-- Copyright (c) 2006 Frank Buss (fb@frank-buss.de) -- See license.txt for license -- -- I2C slave -- -- Usage: -- -- Master starts transfer: -- transfer_started is true until next stop bit -- read_mode is true (until next start or stop bit is detected), if the master wants to read data -- -- If read_mode is set: -- You can set data_out while data_out_requested is high (which is high for the time the fireset -- acknowlege is written and for the next bytes for the time the acknowledge from master is sampled) -- This byte will be written to the I2C master. -- -- If read mode is cleared: -- data_in is valid when data_in_valid is true (this is true, while the acknowledge is written) -- -- Special timeout behaviour: -- When the slave writes a 0 bit and the master doesn't respond with a clock, or if the slave -- missed a clock pulse, then the slave would block the bus until the next stop bit. -- A timeout counter avoids this: If the clock is not received within the next 1 ms after writing -- a bit to the bus, SDA will be released and the write state machine will be resetted to idle. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity i2c_slave is generic( clock_frequency: natural; address: unsigned(6 downto 0)); port( -- global signals clock: in std_logic; reset: in std_logic; -- byte to send to master data_out: in unsigned(7 downto 0); -- last received byte from master data_in: out unsigned(7 downto 0); -- true, if master wants to read this device read_mode: out boolean; -- true, if start was detected start_detected: out boolean; -- true, if stop was detected stop_detected: out boolean; -- true, if a valid address was received and acknolwedged transfer_started: out boolean; -- true, if data_write has to be filled to send the next byte data_out_requested: out boolean; -- true, if the master sent a byte. Now data_received is valid. data_in_valid: out boolean; -- I2C SDA and SCL signals sda: inout std_logic; scl: in std_logic); end entity i2c_slave; architecture rtl of i2c_slave is -- 4 bits are sampled to detect filter spikes -- sample rate: 1 us per 4 bits = 4 mbits/s constant sample_cycles: natural := clock_frequency / 4e6; signal sample_cycles_counter: natural range 0 to (sample_cycles - 1) := 0; -- write timeout counter constant write_timeout: natural := clock_frequency / 1e3; signal write_timeout_counter: natural range 0 to write_timeout := 0; -- signals for filtering input signal sda_sampled: unsigned(3 downto 0) := (others => '1'); signal scl_sampled: unsigned(3 downto 0) := (others => '1'); signal sda_falling_edge: boolean := false; signal sda_rising_edge: boolean := false; signal scl_falling_edge: boolean := false; signal scl_rising_edge: boolean := false; -- IO buffer signal sda_out: std_logic := '1'; signal sda_in: std_logic := '0'; -- filtered input signal sda_in_delayed: std_logic := '1'; signal scl_delayed: std_logic := '1'; -- signals calculated from input signal start_detected_delayed: boolean := false; signal stop_detected_delayed: boolean := false; signal read_mode_received: boolean := false; -- control signals signal read_byte: boolean := false; signal write_byte: boolean := false; signal read_ack: boolean := false; signal write_ack: boolean := false; -- IO shift registers signal input_shift: unsigned(7 downto 0) := (others => '0'); signal input_shift_count: natural range 0 to 7 := 0; signal output_shift: unsigned(7 downto 0) := (others => '0'); signal output_shift_count: natural range 0 to 7 := 0; type read_state_type is ( idle, read_bit, wait_scl_falling, read_end); signal read_state: read_state_type := idle; type write_state_type is ( idle, write_bit, wait_scl_rising, wait_scl_falling, write_end); signal write_state: write_state_type := idle; type control_state_type is ( idle, wait_for_address, start_write_ack, wait_for_write_ack, start_read_byte, wait_for_read_byte, start_write_byte, wait_for_write_byte, start_read_ack, wait_for_read_ack); signal control_state: control_state_type := idle; begin sample_process: process(clock, reset) begin if reset = '1' then sda_sampled <= (others => '1'); scl_sampled <= (others => '1'); sample_cycles_counter <= 0; else if rising_edge(clock) then if sample_cycles_counter = 0 then sample_cycles_counter <= sample_cycles - 1; sda_sampled <= sda_sampled(2 downto 0) & sda_in; scl_sampled <= scl_sampled(2 downto 0) & scl; else sample_cycles_counter <= sample_cycles_counter -1; end if; end if; end if; end process; -- This process provides 2 functions: -- If read_byte is set to true, then 8 bits are read from the I2C bus -- into input_shift. -- If read_ack is set to true, then one bit will be read from the I2C bus -- for the acknowledge from master into input_shift(0). -- Start or stop bit detection resets the state machine. read_process: process(clock, reset) begin if reset = '1' then read_state <= idle; input_shift <= (others => '0'); else if rising_edge(clock) then case read_state is when idle => if read_byte then input_shift_count <= 7; read_state <= read_bit; end if; if read_ack then input_shift_count <= 0; read_state <= read_bit; end if; when read_bit => if scl_rising_edge then input_shift <= input_shift(6 downto 0) & sda_in_delayed; read_state <= wait_scl_falling; end if; when wait_scl_falling => if scl_falling_edge then if input_shift_count = 0 then read_state <= read_end; else input_shift_count <= input_shift_count - 1; read_state <= read_bit; end if; end if; when read_end => if (not read_byte) and (not read_ack) then read_state <= idle; end if; end case; if start_detected_delayed or stop_detected_delayed then read_state <= idle; end if; end if; end if; end process; -- This process provides 2 functions: -- If write_byte is set to true, then 8 bits are written from data_out -- to the I2C bus. -- If write_ack is set to true, then one 0 bit will be written to the I2C bus -- for the acknowledge from slave. -- Start or stop bit detection resets the state machine. write_process: process(clock, reset) begin if reset = '1' then write_state <= idle; output_shift <= (others => '0'); else if rising_edge(clock) then case write_state is when idle => sda_out <= '1'; if write_ack then output_shift <= x"00"; output_shift_count <= 0; write_state <= write_bit; end if; if write_byte then output_shift <= data_out; output_shift_count <= 7; write_state <= write_bit; end if; when write_bit => if scl_falling_edge then sda_out <= output_shift(7); write_timeout_counter <= write_timeout; write_state <= wait_scl_rising; end if; when wait_scl_rising => if scl_rising_edge then if output_shift_count = 0 then write_state <= wait_scl_falling; else output_shift_count <= output_shift_count - 1; output_shift <= output_shift(6 downto 0) & '0'; write_state <= write_bit; end if; else if write_timeout_counter = 0 then write_state <= idle; else write_timeout_counter <= write_timeout_counter - 1; end if; end if; when wait_scl_falling => if scl_falling_edge then write_state <= write_end; end if; when write_end => sda_out <= '1'; if (not write_ack) and (not write_byte) then write_state <= idle; end if; end case; if start_detected_delayed or stop_detected_delayed then write_state <= idle; end if; end if; end if; end process; -- Process for receiving and sending bytes to the I2C bus, -- with the proper acknowledge generators and detection. control_process: process(clock, reset) begin if reset = '1' then control_state <= idle; else if rising_edge(clock) then case control_state is when idle => transfer_started <= false; data_out_requested <= false; data_in_valid <= false; read_byte <= false; write_byte <= false; read_ack <= false; write_ack <= false; read_mode_received <= false; when wait_for_address => if read_state = read_end then read_byte <= false; read_mode_received <= input_shift(0) = '1'; if input_shift(7 downto 1) = address then control_state <= start_write_ack; else control_state <= idle; end if; end if; when start_write_ack => write_ack <= true; control_state <= wait_for_write_ack; when wait_for_write_ack => if read_mode_received then data_out_requested <= true; end if; transfer_started <= true; if write_state = write_end then data_in_valid <= false; write_ack <= false; if read_mode_received then control_state <= start_write_byte; else control_state <= start_read_byte; end if; end if; when start_read_byte => read_byte <= true; control_state <= wait_for_read_byte; when wait_for_read_byte => if read_state = read_end then data_in <= input_shift; data_in_valid <= true; read_byte <= false; control_state <= start_write_ack; end if; when start_write_byte => write_byte <= true; control_state <= wait_for_write_byte; when wait_for_write_byte => data_out_requested <= false; if write_state = write_end then write_byte <= false; control_state <= start_read_ack; end if; when start_read_ack => data_out_requested <= true; read_ack <= true; control_state <= wait_for_read_ack; when wait_for_read_ack => if read_state = read_end then read_ack <= false; if input_shift(0) = '1' then -- no acknowledge from master, finish control_state <= idle; else -- acknowledge from master, send next byte control_state <= start_write_byte; end if; end if; end case; if start_detected_delayed then read_byte <= true; read_mode_received <= false; control_state <= wait_for_address; end if; if stop_detected_delayed then control_state <= idle; end if; end if; end if; end process; -- update and sample the inout sda signal sda <= sda_out when sda_out = '0' else 'Z'; sda_in <= '1' when sda /= '0' else '0'; -- to avoid "port", copy the read_mode flag read_mode <= read_mode_received; -- check for edges (this concept is used to filter spikes) sda_falling_edge <= true when sda_sampled = b"1100" else false; sda_rising_edge <= true when sda_sampled = b"0011" else false; scl_falling_edge <= true when scl_sampled = b"1100" else false; scl_rising_edge <= true when scl_sampled = b"0011" else false; -- these signals are used to ensure that the data signals are evaluated after -- the edges are detected sda_in_delayed <= sda_sampled(2); scl_delayed <= scl_sampled(2); -- detect start/stop condition start_detected_delayed <= (scl_delayed = '1') and sda_falling_edge and (not (scl_rising_edge or scl_falling_edge)); stop_detected_delayed <= (scl_delayed = '1') and sda_rising_edge and (not (scl_rising_edge or scl_falling_edge)); -- copy to host start_detected <= start_detected_delayed; stop_detected <= stop_detected_delayed; end architecture rtl;
