LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.ALL; -- LIBRARY lpm; Alternative Implementation von lpm_ram -- USE lpm.lpm_components.All; ENTITY RAM IS PORT( clk : IN std_logic; Enabled : IN std_logic; we : IN std_logic; Adress : IN std_logic_vector(3 downto 0); data : INOUT std_logic_vector(3 downto 0) ); END RAM; ARCHITECTURE Memory of RAM IS COMPONENT lpm_ram_io GENERIC (LPM_WIDTH: POSITIVE; LPM_WIDTHAD: POSITIVE; LPM_NUMWORDS: NATURAL := 0; LPM_INDATA: STRING := "REGISTERED"; LPM_ADDRESS_CONTROL: STRING := "REGISTERED"; LPM_OUTDATA: STRING := "REGISTERED"; LPM_FILE: STRING := "UNUSED"; LPM_TYPE: STRING := "LPM_RAM_IO"; LPM_HINT: STRING := "UNUSED"); PORT (address: IN STD_LOGIC_VECTOR(LPM_WIDTHAD-1 DOWNTO 0); inclock, outclock: IN STD_LOGIC := '0'; outenab : IN STD_LOGIC := '1'; we: IN STD_LOGIC; dio: INOUT STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0)); END COMPONENT; SIGNAL dat_sig : std_logic_vector(3 downto 0); BEGIN data<=dat_sig when(Enabled='1') else "ZZZZ"; MEM: lpm_ram_io GENERIC MAP ( LPM_WIDTH => 4, LPM_WIDTHAD => 4, LPM_NUMWORDS => 16, LPM_INDATA => "REGISTERED", LPM_ADDRESS_CONTROL => "REGISTERED", LPM_OUTDATA => "REGISTERED", LPM_FILE => "UNUSED", LPM_TYPE => "LPM_RAM_IO", LPM_HINT => "UNUSED" ) PORT MAP (Adress, clk, clk, Enabled, we, dat_sig); END Memory;
