-- VHDL Architecture my_project_lib.crpt_adapter.fertig2 -- -- Created: -- by - carcom.UNKNOWN (CAE-P11) -- at - 10:44:36 22.04.2009 -- -- using Mentor Graphics HDL Designer(TM) 2008.1 (Build 17) -- --VHDL Entity my_project_lib.crpt_adapter.arch_name -- -- Created: -- by - carcom.UNKNOWN (CAE-P11) -- at - 10:43:17 22.04.2009 -- -- using Mentor Graphics HDL Designer(TM) 2008.1 (Build 17) -- LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; ENTITY crpt_adapter IS PORT( -- general inputs CRPT_Clk : IN std_logic; CRPT_Rst : IN std_logic; -- Interface towards crypto device CRPT_message : OUT std_ulogic_vector (511 DOWNTO 0); CRPT_message_len : OUT std_ulogic_vector (9 DOWNTO 0); CRPT_message_rdy : in std_ulogic; CRPT_next_message : IN std_ulogic; CRPT_result : in std_ulogic_vector (255 DOWNTO 0); CRPT_result_rdy : IN std_ulogic; crpt_next_result : out std_ulogic; -- DO NOT EDIT BELOW THIS LINE --------------------- -- Bus protocol ports, do not add or delete. FSL_Clk : IN std_logic; FSL_Rst : IN std_logic; FSL_S_Clk : OUT std_logic; FSL_S_Read : OUT std_logic; FSL_S_Data : IN std_ulogic_vector (0 TO 31); FSL_S_Control : IN std_logic; FSL_S_Exists : IN std_logic; FSL_M_Clk : OUT std_logic; FSL_M_Write : in std_logic; --geändert von out auf in FSL_M_Data : inout std_ulogic_vector (0 TO 31);--haben wir geändert von logic in u logic und auf in FSL_M_Control : in std_logic;--geändert auf in FSL_M_Full : out std_logic --out statt in neu -- H : in std_ulogic_vector (0 TO 31); -- DO NOT EDIT ABOVE THIS LINE --------------------- ); -- Declarations attribute SIGIS : string; attribute SIGIS of FSL_Clk : signal is "Clk"; attribute SIGIS of FSL_S_Clk : signal is "Clk"; attribute SIGIS of FSL_M_Clk : signal is "Clk"; END ENTITY crpt_adapter; ARCHITECTURE fertig2 OF crpt_adapter IS signal m: std_ulogic_vector (0 to 255); signal Read_cycle2 : integer:=0 ; signal Time_out2 : integer:=0 ; TYPE STATE_TYPE IS ( HW, Adapter, MP_Ubergabe ); -- Declare current and next state signals SIGNAL current_state : STATE_TYPE; SIGNAL next_state : STATE_TYPE; BEGIN clocked_proc : PROCESS ( CRPT_Clk, CRPT_Rst ) ----------------------------------------------------------------- variable c: integer := 0; BEGIN IF (CRPT_Rst = '1') THEN current_state <= HW; ELSIF (CRPT_Clk'EVENT AND CRPT_Clk = '1') THEN -- test state register statements current_state <= next_state; ELSIF Read_Cycle2 >0 THEN -- test state register statements c:=c+1; Time_out2 <=c; -- Combined Actions END IF; END PROCESS clocked_proc; ----------------------------------------------------------------- nextstate_proc : PROCESS ( CRPT_next_message, CRPT_result_rdy, Read_cycle2, FSL_M_Control, current_state ) ----------------------------------------------------------------- BEGIN CASE current_state IS WHEN HW => IF ((CRPT_result_rdy'event) and (CRPT_result_rdy='1')) THEN next_state <= Adapter; ELSE next_state <= HW; END IF; WHEN Adapter => IF ((CRPT_result_rdy'event) and (CRPT_result_rdy='0')) THEN next_state <= HW; Elsif (FSL_M_Control='1')and( Read_cycle2=0) then next_state <= MP_Ubergabe; ELSE next_state <= Adapter; END IF; WHEN MP_Ubergabe => IF ((CRPT_result_rdy = '1') and (CRPT_result_rdy'event)and (Read_cycle2=7))then next_state <= Adapter; ELSIF (Read_cycle2=7) THEN next_state <= HW; END IF; WHEN OTHERS => next_state <= HW; END CASE; END PROCESS nextstate_proc; --_____________________________________________________________________________ states : process ( current_state, CRPT_Clk, CRPT_result_rdy ) variable l: integer := 0; Begin CASE current_state IS WHEN Adapter => m <= CRPT_result; crpt_next_result<='1'; WHEN MP_Ubergabe => FSL_M_Full<='0' ; FSL_M_Data<=m(((32*L)+0) to ((32*L)+31)); L:= L + 1; if (FSL_M_data="00000000000000000000000000000001")then FSL_M_Full<='1'; FSL_M_Full<='1'; elsif (L = 8) then L:=0; end if; Read_Cycle2 <= L; When HW => Read_Cycle2 <=0; L:=0; WHEN OTHERS => NULL; END CASE; END PROCESS states; END ARCHITECTURE fertig2;
