on;
Add J1 Next 0 (0 0);
Package J1;
CONNECT 1 1 2 2;
Edit REF18.sym;
LAYER Symbols;
LAYER Pins;
Edit REF18.dev;
Prefix 'REF';
Value on;
Add REF18 Next 0 (0 0);
Edit R18.sym;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R18.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
SMD 1000 1250 -0 R270.0 '2' (0 -1000);
SMD 1000 1250 -0 R270.0 '1' (0 1000);
LAYER tPlace;
WIRE 300 ROUND (625 -1000) (-625 -1000);
WIRE 300 ROUND (625 1000) (-625 1000);
CHANGE SIZE 800;
CHANGE RATIO 9;
TEXT >NAME R90.0 (1872 -5198);
Edit R18.dev;
Prefix 'R';
Value on;
Add R18 Next 0 (0 0);
Package R18;
CONNECT 1 1 2 2;
Edit R19.sym;
LAYER Pins;
PIN '1' 0 Pas None R180 Short Off (5080 0);
PIN '2' 0 Pas None R0 Short Off (-5080 0);
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
TEXT >NAME R0.0 (-11860 -4540);
LAYER Values;
TEXT >VALUE R0.0 (-5825 2445);
EDIT R19.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
Edit R19.dev;
Prefix 'R';
Value on;
Add R19 Next 0 (0 0);
Package R19;
CONNECT 1 1 2 2;
Edit REF19.sym;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
CHANGE RATIO 13;
Edit REF19.dev;
Prefix 'REF';
Value on;
Add REF19 Next 0 (0 0);
Edit REF20.sym;
LAYER Pins;
LAYER Symbols;
Edit REF20.dev;
Prefix 'REF';
Value on;
Add REF20 Next 0 (0 0);
Edit Q1.sym;
WIRE 300 ROUND (-1270 -2540) (-1270 2540);
WIRE 300 ROUND (-1270 2540) (1270 2540);
WIRE 300 ROUND (1270 2540) (1270 -2540);
WIRE 300 ROUND (1270 -2540) (-1270 -2540);
LAYER Pins;
PIN '2' 0 Pas None R180 Short Off (4445 0);
LAYER Names;
CHANGE SIZE 2000;
TEXT >NAME R0.0 (-4445 3175);
LAYER Values;
TEXT >VALUE R0.0 (-3810 -5080);
LAYER Symbols;
WIRE 300 ROUND (-1905 -1905) (-1905 1905);
WIRE 300 ROUND (1905 1905) (1905 -1905);
LAYER Pins;
PIN '1' 0 Pas None R0 Short Off (-4445 0);
EDIT Q1.pac;
DESCRIPTION 'HC49/U';
LAYER tPlace;
WIRE 300 ROUND (4000 2000) (-4000 2000);
WIRE 300 ROUND (-4000 -2000) (4000 -2000);
ARC 300 CCW (4000 -2000) (3383 2000) (4000 2000);
ARC 300 CCW (-4000 2000) (-3618 -2000) (-4000 -2000);
LAYER Vias;
CHANGE DRILL 700;
PAD '1' 1700 R180.0 Octagon (2540 0);
CHANGE DRILL 700;
PAD '2' 1700 R180.0 Octagon (-2540 0);
LAYER tPlace;
WIRE 300 ROUND (4635 2635) (-4635 2635);
WIRE 300 ROUND (-4635 -2635) (4635 -2635);
ARC 300 CCW (4635 -2635) (2429 2635) (4635 2635);
ARC 300 CCW (-4635 2635) (-2754 -2635) (-4635 -2635);
TEXT >NAME R0.0 (-2990 -5175);
TEXT >VALUE R0.0 (-450 3080);
Edit Q1.dev;
Prefix 'Q';
Description 'Quarz 16MHz';
Value on;
Add Q1 Next 0 (0 0);
Package Q1;
CONNECT 2 2 1 1;
Edit C1.sym;
LAYER Pins;
PIN '1' 0 Pas None R90 Short Off (0 -3810);
PIN '2' 0 Pas None R270 Short Off (0 3810);
LAYER Symbols;
RECT (-1905 -952) (1905 -318);
RECT (-1905 318) (1905 952);
LAYER Names;
TEXT >NAME R90.0 (-3175 -3493);
LAYER Values;
TEXT >VALUE R90.0 (5080 -3493);
EDIT C1.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
TEXT >NAME R90.0 (1872 -2798);
TEXT >VALUE R90.0 (-1105 -1450);
Edit C1.dev;
Prefix 'C';
Description 'Keramik-Vielschicht-Kondensator 22pF, 50V';
Value on;
Add C1 Next 0 (0 0);
Package C1;
CONNECT 1 1 2 2;
Edit C5.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
EDIT C5.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
Edit C5.dev;
Prefix 'C';
Value on;
Add C5 Next 0 (0 0);
Package C5;
CONNECT 1 1 2 2;
Edit REF21.sym;
LAYER Symbols;
LAYER Pins;
Edit REF21.dev;
Prefix 'REF';
Value on;
Add REF21 Next 0 (0 0);
Edit K1.sym;
PIN '2' 0 Pas None R270 Point Off (-6350 1270);
PIN '3' 0 Pas None R90 Point Off (-3810 -1270);
PIN '4' 0 Pas None R270 Point Off (-3810 1270);
PIN '5' 0 Pas None R90 Point Off (-1270 -1270);
PIN '6' 0 Pas None R270 Point Off (-1270 1270);
PIN '7' 0 Pas None R90 Point Off (1270 -1270);
PIN '8' 0 Pas None R270 Point Off (1270 1270);
PIN '9' 0 Pas None R90 Point Off (3810 -1270);
PIN '10' 0 Pas None R270 Point Off (3810 1270);
LAYER Symbols;
WIRE 300 ROUND (-8890 -3175) (8890 -3175);
WIRE 300 ROUND (8890 -3175) (8890 3175);
WIRE 300 ROUND (8890 3175) (-8890 3175);
WIRE 300 ROUND (-8890 3175) (-8890 -3175);
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
TEXT >NAME R90.0 (-10160 -3175);
LAYER Values;
TEXT >VALUE R90.0 (12700 -3175);
LAYER Pins;
PIN '1' 0 Pas None R90 Point Off (-6350 -1270);
PIN '11' 0 Pas None R90 Point Off (6350 -1270);
PIN '12' 0 Pas None R270 Point Off (6350 1270);
EDIT K1.pac;
DESCRIPTION '2X06';
LAYER Vias;
CHANGE DRILL 900;
CHANGE DRILL 900;
PAD '2' 1400 R180.0 Octagon (0 -2540);
CHANGE DRILL 900;
PAD '3' 1400 R180.0 Octagon (-2540 0);
CHANGE DRILL 900;
PAD '4' 1400 R180.0 Octagon (-2540 -2540);
CHANGE DRILL 900;
PAD '5' 1400 R180.0 Octagon (-5080 0);
CHANGE DRILL 900;
PAD '6' 1400 R180.0 Octagon (-5080 -2540);
CHANGE DRILL 900;
PAD '7' 1400 R180.0 Octagon (-7620 0);
CHANGE DRILL 900;
PAD '8' 1400 R180.0 Octagon (-7620 -2540);
CHANGE DRILL 900;
PAD '9' 1400 R180.0 Octagon (-10160 0);
CHANGE DRILL 900;
PAD '10' 1400 R180.0 Octagon (-10160 -2540);
CHANGE DRILL 900;
PAD '11' 1400 R180.0 Octagon (-12700 0);
CHANGE DRILL 900;
PAD '12' 1400 R180.0 Octagon (-12700 -2540);
LAYER tPlace;
WIRE 300 ROUND (-1270 635) (-1905 1270);
WIRE 300 ROUND (-3175 1270) (-3810 635);
WIRE 300 ROUND (-3810 635) (-4445 1270);
WIRE 300 ROUND (-5715 1270) (-6350 635);
WIRE 300 ROUND (-6350 635) (-6985 1270);
WIRE 300 ROUND (-8255 1270) (-8890 635);
WIRE 300 ROUND (-8890 635) (-9525 1270);
WIRE 300 ROUND (-10795 1270) (-11430 635);
WIRE 300 ROUND (1270 635) (1270 -3175);
WIRE 300 ROUND (1270 -3175) (635 -3810);
WIRE 300 ROUND (-635 -3810) (-1270 -3175);
WIRE 300 ROUND (-1270 -3175) (-1905 -3810);
WIRE 300 ROUND (-1905 -3810) (-3175 -3810);
WIRE 300 ROUND (-3175 -3810) (-3810 -3175);
WIRE 300 ROUND (-3810 -3175) (-4445 -3810);
WIRE 300 ROUND (-4445 -3810) (-5715 -3810);
WIRE 300 ROUND (-5715 -3810) (-6350 -3175);
WIRE 300 ROUND (-6350 -3175) (-6985 -3810);
WIRE 300 ROUND (-6985 -3810) (-8255 -3810);
WIRE 300 ROUND (-8255 -3810) (-8890 -3175);
WIRE 300 ROUND (-8890 -3175) (-9525 -3810);
WIRE 300 ROUND (-9525 -3810) (-10795 -3810);
WIRE 300 ROUND (-10795 -3810) (-11430 -3175);
WIRE 300 ROUND (-1270 -3175) (-1270 635);
WIRE 300 ROUND (-3810 -3175) (-3810 635);
WIRE 300 ROUND (-6350 -3175) (-6350 635);
WIRE 300 ROUND (-8890 -3175) (-8890 635);
WIRE 300 ROUND (-11430 -3175) (-11430 635);
TEXT >NAME R0.0 (-12495 1810);
WIRE 300 ROUND (-9525 1270) (-10795 1270);
WIRE 300 ROUND (-6985 1270) (-8255 1270);
WIRE 300 ROUND (-4445 1270) (-5715 1270);
WIRE 300 ROUND (-1905 1270) (-3175 1270);
WIRE 300 ROUND (635 1270) (-635 1270);
WIRE 300 ROUND (-11430 635) (-12065 1270);
WIRE 300 ROUND (-13335 1270) (-13970 635);
WIRE 300 ROUND (-11430 -3175) (-12065 -3810);
WIRE 300 ROUND (-12065 -3810) (-13335 -3810);
WIRE 300 ROUND (-13335 -3810) (-13970 -3175);
WIRE 300 ROUND (-13970 -3175) (-13970 635);
WIRE 300 ROUND (-12065 1270) (-13335 1270);
Edit K1.dev;
Prefix 'K';
Value on;
Add K1 Next 0 (0 0);
Package K1;
CONNECT 2 2 3 3 4 4 5 5 6 6 7 7 8 8 9 9 10 10 1 1 11 11 12 12;
Edit TH1.sym;
LAYER Symbols;
WIRE 300 ROUND (4445 0) (-5715 0);
WIRE 300 ROUND (-5715 0) (-5715 3810);
WIRE 300 ROUND (-5715 3810) (-4445 3810);
WIRE 300 ROUND (-4445 3810) (-4445 1270);
WIRE 300 ROUND (-4445 1270) (-3175 1270);
WIRE 300 ROUND (-3175 1270) (-3175 3810);
WIRE 300 ROUND (-3175 3810) (-1905 3810);
WIRE 300 ROUND (-1905 3810) (-1905 1270);
WIRE 300 ROUND (-1905 1270) (-635 1270);
WIRE 300 ROUND (-635 1270) (-635 3810);
WIRE 300 ROUND (635 3810) (635 1270);
WIRE 300 ROUND (635 1270) (1905 1270);
WIRE 300 ROUND (1905 1270) (1905 3810);
WIRE 300 ROUND (1905 3810) (3175 3810);
WIRE 300 ROUND (3175 3810) (3175 1270);
WIRE 300 ROUND (3175 1270) (4445 1270);
WIRE 300 ROUND (4445 1270) (4445 3810);
WIRE 300 ROUND (4445 3810) (5715 3810);
WIRE 300 ROUND (5715 3810) (5715 0);
WIRE 300 ROUND (5715 0) (4445 0);
LAYER Values;
CHANGE RATIO 13;
TEXT >VALUE R0.0 (-5715 -3175);
LAYER Names;
TEXT >NAME R0.0 (-6350 4445);
Edit TH1.dev;
Prefix 'TH';
Description 'KÜHLKÖRPER FK201/SA-CB Fingerkühlkörper Aluminium schwarz eloxiert, mit Kombilochung für Gehäuse TO-3, TO-55, SOT-9, SOT-32 und TO-220. Abm. (BxHxT) mm 45 x 45 x 25,4 ; K/W';
Value on;
Add TH1 Next 0 (0 0);
Edit TH2.sym;
LAYER Symbols;
LAYER Values;
LAYER Names;
Edit TH2.dev;
Prefix 'TH';
Value on;
Add TH2 Next 0 (0 0);
Edit TH3.sym;
LAYER Symbols;
LAYER Values;
LAYER Names;
Edit TH3.dev;
Prefix 'TH';
Value on;
Add TH3 Next 0 (0 0);
Edit TH4.sym;
LAYER Symbols;
LAYER Values;
LAYER Names;
Edit TH4.dev;
Prefix 'TH';
Value on;
Add TH4 Next 0 (0 0);
Edit TH5.sym;
LAYER Symbols;
LAYER Values;
LAYER Names;
Edit TH5.dev;
Prefix 'TH';
Value on;
Add TH5 Next 0 (0 0);
Edit KL2.sym;
LAYER Values;
TEXT >VALUE R90.0 (-6255 -6595);
LAYER Names;
TEXT >NAME R90.0 (8255 -9475);
LAYER Pins;
PIN '1' 0 Pas None R90 Short Off (3810 -4445);
PIN '2' 0 Pas None R90 Short Off (-3810 -4445);
LAYER Symbols;
ARC 300 CCW (-5810 0) (-1810 0) (-1810 0);
ARC 300 CCW (1810 0) (5810 0) (5810 0);
EDIT KL2.pac;
LAYER Vias;
CHANGE DRILL 1300;
PAD '1' 2300 R90.0 Octagon (0 -2540);
CHANGE DRILL 1300;
PAD '2' 2300 R90.0 Octagon (0 2540);
LAYER tPlace;
WIRE 300 ROUND (-4050 -5080) (-4050 5080);
CIRCLE 300 (0 -2540) (0 -635);
CIRCLE 300 (0 2540) (0 4445);
WIRE 300 ROUND (3000 5080) (3000 -5080);
WIRE 300 ROUND (-3000 -5080) (-3000 5080);
WIRE 300 ROUND (1589 1588) (-951 4128);
WIRE 300 ROUND (953 952) (-1587 3492);
WIRE 300 ROUND (1589 -3492) (-951 -952);
WIRE 300 ROUND (953 -4128) (-1587 -1588);
WIRE 300 ROUND (4050 -5080) (4050 5080);
WIRE 300 ROUND (-4050 -5080) (4050 -5080);
WIRE 300 ROUND (-4050 5080) (4050 5080);
TEXT >NAME R90.0 (-4445 -5715);
TEXT >VALUE R90.0 (6350 -5080);
Edit KL2.dev;
Prefix 'KL';
Value on;
Add KL2 Next 0 (0 0);
Package KL2;
CONNECT 1 1 2 2;
Edit KL3.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL3.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL3.dev;
Prefix 'KL';
Value on;
Add KL3 Next 0 (0 0);
Package KL3;
CONNECT 1 1 2 2;
Edit KL4.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL4.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL4.dev;
Prefix 'KL';
Value on;
Add KL4 Next 0 (0 0);
Package KL4;
CONNECT 1 1 2 2;
Edit KL5.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL5.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL5.dev;
Prefix 'KL';
Value on;
Add KL5 Next 0 (0 0);
Package KL5;
CONNECT 1 1 2 2;
Edit KL6.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL6.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL6.dev;
Prefix 'KL';
Value on;
Add KL6 Next 0 (0 0);
Package KL6;
CONNECT 1 1 2 2;
Edit KL7.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL7.pac;
LAYER Vias;
CHANGE DRILL 1300;
PAD '1' 2300 R180.0 Octagon (2540 0);
CHANGE DRILL 1300;
PAD '2' 2300 R180.0 Octagon (-2540 0);
LAYER tPlace;
WIRE 300 ROUND (5080 -4050) (-5080 -4050);
WIRE 300 ROUND (-1588 1589) (-4128 -951);
WIRE 300 ROUND (-952 953) (-3492 -1587);
WIRE 300 ROUND (3492 1589) (952 -951);
WIRE 300 ROUND (4128 953) (1588 -1587);
WIRE 300 ROUND (5080 4050) (-5080 4050);
WIRE 300 ROUND (5080 -4050) (5080 4050);
WIRE 300 ROUND (-5080 -4050) (-5080 4050);
TEXT >NAME R0.0 (1915 -6445);
TEXT >VALUE R0.0 (-8860 4350);
Edit KL7.dev;
Prefix 'KL';
Value on;
Add KL7 Next 0 (0 0);
Package KL7;
CONNECT 1 1 2 2;
Edit KL8.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL8.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL8.dev;
Prefix 'KL';
Value on;
Add KL8 Next 0 (0 0);
Package KL8;
CONNECT 1 1 2 2;
Edit KL9.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL9.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL9.dev;
Prefix 'KL';
Value on;
Add KL9 Next 0 (0 0);
Package KL9;
CONNECT 1 1 2 2;
Edit REF22.sym;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1500;
Edit REF22.dev;
Prefix 'REF';
Value on;
Add REF22 Next 0 (0 0);
Edit REF23.sym;
LAYER Pins;
Edit REF23.dev;
Prefix 'REF';
Value on;
Add REF23 Next 0 (0 0);
Edit J2.sym;
LAYER Symbols;
LAYER Pins;
LAYER Symbols;
CHANGE SIZE 1560;
CHANGE RATIO 11;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 13;
LAYER Values;
EDIT J2.pac;
DESCRIPTION '1X02';
LAYER Vias;
CHANGE DRILL 900;
PAD '1' 1400 R0.0 Octagon (0 0);
CHANGE DRILL 900;
PAD '2' 1400 R0.0 Octagon (2540 0);
LAYER tPlace;
CHANGE SIZE 1500;
TEXT >NAME R0.0 (-1346 1829);
WIRE 300 ROUND (635 1270) (1270 635);
WIRE 300 ROUND (1270 635) (1270 -635);
WIRE 300 ROUND (1270 -635) (635 -1270);
WIRE 300 ROUND (1270 635) (1905 1270);
WIRE 300 ROUND (1905 1270) (3175 1270);
WIRE 300 ROUND (3175 -1270) (1905 -1270);
WIRE 300 ROUND (1905 -1270) (1270 -635);
TEXT >VALUE R0.0 (-1270 -3810);
Edit J2.dev;
Prefix 'J';
Value on;
Add J2 Next 0 (0 0);
Package J2;
CONNECT 1 1 2 2;
Edit R20.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R20.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
SMD 1000 1250 -0 R180.0 '2' (-1000 0);
SMD 1000 1250 -0 R180.0 '1' (1000 0);
LAYER tPlace;
WIRE 300 ROUND (-1000 -625) (-1000 625);
WIRE 300 ROUND (1000 -625) (1000 625);
CHANGE SIZE 800;
CHANGE RATIO 9;
TEXT >NAME R0.0 (-1363 -1872);
Edit R20.dev;
Prefix 'R';
Value on;
Add R20 Next 0 (0 0);
Package R20;
CONNECT 1 1 2 2;
Edit KL10.sym;
LAYER Values;
CHANGE SIZE 2000;
CHANGE RATIO 13;
TEXT >VALUE R0.0 (-8630 -8255);
LAYER Names;
TEXT >NAME R0.0 (4240 6255);
LAYER Pins;
PIN '1' 0 Pas None R180 Short Off (4445 3810);
PIN '2' 0 Pas None R180 Short Off (4445 -3810);
LAYER Symbols;
ARC 300 CCW (0 -5810) (0 -1810) (0 -1810);
ARC 300 CCW (0 1810) (0 5810) (0 5810);
EDIT KL10.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL10.dev;
Prefix 'KL';
Value on;
Add KL10 Next 0 (0 0);
Package KL10;
CONNECT 1 1 2 2;
Edit KL11.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL11.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL11.dev;
Prefix 'KL';
Value on;
Add KL11 Next 0 (0 0);
Package KL11;
CONNECT 1 1 2 2;
Edit KL12.sym;
LAYER Values;
LAYER Names;
LAYER Pins;
LAYER Symbols;
EDIT KL12.pac;
LAYER Vias;
CHANGE DRILL 1300;
CHANGE DRILL 1300;
LAYER tPlace;
Edit KL12.dev;
Prefix 'KL';
Value on;
Add KL12 Next 0 (0 0);
Package KL12;
CONNECT 1 1 2 2;
Edit REF24.sym;
LAYER Symbols;
LAYER Pins;
Edit REF24.dev;
Prefix 'REF';
Value on;
Add REF24 Next 0 (0 0);
Edit C6.sym;
LAYER Symbols;
LAYER Names;
LAYER Values;
EDIT C6.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
TEXT >NAME R0.0 (-78 -1872);
TEXT >VALUE R0.0 (-882 1105);
Edit C6.dev;
Prefix 'C';
Description 'Keramik-Vielschicht-Kondensator 0,1µF, 50V';
Value on;
Add C6 Next 0 (0 0);
Package C6;
CONNECT 1 1 2 2;
Edit C7.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
EDIT C7.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
Edit C7.dev;
Prefix 'C';
Value on;
Add C7 Next 0 (0 0);
Package C7;
CONNECT 1 1 2 2;
Edit C8.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
EDIT C8.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
TEXT >NAME R90.0 (1872 -78);
TEXT >VALUE R90.0 (-1105 -882);
Edit C8.dev;
Prefix 'C';
Value on;
Add C8 Next 0 (0 0);
Package C8;
CONNECT 1 1 2 2;
Edit REF25.sym;
LAYER Symbols;
LAYER Pins;
Edit REF25.dev;
Prefix 'REF';
Value on;
Add REF25 Next 0 (0 0);
Edit L8.sym;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
LAYER Values;
LAYER Pins;
EDIT L8.pac;
DESCRIPTION 'FESTINDUKTIVITÄT';
LAYER tPlace;
WIRE 300 ROUND (-2300 -3750) (2300 -3750);
WIRE 300 ROUND (2300 -3750) (2300 3750);
WIRE 300 ROUND (2300 3750) (-2300 3750);
WIRE 300 ROUND (-2300 3750) (-2300 -3750);
LAYER Vias;
CHANGE DRILL 800;
PAD '1' 1800 R90.0 Octagon (0 -2540);
CHANGE DRILL 800;
PAD '2' 1800 R90.0 Octagon (0 2540);
LAYER tPlace;
TEXT >VALUE R90.0 (5080 -3810);
Edit L8.dev;
Prefix 'L';
Description 'Miniatur-Festinduktivität 68µH';
Value on;
Add L8 Next 0 (0 0);
Package L8;
CONNECT 2 2 1 1;
Edit L9.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L9.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
Edit L9.dev;
Prefix 'L';
Value on;
Add L9 Next 0 (0 0);
Package L9;
CONNECT 2 2 1 1;
Edit L10.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L10.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
Edit L10.dev;
Prefix 'L';
Value on;
Add L10 Next 0 (0 0);
Package L10;
CONNECT 2 2 1 1;
Edit L11.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L11.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
Edit L11.dev;
Prefix 'L';
Value on;
Add L11 Next 0 (0 0);
Package L11;
CONNECT 2 2 1 1;
Edit L12.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
LAYER Values;
LAYER Pins;
EDIT L12.pac;
LAYER tPlace;
LAYER Vias;
CHANGE DRILL 800;
CHANGE DRILL 800;
LAYER tPlace;
Edit L12.dev;
Prefix 'L';
Value on;
Add L12 Next 0 (0 0);
Package L12;
CONNECT 2 2 1 1;
EDIT GEH1.pac;
DESCRIPTION 'P-EURO';
LAYER Dimension;
WIRE 300 ROUND (0 0) (0 100330);
WIRE 300 ROUND (0 100330) (160020 100330);
WIRE 300 ROUND (160020 100330) (160020 0);
WIRE 300 ROUND (160020 0) (0 0);
LAYER Bottom;
WIRE 1000 ROUND (0 0) (0 10160);
WIRE 1000 ROUND (0 0) (10160 0);
WIRE 1000 ROUND (0 90170) (0 100330);
WIRE 1000 ROUND (0 100330) (10160 100330);
WIRE 1000 ROUND (149860 100330) (160020 100330);
WIRE 1000 ROUND (160020 100330) (160020 90170);
WIRE 1000 ROUND (160020 10160) (160020 0);
WIRE 1000 ROUND (160020 0) (149860 0);
LAYER Top;
WIRE 1000 ROUND (10160 0) (0 0);
Edit GEH1.dev;
Prefix 'GEH';
Description '';
Value on;
Package GEH1;
CONNECT;
Edit D1.sym;
LAYER Symbols;
WIRE 300 ROUND (-1270 0) (2540 0);
LAYER Pins;
PIN 'A' 0 Pas None R0 Short Off (-3810 0);
PIN 'K' 0 Pas None R180 Short Off (5080 0);
LAYER Symbols;
WIRE 300 ROUND (-1270 -1905) (2540 0);
WIRE 300 ROUND (2540 0) (-1270 1905);
WIRE 300 ROUND (-1270 1905) (-1270 -1905);
WIRE 300 ROUND (2508 1905) (2508 -1905);
LAYER Names;
LAYER Values;
TEXT >VALUE R0.0 (-3810 -4445);
LAYER Symbols;
WIRE 300 ROUND (1142 2015) (2963 3896);
POLYGON (3873 4838) 0 (2762 2914) 0 (1976 3582) 0 (3873 4838);
WIRE 300 ROUND (-73 3084) (1747 4966);
POLYGON (2657 5907) 0 (1546 3982) 0 (766 4710) 0 (2657 5907);
EDIT D1.pac;
DESCRIPTION '1206';
LAYER tGlue;
CIRCLE 0 (0 0) (400 0);
LAYER Top;
LAYER tPlace;
CHANGE SIZE 1500;
TEXT >NAME R0.0 (-62 -2700);
Edit D1.dev;
Prefix 'D';
Description 'Leuchtdiode, SMD 1206, Diffus, grün';
Value on;
Add D1 Next 0 (0 0);
Package D1;
CONNECT A 1 K 2;
Edit R4.sym;
LAYER Pins;
LAYER Symbols;
LAYER Names;
CHANGE SIZE 2000;
CHANGE RATIO 10;
LAYER Values;
EDIT R4.pac;
DESCRIPTION '0805';
LAYER tGlue;
LAYER Top;
LAYER tPlace;
CHANGE SIZE 800;
CHANGE RATIO 9;
TEXT >NAME R0.0 (-596 -1872);
Edit R4.dev;
Prefix 'R';
Value on;
Add R4 Next 0 (0 0);
Package R4;
CONNECT 1 1 2 2;
Edit REF26.sym;
LAYER Symbols;
LAYER Pins;
Edit REF26.dev;
Prefix 'REF';
Description 'Referenz GND';
Value on;
Add REF26 Next 0 (0 0);
#2008-06-30-DMX-Dimmer.lbr speichern und schliessen
Write;
Close;
#TARGET3001 Schaltplan aufbauen
Grid MIC;
SET WIRE_BEND 2;
#Schaltplan:
LAYER Symbols;
ADD 'IC1' IC1@2008-06-30-DMX-Dimmer.lbr R0 (-81280 27305);
VALUE IC1 'ATMEGA8(TQFP32)';
ADD 'IC2' IC2@2008-06-30-DMX-Dimmer.lbr R0 (-154906 29711);
VALUE IC2 'LTC485CS8';
ADD 'REF4' REF4@2008-06-30-DMX-Dimmer.lbr R0 (-227965 116205);
VALUE REF4 'GND';
ADD 'REF49' REF49@2008-06-30-DMX-Dimmer.lbr R0 (-173990 120650);
VALUE REF49 'GND';
ADD 'REF8' REF8@2008-06-30-DMX-Dimmer.lbr R0 (-131739 154533);
VALUE REF8 '+5V';
ADD 'BR1' BR1@2008-06-30-DMX-Dimmer.lbr R0 (-243205 138430);
VALUE BR1 'GLEICHRICHTER-SMD_1000V/0,8A';
ADD 'REF9' REF9@2008-06-30-DMX-Dimmer.lbr R0 (-257175 125095);
VALUE REF9 'GND';
ADD 'L1' L1@2008-06-30-DMX-Dimmer.lbr R0 (-251460 150495);
VALUE L1 '150µH DR74-150-R';
ADD 'IC3' IC3@2008-06-30-DMX-Dimmer.lbr R0 (-193040 136525);
VALUE IC3 'LM2674M';
ADD 'C3' C3@2008-06-30-DMX-Dimmer.lbr R0 (-227965 126365);
VALUE C3 '1µF';
ADD 'C2' C2@2008-06-30-DMX-Dimmer.lbr R0 (-189230 149225);
VALUE C2 '10nF';
ADD 'REF6' REF6@2008-06-30-DMX-Dimmer.lbr R0 (-161989 120440);
VALUE REF6 'GND';
ADD 'L2' L2@2008-06-30-DMX-Dimmer.lbr R0 (-147160 139756);
VALUE L2 '220µH EPCOS SMT';
ADD 'D3' D3@2008-06-30-DMX-Dimmer.lbr R0 (-161941 131073);
VALUE D3 'MBRA160T3';
ADD 'C4' C4@2008-06-30-DMX-Dimmer.lbr R0 (-134930 131476);
VALUE C4 '22µF';
ADD 'REF7' REF7@2008-06-30-DMX-Dimmer.lbr R0 (-134941 121014);
VALUE REF7 'GND';
ADD 'REF10' REF10@2008-06-30-DMX-Dimmer.lbr R0 (-205740 132715);
VALUE REF10 '+5V';
ADD 'IC4' IC4@2008-06-30-DMX-Dimmer.lbr R0 (15240 87630);
VALUE IC4 'MOC3052M';
ADD 'R1' R1@2008-06-30-DMX-Dimmer.lbr R0 (23495 126365);
VALUE R1 '330';
ADD 'TRIAC1' TRIAC1@2008-06-30-DMX-Dimmer.lbr R0 (15875 148590);
VALUE TRIAC1 'TIC236M';
ADD 'R2' R2@2008-06-30-DMX-Dimmer.lbr R0 (15240 170180);
VALUE R2 'S05K275';
ADD 'F1' F1@2008-06-30-DMX-Dimmer.lbr R0 (6985 185420);
VALUE F1 '6,3A';
ADD 'L3' L3@2008-06-30-DMX-Dimmer.lbr R0 (20320 180975);
VALUE L3 'B82111-E-C23';
ADD 'R5' R5@2008-06-30-DMX-Dimmer.lbr R0 (9525 52070);
VALUE R5 '470';
ADD 'REF1' REF1@2008-06-30-DMX-Dimmer.lbr R0 (23495 66040);
VALUE REF1 'GND';
ADD 'IC5' IC5@2008-06-30-DMX-Dimmer.lbr R0 (50165 87630);
VALUE IC5 'MOC3052M';
ADD 'R3' R3@2008-06-30-DMX-Dimmer.lbr R0 (58420 126365);
VALUE R3 '330';
ADD 'TRIAC2' TRIAC2@2008-06-30-DMX-Dimmer.lbr R0 (50800 148590);
VALUE TRIAC2 'TIC236M';
ADD 'R6' R6@2008-06-30-DMX-Dimmer.lbr R0 (50165 170180);
VALUE R6 'S05K275';
ADD 'F2' F2@2008-06-30-DMX-Dimmer.lbr R0 (41910 185420);
VALUE F2 '6,3A';
ADD 'L4' L4@2008-06-30-DMX-Dimmer.lbr R0 (55245 180975);
VALUE L4 'B82111-E-C23';
ADD 'R7' R7@2008-06-30-DMX-Dimmer.lbr R0 (44450 52070);
VALUE R7 '470';
ADD 'REF2' REF2@2008-06-30-DMX-Dimmer.lbr R0 (58420 66040);
VALUE REF2 'GND';
ADD 'IC6' IC6@2008-06-30-DMX-Dimmer.lbr R0 (85090 87630);
VALUE IC6 'MOC3052M';
ADD 'R8' R8@2008-06-30-DMX-Dimmer.lbr R0 (93345 126365);
VALUE R8 '330';
ADD 'TRIAC3' TRIAC3@2008-06-30-DMX-Dimmer.lbr R0 (85725 148590);
VALUE TRIAC3 'TIC236M';
ADD 'R9' R9@2008-06-30-DMX-Dimmer.lbr R0 (85090 170180);
VALUE R9 'S05K275';
ADD 'F3' F3@2008-06-30-DMX-Dimmer.lbr R0 (76835 185420);
VALUE F3 '6,3A';
ADD 'L5' L5@2008-06-30-DMX-Dimmer.lbr R0 (90170 180975);
VALUE L5 'B82111-E-C23';
ADD 'R10' R10@2008-06-30-DMX-Dimmer.lbr R0 (79375 52070);
VALUE R10 '470';
ADD 'REF3' REF3@2008-06-30-DMX-Dimmer.lbr R0 (93345 66040);
VALUE REF3 'GND';
ADD 'IC7' IC7@2008-06-30-DMX-Dimmer.lbr R0 (122555 86995);
VALUE IC7 'MOC3052M';
ADD 'R11' R11@2008-06-30-DMX-Dimmer.lbr R0 (130810 125730);
VALUE R11 '330';
ADD 'TRIAC4' TRIAC4@2008-06-30-DMX-Dimmer.lbr R0 (123190 147955);
VALUE TRIAC4 'TIC236M';
ADD 'R12' R12@2008-06-30-DMX-Dimmer.lbr R0 (122555 169545);
VALUE R12 'S05K275';
ADD 'F4' F4@2008-06-30-DMX-Dimmer.lbr R0 (114300 184785);
VALUE F4 '6,3A';
ADD 'L6' L6@2008-06-30-DMX-Dimmer.lbr R0 (127635 180340);
VALUE L6 'B82111-E-C23';
ADD 'R13' R13@2008-06-30-DMX-Dimmer.lbr R0 (116840 51435);
VALUE R13 '470';
ADD 'REF5' REF5@2008-06-30-DMX-Dimmer.lbr R0 (130810 65405);
VALUE REF5 'GND';
ADD 'IC8' IC8@2008-06-30-DMX-Dimmer.lbr R0 (160020 85090);
VALUE IC8 'MOC3052M';
ADD 'R14' R14@2008-06-30-DMX-Dimmer.lbr R0 (168275 123825);
VALUE R14 '330';
ADD 'TRIAC5' TRIAC5@2008-06-30-DMX-Dimmer.lbr R0 (160655 146050);
VALUE TRIAC5 'TIC236M';
ADD 'R15' R15@2008-06-30-DMX-Dimmer.lbr R0 (160020 167640);
VALUE R15 'S05K275';
ADD 'F5' F5@2008-06-30-DMX-Dimmer.lbr R0 (151765 182880);
VALUE F5 '6,3A';
ADD 'L7' L7@2008-06-30-DMX-Dimmer.lbr R0 (165100 178435);
VALUE L7 'B82111-E-C23';
ADD 'R16' R16@2008-06-30-DMX-Dimmer.lbr R0 (154305 49530);
VALUE R16 '470';
ADD 'REF11' REF11@2008-06-30-DMX-Dimmer.lbr R0 (168275 63500);
VALUE REF11 'GND';
ADD 'Tr1' Tr1@2008-06-30-DMX-Dimmer.lbr R0 (-306070 153035);
VALUE Tr1 'TRAFO_EI30_PRI230V-SEK6V/166MA';
ADD 'KL1' KL1@2008-06-30-DMX-Dimmer.lbr R0 (196215 206375);
VALUE KL1 'KLEMME2POL';
ADD 'REF12' REF12@2008-06-30-DMX-Dimmer.lbr R0 (-80010 -635);
VALUE REF12 'GND';
ADD 'REF13' REF13@2008-06-30-DMX-Dimmer.lbr R0 (-82550 62230);
VALUE REF13 'GND';
ADD 'REF14' REF14@2008-06-30-DMX-Dimmer.lbr R0 (-74930 62230);
VALUE REF14 '+5V';
ADD 'REF15' REF15@2008-06-30-DMX-Dimmer.lbr R0 (-77470 -6350);
VALUE REF15 '+5V';
ADD 'K7' K7@2008-06-30-DMX-Dimmer.lbr R0 (-34925 -79375);
VALUE K7 'K2X3';
ADD 'REF16' REF16@2008-06-30-DMX-Dimmer.lbr R0 (-27940 -53340);
VALUE REF16 '+5V';
ADD 'REF17' REF17@2008-06-30-DMX-Dimmer.lbr R0 (-22860 -81915);
VALUE REF17 'GND';
ADD 'IC9' 'a' IC9@2008-06-30-DMX-Dimmer.lbr R0 (179705 -6985);
VALUE IC9 'PC827';
ADD 'IC10' 'a' IC10@2008-06-30-DMX-Dimmer.lbr R0 (179705 -31750);
VALUE IC10 'PC827';
ADD 'R17' R17@2008-06-30-DMX-Dimmer.lbr R0 (216535 -17780);
VALUE R17 '56K';
ADD 'J1' J1@2008-06-30-DMX-Dimmer.lbr R0 (156210 -10795);
VALUE J1 'JUMPER2';
ADD 'REF18' REF18@2008-06-30-DMX-Dimmer.lbr R0 (158750 3810);
VALUE REF18 'GND';
ADD 'R18' R18@2008-06-30-DMX-Dimmer.lbr R0 (163830 -57150);
VALUE R18 '10K';
ADD 'R19' R19@2008-06-30-DMX-Dimmer.lbr R0 (-64770 -81915);
VALUE R19 '10K';
ADD 'REF19' REF19@2008-06-30-DMX-Dimmer.lbr R0 (163830 -67945);
VALUE REF19 '+5V';
ADD 'REF20' REF20@2008-06-30-DMX-Dimmer.lbr R0 (-79375 -81915);
VALUE REF20 '+5V';
ADD 'Q1' Q1@2008-06-30-DMX-Dimmer.lbr R0 (-64135 -6350);
VALUE Q1 '16Meg';
ADD 'C1' C1@2008-06-30-DMX-Dimmer.lbr R0 (-71120 -19050);
VALUE C1 '22pF';
ADD 'C5' C5@2008-06-30-DMX-Dimmer.lbr R0 (-59690 -19050);
VALUE C5 '22pF';
ADD 'REF21' REF21@2008-06-30-DMX-Dimmer.lbr R0 (-65405 -26670);
VALUE REF21 'GND';
ADD 'K1' K1@2008-06-30-DMX-Dimmer.lbr R0 (-100965 72390);
VALUE K1 'K2X6';
ADD 'TH1' TH1@2008-06-30-DMX-Dimmer.lbr R0 (-40005 162560);
VALUE TH1 'ABM.(BXHXT)MM45X45X25,4';
ADD 'TH2' TH2@2008-06-30-DMX-Dimmer.lbr R0 (-40005 149860);
VALUE TH2 'ABM.(BXHXT)MM45X45X25,4';
ADD 'TH3' TH3@2008-06-30-DMX-Dimmer.lbr R0 (-40005 132715);
VALUE TH3 'ABM.(BXHXT)MM45X45X25,4';
ADD 'TH4' TH4@2008-06-30-DMX-Dimmer.lbr R0 (-40005 120650);
VALUE TH4 'ABM.(BXHXT)MM45X45X25,4';
ADD 'TH5' TH5@2008-06-30-DMX-Dimmer.lbr R0 (-40005 107315);
VALUE TH5 'ABM.(BXHXT)MM45X45X25,4';
ADD 'KL2' KL2@2008-06-30-DMX-Dimmer.lbr R0 (10795 218440);
VALUE KL2 'KLEMME2POL';
ADD 'KL3' KL3@2008-06-30-DMX-Dimmer.lbr R0 (45720 218440);
VALUE KL3 'KLEMME2POL';
ADD 'KL4' KL4@2008-06-30-DMX-Dimmer.lbr R0 (80645 218440);
VALUE KL4 'KLEMME2POL';
ADD 'KL5' KL5@2008-06-30-DMX-Dimmer.lbr R0 (118110 218440);
VALUE KL5 'KLEMME2POL';
ADD 'KL6' KL6@2008-06-30-DMX-Dimmer.lbr R0 (155575 218440);
VALUE KL6 'KLEMME2POL';
ADD 'KL7' KL7@2008-06-30-DMX-Dimmer.lbr R0 (46990 249555);
VALUE KL7 'KLEMME2POL';
ADD 'KL8' KL8@2008-06-30-DMX-Dimmer.lbr R0 (62230 249555);
VALUE KL8 'KLEMME2POL';
ADD 'KL9' KL9@2008-06-30-DMX-Dimmer.lbr R0 (77470 249555);
VALUE KL9 'KLEMME2POL';
ADD 'REF22' REF22@2008-06-30-DMX-Dimmer.lbr R0 (-172085 6350);
VALUE REF22 '+5V';
ADD 'REF23' REF23@2008-06-30-DMX-Dimmer.lbr R0 (-169545 50800);
VALUE REF23 'GND';
ADD 'J2' J2@2008-06-30-DMX-Dimmer.lbr R0 (-203200 40005);
VALUE J2 'JUMPER2';
ADD 'R20' R20@2008-06-30-DMX-Dimmer.lbr R0 (-192405 27940);
VALUE R20 '120';
ADD 'KL10' KL10@2008-06-30-DMX-Dimmer.lbr R0 (-237490 46355);
VALUE KL10 'KLEMME2POL';
ADD 'KL11' KL11@2008-06-30-DMX-Dimmer.lbr R0 (-237490 27305);
VALUE KL11 'KLEMME2POL';
ADD 'KL12' KL12@2008-06-30-DMX-Dimmer.lbr R0 (-237490 64770);
VALUE KL12 'KLEMME2POL';
ADD 'REF24' REF24@2008-06-30-DMX-Dimmer.lbr R0 (-227330 68580);
VALUE REF24 'GND';
ADD 'C6' C6@2008-06-30-DMX-Dimmer.lbr R0 (-78740 57785);
VALUE C6 '0,1µF';
ADD 'C7' C7@2008-06-30-DMX-Dimmer.lbr R0 (-156210 47625);
VALUE C7 '0,1µF';
ADD 'C8' C8@2008-06-30-DMX-Dimmer.lbr R0 (-121285 129540);
VALUE C8 '0,1µF';
ADD 'REF25' REF25@2008-06-30-DMX-Dimmer.lbr R0 (-121285 121285);
VALUE REF25 'GND';
ADD 'L8' L8@2008-06-30-DMX-Dimmer.lbr R0 (28575 180975);
VALUE L8 '40µH';
ADD 'L9' L9@2008-06-30-DMX-Dimmer.lbr R0 (63500 180975);
VALUE L9 '40µH';
ADD 'L10' L10@2008-06-30-DMX-Dimmer.lbr R0 (99060 180975);
VALUE L10 '40µH';
ADD 'L11' L11@2008-06-30-DMX-Dimmer.lbr R0 (135890 180340);
VALUE L11 '40µH';
ADD 'L12' L12@2008-06-30-DMX-Dimmer.lbr R0 (173355 178435);
VALUE L12 '40µH';
ADD 'D1' D1@2008-06-30-DMX-Dimmer.lbr R0 (-6350 10795);
VALUE D1 'LED-SMD1206_GRUEN';
ADD 'R4' R4@2008-06-30-DMX-Dimmer.lbr R0 (7620 10795);
VALUE R4 '560';
ADD 'REF26' REF26@2008-06-30-DMX-Dimmer.lbr R0 (18415 10795);
VALUE REF26 'GND';
Grid MIC 635 2;
SET AUTO_JUNCTION ON;
LAYER Nets;
NET 'GND' (-257175 125095) (-257175 138430);
NET 'GND' (-253365 138430) (-257175 138430);
NET 'GND' (-227965 116205) (-227965 118745);
NET 'GND' (-173990 120650) (-173990 135255);
NET 'GND' (-173990 135255) (-179070 135255);
NET 'GND' (-227965 118745) (-227965 116205);
NET 'GND' (-161989 120440) (-161958 127240);
NET 'GND' (-161989 120440) (-161941 127263);
NET 'GND' (-134941 121014) (-135077 121014);
NET 'GND' (-134941 121014) (-134930 123856);
NET 'GND' (23495 66040) (23495 73660);
NET 'GND' (-80010 -635) (-80010 4445);
NET 'GND' (-80010 4445) (-85090 4445);
NET 'GND' (-80010 4445) (-80010 6985);
NET 'GND' (-85090 4445) (-85090 6985);
NET 'GND' (-82550 62230) (-82550 57785);
NET 'GND' (-22860 -81915) (-33655 -81915);
NET 'GND' (158750 0) (158750 3810);
NET 'GND' (158750 -13335) (158750 0);
NET 'GND' (158750 0) (168275 0);
NET 'GND' (-65405 -26670) (-65405 -22860);
NET 'GND' (-71120 -22860) (-65405 -22860);
NET 'GND' (-65405 -22860) (-59690 -22860);
NET 'GND' (-85725 55880) (-82550 55880);
NET 'GND' (-85725 55880) (-85725 73660);
NET 'GND' (-94615 73660) (-85725 73660);
NET 'GND' (-97155 73660) (-94615 73660);
NET 'GND' (-99695 73660) (-97155 73660);
NET 'GND' (-107315 73660) (-104775 73660);
NET 'GND' (-104775 73660) (-102235 73660);
NET 'GND' (-102235 73660) (-99695 73660);
NET 'GND' (-82550 55880) (-82550 47625);
NET 'GND' (-169545 50800) (-169545 47625);
NET 'GND' (-227330 68580) (-233045 68580);
NET 'GND' (-233045 60960) (-233045 68580);
NET 'GND' (-82550 55880) (-82550 57785);
NET 'GND' (-82550 57785) (-82550 55880);
NET 'GND' (-169545 35560) (-169545 47625);
NET 'GND' (-169545 35560) (-167005 35560);
NET 'GND' (-169545 47625) (-160020 47625);
NET 'GND' (-160020 47625) (-169545 47625);
NET 'GND' (-169545 47625) (-169545 35560);
NET 'GND' (-121285 121285) (-121285 125730);
NET 'GND' (168275 63500) (168275 71120);
NET 'GND' (130810 65405) (130810 73025);
NET 'GND' (93345 66040) (93345 73660);
NET 'GND' (58420 66040) (58420 73660);
NET 'GND' (12700 10795) (18415 10795);
NET '+5V' (-134938 154533) (-131739 154533);
NET '+5V' (-134930 140391) (-134938 154533);
NET '+5V' (-134930 140391) (-135255 140335);
NET '+5V' (-134930 131476) (-134930 140391);
NET '+5V' (-205740 132715) (-201930 132715);
NET '+5V' (-77470 -6350) (-77470 1905);
NET '+5V' (-77470 1905) (-82550 1905);
NET '+5V' (-77470 1905) (-77470 6985);
NET '+5V' (-82550 1905) (-82550 6985);
NET '+5V' (-74930 62230) (-74930 57785);
NET '+5V' (-74930 54610) (-80010 54610);
NET '+5V' (-74930 54610) (-74930 47625);
NET '+5V' (-80010 54610) (-80010 47625);
NET '+5V' (-27940 -60325) (-27940 -60960);
NET '+5V' (-27940 -76835) (-33655 -76835);
NET '+5V' (-27940 -53340) (-27940 -60960);
NET '+5V' (-27940 -60960) (-27940 -76835);
NET '+5V' (-79375 -81915) (-69850 -81915);
NET '+5V' (163830 -67945) (163830 -62230);
NET '+5V' (-172085 6350) (-172085 12065);
NET '+5V' (-172085 24130) (-167005 24130);
NET '+5V' (-74930 54610) (-74930 57785);
NET '+5V' (-74930 57785) (-74930 54610);
NET '+5V' (-172085 12065) (-138430 12065);
NET '+5V' (-172085 12065) (-172085 24130);
NET '+5V' (-138430 12065) (-138430 47625);
NET '+5V' (-138430 47625) (-152400 47625);
NET '+5V' (-135255 140335) (-121285 140335);
NET '+5V' (-135255 140335) (-142080 140391);
NET '+5V' (-121285 140335) (-121285 133350);
NET '+UB' (-227965 138430) (-227965 137160);
NET '+UB' (-227965 126365) (-227965 128270);
NET '+UB' (-233045 138430) (-227965 138430);
NET '+UB' (-227965 128270) (-227965 138430);
NET '+UB' (-227965 138430) (-227965 155575);
NET '+UB' (-227965 155575) (-173990 155575);
NET '+UB' (-173990 155575) (-173990 137795);
NET '+UB' (-173990 137795) (-179070 137795);
NET 'VSW' (-179070 140335) (-179070 149225);
NET 'VSW' (-179070 149225) (-185420 149225);
NET 'VSW' (-179070 140335) (-161958 140388);
NET 'VSW' (-161958 140388) (-161958 136130);
NET 'VSW' (-161958 140388) (-152240 140391);
NET 'VSW' (-152240 140391) (-152191 140242);
NET 'VSW' (-161941 136153) (-161958 140388);
NET 'Sig$6' (-193040 149225) (-201930 149225);
NET 'Sig$6' (-201930 149225) (-201930 140335);
NET 'PD0' (-95250 23495) (-114935 23495);
NET 'PD0' (-114935 23495) (-114935 24130);
NET 'PD0' (-114935 24130) (-143510 24130);
NET 'RE/' (-99695 18415) (-99695 -38100);
NET 'RE/' (-99695 18415) (-95250 18415);
NET 'RE/' (-99695 -38100) (163830 -38100);
NET 'RE/' (163830 -13970) (168275 -13970);
NET 'RE/' (163830 -38735) (163830 -38100);
NET 'RE/' (163830 -38735) (168275 -38735);
NET 'RE/' (163830 -52070) (163830 -38735);
NET 'RE/' (163830 -38100) (163830 -13970);
NET 'PD1' (-95250 20955) (-112395 20955);
NET 'PD1' (-112395 20955) (-112395 35560);
NET 'PD1' (-112395 35560) (-143510 35560);
NET 'MainTerm' (23495 101124) (23495 121285);
NET '2' (23495 131445) (23495 145415);
NET 'A1' (15875 144145) (15875 132715);
NET 'A1' (15875 132715) (6985 132715);
NET 'A1' (6985 132715) (6985 100965);
NET 'A1' (6985 132715) (6985 170180);
NET 'A1' (6985 170180) (10160 170180);
NET 'A1' (6985 170180) (6985 180340);
NET 'Sig$14' (20320 170180) (20320 153035);
NET 'Sig$14' (20320 153035) (15875 153035);
NET 'Sig$14' (20320 170180) (20320 180975);
NET 'Sig$14' (28575 180975) (20320 180975);
NET 'Sig$15' (9525 57150) (9525 73660);
NET 'Sig$17' (58420 101124) (58420 121285);
NET 'Sig$18' (58420 131445) (58420 145415);
NET 'Sig$19' (50800 144145) (50800 132715);
NET 'Sig$19' (50800 132715) (41910 132715);
NET 'Sig$19' (41910 132715) (41910 100965);
NET 'Sig$19' (41910 132715) (41910 170180);
NET 'Sig$19' (41910 170180) (45085 170180);
NET 'Sig$19' (41910 170180) (41910 180340);
NET 'Sig$20' (55245 170180) (55245 153035);
NET 'Sig$20' (55245 153035) (50800 153035);
NET 'Sig$20' (55245 170180) (55245 180975);
NET 'Sig$20' (63500 180975) (55245 180975);
NET 'Sig$21' (44450 57150) (44450 73660);
NET 'Sig$23' (93345 101124) (93345 121285);
NET 'Sig$24' (93345 131445) (93345 145415);
NET 'Sig$25' (85725 144145) (85725 132715);
NET 'Sig$25' (85725 132715) (76835 132715);
NET 'Sig$25' (76835 132715) (76835 100965);
NET 'Sig$25' (76835 132715) (76835 170180);
NET 'Sig$25' (76835 170180) (80010 170180);
NET 'Sig$25' (76835 170180) (76835 180340);
NET 'Sig$26' (90170 170180) (90170 153035);
NET 'Sig$26' (90170 153035) (85725 153035);
NET 'Sig$26' (90170 170180) (90170 180975);
NET 'Sig$26' (99060 180975) (90170 180975);
NET 'Sig$27' (79375 57150) (79375 73660);
NET 'Sig$29' (130810 100489) (130810 120650);
NET 'Sig$30' (130810 130810) (130810 144780);
NET 'Sig$31' (123190 143510) (123190 132080);
NET 'Sig$31' (123190 132080) (114300 132080);
NET 'Sig$31' (114300 132080) (114300 100330);
NET 'Sig$31' (114300 132080) (114300 169545);
NET 'Sig$31' (114300 169545) (117475 169545);
NET 'Sig$31' (114300 169545) (114300 179705);
NET 'Sig$32' (127635 169545) (127635 152400);
NET 'Sig$32' (127635 152400) (123190 152400);
NET 'Sig$32' (127635 169545) (127635 180340);
NET 'Sig$32' (135890 180340) (127635 180340);
NET 'Sig$33' (116840 56515) (116840 73025);
NET 'Sig$35' (168275 98584) (168275 118745);
NET 'Sig$36' (168275 128905) (168275 142875);
NET 'Sig$37' (160655 141605) (160655 130175);
NET 'Sig$37' (160655 130175) (151765 130175);
NET 'Sig$37' (151765 130175) (151765 98425);
NET 'Sig$37' (151765 130175) (151765 167640);
NET 'Sig$37' (151765 167640) (154940 167640);
NET 'Sig$37' (151765 167640) (151765 177800);
NET 'Sig$38' (165100 167640) (165100 150495);
NET 'Sig$38' (165100 150495) (160655 150495);
NET 'Sig$38' (165100 167640) (165100 178435);
NET 'Sig$38' (173355 178435) (165100 178435);
NET 'Sig$39' (154305 54610) (154305 71120);
NET 'PB1' (-67310 28575) (154305 28575);
NET 'PB1' (154305 28575) (154305 44450);
NET 'PB2' (-67310 31115) (116840 31115);
NET 'PB2' (116840 31115) (116840 46355);
NET '7' (-298450 144780) (-279400 144780);
NET '7' (-279400 144780) (-279400 128270);
NET '7' (-279400 128270) (-243205 128270);
NET 'N' (-340995 210185) (14605 210185);
NET 'N' (-340995 144780) (-340995 210185);
NET 'N' (-313690 144780) (-340995 144780);
NET 'N' (178435 210185) (178435 188595);
NET 'N' (178435 210185) (191770 210185);
NET 'N' (178435 188595) (207010 188595);
NET 'N' (207010 188595) (207010 0);
NET 'N' (207010 0) (221615 0);
NET 'N' (221615 0) (221615 -17780);
LAYER Symbols;
CHANGE SIZE 1400;
CHANGE RATIO 13;
TEXT 'N' R0.0 (135890 210502);
LAYER Nets;
NET 'N' (159385 210185) (159385 213995);
NET 'N' (159385 210185) (178435 210185);
NET 'N' (121920 210185) (121920 213995);
NET 'N' (121920 210185) (159385 210185);
NET 'N' (84455 210185) (84455 213995);
NET 'N' (84455 210185) (121920 210185);
NET 'N' (49530 210185) (49530 213995);
NET 'N' (49530 210185) (84455 210185);
NET 'N' (14605 210185) (14605 213995);
NET 'N' (14605 210185) (49530 210185);
NET 'L1' (165100 202565) (175895 202565);
NET 'L1' (165100 188595) (165100 202565);
NET 'L1' (127635 202565) (165100 202565);
NET 'L1' (183515 202565) (184150 202565);
NET 'L1' (183515 202565) (191770 202565);
NET 'L1' (127635 190500) (127635 202565);
NET 'L1' (90170 202565) (127635 202565);
NET 'L1' (90170 191135) (90170 202565);
NET 'L1' (55245 202565) (90170 202565);
NET 'L1' (55245 191135) (55245 202565);
NET 'L1' (20320 202565) (55245 202565);
NET 'L1' (20320 202565) (20320 202565);
NET 'L1' (20320 202565) (-331470 202565);
NET 'L1' (20320 191135) (20320 202565);
NET 'L1' (-331470 202565) (-331470 160020);
NET 'L1' (-331470 160020) (-313690 160020);
NET 'L1' (175895 186055) (175895 202565);
NET 'L1' (203835 186055) (175895 186055);
NET 'L1' (203835 0) (203835 186055);
NET 'L1' (203835 0) (191770 0);
NET 'L1' (203835 -38735) (203835 0);
NET 'L1' (191770 -38735) (203835 -38735);
NET 'L1' (175895 202565) (183515 202565);
LAYER Symbols;
TEXT 'L1' R0.0 (135890 202882);
LAYER Nets;
NET 'L1' (28575 191135) (20320 191135);
NET 'L1' (63500 191135) (55245 191135);
NET 'L1' (99060 191135) (90170 191135);
NET 'L1' (135890 190500) (127635 190500);
NET 'L1' (173355 188595) (165100 188595);
NET 'Reset' (-52705 -81915) (-36195 -81915);
NET 'Reset' (-52705 -81915) (-52705 50165);
NET 'Reset' (-52705 50165) (-77470 50165);
NET 'Reset' (-77470 50165) (-77470 47625);
NET 'Reset' (-59690 -81915) (-52705 -81915);
NET 'MISO' (-49530 -76835) (-36195 -76835);
NET 'MISO' (-49530 -76835) (-49530 36195);
NET 'MISO' (44450 36195) (44450 46990);
NET 'MISO' (-49530 36195) (44450 36195);
NET 'MISO' (-49530 36195) (-67310 36195);
NET 'SCK' (-46355 -79375) (-36195 -79375);
NET 'SCK' (-46355 -79375) (-46355 53340);
NET 'SCK' (-5715 46990) (9525 46990);
NET 'SCK' (-5715 53340) (-5715 46990);
NET 'SCK' (-72390 53340) (-46355 53340);
NET 'SCK' (-72390 47625) (-72390 53340);
NET 'SCK' (-46355 53340) (-5715 53340);
NET 'MOSI' (-25400 -53340) (-25400 -53975);
NET 'MOSI' (-25400 -79375) (-33655 -79375);
NET 'MOSI' (-25400 -53975) (-25400 33655);
NET 'MOSI' (-25400 -53975) (-25400 -79375);
NET 'MOSI' (79375 33655) (79375 46990);
NET 'MOSI' (-67310 33655) (-25400 33655);
NET 'MOSI' (-25400 33655) (79375 33655);
NET 'A' (191770 -13970) (211455 -13970);
NET 'A' (211455 -13970) (211455 -17780);
NET 'A' (211455 -17780) (211455 -24765);
NET 'A' (211455 -24765) (191770 -24765);
NET 'E' (168275 -24765) (158750 -24765);
NET 'E' (158750 -24765) (158750 -15875);
NET 'Sig$51' (-143510 27940) (-110490 27940);
NET 'Sig$51' (-143510 27940) (-143510 31750);
NET 'Sig$51' (-110490 27940) (-110490 26035);
NET 'Sig$51' (-110490 26035) (-95250 26035);
NET '1' (-68580 -6350) (-71120 -6350);
NET '1' (-74930 -6350) (-74930 6985);
NET '1' (-71120 -15240) (-71120 -6350);
NET '1' (-71120 -6350) (-74930 -6350);
NET 'Sig$53' (-59690 -6350) (-59690 1270);
NET 'Sig$53' (-59690 1270) (-72390 1270);
NET 'Sig$53' (-72390 1270) (-72390 6985);
NET 'Sig$53' (-59690 -15240) (-59690 -6350);
NET 'PC0' (-87630 47625) (-87630 64135);
NET 'PC0' (-87630 64135) (-94615 64135);
NET 'PC0' (-94615 64135) (-94615 71120);
NET 'PC1' (-90170 47625) (-90170 62230);
NET 'PC1' (-90170 62230) (-97155 62230);
NET 'PC1' (-97155 62230) (-97155 71120);
NET 'PC2' (-95250 36195) (-99695 36195);
NET 'PC2' (-99695 36195) (-99695 71120);
NET 'PC3' (-95250 33655) (-102235 33655);
NET 'PC3' (-102235 33655) (-102235 71120);
NET 'PC4' (-95250 31115) (-104775 31115);
NET 'PC4' (-104775 31115) (-104775 71120);
NET 'PC5' (-95250 28575) (-107315 28575);
NET 'PC5' (-107315 28575) (-107315 71120);
NET 'Sig$60' (6985 190500) (6985 213995);
NET 'Sig$61' (41910 190500) (41910 213995);
NET 'Sig$62' (76835 190500) (76835 213995);
NET 'Sig$63' (114300 189865) (114300 213995);
NET 'Sig$64' (151765 187960) (151765 213995);
NET 'PE' (58420 245110) (66040 245110);
NET 'PE' (50800 245110) (58420 245110);
NET 'PE' (66040 245110) (73660 245110);
NET 'PE' (43180 245110) (50800 245110);
NET 'PE' (73660 245110) (81280 245110);
LAYER Symbols;
TEXT 'PE' R0.0 (60325 242888);
LAYER Nets;
NET 'B' (-167005 27940) (-185420 27940);
NET 'B' (-185420 23495) (-185420 27940);
NET 'B' (-225425 23495) (-185420 23495);
NET 'B' (-225425 23495) (-233045 23495);
NET 'B' (-225425 42545) (-225425 23495);
NET 'B' (-233045 42545) (-225425 42545);
NET 'B' (-185420 27940) (-187325 27940);
NET 'Sig$67' (-197485 27940) (-197485 34925);
NET 'Sig$67' (-197485 34925) (-200660 34925);
NET 'Sig$68' (-200660 37465) (-185420 37465);
NET 'Sig$68' (-185420 37465) (-185420 31750);
NET 'Sig$68' (-185420 31750) (-167005 31750);
NET 'Sig$68' (-185420 50165) (-185420 37465);
NET 'Sig$68' (-222885 50165) (-185420 50165);
NET 'Sig$68' (-222885 31115) (-233045 31115);
NET 'Sig$68' (-222885 50165) (-222885 31115);
NET 'Sig$68' (-233045 50165) (-222885 50165);
NET '9' (-298450 160020) (-243205 160020);
NET '9' (-243205 160020) (-243205 148590);
NET 'K' (-1270 10795) (2540 10795);
NET 'PB0' (-67310 26035) (-22225 26035);
NET 'PB0' (-22225 26035) (-22225 10795);
NET 'PB0' (-22225 10795) (-10160 10795);
#Free elems in schematic:
WINDOW FIT;
BOARD;
Grid MIC;
SET WIRE_BEND 2;
DELETE (1000 1000) (1000 1000) (99000 79000) (99000 79000);
#Board:
MOVE IC1 (49848 63024);
MOVE IC2 (51118 45244);
MOVE BR1 (6032 70644);
MOVE IC3 (24448 74454);
MOVE C3 (27622 82709);
MOVE C2 (20638 74454);
MOVE L2 (25718 66199);
MOVE D3 (24448 79534);
MOVE C4 (30798 75724);
MOVE IC4 (69532 47149);
MOVE R1 (100012 50324);
MOVE TRIAC1 (90488 44609);
MOVE R2 (106998 44609);
MOVE F1 (128588 48419);
MOVE L3 (96838 35084);
MOVE R5 (63818 47149);
MOVE IC5 (69532 59214);
MOVE R3 (100012 62389);
MOVE TRIAC2 (90488 56674);
MOVE R6 (106998 56674);
MOVE F2 (128588 57309);
MOVE L4 (96838 27464);
MOVE R7 (63818 59214);
MOVE IC6 (69532 71279);
MOVE R8 (100012 74454);
MOVE TRIAC3 (90488 68739);
MOVE R9 (106998 68739);
MOVE F3 (128588 66199);
MOVE L5 (96838 19844);
MOVE R10 (63818 71279);
MOVE IC7 (69532 83344);
MOVE R11 (100012 86519);
MOVE TRIAC4 (90488 80804);
MOVE R12 (106998 80804);
MOVE F4 (128588 75089);
MOVE L6 (96838 12224);
MOVE R13 (63818 83344);
MOVE IC8 (69532 95409);
MOVE R14 (100012 98584);
MOVE TRIAC5 (90488 92869);
MOVE R15 (106998 92869);
MOVE F5 (128588 83979);
MOVE L7 (96838 4604);
MOVE R16 (63818 95409);
MOVE Tr1 (16192 37624);
MOVE KL1 (17462 19209);
MOVE K7 (42228 82709);
MOVE IC9 (41592 23654);
MOVE IC10 (51752 23654);
MOVE R17 (47942 18574);
MOVE J1 (50482 35719);
MOVE R18 (41592 35719);
MOVE R19 (40958 63659);
MOVE Q1 (54292 73184);
MOVE C1 (56832 80169);
MOVE C5 (51752 80169);
MOVE K1 (51752 52864);
MOVE KL2 (151448 40799);
MOVE KL3 (151448 50959);
MOVE KL4 (151448 61119);
MOVE KL5 (151448 71279);
MOVE KL6 (151448 81439);
MOVE KL7 (147638 94774);
MOVE KL8 (137478 94774);
MOVE KL9 (127318 94774);
MOVE J2 (61278 43974);
MOVE R20 (58102 45244);
MOVE KL10 (40958 92710);
MOVE KL11 (30798 92710);
MOVE KL12 (13970 92392);
MOVE C6 (42862 61119);
MOVE C7 (58102 42704);
MOVE C8 (34925 76835);
MOVE L8 (103505 35242);
MOVE L9 (94298 27464);
MOVE L10 (103505 19844);
MOVE L11 (94298 12224);
MOVE L12 (103505 4445);
ADD 'GEH1' GEH1@2008-06-30-DMX-Dimmer.lbr R0 (0 0);
MOVE D1 (43815 74771);
MOVE R4 (39529 75406);
Grid MIC 159 2;
LAYER Top;
WIRE 'GND' 300 ROUND (44132 31274) (44132 33814);
WIRE 'GND' 300 ROUND (44132 33814) (46038 35719);
WIRE 'GND' 300 ROUND (46038 35719) (47942 35719);
WIRE 'GND' 300 ROUND (29122 82709) (29122 80899);
WIRE 'GND' 300 ROUND (29122 80899) (30798 79224);
WIRE 'GND' 300 ROUND (30798 79224) (36188 79224);
WIRE 'GND' 300 ROUND (43498 75089) (44768 76359);
WIRE 'GND' 300 ROUND (44768 76359) (44768 77629);
WIRE 'GND' 300 ROUND (25082 76954) (25082 78899);
WIRE 'GND' 300 ROUND (25082 78899) (25718 79534);
WIRE 'GND' 300 ROUND (25718 79534) (26668 79534);
WIRE 'GND' 300 ROUND (26668 79534) (28034 80899);
WIRE 'GND' 300 ROUND (28034 80899) (29122 80899);
WIRE 'GND' 300 ROUND (7682 78264) (14032 84614);
WIRE 'GND' 300 ROUND (14032 84614) (28258 84614);
WIRE 'GND' 300 ROUND (28258 84614) (29122 83749);
WIRE 'GND' 300 ROUND (29122 83749) (29122 82709);
WIRE 'GND' 300 ROUND (56832 81169) (51752 81169);
WIRE 'GND' 300 ROUND (51752 81169) (50212 81169);
WIRE 'GND' 300 ROUND (50212 81169) (46672 77629);
WIRE 'GND' 300 ROUND (46672 77629) (44768 77629);
LAYER Bottom;
WIRE 'GND' 300 ROUND (39052 50324) (41592 50324);
WIRE 'GND' 300 ROUND (41592 50324) (44132 50324);
WIRE 'GND' 300 ROUND (44132 50324) (46672 50324);
WIRE 'GND' 300 ROUND (46672 50324) (49212 50324);
WIRE 'GND' 300 ROUND (49212 50324) (51752 50324);
WIRE 'GND' 300 ROUND (51752 50324) (54610 50324);
WIRE 'GND' 300 ROUND (60008 50324) (65722 44609);
WIRE 'GND' 300 ROUND (65722 44609) (69532 44609);
WIRE 'GND' 300 ROUND (42643 63659) (43498 64514);
LAYER Top;
WIRE 'GND' 300 ROUND (55168 57954) (54698 57484);
WIRE 'GND' 300 ROUND (54354 63424) (55168 62610);
LAYER Bottom;
WIRE 'GND' 300 ROUND (49212 36989) (47942 35719);
LAYER Top;
WIRE 'GND' 300 ROUND (48808 62624) (49608 61824);
LAYER Bottom;
WIRE 'GND' 300 ROUND (41592 50324) (42643 51374);
LAYER Vias;
LAYER Bottom;
WIRE 'GND' 300 ROUND (43498 66991) (43498 64514);
WIRE 'GND' 300 ROUND (54698 57484) (54610 50324);
WIRE 'GND' 300 ROUND (42643 63659) (42643 51374);
LAYER Top;
WIRE 'GND' 300 ROUND (55168 61824) (55168 57954);
WIRE 'GND' 300 ROUND (55168 61824) (55168 62610);
WIRE 'GND' 300 ROUND (53898 63424) (54354 63424);
WIRE 'GND' 300 ROUND (53898 61824) (49608 61824);
WIRE 'GND' 300 ROUND (53898 61824) (55168 61824);
LAYER Bottom;
WIRE 'GND' 300 ROUND (49212 50324) (49212 36989);
LAYER Top;
WIRE 'GND' 300 ROUND (45798 62624) (48808 62624);
WIRE 'GND' 300 ROUND (43498 75089) (43498 66991);
WIRE 'GND' 300 ROUND (47942 35719) (50482 38259);
WIRE 'GND' 300 ROUND (50482 38259) (54292 38259);
WIRE 'GND' 300 ROUND (54292 38259) (55718 39684);
WIRE 'GND' 300 ROUND (55718 39684) (55718 40839);
WIRE 'GND' 300 ROUND (55758 40799) (57198 40799);
WIRE 'GND' 300 ROUND (55758 40799) (55718 40839);
WIRE 'GND' 300 ROUND (57198 40799) (58102 41704);
WIRE 'GND' 300 ROUND (34925 77835) (36188 79098);
WIRE 'GND' 300 ROUND (36188 79098) (36188 79224);
WIRE 'GND' 300 ROUND (45798 62624) (44685 62624);
WIRE 'GND' 300 ROUND (44685 62624) (43862 61801);
WIRE 'GND' 300 ROUND (43862 61801) (43862 61119);
WIRE 'GND' 300 ROUND (11430 92392) (16510 92392);
WIRE 'GND' 300 ROUND (16510 92392) (14032 89915);
WIRE 'GND' 300 ROUND (14032 89915) (14032 84614);
LAYER Bottom;
WIRE 'GND' 300 ROUND (54610 50324) (60008 50324);
WIRE 'GND' 300 ROUND (69532 92869) (68104 92869);
WIRE 'GND' 300 ROUND (68104 92869) (66675 91440);
WIRE 'GND' 300 ROUND (66675 91440) (66675 81756);
WIRE 'GND' 300 ROUND (66675 81756) (67628 80804);
WIRE 'GND' 300 ROUND (67628 80804) (69532 80804);
WIRE 'GND' 300 ROUND (67628 80804) (66675 79851);
WIRE 'GND' 300 ROUND (66675 79851) (66675 69532);
WIRE 'GND' 300 ROUND (66675 69532) (67469 68739);
WIRE 'GND' 300 ROUND (67469 68739) (69532 68739);
WIRE 'GND' 300 ROUND (67469 68739) (66675 67945);
WIRE 'GND' 300 ROUND (66675 67945) (66675 58102);
WIRE 'GND' 300 ROUND (66675 58102) (68104 56674);
WIRE 'GND' 300 ROUND (68104 56674) (69532 56674);
WIRE 'GND' 300 ROUND (68104 56674) (66675 55245);
WIRE 'GND' 300 ROUND (66675 55245) (66675 45561);
WIRE 'GND' 300 ROUND (66675 45561) (65722 44609);
LAYER Top;
WIRE 'GND' 300 ROUND (38529 75406) (36624 77311);
WIRE 'GND' 300 ROUND (36100 77835) (34925 77835);
WIRE 'GND' 300 ROUND (36100 77835) (36624 77311);
WIRE 'GND' 300 ROUND (36624 77311) (36100 77835);
WIRE 'GND' 300 ROUND (36624 77311) (40481 77311);
WIRE 'GND' 300 ROUND (40481 77311) (41592 76200);
WIRE 'GND' 300 ROUND (41592 76200) (43021 76200);
WIRE 'GND' 300 ROUND (43021 76200) (43498 75724);
WIRE 'GND' 300 ROUND (43498 75724) (43498 75089);
WIRE '+5V' 300 ROUND (30528 71954) (26352 71954);
WIRE '+5V' 300 ROUND (30528 71954) (30798 72224);
WIRE '+5V' 300 ROUND (30798 66283) (30798 72224);
WIRE '+5V' 300 ROUND (30798 66283) (30817 66264);
WIRE '+5V' 300 ROUND (30798 72224) (30528 71954);
WIRE '+5V' 300 ROUND (30798 66283) (35962 61119);
WIRE '+5V' 300 ROUND (35962 61119) (40322 61119);
WIRE '+5V' 300 ROUND (40322 61119) (41958 62754);
WIRE '+5V' 300 ROUND (41958 62754) (41958 63659);
WIRE '+5V' 300 ROUND (42192 63424) (45798 63424);
WIRE '+5V' 300 ROUND (42192 63424) (41958 63659);
WIRE '+5V' 300 ROUND (45892 64929) (49848 64929);
WIRE '+5V' 300 ROUND (45892 64929) (45798 65024);
WIRE '+5V' 300 ROUND (49848 64929) (50552 64224);
WIRE '+5V' 300 ROUND (50552 64224) (53898 64224);
WIRE '+5V' 300 ROUND (50552 64224) (49752 63424);
WIRE '+5V' 300 ROUND (49752 63424) (45798 63424);
WIRE '+5V' 300 ROUND (39338 51594) (40542 50390);
WIRE '+5V' 300 ROUND (49752 63424) (50553 62624);
WIRE '+5V' 300 ROUND (41592 48224) (40542 49274);
WIRE '+5V' 300 ROUND (35962 54403) (38771 51594);
LAYER Vias;
LAYER Top;
WIRE '+5V' 300 ROUND (40542 49274) (40542 50390);
WIRE '+5V' 300 ROUND (39338 51594) (38771 51594);
WIRE '+5V' 300 ROUND (53898 62624) (50553 62624);
WIRE '+5V' 300 ROUND (41592 36719) (41592 47149);
WIRE '+5V' 300 ROUND (35962 61119) (35962 54403);
WIRE '+5V' 300 ROUND (30798 72224) (33648 72224);
WIRE '+5V' 300 ROUND (41592 48224) (41592 47149);
WIRE '+5V' 300 ROUND (41592 47149) (41592 48224);
WIRE '+5V' 300 ROUND (41592 47149) (49848 38894);
WIRE '+5V' 300 ROUND (49848 38894) (53340 38894);
WIRE '+5V' 300 ROUND (53340 38894) (54134 39688);
WIRE '+5V' 300 ROUND (54134 39688) (54134 44604);
WIRE '+5V' 300 ROUND (54134 44604) (55718 44649);
WIRE '+5V' 300 ROUND (55718 44649) (55718 47621);
WIRE '+5V' 300 ROUND (55718 47621) (56039 47942);
WIRE '+5V' 300 ROUND (56039 47942) (57785 47942);
WIRE '+5V' 300 ROUND (57785 47942) (58102 47625);
WIRE '+5V' 300 ROUND (58102 47625) (58102 43704);
WIRE '+5V' 300 ROUND (33648 72224) (34925 73501);
WIRE '+5V' 300 ROUND (34925 73501) (34925 75835);
WIRE '+5V' 300 ROUND (41862 61119) (40322 61119);
LAYER Bottom;
WIRE '+5V' 300 ROUND (33648 72224) (33648 74605);
WIRE '+5V' 300 ROUND (33648 74605) (40481 81439);
WIRE '+5V' 300 ROUND (40481 81439) (40481 83979);
WIRE '+5V' 300 ROUND (40481 83979) (41434 84931);
WIRE '+5V' 300 ROUND (41434 84931) (44450 84931);
WIRE '+5V' 300 ROUND (44450 84931) (44768 84614);
WIRE '+5V' 300 ROUND (44768 84614) (44768 82709);
LAYER Top;
WIRE '+UB' 300 ROUND (23812 76954) (23812 82074);
WIRE '+UB' 300 ROUND (23812 82074) (25488 82074);
WIRE '+UB' 300 ROUND (25488 82074) (26122 82709);
WIRE '+UB' 300 ROUND (23812 82074) (14922 82074);
WIRE '+UB' 300 ROUND (14922 82074) (12882 80034);
WIRE '+UB' 300 ROUND (12882 80034) (12882 78264);
WIRE 'VSW' 300 ROUND (20595 66232) (18098 68729);
WIRE 'VSW' 300 ROUND (18098 68729) (18098 74454);
WIRE 'VSW' 300 ROUND (18098 74454) (19098 75454);
WIRE 'VSW' 300 ROUND (19098 75454) (20638 75454);
WIRE 'VSW' 300 ROUND (20638 75454) (22138 76954);
WIRE 'VSW' 300 ROUND (22138 76954) (22542 76954);
WIRE 'VSW' 300 ROUND (22542 76954) (22224 77273);
WIRE 'VSW' 300 ROUND (22224 77273) (22224 79534);
WIRE 'Sig$6' 300 ROUND (22542 71954) (21042 73454);
WIRE 'Sig$6' 300 ROUND (21042 73454) (20638 73454);
WIRE 'PD0' 300 ROUND (53120 52049) (52704 51634);
WIRE 'PD0' 300 ROUND (51048 55426) (53120 53353);
WIRE 'PD0' 300 ROUND (50518 50634) (51517 51634);
WIRE 'PD0' 300 ROUND (51517 51634) (52704 51634);
WIRE 'PD0' 300 ROUND (53120 52049) (53120 53353);
WIRE 'PD0' 300 ROUND (51048 58974) (51048 55426);
WIRE 'PD0' 300 ROUND (50518 44649) (50518 50634);
LAYER Bottom;
WIRE 'RE/' 300 ROUND (51752 31274) (51752 32544);
WIRE 'RE/' 300 ROUND (51752 32544) (50482 33814);
WIRE 'RE/' 300 ROUND (50482 33814) (42862 33814);
WIRE 'RE/' 300 ROUND (42862 33814) (41592 32544);
WIRE 'RE/' 300 ROUND (41592 32544) (41592 31274);
LAYER Top;
WIRE 'RE/' 300 ROUND (41592 31274) (41592 34719);
WIRE 'RE/' 300 ROUND (53181 41275) (53023 40958);
WIRE 'RE/' 300 ROUND (52648 57858) (54764 55742);
LAYER Bottom;
WIRE 'RE/' 300 ROUND (50482 33814) (53022 36354);
LAYER Vias;
LAYER Bottom;
WIRE 'RE/' 300 ROUND (53023 40958) (53022 36354);
LAYER Top;
WIRE 'RE/' 300 ROUND (53181 47308) (53181 41275);
WIRE 'RE/' 300 ROUND (52648 58974) (52648 57858);
WIRE 'RE/' 300 ROUND (54768 48894) (54764 55742);
WIRE 'RE/' 300 ROUND (53181 47308) (54768 48894);
WIRE 'PD1' 300 ROUND (51752 41592) (52388 42228);
WIRE 'PD1' 300 ROUND (52388 48419) (52388 42228);
WIRE 'PD1' 300 ROUND (51848 58974) (51848 56788);
WIRE 'PD1' 300 ROUND (52388 48419) (53968 50000);
WIRE 'PD1' 300 ROUND (51752 40799) (50518 40839);
WIRE 'PD1' 300 ROUND (51752 41592) (51752 40799);
WIRE 'PD1' 300 ROUND (51848 56788) (53968 54667);
WIRE 'PD1' 300 ROUND (53968 54667) (53968 50000);
WIRE 'MainTerm' 300 ROUND (99012 50324) (86042 50324);
WIRE 'MainTerm' 300 ROUND (86042 50324) (81598 45879);
WIRE 'MainTerm' 300 ROUND (81598 45879) (81598 43339);
WIRE 'MainTerm' 300 ROUND (81598 43339) (80328 42069);
WIRE 'MainTerm' 300 ROUND (80328 42069) (77152 42069);
WIRE '2' 300 ROUND (101282 47149) (101282 50054);
WIRE '2' 300 ROUND (101282 50054) (101012 50324);
WIRE '2' 300 ROUND (101012 50324) (101282 50054);
LAYER Bottom;
WIRE 'A1' 1000 ROUND (117288 48419) (110938 42069);
WIRE 'A1' 1000 ROUND (110938 42069) (106998 42069);
WIRE 'A1' 1000 ROUND (106998 42069) (101282 42069);
WIRE 'A1' 1000 ROUND (101282 42069) (93028 42069);
WIRE 'A1' 1000 ROUND (93028 42069) (87948 47149);
WIRE 'A1' 1000 ROUND (87948 47149) (77152 47149);
WIRE 'Sig$14' 1000 ROUND (106998 47149) (104458 44609);
WIRE 'Sig$14' 1000 ROUND (104458 44609) (101282 44609);
LAYER Top;
WIRE 'Sig$14' 1000 ROUND (117158 35084) (113982 38259);
WIRE 'Sig$14' 1000 ROUND (113982 38259) (113982 43974);
WIRE 'Sig$14' 1000 ROUND (113982 43974) (110808 47149);
WIRE 'Sig$14' 1000 ROUND (110808 47149) (106998 47149);
WIRE 'Sig$14' 1000 ROUND (103505 32702) (114776 32702);
WIRE 'Sig$14' 1000 ROUND (114776 32702) (117158 35084);
WIRE 'Sig$15' 300 ROUND (69532 47149) (64818 47149);
WIRE 'Sig$17' 300 ROUND (99012 62389) (86042 62389);
WIRE 'Sig$17' 300 ROUND (86042 62389) (81598 57944);
WIRE 'Sig$17' 300 ROUND (81598 57944) (81598 55404);
WIRE 'Sig$17' 300 ROUND (81598 55404) (80328 54134);
WIRE 'Sig$17' 300 ROUND (80328 54134) (77152 54134);
WIRE 'Sig$18' 300 ROUND (101282 59214) (101282 62119);
WIRE 'Sig$18' 300 ROUND (101282 62119) (101012 62389);
WIRE 'Sig$18' 300 ROUND (101012 62389) (101282 62119);
LAYER Bottom;
WIRE 'Sig$19' 1000 ROUND (117288 57309) (114112 54134);
WIRE 'Sig$19' 1000 ROUND (114112 54134) (106998 54134);
WIRE 'Sig$19' 1000 ROUND (106998 54134) (101282 54134);
WIRE 'Sig$19' 1000 ROUND (101282 54134) (93028 54134);
WIRE 'Sig$19' 1000 ROUND (93028 54134) (87948 59214);
WIRE 'Sig$19' 1000 ROUND (87948 59214) (77152 59214);
WIRE 'Sig$20' 1000 ROUND (106998 59214) (104458 56674);
WIRE 'Sig$20' 1000 ROUND (104458 56674) (101282 56674);
LAYER Top;
WIRE 'Sig$20' 1000 ROUND (117158 27464) (121602 31909);
WIRE 'Sig$20' 1000 ROUND (121602 31909) (121602 57944);
WIRE 'Sig$20' 1000 ROUND (121602 57944) (117792 61754);
WIRE 'Sig$20' 1000 ROUND (117792 61754) (109538 61754);
WIRE 'Sig$20' 1000 ROUND (109538 61754) (106998 59214);
WIRE 'Sig$20' 1000 ROUND (94298 24924) (114618 24924);
WIRE 'Sig$20' 1000 ROUND (114618 24924) (117158 27464);
WIRE 'Sig$21' 300 ROUND (69532 59214) (64818 59214);
WIRE 'Sig$23' 300 ROUND (99012 74454) (86042 74454);
WIRE 'Sig$23' 300 ROUND (86042 74454) (81598 70009);
WIRE 'Sig$23' 300 ROUND (81598 70009) (81598 67469);
WIRE 'Sig$23' 300 ROUND (81598 67469) (80328 66199);
WIRE 'Sig$23' 300 ROUND (80328 66199) (77152 66199);
WIRE 'Sig$24' 300 ROUND (101282 71279) (101282 74184);
WIRE 'Sig$24' 300 ROUND (101282 74184) (101012 74454);
WIRE 'Sig$24' 300 ROUND (101012 74454) (101282 74184);
LAYER Bottom;
WIRE 'Sig$25' 1000 ROUND (117288 66199) (106998 66199);
WIRE 'Sig$25' 1000 ROUND (106998 66199) (101282 66199);
WIRE 'Sig$25' 1000 ROUND (101282 66199) (92392 66199);
WIRE 'Sig$25' 1000 ROUND (92392 66199) (87312 71279);
WIRE 'Sig$25' 1000 ROUND (87312 71279) (77152 71279);
WIRE 'Sig$26' 1000 ROUND (106998 71279) (104458 68739);
WIRE 'Sig$26' 1000 ROUND (104458 68739) (101282 68739);
LAYER Top;
WIRE 'Sig$26' 1000 ROUND (117158 19844) (124460 27146);
WIRE 'Sig$26' 1000 ROUND (124460 27146) (124460 66516);
WIRE 'Sig$26' 1000 ROUND (124460 66516) (120968 70009);
WIRE 'Sig$26' 1000 ROUND (120968 70009) (108268 70009);
WIRE 'Sig$26' 1000 ROUND (108268 70009) (106998 71279);
WIRE 'Sig$26' 1000 ROUND (103505 17304) (114618 17304);
WIRE 'Sig$26' 1000 ROUND (114618 17304) (117158 19844);
WIRE 'Sig$27' 300 ROUND (69532 71279) (64818 71279);
WIRE 'Sig$29' 300 ROUND (99012 86519) (84772 86519);
WIRE 'Sig$29' 300 ROUND (84772 86519) (81598 83344);
WIRE 'Sig$29' 300 ROUND (81598 83344) (81598 79534);
WIRE 'Sig$29' 300 ROUND (81598 79534) (80328 78264);
WIRE 'Sig$29' 300 ROUND (80328 78264) (77152 78264);
WIRE 'Sig$30' 300 ROUND (101282 83344) (101282 86249);
WIRE 'Sig$30' 300 ROUND (101282 86249) (101012 86519);
WIRE 'Sig$30' 300 ROUND (101012 86519) (101282 86249);
LAYER Bottom;
WIRE 'Sig$31' 1000 ROUND (117288 75089) (114112 78264);
WIRE 'Sig$31' 1000 ROUND (114112 78264) (106998 78264);
WIRE 'Sig$31' 1000 ROUND (106998 78264) (101282 78264);
WIRE 'Sig$31' 1000 ROUND (101282 78264) (92392 78264);
WIRE 'Sig$31' 1000 ROUND (92392 78264) (87312 83344);
WIRE 'Sig$31' 1000 ROUND (87312 83344) (77152 83344);
WIRE 'Sig$32' 1000 ROUND (106998 83344) (104458 80804);
WIRE 'Sig$32' 1000 ROUND (104458 80804) (101282 80804);
LAYER Top;
WIRE 'Sig$32' 1000 ROUND (117158 12224) (127318 22384);
WIRE 'Sig$32' 1000 ROUND (127318 22384) (127318 74454);
WIRE 'Sig$32' 1000 ROUND (127318 74454) (121602 80169);
WIRE 'Sig$32' 1000 ROUND (121602 80169) (113982 80169);
WIRE 'Sig$32' 1000 ROUND (113982 80169) (110808 83344);
WIRE 'Sig$32' 1000 ROUND (110808 83344) (106998 83344);
WIRE 'Sig$32' 1000 ROUND (94298 9684) (114618 9684);
WIRE 'Sig$32' 1000 ROUND (114618 9684) (117158 12224);
WIRE 'Sig$33' 300 ROUND (69532 83344) (64818 83344);
WIRE 'Sig$35' 300 ROUND (99012 98584) (85408 98584);
WIRE 'Sig$35' 300 ROUND (85408 98584) (81598 94774);
WIRE 'Sig$35' 300 ROUND (81598 94774) (81598 91599);
WIRE 'Sig$35' 300 ROUND (81598 91599) (80328 90329);
WIRE 'Sig$35' 300 ROUND (80328 90329) (77152 90329);
WIRE 'Sig$36' 300 ROUND (101282 95409) (101282 98314);
WIRE 'Sig$36' 300 ROUND (101282 98314) (101012 98584);
WIRE 'Sig$36' 300 ROUND (101012 98584) (101282 98314);
LAYER Bottom;
WIRE 'Sig$37' 1000 ROUND (106998 90329) (110938 90329);
WIRE 'Sig$37' 1000 ROUND (110938 90329) (117288 83979);
WIRE 'Sig$37' 1000 ROUND (106998 90329) (101282 90329);
WIRE 'Sig$37' 1000 ROUND (101282 90329) (92392 90329);
WIRE 'Sig$37' 1000 ROUND (92392 90329) (87312 95409);
WIRE 'Sig$37' 1000 ROUND (87312 95409) (77152 95409);
WIRE 'Sig$38' 1000 ROUND (106998 95409) (104458 92869);
WIRE 'Sig$38' 1000 ROUND (104458 92869) (101282 92869);
LAYER Top;
WIRE 'Sig$38' 1000 ROUND (117158 4604) (130175 17621);
WIRE 'Sig$38' 1000 ROUND (130175 17621) (130175 79216);
WIRE 'Sig$38' 1000 ROUND (130175 79216) (113982 95409);
WIRE 'Sig$38' 1000 ROUND (113982 95409) (106998 95409);
WIRE 'Sig$38' 1000 ROUND (117158 4604) (106204 4604);
WIRE 'Sig$38' 1000 ROUND (106204 4604) (103505 1905);
WIRE 'Sig$39' 300 ROUND (69532 95409) (64818 95409);
LAYER Bottom;
WIRE 'PB1' 300 ROUND (57308 75964) (58973 77629);
LAYER Top;
WIRE 'PB1' 300 ROUND (62818 95409) (58973 91564);
WIRE 'PB1' 300 ROUND (49448 74694) (50718 75964);
LAYER Vias;
LAYER Bottom;
WIRE 'PB1' 300 ROUND (50718 75964) (57308 75964);
LAYER Top;
WIRE 'PB1' 300 ROUND (58973 77629) (58973 91564);
WIRE 'PB1' 300 ROUND (49448 67074) (49448 74694);
LAYER Bottom;
WIRE 'PB2' 300 ROUND (49088 75089) (48847 75329);
LAYER Top;
WIRE 'PB2' 300 ROUND (48847 75329) (48847 75329);
WIRE 'PB2' 300 ROUND (48648 75129) (48847 75329);
LAYER Vias;
LAYER Bottom;
WIRE 'PB2' 300 ROUND (62818 75089) (49088 75089);
LAYER Top;
WIRE 'PB2' 300 ROUND (62818 83344) (62818 75089);
WIRE 'PB2' 300 ROUND (48648 67074) (48648 75129);
WIRE '7' 300 ROUND (21272 47783) (12882 56173);
WIRE '7' 300 ROUND (12882 56173) (12882 69524);
LAYER Bottom;
WIRE 'N' 1500 ROUND (151448 78899) (155258 75089);
WIRE 'N' 1500 ROUND (155258 75089) (155258 72549);
WIRE 'N' 1500 ROUND (155258 72549) (151448 68739);
WIRE 'N' 1500 ROUND (151448 68739) (155258 64929);
WIRE 'N' 1500 ROUND (155258 64929) (155258 62389);
WIRE 'N' 1500 ROUND (155258 62389) (151448 58579);
WIRE 'N' 1500 ROUND (151448 58579) (155258 54769);
WIRE 'N' 1500 ROUND (155258 54769) (155258 52229);
WIRE 'N' 1500 ROUND (155258 52229) (151448 48419);
WIRE 'N' 1500 ROUND (151448 48419) (155258 44609);
WIRE 'N' 1500 ROUND (155258 44609) (155258 42069);
WIRE 'N' 1500 ROUND (155258 42069) (151448 38259);
WIRE 'N' 1500 ROUND (151448 38259) (151448 23019);
WIRE 'N' 1500 ROUND (151448 23019) (136842 8414);
WIRE 'N' 1500 ROUND (20002 19209) (26352 25559);
WIRE 'N' 1500 ROUND (26352 25559) (26352 27464);
LAYER Top;
WIRE 'N' 1500 ROUND (43268 15399) (46442 18574);
LAYER Bottom;
WIRE 'N' 1500 ROUND (52388 8414) (51118 7144);
WIRE 'N' 1500 ROUND (51118 7144) (46038 7144);
WIRE 'N' 1500 ROUND (23812 7144) (20002 10954);
WIRE 'N' 1500 ROUND (20002 10954) (20002 19209);
LAYER Top;
WIRE 'N' 1500 ROUND (43268 15399) (43268 9914);
WIRE 'N' 1500 ROUND (43268 9914) (46038 7144);
LAYER Vias;
LAYER Bottom;
WIRE 'N' 1500 ROUND (46038 7144) (23812 7144);
WIRE 'N' 1500 ROUND (46038 7144) (51118 7144);
WIRE 'N' 1500 ROUND (52388 8414) (87948 8414);
WIRE 'N' 1500 ROUND (87948 8414) (87948 6191);
WIRE 'N' 1500 ROUND (87948 6191) (90011 4128);
WIRE 'N' 1500 ROUND (90011 4128) (111284 4128);
WIRE 'N' 1500 ROUND (111284 4128) (115411 8255);
WIRE 'N' 1500 ROUND (115411 8255) (136684 8255);
WIRE 'N' 1500 ROUND (136684 8255) (136842 8414);
WIRE 'L1' 1500 ROUND (76518 12224) (76518 19844);
WIRE 'L1' 1500 ROUND (76518 19844) (76518 27464);
WIRE 'L1' 1500 ROUND (76518 27464) (76518 35084);
WIRE 'L1' 1500 ROUND (76518 19844) (60642 19844);
WIRE 'L1' 1500 ROUND (60642 19844) (58738 17939);
WIRE 'L1' 1500 ROUND (58738 17939) (54292 17939);
WIRE 'L1' 1500 ROUND (54292 17939) (51752 20479);
WIRE 'L1' 1500 ROUND (51752 20479) (51752 23654);
LAYER Top;
WIRE 'L1' 1500 ROUND (14922 9684) (14922 19209);
WIRE 'L1' 1500 ROUND (14922 9684) (17462 7144);
WIRE 'L1' 1500 ROUND (17462 7144) (30798 7144);
WIRE 'L1' 1500 ROUND (30798 7144) (35878 12224);
LAYER Vias;
LAYER Bottom;
WIRE 'L1' 1500 ROUND (35878 12224) (36512 12859);
WIRE 'L1' 1500 ROUND (36512 12859) (51118 12859);
WIRE 'L1' 1500 ROUND (51118 12859) (54292 16034);
WIRE 'L1' 1500 ROUND (54292 16034) (54292 17939);
WIRE 'L1' 1500 ROUND (51118 12859) (44132 19844);
WIRE 'L1' 1500 ROUND (44132 19844) (44132 23654);
WIRE 'L1' 1500 ROUND (14922 19209) (6668 27463);
WIRE 'L1' 1500 ROUND (6668 27463) (6032 27463);
LAYER Top;
WIRE 'L1' 1500 ROUND (76518 4604) (76518 12224);
LAYER Bottom;
WIRE 'L1' 1500 ROUND (103505 37782) (102076 37782);
WIRE 'L1' 1500 ROUND (102076 37782) (94298 30004);
WIRE 'L1' 1500 ROUND (94298 30004) (93980 30004);
WIRE 'L1' 1500 ROUND (93980 30004) (90329 26352);
WIRE 'L1' 1500 ROUND (90329 26352) (90329 18732);
WIRE 'L1' 1500 ROUND (90329 18732) (94298 14764);
WIRE 'L1' 1500 ROUND (94298 14764) (94932 14764);
WIRE 'L1' 1500 ROUND (94932 14764) (102552 22384);
WIRE 'L1' 1500 ROUND (102552 22384) (103505 22384);
WIRE 'L1' 1500 ROUND (94298 14764) (102076 6985);
WIRE 'L1' 1500 ROUND (102076 6985) (103505 6985);
WIRE 'L1' 1500 ROUND (90329 18732) (89218 19844);
WIRE 'L1' 1500 ROUND (89218 19844) (76518 19844);
LAYER Top;
WIRE 'Reset' 300 ROUND (39958 63659) (39846 63772);
WIRE 'Reset' 300 ROUND (39846 63772) (39846 72072);
WIRE 'Reset' 300 ROUND (39846 72072) (40958 73184);
LAYER Vias;
LAYER Bottom;
WIRE 'Reset' 300 ROUND (40958 73184) (42228 74454);
WIRE 'Reset' 300 ROUND (42228 74454) (42228 77629);
LAYER Top;
WIRE 'Reset' 300 ROUND (39958 63659) (41069 64770);
WIRE 'Reset' 300 ROUND (41069 64770) (44291 64770);
WIRE 'Reset' 300 ROUND (44291 64770) (44838 64224);
WIRE 'Reset' 300 ROUND (44838 64224) (45798 64224);
LAYER Bottom;
WIRE 'MISO' 300 ROUND (46038 69374) (43498 71914);
WIRE 'MISO' 300 ROUND (56968 67074) (57208 66834);
LAYER Top;
WIRE 'MISO' 300 ROUND (62818 59214) (60277 61754);
LAYER Vias;
LAYER Bottom;
WIRE 'MISO' 300 ROUND (43498 75850) (43498 71914);
WIRE 'MISO' 300 ROUND (60277 66834) (57208 66834);
LAYER Top;
WIRE 'MISO' 300 ROUND (60277 66834) (60277 61754);
WIRE 'MISO' 300 ROUND (45777 67074) (45777 67124);
LAYER Bottom;
WIRE 'MISO' 300 ROUND (45777 67074) (56968 67074);
LAYER Top;
WIRE 'MISO' 300 ROUND (47048 67074) (45777 67074);
WIRE 'MISO' 300 ROUND (46038 67334) (46038 69374);
WIRE 'MISO' 300 ROUND (46038 67334) (45777 67074);
LAYER Bottom;
WIRE 'MISO' 300 ROUND (43498 71914) (43498 75850);
WIRE 'MISO' 300 ROUND (43498 75850) (43498 81439);
WIRE 'MISO' 300 ROUND (43498 81439) (42228 82709);
WIRE 'SCK' 300 ROUND (62818 57889) (55465 65241);
WIRE 'SCK' 300 ROUND (42622 65993) (39360 69255);
LAYER Top;
WIRE 'SCK' 300 ROUND (51513 65241) (50917 65836);
WIRE 'SCK' 300 ROUND (42667 65824) (42622 65779);
WIRE 'SCK' 300 ROUND (45798 65824) (45810 65836);
LAYER Bottom;
WIRE 'SCK' 300 ROUND (42228 80169) (39360 77302);
LAYER Vias;
LAYER Bottom;
WIRE 'SCK' 300 ROUND (53050 65241) (55465 65241);
WIRE 'SCK' 300 ROUND (53050 65241) (51513 65241);
LAYER Vias;
LAYER Bottom;
WIRE 'SCK' 300 ROUND (42622 65779) (42622 65993);
WIRE 'SCK' 300 ROUND (39360 69255) (39360 77302);
LAYER Top;
WIRE 'SCK' 300 ROUND (45810 65836) (50917 65836);
WIRE 'SCK' 300 ROUND (62818 47149) (62818 57889);
WIRE 'SCK' 300 ROUND (45798 65824) (42667 65824);
LAYER Bottom;
WIRE 'MOSI' 300 ROUND (44768 80169) (47308 77629);
WIRE 'MOSI' 300 ROUND (47308 74056) (50085 71279);
WIRE 'MOSI' 300 ROUND (47308 76599) (47308 74056);
LAYER Top;
WIRE 'MOSI' 300 ROUND (47848 76059) (47308 76599);
LAYER Vias;
LAYER Bottom;
WIRE 'MOSI' 300 ROUND (52727 71279) (50085 71279);
LAYER Vias;
LAYER Bottom;
WIRE 'MOSI' 300 ROUND (47308 76599) (47308 77629);
WIRE 'MOSI' 300 ROUND (61618 71279) (52727 71279);
LAYER Top;
WIRE 'MOSI' 300 ROUND (62818 71279) (61618 71279);
WIRE 'MOSI' 300 ROUND (47848 67074) (47848 76059);
WIRE 'A' 300 ROUND (49442 18574) (52388 18574);
WIRE 'A' 300 ROUND (52388 18574) (54292 20479);
WIRE 'A' 300 ROUND (54292 20479) (54292 23654);
WIRE 'A' 300 ROUND (49442 18574) (49442 20249);
WIRE 'A' 300 ROUND (49442 20249) (48578 21114);
WIRE 'A' 300 ROUND (48578 21114) (42228 21114);
WIRE 'A' 300 ROUND (42228 21114) (41592 21749);
WIRE 'A' 300 ROUND (41592 21749) (41592 23654);
WIRE 'E' 300 ROUND (54292 31274) (54292 33814);
WIRE 'E' 300 ROUND (54292 33814) (52388 35719);
WIRE 'E' 300 ROUND (52388 35719) (50482 35719);
LAYER Bottom;
WIRE 'Sig$51' 300 ROUND (52870 51634) (53286 52050);
WIRE 'Sig$51' 300 ROUND (50248 60974) (53286 57936);
LAYER Top;
WIRE 'Sig$51' 300 ROUND (50518 43379) (47977 45919);
LAYER Vias;
LAYER Bottom;
WIRE 'Sig$51' 300 ROUND (47977 51634) (52870 51634);
WIRE 'Sig$51' 300 ROUND (53286 57936) (53286 52050);
LAYER Top;
WIRE 'Sig$51' 300 ROUND (47977 51634) (47977 45919);
WIRE 'Sig$51' 300 ROUND (50518 42109) (50518 43379);
WIRE 'Sig$51' 300 ROUND (50248 58974) (50248 60974);
WIRE '1' 300 ROUND (53898 65024) (55022 65024);
WIRE '1' 300 ROUND (55022 65024) (55562 65564);
WIRE '1' 300 ROUND (55562 65564) (55562 71914);
WIRE '1' 300 ROUND (55562 71914) (56832 73184);
WIRE '1' 300 ROUND (56832 73184) (56832 79169);
WIRE 'Sig$53' 300 ROUND (53898 65824) (53898 71039);
WIRE 'Sig$53' 300 ROUND (53898 71039) (51752 73184);
WIRE 'Sig$53' 300 ROUND (51752 73184) (51752 79169);
WIRE 'PC0' 300 ROUND (43876 59549) (39052 54725);
WIRE 'PC0' 300 ROUND (45351 61024) (43876 59549);
WIRE 'PC0' 300 ROUND (39052 52864) (39052 54725);
WIRE 'PC0' 300 ROUND (45798 61024) (45351 61024);
WIRE 'PC1' 300 ROUND (41592 56019) (45798 60224);
WIRE 'PC1' 300 ROUND (41592 52864) (41592 56019);
WIRE 'PC2' 300 ROUND (47048 55779) (44132 52864);
WIRE 'PC2' 300 ROUND (47048 58974) (47048 55779);
WIRE 'PC3' 300 ROUND (46672 52864) (47848 54039);
WIRE 'PC3' 300 ROUND (47848 58974) (47848 54039);
WIRE 'PC4' 300 ROUND (48648 53429) (49212 52864);
WIRE 'PC4' 300 ROUND (48648 58974) (48648 53429);
WIRE 'PC5' 300 ROUND (51725 52864) (49448 55141);
WIRE 'PC5' 300 ROUND (49448 57704) (49448 55141);
WIRE 'PC5' 300 ROUND (51752 52864) (51725 52864);
WIRE 'PC5' 300 ROUND (49448 58974) (49448 57704);
LAYER Bottom;
WIRE 'Sig$60' 1000 ROUND (151448 43339) (146368 48419);
WIRE 'Sig$60' 1000 ROUND (146368 48419) (139888 48419);
WIRE 'Sig$61' 1000 ROUND (151448 53499) (147638 57309);
WIRE 'Sig$61' 1000 ROUND (147638 57309) (139888 57309);
WIRE 'Sig$62' 1000 ROUND (151448 63659) (148908 66199);
WIRE 'Sig$62' 1000 ROUND (148908 66199) (139888 66199);
WIRE 'Sig$63' 1000 ROUND (151448 73819) (150178 75089);
WIRE 'Sig$63' 1000 ROUND (150178 75089) (139888 75089);
WIRE 'Sig$64' 1000 ROUND (151448 83979) (139888 83979);
LAYER Top;
WIRE 'PE' 300 ROUND (145098 94774) (150178 94774);
WIRE 'PE' 300 ROUND (140018 94774) (145098 94774);
WIRE 'PE' 300 ROUND (134938 94774) (140018 94774);
WIRE 'PE' 300 ROUND (129858 94774) (134938 94774);
WIRE 'PE' 300 ROUND (124778 94774) (129858 94774);
LAYER Bottom;
WIRE 'PE' 300 ROUND (150178 94774) (145098 94774);
WIRE 'PE' 300 ROUND (140018 94774) (134938 94774);
WIRE 'PE' 300 ROUND (129858 94774) (124778 94774);
LAYER Top;
WIRE 'B' 300 ROUND (55718 43379) (56238 43379);
WIRE 'B' 300 ROUND (56238 43379) (56832 43974);
WIRE 'B' 300 ROUND (56832 43974) (56832 44974);
WIRE 'B' 300 ROUND (56832 44974) (57102 45244);
WIRE 'B' 300 ROUND (56832 44974) (56832 46831);
LAYER Vias;
LAYER Bottom;
WIRE 'B' 300 ROUND (56832 46831) (56832 49212);
LAYER Vias;
LAYER Top;
WIRE 'B' 300 ROUND (56832 49212) (57785 50165);
WIRE 'B' 300 ROUND (57785 50165) (57785 70326);
WIRE 'B' 300 ROUND (57785 70326) (60325 72866);
WIRE 'B' 300 ROUND (60325 72866) (60325 88662);
LAYER Vias;
LAYER Bottom;
WIRE 'B' 300 ROUND (61278 89852) (58420 92710);
WIRE 'B' 300 ROUND (58420 92710) (43498 92710);
LAYER Top;
WIRE 'B' 300 ROUND (43498 92710) (40799 95409);
WIRE 'B' 300 ROUND (40799 95409) (34925 95409);
WIRE 'B' 300 ROUND (34925 95409) (33338 93821);
WIRE 'B' 300 ROUND (33338 93821) (33338 92710);
WIRE 'B' 300 ROUND (60325 88662) (61278 89852);
WIRE 'Sig$67' 300 ROUND (59102 45244) (60372 43974);
WIRE 'Sig$67' 300 ROUND (60372 43974) (61278 43974);
WIRE 'Sig$68' 300 ROUND (55758 42069) (56198 42069);
WIRE 'Sig$68' 300 ROUND (55758 42069) (55718 42109);
WIRE 'Sig$68' 300 ROUND (56198 42069) (56832 42704);
WIRE 'Sig$68' 300 ROUND (56832 42704) (63182 42704);
WIRE 'Sig$68' 300 ROUND (63182 42704) (63818 43339);
WIRE 'Sig$68' 300 ROUND (63818 43339) (63818 43974);
WIRE 'Sig$68' 300 ROUND (63818 43974) (58896 48895);
WIRE 'Sig$68' 300 ROUND (58896 48895) (58896 70168);
WIRE 'Sig$68' 300 ROUND (58896 70168) (61595 72866);
WIRE 'Sig$68' 300 ROUND (61595 72866) (61595 87630);
WIRE 'Sig$68' 300 ROUND (61595 87630) (62706 88741);
WIRE 'Sig$68' 300 ROUND (62706 88741) (62706 91599);
LAYER Vias;
LAYER Bottom;
WIRE 'Sig$68' 300 ROUND (62706 91599) (59214 95091);
WIRE 'Sig$68' 300 ROUND (59214 95091) (40799 95091);
WIRE 'Sig$68' 300 ROUND (40799 95091) (38418 92710);
WIRE 'Sig$68' 300 ROUND (38418 92710) (38418 91599);
WIRE 'Sig$68' 300 ROUND (38418 91599) (36671 89852);
WIRE 'Sig$68' 300 ROUND (36671 89852) (31115 89852);
WIRE 'Sig$68' 300 ROUND (31115 89852) (28258 92710);
LAYER Top;
WIRE '9' 300 ROUND (11112 47783) (7682 51213);
WIRE '9' 300 ROUND (7682 51213) (7682 69524);
WIRE 'K' 300 ROUND (42315 74771) (41680 75406);
WIRE 'K' 300 ROUND (41680 75406) (40529 75406);
WIRE 'PB0' 300 ROUND (50248 67074) (50248 68662);
WIRE 'PB0' 300 ROUND (50248 68662) (50641 69056);
LAYER Vias;
LAYER Bottom;
WIRE 'PB0' 300 ROUND (50641 69056) (47942 71755);
WIRE 'PB0' 300 ROUND (47942 71755) (46514 71755);
LAYER Vias;
LAYER Top;
WIRE 'PB0' 300 ROUND (46514 71755) (45315 72954);
WIRE 'PB0' 300 ROUND (45315 72954) (45315 74771);
RATSNEST;
#Free elems in board:
#Vias originally belonging to a package:
CHANGE DRILL 600;
VIA (43498 66991);
CHANGE DRILL 600;
VIA (54698 57484);
CHANGE DRILL 600;
VIA (33648 72224);
CHANGE DRILL 600;
VIA (53023 40958);
CHANGE DRILL 600;
VIA (50718 75964);
CHANGE DRILL 600;
VIA (58973 77629);
CHANGE DRILL 600;
VIA (62818 75089);
CHANGE DRILL 600;
VIA (48847 75329);
CHANGE DRILL 600;
VIA (46038 7144);
CHANGE DRILL 600;
VIA (35878 12224);
CHANGE DRILL 600;
VIA (40958 73184);
CHANGE DRILL 600;
VIA (46038 69374);
CHANGE DRILL 600;
VIA (60277 66834);
CHANGE DRILL 600;
VIA (45777 67074);
CHANGE DRILL 600;
VIA (62818 57889);
CHANGE DRILL 600;
VIA (51513 65241);
CHANGE DRILL 600;
VIA (42622 65779);
CHANGE DRILL 600;
VIA (61618 71279);
CHANGE DRILL 600;
VIA (47308 76599);
CHANGE DRILL 600;
VIA (50248 60974);
CHANGE DRILL 600;
VIA (47977 51634);
CHANGE DRILL 600;
VIA (56832 46831);
CHANGE DRILL 600;
VIA (56832 49212);
CHANGE DRILL 600;
VIA (61278 89852);
CHANGE DRILL 600;
VIA (62706 91599);
CHANGE DRILL 600;
VIA (50641 69056);
CHANGE DRILL 600;
VIA (46514 71755);
WINDOW FIT;
