---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; --use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.NUMERIC_STD.all; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity toplevel is Port ( LEDs_out : out Std_Logic_Vector (7 downto 0); DIP_Switches : in Std_Logic_Vector (7 downto 0); -- Push_Button_Reset : in Std_Logic; reset : in Std_Logic; -- RS232 : inout Std_Logic_Vector (xxx); CLK : in Std_Logic); end toplevel; architecture Behavioral of toplevel is signal LEDs_in : Std_Logic_Vector (7 downto 0) := (others => '0'); signal count : integer range 0 to (125000000/2-1); signal signed_DIP : SIGNED(7 downto 0); begin process(reset,CLK) begin if reset = '1' then count <= 0; LEDs_in <= X"01"; signed_DIP <= SIGNED(DIP_Switches); elsif rising_edge(CLK) then if count < ((125000000 / signed_DIP) - 1) then count <= count +1; else LEDs_in <= LEDs_in(6 downto 0) & LEDs_in(7); count <= 0; end if; end if; end process; LEDs_out <= LEDs_in; end Behavioral;
