library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following lines to use the declarations that are -- provided for instantiating Xilinx primitive components. --library UNISIM; --use UNISIM.VComponents.all; entity Mem_interface is Port ( --Load/Store Signale address : in std_logic_vector(31 downto 0); data_wr : in std_logic_vector(31 downto 0); data_rd : out std_logic_vector(31 downto 0); wr : in std_logic; rd : in std_logic; --Fetch-Signale pc : in std_logic_vector(31 downto 0); fetch_valid : out std_logic; instruction : out std_logic_vector(31 downto 0); --allgemeine Ausgangs-Signale (Memory) rd_out: out std_logic; wr_out: out std_logic; memory_address : out std_logic_vector(31 downto 0); mem_wr_data : out std_logic_vector(31 downto 0); --allgemeine Signale (Pipeline) mem_stall_out: out std_logic; --FlashROM-Signale flash_rd : in std_logic_vector(31 downto 0); flash_ready: in std_logic; cs_flash: out std_logic; --SDRAM-Signale sdram_ready : in std_logic; sdram_rd : in std_logic_vector(31 downto 0); cs_sdram: out std_logic; --LCD-Signale LCD_ready: in std_logic; cs_lcd: out std_logic; --Takt, Reset, LEDs clk : in std_logic; reset : in std_logic; LED_out : out std_logic_vector(7 downto 0); brake : in std_logic; flash_ready_out : out std_logic; --Programcounter copy_count : in std_logic_vector(31 downto 0); --BootLoader-Data bl_data : in std_logic_vector(31 downto 0)); end Mem_interface; --Adressbereiche: --fetch: --0-0x3fff :FlashROM --0x3fff-> :SDRAM -- --load/store: -- store: load: --0-0x7f LCD Flash --0x80 LEDs Flash --0x90-0x9f RS232 RS232 -- nur für die RS232 Gruppe --0x90-0x9f PS2 PS2 -- nur für die PS2 Gruppe --0x90-0x9f SPI SPI -- nur für die SPI Gruppe --0xa0-0x3fff SDRAM Flash --0x3fff-> SDRAM SDRAM architecture Behavioral of Mem_interface is constant sel_SDRAM : std_logic_vector(2 downto 0) := "000"; constant sel_FLASH : std_logic_vector(2 downto 0) := "001"; constant sel_RS232 : std_logic_vector(2 downto 0) := "010"; constant sel_PS2 : std_logic_vector(2 downto 0) := "011"; constant sel_SPI : std_logic_vector(2 downto 0) := "100"; signal data_sel: std_logic_vector(2 downto 0); signal data_save: std_logic_vector(31 downto 0); begin flash_ready_out <= flash_ready; process (clk, brake) begin if clk'event and clk='1' then data_rd<=data_save; -- Taktsynchrone Ausgabe der gelesenen Daten if brake='1' then mem_stall_out <= '1'; -- Pipeline aufhalten mem_wr_data <= bl_data; else mem_stall_out <= '0'; -- Pipeline weiterlaufen lassen mem_wr_data <= data_wr; end if; end if; end process; process (flash_rd,sdram_rd,data_sel) begin -- Asynchrones Puffern gelesener Daten case data_sel is when sel_SDRAM => instruction <= sdram_rd; data_save <= sdram_rd; when sel_FLASH => instruction <= flash_rd; data_save <= flash_rd; when others => null; end case; end process; process (address,pc,rd,wr,flash_ready,sdram_ready,LCD_ready,copy_count) begin -- Verarbeitung eingehender Speicherzugriffe if rd='1' or wr='1' then -- load oder store fetch_valid<='0'; --D, S if brake = '0' then memory_address<=address; mem_stall_out<='0'; else if (copy_count > 16383) then -- Wenn Wert größer als 3FFF memory_address<=copy_count; mem_stall_out<='1'; end if; end if; --Ende cs_sdram <='0'; cs_LCD <='0'; cs_flash <= '0'; rd_out<='0'; wr_out<='0'; if wr='1' then wr_out<='1'; if address(31 downto 7)=conv_std_logic_vector(0,25) then --schreiben auf LCD if LCD_ready='0' then mem_stall_out<='1'; cs_LCD <='1'; end if; else --schreiben in SDRAM if sdram_ready='0' then mem_stall_out<='1'; cs_sdram <='1'; end if; end if; else rd_out<='1'; --D,S if brake = '0' then if address(31 downto 14)=conv_std_logic_vector(0,18) then --Von Adresse lesen --lesen aus Flash if flash_ready='0' then mem_stall_out<='1'; cs_flash <='1'; end if; data_sel<=sel_FLASH; else --lesen aus SDRAM if sdram_ready='0' then mem_stall_out<='1'; cs_sdram <='1'; end if; data_sel<=sel_SDRAM; end if; else if copy_count(31 downto 14)=conv_std_logic_vector(0,18) then --Von Counter lesen --lesen aus Flash if flash_ready='0' then mem_stall_out<='1'; cs_flash <='1'; end if; data_sel<=sel_FLASH; else --lesen aus SDRAM if sdram_ready='0' then mem_stall_out<='1'; cs_sdram <='1'; end if; data_sel<=sel_SDRAM; end if; end if; end if; --Ende D,S else -- fetch --D,S if brake = '0' then memory_address<=PC; mem_stall_out<='0'; else memory_address<=copy_count; end if; --Ende D,S rd_out<='1'; wr_out<='0'; cs_sdram <='0'; cs_LCD <='0'; cs_flash<='0'; fetch_valid<='0'; --S, D if brake = '0' then if pc(31 downto 14)=conv_std_logic_vector(0,18) then --fetch aus Flash data_sel<=sel_FLASH; if flash_ready='0' then fetch_valid<='0'; cs_flash <='1'; else fetch_valid<='1'; end if; else --fetch aus SDRAM data_sel<=sel_SDRAM; if sdram_ready='0' then fetch_valid<='0'; cs_sdram <='1'; else fetch_valid<='1'; end if; end if; else if copy_count(31 downto 14)=conv_std_logic_vector(0,18) then --fetch aus Flash data_sel<=sel_FLASH; if flash_ready='0' then fetch_valid<='0'; cs_flash <='1'; else fetch_valid<='1'; end if; else --fetch aus SDRAM data_sel<=sel_SDRAM; if sdram_ready='0' then fetch_valid<='0'; cs_sdram <='1'; else fetch_valid<='1'; end if; end if; end if; --Ende D,S end if; end process; process (clk, reset) begin -- Schreiben des LCDs if reset='1' then LED_out<="11111111"; elsif clk'event and clk='1' then if address=conv_std_logic_vector(128,32) and wr='1' then LED_out <= not data_wr(7 downto 0); end if; end if; end process; end Behavioral;
