/* * Copyright (c) 2006-2008 by Roland Riegel * * This file is free software; you can redistribute it and/or modify * it under the terms of either the GNU General Public License version 2 * or the GNU Lesser General Public License version 2.1, both as * published by the Free Software Foundation. */ #include #include #include "sd_raw.h" /** * \addtogroup sd_raw MMC/SD/SDHC card raw access * * This module implements read and write access to MMC, SD * and SDHC cards. It serves as a low-level driver for the * higher level modules such as partition and file system * access. * * @{ */ /** * \file * MMC/SD/SDHC raw access implementation (license: GPLv2 or LGPLv2.1) * * \author Roland Riegel */ /** * \addtogroup sd_raw_config MMC/SD configuration * Preprocessor defines to configure the MMC/SD support. */ /** * @} */ /* commands available in SPI mode */ /* CMD0: response R1 */ #define CMD_GO_IDLE_STATE 0x00 /* CMD1: response R1 */ #define CMD_SEND_OP_COND 0x01 /* CMD8: response R7 */ #define CMD_SEND_IF_COND 0x08 /* CMD9: response R1 */ #define CMD_SEND_CSD 0x09 /* CMD10: response R1 */ #define CMD_SEND_CID 0x0a /* CMD12: response R1 */ #define CMD_STOP_TRANSMISSION 0x0c /* CMD13: response R2 */ #define CMD_SEND_STATUS 0x0d /* CMD16: arg0[31:0]: block length, response R1 */ #define CMD_SET_BLOCKLEN 0x10 /* CMD17: arg0[31:0]: data address, response R1 */ #define CMD_READ_SINGLE_BLOCK 0x11 /* CMD18: arg0[31:0]: data address, response R1 */ #define CMD_READ_MULTIPLE_BLOCK 0x12 /* CMD24: arg0[31:0]: data address, response R1 */ #define CMD_WRITE_SINGLE_BLOCK 0x18 /* CMD25: arg0[31:0]: data address, response R1 */ #define CMD_WRITE_MULTIPLE_BLOCK 0x19 /* CMD27: response R1 */ #define CMD_PROGRAM_CSD 0x1b /* CMD28: arg0[31:0]: data address, response R1b */ #define CMD_SET_WRITE_PROT 0x1c /* CMD29: arg0[31:0]: data address, response R1b */ #define CMD_CLR_WRITE_PROT 0x1d /* CMD30: arg0[31:0]: write protect data address, response R1 */ #define CMD_SEND_WRITE_PROT 0x1e /* CMD32: arg0[31:0]: data address, response R1 */ #define CMD_TAG_SECTOR_START 0x20 /* CMD33: arg0[31:0]: data address, response R1 */ #define CMD_TAG_SECTOR_END 0x21 /* CMD34: arg0[31:0]: data address, response R1 */ #define CMD_UNTAG_SECTOR 0x22 /* CMD35: arg0[31:0]: data address, response R1 */ #define CMD_TAG_ERASE_GROUP_START 0x23 /* CMD36: arg0[31:0]: data address, response R1 */ #define CMD_TAG_ERASE_GROUP_END 0x24 /* CMD37: arg0[31:0]: data address, response R1 */ #define CMD_UNTAG_ERASE_GROUP 0x25 /* CMD38: arg0[31:0]: stuff bits, response R1b */ #define CMD_ERASE 0x26 /* ACMD41: arg0[31:0]: OCR contents, response R1 */ #define CMD_SD_SEND_OP_COND 0x29 /* CMD42: arg0[31:0]: stuff bits, response R1b */ #define CMD_LOCK_UNLOCK 0x2a /* CMD55: arg0[31:0]: stuff bits, response R1 */ #define CMD_APP 0x37 /* CMD58: arg0[31:0]: stuff bits, response R3 */ #define CMD_READ_OCR 0x3a /* CMD59: arg0[31:1]: stuff bits, arg0[0:0]: crc option, response R1 */ #define CMD_CRC_ON_OFF 0x3b /* command responses */ /* R1: size 1 byte */ #define R1_IDLE_STATE 0 #define R1_ERASE_RESET 1 #define R1_ILL_COMMAND 2 #define R1_COM_CRC_ERR 3 #define R1_ERASE_SEQ_ERR 4 #define R1_ADDR_ERR 5 #define R1_PARAM_ERR 6 /* R1b: equals R1, additional busy bytes */ /* R2: size 2 bytes */ #define R2_CARD_LOCKED 0 #define R2_WP_ERASE_SKIP 1 #define R2_ERR 2 #define R2_CARD_ERR 3 #define R2_CARD_ECC_FAIL 4 #define R2_WP_VIOLATION 5 #define R2_INVAL_ERASE 6 #define R2_OUT_OF_RANGE 7 #define R2_CSD_OVERWRITE 7 #define R2_IDLE_STATE (R1_IDLE_STATE + 8) #define R2_ERASE_RESET (R1_ERASE_RESET + 8) #define R2_ILL_COMMAND (R1_ILL_COMMAND + 8) #define R2_COM_CRC_ERR (R1_COM_CRC_ERR + 8) #define R2_ERASE_SEQ_ERR (R1_ERASE_SEQ_ERR + 8) #define R2_ADDR_ERR (R1_ADDR_ERR + 8) #define R2_PARAM_ERR (R1_PARAM_ERR + 8) /* R3: size 5 bytes */ #define R3_OCR_MASK (0xffffffffUL) #define R3_IDLE_STATE (R1_IDLE_STATE + 32) #define R3_ERASE_RESET (R1_ERASE_RESET + 32) #define R3_ILL_COMMAND (R1_ILL_COMMAND + 32) #define R3_COM_CRC_ERR (R1_COM_CRC_ERR + 32) #define R3_ERASE_SEQ_ERR (R1_ERASE_SEQ_ERR + 32) #define R3_ADDR_ERR (R1_ADDR_ERR + 32) #define R3_PARAM_ERR (R1_PARAM_ERR + 32) /* Data Response: size 1 byte */ #define DR_STATUS_MASK 0x0e #define DR_STATUS_ACCEPTED 0x05 #define DR_STATUS_CRC_ERR 0x0a #define DR_STATUS_WRITE_ERR 0x0c /* status bits for card types */ #define SD_RAW_SPEC_1 0 #define SD_RAW_SPEC_2 1 #define SD_RAW_SPEC_SDHC 2 #if !SD_RAW_SAVE_RAM /* static data buffer for acceleration */ static uint8_t raw_block[512]; /* offset where the data within raw_block lies on the card */ static offset_t raw_block_address; #if SD_RAW_WRITE_BUFFERING /* flag to remember if raw_block was written to the card */ static uint8_t raw_block_written; #endif #endif /* card type state */ static uint8_t sd_raw_card_type; /* private helper functions */ static void sd_raw_send_byte(uint8_t b); static uint8_t sd_raw_rec_byte(); static uint8_t sd_raw_send_command(uint8_t command, uint32_t arg); /** * \ingroup sd_raw * Initializes memory card communication. * * \returns 0 on failure, 1 on success. */ uint8_t sd_raw_init() { /* enable inputs for reading card status */ configure_pin_available(); configure_pin_locked(); /* enable outputs for MOSI, SCK, SS, input for MISO */ configure_pin_mosi(); configure_pin_sck(); configure_pin_ss(); configure_pin_miso(); unselect_card(); /* initialize SPI with lowest frequency; max. 400kHz during identification mode of card */ SPCR = (0 << SPIE) | // SPI Interrupt Enable (1 << SPE) | // SPI Enable (0 << DORD) | // Data Order: MSB first (1 << MSTR) | // Master mode (0 << CPOL) | // Clock Polarity: SCK low when idle (0 << CPHA) | // Clock Phase: sample on rising SCK edge (1 << SPR1) | // Clock Frequency: f_OSC / 128 (1 << SPR0); SPSR &= ~(1 << SPI2X); /* No doubled clock frequency */ /* initialization procedure */ sd_raw_card_type = 0; if(!sd_raw_available()) return 0; /* card needs 74 cycles minimum to start up */ for(uint8_t i = 0; i < 10; ++i) { /* wait 8 clock cycles */ sd_raw_rec_byte(); } /* address card */ select_card(); /* reset card */ uint8_t response; for(uint16_t i = 0; ; ++i) { response = sd_raw_send_command(CMD_GO_IDLE_STATE, 0); if(response == (1 << R1_IDLE_STATE)) break; if(i == 0x1ff) { unselect_card(); return 0; } } #if SD_RAW_SDHC /* check for version of SD card specification */ response = sd_raw_send_command(CMD_SEND_IF_COND, 0x100 /* 2.7V - 3.6V */ | 0xaa /* test pattern */); if((response & (1 << R1_ILL_COMMAND)) == 0) { sd_raw_rec_byte(); sd_raw_rec_byte(); if((sd_raw_rec_byte() & 0x01) == 0) return 0; /* card operation voltage range doesn't match */ if(sd_raw_rec_byte() != 0xaa) return 0; /* wrong test pattern */ /* card conforms to SD 2 card specification */ sd_raw_card_type |= (1 << SD_RAW_SPEC_2); } else #endif { /* determine SD/MMC card type */ sd_raw_send_command(CMD_APP, 0); response = sd_raw_send_command(CMD_SD_SEND_OP_COND, 0); if((response & (1 << R1_ILL_COMMAND)) == 0) { /* card conforms to SD 1 card specification */ sd_raw_card_type |= (1 << SD_RAW_SPEC_1); } else { /* MMC card */ } } /* wait for card to get ready */ for(uint16_t i = 0; ; ++i) { if(sd_raw_card_type & ((1 << SD_RAW_SPEC_1) | (1 << SD_RAW_SPEC_2))) { uint32_t arg = 0; #if SD_RAW_SDHC if(sd_raw_card_type & (1 << SD_RAW_SPEC_2)) arg = 0x40000000; #endif sd_raw_send_command(CMD_APP, 0); response = sd_raw_send_command(CMD_SD_SEND_OP_COND, arg); } else { response = sd_raw_send_command(CMD_SEND_OP_COND, 0); } if((response & (1 << R1_IDLE_STATE)) == 0) break; if(i == 0x7fff) { unselect_card(); return 0; } } #if SD_RAW_SDHC if(sd_raw_card_type & (1 << SD_RAW_SPEC_2)) { if(sd_raw_send_command(CMD_READ_OCR, 0)) { unselect_card(); return 0; } if(sd_raw_rec_byte() & 0x40) sd_raw_card_type |= (1 << SD_RAW_SPEC_SDHC); sd_raw_rec_byte(); sd_raw_rec_byte(); sd_raw_rec_byte(); } #endif /* set block size to 512 bytes */ if(sd_raw_send_command(CMD_SET_BLOCKLEN, 512)) { unselect_card(); return 0; } /* deaddress card */ unselect_card(); //* switch to highest SPI frequency possible // Frequenz FCPU /8 SPCR &= ~((1 << SPR1));//| (1 << SPR0)); //* Clock Frequency: f_OSC / 4 */ Beim Mega64 geht 1/4 nicht daher 1/16 // SPSR |= (1 << SPI2X); /* Doubled Clock Frequency: f_OSC / 2 */ #if !SD_RAW_SAVE_RAM /* the first block is likely to be accessed first, so precache it here */ raw_block_address = (offset_t) -1; #if SD_RAW_WRITE_BUFFERING raw_block_written = 1; #endif if(!sd_raw_read(0, raw_block, sizeof(raw_block))) return 0; #endif return 1; } /** * \ingroup sd_raw * Checks wether a memory card is located in the slot. * * \returns 1 if the card is available, 0 if it is not. */ uint8_t sd_raw_available() { return get_pin_available() == 0x00; } /** * \ingroup sd_raw * Checks wether the memory card is locked for write access. * * \returns 1 if the card is locked, 0 if it is not. */ uint8_t sd_raw_locked() { return get_pin_locked() == 0x00; } /** * \ingroup sd_raw * Sends a raw byte to the memory card. * * \param[in] b The byte to sent. * \see sd_raw_rec_byte */ void sd_raw_send_byte(uint8_t b) { SPDR = b; /* wait for byte to be shifted out */ while(!(SPSR & (1 << SPIF))); SPSR &= ~(1 << SPIF); } /** * \ingroup sd_raw * Receives a raw byte from the memory card. * * \returns The byte which should be read. * \see sd_raw_send_byte */ uint8_t sd_raw_rec_byte() { /* send dummy data for receiving some */ SPDR = 0xff; while(!(SPSR & (1 << SPIF))); SPSR &= ~(1 << SPIF); return SPDR; } /** * \ingroup sd_raw * Send a command to the memory card which responses with a R1 response (and possibly others). * * \param[in] command The command to send. * \param[in] arg The argument for command. * \returns The command answer. */ uint8_t sd_raw_send_command(uint8_t command, uint32_t arg) { uint8_t response; /* wait some clock cycles */ sd_raw_rec_byte(); /* send command via SPI */ sd_raw_send_byte(0x40 | command); sd_raw_send_byte((arg >> 24) & 0xff); sd_raw_send_byte((arg >> 16) & 0xff); sd_raw_send_byte((arg >> 8) & 0xff); sd_raw_send_byte((arg >> 0) & 0xff); switch(command) { case CMD_GO_IDLE_STATE: sd_raw_send_byte(0x95); break; case CMD_SEND_IF_COND: sd_raw_send_byte(0x87); break; default: sd_raw_send_byte(0xff); break; } /* receive response */ for(uint8_t i = 0; i < 10; ++i) { response = sd_raw_rec_byte(); if(response != 0xff) break; } return response; } /** * \ingroup sd_raw * Reads raw data from the card. * * \param[in] offset The offset from which to read. * \param[out] buffer The buffer into which to write the data. * \param[in] length The number of bytes to read. * \returns 0 on failure, 1 on success. * \see sd_raw_read_interval, sd_raw_write, sd_raw_write_interval */ uint8_t sd_raw_read(offset_t offset, uint8_t* buffer, uintptr_t length) { uint32_t block_address; uint16_t block_offset; uint16_t read_length; while(length > 0) { /* determine byte count to read at once */ block_address = offset / 512; block_offset = offset & 0x01ff; read_length = 512 - block_offset; /* read up to block border */ if(read_length > length) read_length = length; #if !SD_RAW_SAVE_RAM /* check if the requested data is cached */ if(block_address != raw_block_address) #endif { #if SD_RAW_WRITE_BUFFERING if(!sd_raw_sync()) return 0; #endif /* address card */ select_card(); /* send single block request */ #if SD_RAW_SDHC if(sd_raw_send_command(CMD_READ_SINGLE_BLOCK, ((sd_raw_card_type & SD_RAW_SPEC_SDHC) ? block_address : block_address * 512))) #else if(sd_raw_send_command(CMD_READ_SINGLE_BLOCK, block_address * 512)) #endif { unselect_card(); return 0; } // JKLM uint8_t tmp=0xFF; // wait for data block (start byte 0xfe) while(tmp && (sd_raw_rec_byte() != 0xfe)) tmp--; if (!tmp) { unselect_card(); return 0; } // while(sd_raw_rec_byte() != 0xfe); #if SD_RAW_SAVE_RAM /* read byte block */ uint16_t read_to = block_offset + read_length; for(uint16_t i = 0; i < 512; ++i) { uint8_t b = sd_raw_rec_byte(); if(i >= block_offset && i < read_to) *buffer++ = b; } #else /* read byte block */ uint8_t* cache = raw_block; for(uint16_t i = 0; i < 512; ++i) *cache++ = sd_raw_rec_byte(); raw_block_address = block_address; memcpy(buffer, raw_block + block_offset, read_length); buffer += read_length; #endif /* read crc16 */ sd_raw_rec_byte(); sd_raw_rec_byte(); /* deaddress card */ unselect_card(); /* let card some time to finish */ sd_raw_rec_byte(); } #if !SD_RAW_SAVE_RAM else { /* use cached data */ memcpy(buffer, raw_block + block_offset, read_length); buffer += read_length; } #endif length -= read_length; offset += read_length; } return 1; } /** * \ingroup sd_raw * Continuously reads units of \c interval bytes and calls a callback function. * * This function starts reading at the specified offset. Every \c interval bytes, * it calls the callback function with the associated data buffer. * * By returning zero, the callback may stop reading. * * \note Within the callback function, you can not start another read or * write operation. * \note This function only works if the following conditions are met: * - (offset - (offset % 512)) % interval == 0 * - length % interval == 0 * * \param[in] offset Offset from which to start reading. * \param[in] buffer Pointer to a buffer which is at least interval bytes in size. * \param[in] interval Number of bytes to read before calling the callback function. * \param[in] length Number of bytes to read altogether. * \param[in] callback The function to call every interval bytes. * \param[in] p An opaque pointer directly passed to the callback function. * \returns 0 on failure, 1 on success * \see sd_raw_write_interval, sd_raw_read, sd_raw_write */ uint8_t sd_raw_read_interval(offset_t offset, uint8_t* buffer, uintptr_t interval, uintptr_t length, sd_raw_read_interval_handler_t callback, void* p) { if(!buffer || interval == 0 || length < interval || !callback) return 0; #if !SD_RAW_SAVE_RAM while(length >= interval) { /* as reading is now buffered, we directly * hand over the request to sd_raw_read() */ if(!sd_raw_read(offset, buffer, interval)) return 0; if(!callback(buffer, offset, p)) break; offset += interval; length -= interval; } return 1; #else /* address card */ select_card(); uint16_t block_offset; uint16_t read_length; uint8_t* buffer_cur; uint8_t finished = 0; do { /* determine byte count to read at once */ block_offset = offset & 0x01ff; read_length = 512 - block_offset; /* send single block request */ #if SD_RAW_SDHC if(sd_raw_send_command(CMD_READ_SINGLE_BLOCK, ((sd_raw_card_type & SD_RAW_SPEC_SDHC) ? (uint32_t) offset & 0xfffffe00 : offset / 512))) #else if(sd_raw_send_command(CMD_READ_SINGLE_BLOCK, offset & 0xfffffe00)) #endif { unselect_card(); return 0; } // JKLM uint8_t tmp=0xFF; // wait for data block (start byte 0xfe) while(tmp && (sd_raw_rec_byte() != 0xfe)) tmp--; if (!tmp) { unselect_card(); return 0; } // while(sd_raw_rec_byte() != 0xfe); /* read up to the data of interest */ for(uint16_t i = 0; i < block_offset; ++i) sd_raw_rec_byte(); /* read interval bytes of data and execute the callback */ do { if(read_length < interval || length < interval) break; buffer_cur = buffer; for(uint16_t i = 0; i < interval; ++i) *buffer_cur++ = sd_raw_rec_byte(); if(!callback(buffer, offset + (512 - read_length), p)) { finished = 1; break; } read_length -= interval; length -= interval; } while(read_length > 0 && length > 0); /* read rest of data block */ while(read_length-- > 0) sd_raw_rec_byte(); /* read crc16 */ sd_raw_rec_byte(); sd_raw_rec_byte(); if(length < interval) break; offset = (offset & 0xfffffe00) + 512; } while(!finished); /* deaddress card */ unselect_card(); /* let card some time to finish */ sd_raw_rec_byte(); return 1; #endif } #if DOXYGEN || SD_RAW_WRITE_SUPPORT /** * \ingroup sd_raw * Writes raw data to the card. * * \note If write buffering is enabled, you might have to * call sd_raw_sync() before disconnecting the card * to ensure all remaining data has been written. * * \param[in] offset The offset where to start writing. * \param[in] buffer The buffer containing the data to be written. * \param[in] length The number of bytes to write. * \returns 0 on failure, 1 on success. * \see sd_raw_write_interval, sd_raw_read, sd_raw_read_interval */ uint8_t sd_raw_write(offset_t offset, const uint8_t* buffer, uintptr_t length) { if(get_pin_locked()) return 0; offset_t block_address; uint16_t block_offset; uint16_t write_length; while(length > 0) { /* determine byte count to write at once */ block_offset = offset & 0x01ff; block_address = offset - block_offset; write_length = 512 - block_offset; /* write up to block border */ if(write_length > length) write_length = length; /* Merge the data to write with the content of the block. * Use the cached block if available. */ if(block_address != raw_block_address) { #if SD_RAW_WRITE_BUFFERING if(!sd_raw_sync()) return 0; #endif if(block_offset || write_length < 512) { if(!sd_raw_read(block_address, raw_block, sizeof(raw_block))) return 0; } raw_block_address = block_address; } if(buffer != raw_block) { memcpy(raw_block + block_offset, buffer, write_length); #if SD_RAW_WRITE_BUFFERING raw_block_written = 0; if(length == write_length) return 1; #endif } /* address card */ select_card(); /* send single block request */ #if SD_RAW_SDHC if(sd_raw_send_command(CMD_WRITE_SINGLE_BLOCK, (sd_raw_card_type & (1 << SD_RAW_SPEC_SDHC) ? block_address / 512 : block_address))) #else if(sd_raw_send_command(CMD_WRITE_SINGLE_BLOCK, block_address)) #endif { unselect_card(); return 0; } /* send start byte */ sd_raw_send_byte(0xfe); /* write byte block */ uint8_t* cache = raw_block; for(uint16_t i = 0; i < 512; ++i) sd_raw_send_byte(*cache++); /* write dummy crc16 */ sd_raw_send_byte(0xff); sd_raw_send_byte(0xff); // JKLM uint16_t tmp=0x1FFF; // wait for data block while(tmp && (sd_raw_rec_byte() != 0xff)) tmp--; if (!tmp) { unselect_card(); return 0; } // while(sd_raw_rec_byte() != 0xff); sd_raw_rec_byte(); /* deaddress card */ unselect_card(); buffer += write_length; offset += write_length; length -= write_length; #if SD_RAW_WRITE_BUFFERING raw_block_written = 1; #endif } return 1; } #endif #if DOXYGEN || SD_RAW_WRITE_SUPPORT /** * \ingroup sd_raw * Writes a continuous data stream obtained from a callback function. * * This function starts writing at the specified offset. To obtain the * next bytes to write, it calls the callback function. The callback fills the * provided data buffer and returns the number of bytes it has put into the buffer. * * By returning zero, the callback may stop writing. * * \param[in] offset Offset where to start writing. * \param[in] buffer Pointer to a buffer which is used for the callback function. * \param[in] length Number of bytes to write in total. May be zero for endless writes. * \param[in] callback The function used to obtain the bytes to write. * \param[in] p An opaque pointer directly passed to the callback function. * \returns 0 on failure, 1 on success * \see sd_raw_read_interval, sd_raw_write, sd_raw_read */ uint8_t sd_raw_write_interval(offset_t offset, uint8_t* buffer, uintptr_t length, sd_raw_write_interval_handler_t callback, void* p) { #if SD_RAW_SAVE_RAM #error "SD_RAW_WRITE_SUPPORT is not supported together with SD_RAW_SAVE_RAM" #endif if(!buffer || !callback) return 0; uint8_t endless = (length == 0); while(endless || length > 0) { uint16_t bytes_to_write = callback(buffer, offset, p); if(!bytes_to_write) break; if(!endless && bytes_to_write > length) return 0; /* as writing is always buffered, we directly * hand over the request to sd_raw_write() */ if(!sd_raw_write(offset, buffer, bytes_to_write)) return 0; offset += bytes_to_write; length -= bytes_to_write; } return 1; } #endif #if DOXYGEN || SD_RAW_WRITE_SUPPORT /** * \ingroup sd_raw * Writes the write buffer's content to the card. * * \note When write buffering is enabled, you should * call this function before disconnecting the * card to ensure all remaining data has been * written. * * \returns 0 on failure, 1 on success. * \see sd_raw_write */ uint8_t sd_raw_sync() { #if SD_RAW_WRITE_BUFFERING if(raw_block_written) return 1; if(!sd_raw_write(raw_block_address, raw_block, sizeof(raw_block))) return 0; raw_block_written = 1; #endif return 1; } #endif /** * \ingroup sd_raw * Reads informational data from the card. * * This function reads and returns the card's registers * containing manufacturing and status information. * * \note: The information retrieved by this function is * not required in any way to operate on the card, * but it might be nice to display some of the data * to the user. * * \param[in] info A pointer to the structure into which to save the information. * \returns 0 on failure, 1 on success. */ uint8_t sd_raw_get_info(struct sd_raw_info* info) { if(!info || !sd_raw_available()) return 0; memset(info, 0, sizeof(*info)); select_card(); /* read cid register */ if(sd_raw_send_command(CMD_SEND_CID, 0)) { unselect_card(); return 0; } // JKLM uint8_t tmp=0xFF; // wait for data block (start byte 0xfe) while(tmp && (sd_raw_rec_byte() != 0xfe)) tmp--; if (!tmp) { unselect_card(); return 0; } // while(sd_raw_rec_byte() != 0xfe); for(uint8_t i = 0; i < 18; ++i) { uint8_t b = sd_raw_rec_byte(); switch(i) { case 0: info->manufacturer = b; break; case 1: case 2: info->oem[i - 1] = b; break; case 3: case 4: case 5: case 6: case 7: info->product[i - 3] = b; break; case 8: info->revision = b; break; case 9: case 10: case 11: case 12: info->serial |= (uint32_t) b << ((12 - i) * 8); break; case 13: info->manufacturing_year = b << 4; break; case 14: info->manufacturing_year |= b >> 4; info->manufacturing_month = b & 0x0f; break; } } /* read csd register */ uint8_t csd_read_bl_len = 0; uint8_t csd_c_size_mult = 0; #if SD_RAW_SDHC uint16_t csd_c_size = 0; #else uint32_t csd_c_size = 0; #endif if(sd_raw_send_command(CMD_SEND_CSD, 0)) { unselect_card(); return 0; } // JKLM tmp=0xFF; // wait for data block (start byte 0xfe) while(tmp && (sd_raw_rec_byte() != 0xfe)) tmp--; if (!tmp) { unselect_card(); return 0; } // while(sd_raw_rec_byte() != 0xfe); for(uint8_t i = 0; i < 18; ++i) { uint8_t b = sd_raw_rec_byte(); if(i == 14) { if(b & 0x40) info->flag_copy = 1; if(b & 0x20) info->flag_write_protect = 1; if(b & 0x10) info->flag_write_protect_temp = 1; info->format = (b & 0x0c) >> 2; } else { #if SD_RAW_SDHC if(sd_raw_card_type & (1 << SD_RAW_SPEC_2)) { switch(i) { case 7: b &= 0x3f; case 8: case 9: csd_c_size <<= 8; csd_c_size |= b; break; } if(i == 9) { ++csd_c_size; info->capacity = (offset_t) csd_c_size * 512 * 1024; } } else #endif { switch(i) { case 5: csd_read_bl_len = b & 0x0f; break; case 6: csd_c_size = b & 0x03; csd_c_size <<= 8; break; case 7: csd_c_size |= b; csd_c_size <<= 2; break; case 8: csd_c_size |= b >> 6; ++csd_c_size; break; case 9: csd_c_size_mult = b & 0x03; csd_c_size_mult <<= 1; break; case 10: csd_c_size_mult |= b >> 7; info->capacity = (uint32_t) csd_c_size << (csd_c_size_mult + csd_read_bl_len + 2); break; } } } } unselect_card(); return 1; }
